[pgrouting-users] osm_relations table does not get populated
Tokura Gou
tokura.gou at gmail.com
Mon Jun 5 03:07:50 PDT 2023
Another input dataset:
Attaching another `.osm` extract (please rename from `.txt`). This file
contains at least one `highway` ("Sydney Road") which is a part of a route
`relation` ("270 Brighton - East Grinstead").
This `highway` has a tag `highway=secondary` which is declared in
`mapconfig.xml`.
On Mon, Jun 5, 2023 at 11:17 AM Tokura Gou <tokura.gou at gmail.com> wrote:
> Hello Imre,
> Thanks for your comment.
> I will test with another data set.
> Meanwhile, may I ask:
> 1. It seems that by default osm2pgrouting will only store those
> osm_relations that are related to routes and that contain "highway"-tagged
> ways, is this correct?
> 2. Is it possible to edit mapconfig.xml to include other, non-highway
> relations?
> Thank you.
> On Sun, Jun 4, 2023 at 4:21 PM Imre Samu <pella.samu at gmail.com> wrote:
>> Hello,
>> In the data file you've provided, named
>> 'haywards-heath-uk-small-extract.txt',
>> there are 8 OpenStreetMap (OSM) relation objects [2]
>> that are marked as either 'boundary=*' or 'landuse=residential'.
>> It appears that none of these are related to routes or are included in
>> the 'mapconfig.xml' [1] file.
>> Could you please specify which OSM relation you're missing from your
>> table?
>> Could you also test it with another input data set? Specifically, one
>> that includes a 'highway=*' osm relation in the extract.
>> [1] https://github.com/pgRouting/osm2pgrouting/blob/main/mapconfig.xml
>> [2] osmium cat haywards-heath-uk-small-extract.osm.xml -t relation -f
>> opl | cut -d' ' -f8
>> [3] https://taginfo.openstreetmap.org/keys/highway#overview
>> Regards,
>> Imre
>> Tokura Gou <tokura.gou at gmail.com> ezt írta (időpont: 2023. jún. 3., Szo,
>> 19:11):
>>> Hello Vicky and thanks for your response,
>>> Maybe due to formatting issues the data and the command were not visible.
>>> 1. Data:
>>> https://github.com/pgRouting/osm2pgrouting/files/11598959/haywards-heath-uk-small-extract.txt
>>> 2. Exact command: osm2pgrouting -f home/map.osm -c
>>> "/usr/local/share/osm2pgrouting/mapconfig.xml" -d city_routing -U
>>> [username] -W [password] --clean --tags --addnodes
>>> On Fri, Jun 2, 2023 at 6:25 PM Vicky Vergara <vicky at erosion.dev> wrote:
>>>> Hello,
>>>> I can not reproduce your problem:
>>>> What is needed:
>>>> 1) The exact data that has been used, can be in the form of a link to a
>>>> shared file, the wget command to download from osm.
>>>> 2) the exact command that is been used (use mylogin and mypass instead
>>>> of the real ones when posting the command)
>>>> Regards
>>>> Vicky
>>>> On Fri, Jun 2, 2023 at 3:52 AM Tokura Gou <tokura.gou at gmail.com> wrote:
>>>>> *Problem*
>>>>> When running osm2pgrouting on a typical .osm file with the --addnodes
>>>>> option, osm_relations table stays empty.
>>>>> *To Reproduce*
>>>>> osm2pgrouting -f home/map.osm -c "/usr/local/share/osm2pgrouting/mapconfig.xml" -d city_routing -U [username] -W [password] --clean --tags --addnodes
>>>>> *Expectation*
>>>>> I use the --addnodes flag as per the documentation and I can see that
>>>>> osm_nodes and osm_ways tables do get populated. However, osm_relations
>>>>> has 0 records after running osm2pgrouting and "Final osm_relations:"
>>>>> is never mentioned in the output:
>>>>> Creating tables...
>>>>> TABLE: ways_vertices_pgr created ... OK.
>>>>> TABLE: ways created ... OK.
>>>>> TABLE: pointsofinterest created ... OK.
>>>>> TABLE: configuration created ... OK.
>>>>> TABLE: osm_nodes created ... OK.
