[pgrouting-users] osm_relations table does not get populated
Imre Samu pella.samu at gmail.com
Sun Jun 4 06:58:53 PDT 2023
Hello,
In the data file you've provided, named
'haywards-heath-uk-small-extract.txt',
there are 8 OpenStreetMap (OSM) relation objects [2]
that are marked as either 'boundary=*' or 'landuse=residential'.
It appears that none of these are related to routes or are included in the
'mapconfig.xml' [1] file.
Could you please specify which OSM relation you're missing from your table?
Could you also test it with another input data set?  Specifically, one that
includes a 'highway=*' osm relation in the extract.
[1] https://github.com/pgRouting/osm2pgrouting/blob/main/mapconfig.xml
[2] osmium cat haywards-heath-uk-small-extract.osm.xml -t relation  -f opl
| cut -d' ' -f8
[3] https://taginfo.openstreetmap.org/keys/highway#overview
Regards,
  Imre
Tokura Gou <tokura.gou at gmail.com> ezt írta (időpont: 2023. jún. 3., Szo,
19:11):
> Hello Vicky and thanks for your response,
> Maybe due to formatting issues the data and the command were not visible.
> 1. Data:
> https://github.com/pgRouting/osm2pgrouting/files/11598959/haywards-heath-uk-small-extract.txt
> 2. Exact command: osm2pgrouting -f home/map.osm -c
> "/usr/local/share/osm2pgrouting/mapconfig.xml" -d city_routing -U
> [username] -W [password] --clean --tags --addnodes
> On Fri, Jun 2, 2023 at 6:25 PM Vicky Vergara <vicky at erosion.dev> wrote:
>> Hello,
>> I can not reproduce your problem:
>> What is needed:
>> 1) The exact data that has been used, can be in the form of a link to a
>> shared file, the wget command to download from osm.
>> 2) the exact command that is been used (use mylogin and mypass instead of
>> the real ones when posting the command)
>> Regards
>> Vicky
>> On Fri, Jun 2, 2023 at 3:52 AM Tokura Gou <tokura.gou at gmail.com> wrote:
>>> *Problem*
>>> When running osm2pgrouting on a typical .osm file with the --addnodes
>>> option, osm_relations table stays empty.
>>> *To Reproduce*
>>> osm2pgrouting -f home/map.osm -c "/usr/local/share/osm2pgrouting/mapconfig.xml" -d city_routing -U [username] -W [password] --clean --tags --addnodes
>>> *Expectation*
>>> I use the --addnodes flag as per the documentation and I can see that
>>> osm_nodes and osm_ways tables do get populated. However, osm_relations has
>>> 0 records after running osm2pgrouting and "Final osm_relations:" is
>>> never mentioned in the output:
>>> Creating tables...
>>> TABLE: ways_vertices_pgr created ... OK.
>>> TABLE: ways created ... OK.
>>> TABLE: pointsofinterest created ... OK.
>>> TABLE: configuration created ... OK.
>>> TABLE: osm_nodes created ... OK.
>>> TABLE: osm_ways created ... OK.
>>> TABLE: osm_relations created ... OK.
>>> Opening configuration file: /usr/local/share/osm2pgrouting/mapconfig.xml
>>>     Parsing configuration
>>> Exporting configuration ...
>>>   - Done
>>> Counting lines ...
>>>   - Done
>>> Opening data file: home/map.osm  total lines: 175957
>>>     Parsing data
>>> Current osm_nodes:      48000
>>> Final osm_nodes:        48375
>>> Current osm_ways:       6000
>>> Final osm_ways:         6320
>>> End Of file
>>>     Finish Parsing data
>>> Adding auxiliary tables to database...
>>> Export Ways ...
>>> Creating indexes ...
>>> Processing Points of Interest ...
>>> Adding functions for processing Points of Interest ...
>>> To process pointsOfInterest table:
>>> osm2pgr_pois_update(radius default 200, within default 50)
>>>   - Using areas of (radius)mts on POIS
>>>   - Using edges that are at least (within) mts of each POI
>>> POIS that do not have a closest edge is considered as too far
>>> size of streets: 6320
>>> Execution started at: Tue May 30 10:07:09 2023
>>> Execution ended at:   Tue May 30 10:07:21 2023
>>> Elapsed time: 11.767 Seconds.
>>> User CPU time: -> 1.12268 seconds
>>> *Sample Data*
>>> A sample .osm file is attached (please rename from txt to osm if
>>> needed), however I have tried other .osm exports that contain osm relations
>>> with the same result.
>>> <https://github.com/pgRouting/osm2pgrouting/files/11598959/haywards-heath-uk-small-extract.txt>
>>> *Platform/versions*
>>> SELECT version();
>>> PostgreSQL 15.3 (Debian 15.3-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
>>> SELECT postgis_full_version();
>>> POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="150" GEOS="3.9.0-CAPI-1.16.2" PROJ="7.2.1" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
>>> SELECT pgr_version();
>>> 3.4.1
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20230604/576eea72/attachment-0001.htm>
More information about the Pgrouting-users mailing list
