[pgrouting-users] osm_relations table does not get populated
Tokura Gou tokura.gou at gmail.com
Mon Jun 5 02:17:30 PDT 2023
Hello Imre,
Thanks for your comment.
I will test with another data set.
Meanwhile, may I ask:
1. It seems that by default osm2pgrouting will only store those
osm_relations that are related to routes and that contain "highway"-tagged
ways, is this correct?
2. Is it possible to edit mapconfig.xml to include other, non-highway
relations?
Thank you.
On Sun, Jun 4, 2023 at 4:21 PM Imre Samu <pella.samu at gmail.com> wrote:
> Hello,
> In the data file you've provided, named
> 'haywards-heath-uk-small-extract.txt',
> there are 8 OpenStreetMap (OSM) relation objects [2]
> that are marked as either 'boundary=*' or 'landuse=residential'.
> It appears that none of these are related to routes or are included in the
> 'mapconfig.xml' [1] file.
> Could you please specify which OSM relation you're missing from your table?
> Could you also test it with another input data set?  Specifically, one
> that includes a 'highway=*' osm relation in the extract.
> [1] https://github.com/pgRouting/osm2pgrouting/blob/main/mapconfig.xml
> [2] osmium cat haywards-heath-uk-small-extract.osm.xml -t relation  -f opl
> | cut -d' ' -f8
> [3] https://taginfo.openstreetmap.org/keys/highway#overview
> Regards,
>   Imre
> Tokura Gou <tokura.gou at gmail.com> ezt írta (időpont: 2023. jún. 3., Szo,
> 19:11):
>> Hello Vicky and thanks for your response,
>> Maybe due to formatting issues the data and the command were not visible.
>> 1. Data:
>> https://github.com/pgRouting/osm2pgrouting/files/11598959/haywards-heath-uk-small-extract.txt
>> 2. Exact command: osm2pgrouting -f home/map.osm -c
>> "/usr/local/share/osm2pgrouting/mapconfig.xml" -d city_routing -U
>> [username] -W [password] --clean --tags --addnodes
>> On Fri, Jun 2, 2023 at 6:25 PM Vicky Vergara <vicky at erosion.dev> wrote:
>>> Hello,
>>> I can not reproduce your problem:
>>> What is needed:
>>> 1) The exact data that has been used, can be in the form of a link to a
>>> shared file, the wget command to download from osm.
>>> 2) the exact command that is been used (use mylogin and mypass instead
>>> of the real ones when posting the command)
>>> Regards
>>> Vicky
>>> On Fri, Jun 2, 2023 at 3:52 AM Tokura Gou <tokura.gou at gmail.com> wrote:
>>>> *Problem*
>>>> When running osm2pgrouting on a typical .osm file with the --addnodes
>>>> option, osm_relations table stays empty.
>>>> *To Reproduce*
>>>> osm2pgrouting -f home/map.osm -c "/usr/local/share/osm2pgrouting/mapconfig.xml" -d city_routing -U [username] -W [password] --clean --tags --addnodes
>>>> *Expectation*
>>>> I use the --addnodes flag as per the documentation and I can see that
>>>> osm_nodes and osm_ways tables do get populated. However, osm_relations has
>>>> 0 records after running osm2pgrouting and "Final osm_relations:" is
>>>> never mentioned in the output:
>>>> Creating tables...
>>>> TABLE: ways_vertices_pgr created ... OK.
>>>> TABLE: ways created ... OK.
>>>> TABLE: pointsofinterest created ... OK.
>>>> TABLE: configuration created ... OK.
>>>> TABLE: osm_nodes created ... OK.
>>>> TABLE: osm_ways created ... OK.
>>>> TABLE: osm_relations created ... OK.
>>>> Opening configuration file: /usr/local/share/osm2pgrouting/mapconfig.xml
>>>>     Parsing configuration
>>>> Exporting configuration ...
>>>>   - Done
>>>> Counting lines ...
>>>>   - Done
>>>> Opening data file: home/map.osm  total lines: 175957
>>>>     Parsing data
>>>> Current osm_nodes:      48000
>>>> Final osm_nodes:        48375
>>>> Current osm_ways:       6000
>>>> Final osm_ways:         6320
>>>> End Of file
>>>>     Finish Parsing data
>>>> Adding auxiliary tables to database...
>>>> Export Ways ...
>>>> Creating indexes ...
>>>> Processing Points of Interest ...
>>>> Adding functions for processing Points of Interest ...
>>>> To process pointsOfInterest table:
>>>> osm2pgr_pois_update(radius default 200, within default 50)
>>>>   - Using areas of (radius)mts on POIS
>>>>   - Using edges that are at least (within) mts of each POI
>>>> POIS that do not have a closest edge is considered as too far
>>>> size of streets: 6320
>>>> Execution started at: Tue May 30 10:07:09 2023
>>>> Execution ended at:   Tue May 30 10:07:21 2023
>>>> Elapsed time: 11.767 Seconds.
>>>> User CPU time: -> 1.12268 seconds
>>>> *Sample Data*
>>>> A sample .osm file is attached (please rename from txt to osm if
>>>> needed), however I have tried other .osm exports that contain osm relations
>>>> with the same result.
>>>> <https://github.com/pgRouting/osm2pgrouting/files/11598959/haywards-heath-uk-small-extract.txt>
>>>> *Platform/versions*
>>>> SELECT version();
>>>> PostgreSQL 15.3 (Debian 15.3-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
>>>> SELECT postgis_full_version();
>>>> POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="150" GEOS="3.9.0-CAPI-1.16.2" PROJ="7.2.1" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
>>>> SELECT pgr_version();
>>>> 3.4.1
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20230605/ac041977/attachment-0001.htm>
More information about the Pgrouting-users mailing list