>>>>> TABLE: osm_ways created ... OK.
>>>>> TABLE: osm_relations created ... OK.
>>>>> Opening configuration file: /usr/local/share/osm2pgrouting/mapconfig.xml
>>>>> Parsing configuration
>>>>> Exporting configuration ...
>>>>> - Done
>>>>> Counting lines ...
>>>>> - Done
>>>>> Opening data file: home/map.osm total lines: 175957
>>>>> Parsing data
>>>>> Current osm_nodes: 48000
>>>>> Final osm_nodes: 48375
>>>>> Current osm_ways: 6000
>>>>> Final osm_ways: 6320
>>>>> End Of file
>>>>> Finish Parsing data
>>>>> Adding auxiliary tables to database...
>>>>> Export Ways ...
>>>>> Creating indexes ...
>>>>> Processing Points of Interest ...
>>>>> Adding functions for processing Points of Interest ...
>>>>> To process pointsOfInterest table:
>>>>> osm2pgr_pois_update(radius default 200, within default 50)
>>>>> - Using areas of (radius)mts on POIS
>>>>> - Using edges that are at least (within) mts of each POI
>>>>> POIS that do not have a closest edge is considered as too far
>>>>> size of streets: 6320
>>>>> Execution started at: Tue May 30 10:07:09 2023
>>>>> Execution ended at: Tue May 30 10:07:21 2023
>>>>> Elapsed time: 11.767 Seconds.
>>>>> User CPU time: -> 1.12268 seconds
>>>>> *Sample Data*
>>>>> A sample .osm file is attached (please rename from txt to osm if
>>>>> needed), however I have tried other .osm exports that contain osm relations
>>>>> with the same result.
>>>>> <https://github.com/pgRouting/osm2pgrouting/files/11598959/haywards-heath-uk-small-extract.txt>
>>>>> *Platform/versions*
>>>>> SELECT version();
>>>>> PostgreSQL 15.3 (Debian 15.3-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
>>>>> SELECT postgis_full_version();
>>>>> POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="150" GEOS="3.9.0-CAPI-1.16.2" PROJ="7.2.1" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
>>>>> SELECT pgr_version();
>>>>> 3.4.1
>>>>> _______________________________________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20230605/22c3517e/attachment-0001.htm>
<?xml version='1.0' encoding='UTF-8'?>
<osm version='0.6' generator='JOSM'>
<bounds minlat='51.004729' minlon='-0.103969' maxlat='51.0077587' maxlon='-0.1008547' origin='CGImap 0.8.8 (3926023 spike-08.openstreetmap.org)' />
<node id='32197185' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133932731' lat='51.0090669' lon='-0.1036388' />
<node id='32197190' timestamp='2007-09-02T20:58:24Z' uid='10475' user='riad' visible='true' version='1' changeset='292788' lat='51.0088704' lon='-0.103588'>
<tag k='created_by' v='JOSM' />
</node>
<node id='32197191' timestamp='2013-09-09T20:45:57Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17757325' lat='51.0075478' lon='-0.1038199' />
<node id='32197192' timestamp='2012-09-08T20:42:41Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='13038000' lat='51.0066148' lon='-0.1034871' />
<node id='32197193' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='4' changeset='133899701' lat='51.0059745' lon='-0.1034543' />
<node id='32197195' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='5' changeset='133899701' lat='51.0057468' lon='-0.1034387' />
<node id='32197196' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='5' changeset='133899701' lat='51.0057703' lon='-0.1036071' />
<node id='32197197' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='4' changeset='133899701' lat='51.005918' lon='-0.1036537' />
<node id='32197198' timestamp='2018-09-17T20:00:47Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='62676066' lat='51.0059743' lon='-0.102986' />
<node id='32197199' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059926' lon='-0.101016' />
<node id='32197200' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0059858' lon='-0.1002501' />
<node id='32197202' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.006497' lon='-0.0975011' />
<node id='32197206' timestamp='2018-11-05T20:25:08Z' uid='5443821' user='Thomas Jarvis' visible='true' version='4' changeset='64210088' lat='51.0058111' lon='-0.1057443' />
<node id='32197230' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='4' changeset='133899701' lat='51.0057894' lon='-0.1033387' />
<node id='34696066' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='4' changeset='133899701' lat='51.0056153' lon='-0.1034061' />
<node id='34696068' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='5' changeset='133899701' lat='51.0061531' lon='-0.103417' />
<node id='34696070' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0062061' lon='-0.1032721' />
<node id='34696071' timestamp='2013-09-09T20:45:58Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17757325' lat='51.0063576' lon='-0.1029707' />
<node id='34696072' timestamp='2013-09-09T20:45:58Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17757325' lat='51.0065636' lon='-0.1026109' />
<node id='34696074' timestamp='2013-09-09T20:45:58Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17757325' lat='51.0067786' lon='-0.1018769' />
<node id='34696075' timestamp='2013-09-09T20:45:58Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17757325' lat='51.0069395' lon='-0.1002519' />
<node id='34696079' timestamp='2007-09-20T16:31:01Z' uid='10475' user='riad' visible='true' version='1' changeset='479142' lat='51.0073692' lon='-0.097662'>
</node>
<node id='36292811' timestamp='2010-05-14T22:35:13Z' uid='99091' user='Curtis3250692' visible='true' version='7' changeset='4700988' lat='50.9955997' lon='-0.0682538' />
<node id='38904403' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133895069' lat='51.007157' lon='-0.096865' />
<node id='38904407' timestamp='2007-09-20T16:31:00Z' uid='10475' user='riad' visible='true' version='1' changeset='479142' lat='51.0074306' lon='-0.0979413'>
</node>
<node id='38904420' timestamp='2015-03-14T22:17:10Z' uid='481116' user='bigalxyz123' visible='true' version='3' changeset='29481865' lat='51.0067003' lon='-0.1023579' />
<node id='38904423' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060511' lon='-0.0998072' />
<node id='38904427' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0059871' lon='-0.1007731' />
<node id='38904551' timestamp='2013-09-19T22:35:11Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17931480' lat='51.0075576' lon='-0.0980082' />
<node id='38904554' timestamp='2013-09-19T22:35:11Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17931480' lat='51.0077602' lon='-0.0981425' />
<node id='38904557' timestamp='2023-03-20T12:36:23Z' uid='577089' user='JodaStephen' visible='true' version='4' changeset='133897367' lat='51.0082538' lon='-0.0984908' />
<node id='38904560' timestamp='2023-03-20T12:36:23Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133897367' lat='51.0082531' lon='-0.0985396' />
<node id='38904563' timestamp='2007-09-02T18:54:46Z' uid='10475' user='riad' visible='true' version='1' changeset='292788' lat='51.0078176' lon='-0.1004987'>
</node>
<node id='38904566' timestamp='2015-03-14T22:17:10Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='29481865' lat='51.0073794' lon='-0.1024815' />
<node id='38904569' timestamp='2013-09-09T20:45:57Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17757325' lat='51.0073511' lon='-0.1025861' />
<node id='38904571' timestamp='2007-09-02T18:54:51Z' uid='10475' user='riad' visible='true' version='1' changeset='292788' lat='51.0073416' lon='-0.1026609'>
</node>
<node id='38904572' timestamp='2007-09-02T18:54:54Z' uid='10475' user='riad' visible='true' version='1' changeset='292788' lat='51.0073147' lon='-0.1028179'>
</node>
<node id='38904574' timestamp='2007-09-02T18:54:56Z' uid='10475' user='riad' visible='true' version='1' changeset='292788' lat='51.007235' lon='-0.1029391'>
</node>
<node id='38904576' timestamp='2013-09-09T20:45:57Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17757325' lat='51.0068582' lon='-0.1028489' />
<node id='38904578' timestamp='2013-09-09T20:45:57Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17757325' lat='51.0068221' lon='-0.1030942' />
<node id='38904580' timestamp='2013-09-09T20:45:57Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17757325' lat='51.0070272' lon='-0.1029006' />
<node id='38904582' timestamp='2013-09-09T20:45:57Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17757325' lat='51.0071908' lon='-0.1029658' />
<node id='38904583' timestamp='2013-09-09T20:45:57Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17757325' lat='51.0071576' lon='-0.1031864' />
<node id='38904585' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0055846' lon='-0.1007899' />
<node id='38904587' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0055819' lon='-0.1005793' />
<node id='38904589' timestamp='2013-09-09T20:45:57Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17757325' lat='51.0069921' lon='-0.1031514' />
<node id='38904596' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.006009' lon='-0.1025491' />
<node id='38906017' timestamp='2007-09-02T19:24:34Z' uid='10475' user='riad' visible='true' version='1' changeset='292788' lat='51.0084799' lon='-0.1036395'>
</node>
<node id='55300265' timestamp='2015-03-14T22:17:11Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='29481865' lat='51.0082411' lon='-0.098452' />
<node id='384953329' timestamp='2017-04-06T22:46:14Z' uid='5443821' user='Thomas Jarvis' visible='true' version='3' changeset='47523087' lat='50.9877735' lon='-0.0868374' />
<node id='384953331' timestamp='2017-04-11T12:57:33Z' uid='5443821' user='Thomas Jarvis' visible='true' version='3' changeset='47656595' lat='50.9880042' lon='-0.0865206' />
<node id='384953332' timestamp='2017-04-11T12:57:33Z' uid='5443821' user='Thomas Jarvis' visible='true' version='4' changeset='47656595' lat='50.9888343' lon='-0.0864806' />
<node id='384953334' timestamp='2022-12-11T18:18:45Z' uid='10573400' user='PeterMapit' visible='true' version='9' changeset='129971525' lat='50.9882398' lon='-0.0843424' />
<node id='384953335' timestamp='2010-05-09T15:30:18Z' uid='99091' user='Curtis3250692' visible='true' version='2' changeset='4649974' lat='50.9909364' lon='-0.0787316' />
<node id='384953337' timestamp='2010-05-09T15:30:18Z' uid='99091' user='Curtis3250692' visible='true' version='2' changeset='4649974' lat='50.9924491' lon='-0.0797616' />
<node id='384953339' timestamp='2018-10-14T20:36:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='3' changeset='63519752' lat='50.9948875' lon='-0.0707066' />
<node id='384953340' timestamp='2022-08-09T11:13:47Z' uid='10573400' user='PeterMapit' visible='true' version='5' changeset='124680413' lat='50.9955401' lon='-0.0671765' />
<node id='384953342' timestamp='2022-08-10T14:21:06Z' uid='10573400' user='PeterMapit' visible='true' version='3' changeset='124734455' lat='50.9954861' lon='-0.0702784' />
<node id='384953359' timestamp='2019-08-26T13:57:00Z' uid='5443821' user='Thomas Jarvis' visible='true' version='3' changeset='73754935' lat='51.007067' lon='-0.0761191' />
<node id='384953362' timestamp='2010-05-09T15:30:22Z' uid='99091' user='Curtis3250692' visible='true' version='2' changeset='4649974' lat='51.0090855' lon='-0.0738178' />
<node id='384953364' timestamp='2016-11-27T17:08:24Z' uid='97369' user='fcrump' visible='true' version='3' changeset='43987250' lat='51.0096035' lon='-0.0742689' />
<node id='384953365' timestamp='2010-05-09T15:30:23Z' uid='99091' user='Curtis3250692' visible='true' version='2' changeset='4649974' lat='51.0102601' lon='-0.072938' />
<node id='384953366' timestamp='2011-01-26T16:00:34Z' uid='396049' user='DaveMorey' visible='true' version='2' changeset='7094684' lat='51.0117646' lon='-0.0734821' />
<node id='384953367' timestamp='2011-01-26T16:00:34Z' uid='396049' user='DaveMorey' visible='true' version='3' changeset='7094684' lat='51.0119954' lon='-0.073643' />
<node id='384953369' timestamp='2022-05-14T17:20:22Z' uid='10573400' user='PeterMapit' visible='true' version='6' changeset='120987247' lat='51.0136021' lon='-0.0756952' />
<node id='384953371' timestamp='2020-09-14T14:21:14Z' uid='97369' user='fcrump' visible='true' version='3' changeset='90871243' lat='51.0142098' lon='-0.0772462' />
<node id='384953373' timestamp='2016-11-27T17:08:24Z' uid='97369' user='fcrump' visible='true' version='2' changeset='43987250' lat='51.0154048' lon='-0.0759431' />
<node id='384953375' timestamp='2017-09-10T17:01:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='3' changeset='51913813' lat='51.0158496' lon='-0.0757508' />
<node id='384953377' timestamp='2017-09-10T17:01:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='51913813' lat='51.0167395' lon='-0.0753119' />
<node id='384953379' timestamp='2017-09-10T17:01:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='3' changeset='51913813' lat='51.0176743' lon='-0.0751533' />
<node id='384953381' timestamp='2017-09-10T17:01:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='3' changeset='51913813' lat='51.018117' lon='-0.0777335' />
<node id='384953383' timestamp='2010-05-09T15:30:23Z' uid='99091' user='Curtis3250692' visible='true' version='2' changeset='4649974' lat='51.0178874' lon='-0.0814138' />
<node id='384953385' timestamp='2018-12-14T12:23:44Z' uid='5443821' user='Thomas Jarvis' visible='true' version='4' changeset='65471108' lat='51.0188973' lon='-0.0837425' />
<node id='384953387' timestamp='2016-11-27T17:08:24Z' uid='97369' user='fcrump' visible='true' version='3' changeset='43987250' lat='51.0185622' lon='-0.0868903' />
<node id='384953388' timestamp='2010-05-09T15:30:24Z' uid='99091' user='Curtis3250692' visible='true' version='2' changeset='4649974' lat='51.0177389' lon='-0.0875078' />
<node id='384953391' timestamp='2016-11-27T17:08:24Z' uid='97369' user='fcrump' visible='true' version='2' changeset='43987250' lat='51.0178066' lon='-0.0888917' />
<node id='384953392' timestamp='2017-10-03T09:11:34Z' uid='5443821' user='Thomas Jarvis' visible='true' version='3' changeset='52589270' lat='51.0179666' lon='-0.0904473' />
<node id='384953394' timestamp='2016-11-27T17:08:24Z' uid='97369' user='fcrump' visible='true' version='2' changeset='43987250' lat='51.016775' lon='-0.0908503' />
<node id='384953396' timestamp='2016-11-27T17:08:24Z' uid='97369' user='fcrump' visible='true' version='2' changeset='43987250' lat='51.0170311' lon='-0.092834' />
<node id='384953397' timestamp='2021-11-20T18:11:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='4' changeset='114036454' lat='51.0180298' lon='-0.0928361' />
<node id='565764715' timestamp='2021-01-11T12:27:53Z' uid='63012' user='stthomse' visible='true' version='4' changeset='97306594' lat='51.0053952' lon='-0.1034951'>
<tag k='alt_name' v='Haywards Heath Station' />
<tag k='bus' v='yes' />
<tag k='highway' v='bus_stop' />
<tag k='name' v='Perrymount Road' />
<tag k='naptan:AltCommonName' v='Haywards Heath Station' />
<tag k='naptan:AltStreet' v='Not Specified' />
<tag k='naptan:AtcoCode' v='4400EG0050' />
<tag k='naptan:Bearing' v='N' />
<tag k='naptan:CommonName' v='Perrymount Road' />
<tag k='naptan:Indicator' v='towards roundabout' />
<tag k='naptan:Landmark' v='Sydney Road' />
<tag k='naptan:NaptanCode' v='wsxampwm' />
<tag k='naptan:PlusbusZoneRef' v='HYWRDSH' />
<tag k='naptan:ShortCommonName' v='Perrymount Rd/Stn' />
<tag k='naptan:Street' v='Perrymount Road' />
<tag k='naptan:verified' v='no' />
<tag k='public_transport' v='platform' />
<tag k='source' v='naptan_import' />
</node>
<node id='565764716' timestamp='2021-01-11T12:27:53Z' uid='63012' user='stthomse' visible='true' version='4' changeset='97306594' lat='51.0054064' lon='-0.103331'>
<tag k='naptan:AtcoCode' v='4400EG0051' />
<tag k='naptan:Bearing' v='S' />
<tag k='naptan:Indicator' v='away from roundabout' />
<tag k='naptan:NaptanCode' v='wsxampwp' />
</node>
<node id='727569195' timestamp='2017-04-11T12:57:33Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='47656595' lat='50.9879003' lon='-0.0866418' />
<node id='727570008' timestamp='2010-05-09T15:30:19Z' uid='99091' user='Curtis3250692' visible='true' version='1' changeset='4649974' lat='50.9926517' lon='-0.0792895' />
<node id='727570012' timestamp='2010-05-09T15:30:19Z' uid='99091' user='Curtis3250692' visible='true' version='1' changeset='4649974' lat='50.9920304' lon='-0.0788603' />
<node id='727570035' timestamp='2022-08-10T14:21:06Z' uid='10573400' user='PeterMapit' visible='true' version='3' changeset='124734455' lat='50.9962215' lon='-0.0703987' />
<node id='727570096' timestamp='2010-05-09T15:30:22Z' uid='99091' user='Curtis3250692' visible='true' version='1' changeset='4649974' lat='51.0078974' lon='-0.0769506' />
<node id='727570119' timestamp='2010-05-09T15:30:23Z' uid='99091' user='Curtis3250692' visible='true' version='1' changeset='4649974' lat='51.0171584' lon='-0.0787745' />
<node id='727570124' timestamp='2010-05-09T15:30:23Z' uid='99091' user='Curtis3250692' visible='true' version='1' changeset='4649974' lat='51.0180763' lon='-0.0834952' />
<node id='727570144' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133940215' lat='51.018267' lon='-0.0934864' />
<node id='727575929' timestamp='2010-05-09T15:33:58Z' uid='99091' user='Curtis3250692' visible='true' version='1' changeset='4649991' lat='50.9884512' lon='-0.0806842' />
<node id='727576880' timestamp='2010-05-09T15:34:12Z' uid='99091' user='Curtis3250692' visible='true' version='1' changeset='4649991' lat='50.9896533' lon='-0.0799332' />
<node id='727576911' timestamp='2018-08-07T21:02:37Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='61447347' lat='50.9896502' lon='-0.0798744' />
<node id='729896815' timestamp='2010-05-14T22:35:13Z' uid='99091' user='Curtis3250692' visible='true' version='2' changeset='4700988' lat='50.9961119' lon='-0.0666425' />
<node id='731383084' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0017468' lon='-0.1020923' />
<node id='731383088' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0019411' lon='-0.1016187' />
<node id='731383093' timestamp='2022-12-05T18:28:37Z' uid='10573400' user='PeterMapit' visible='true' version='3' changeset='129752271' lat='51.0021032' lon='-0.1014674' />
<node id='731383100' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='4' changeset='83117492' lat='51.005725' lon='-0.0983137' />
<node id='731383105' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0055393' lon='-0.0999579' />
<node id='731383109' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0054958' lon='-0.1005593' />
<node id='731383118' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0053819' lon='-0.1005499' />
<node id='731383122' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0052621' lon='-0.10033' />
<node id='731383131' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0051058' lon='-0.1002039' />
<node id='731383137' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0049861' lon='-0.1001932' />
<node id='731383145' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0045295' lon='-0.1004708' />
<node id='731383196' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0019776' lon='-0.102828' />
<node id='731383204' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0019007' lon='-0.1027976' />
<node id='937043331' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='4' changeset='133899701' lat='51.0058883' lon='-0.1039749' />
<node id='1111572408' timestamp='2019-10-15T08:38:12Z' uid='10252560' user='rkkapilk' visible='true' version='2' changeset='75706274' lat='51.0051417' lon='-0.1023708'>
<tag k='barrier' v='gate' />
</node>
<node id='1111591512' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='4' changeset='117291260' lat='51.005356' lon='-0.0942412' />
<node id='1111591514' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='117291260' lat='51.0086973' lon='-0.0916279' />
<node id='1111591518' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='117291260' lat='51.0069936' lon='-0.0938763' />
<node id='1111591522' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='117291260' lat='51.0064057' lon='-0.0930342' />
<node id='1111591535' timestamp='2021-12-09T16:05:35Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='114750425' lat='51.0057148' lon='-0.0938336' />
<node id='1111591540' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='117291260' lat='51.0067813' lon='-0.0935731' />
<node id='1111591549' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='117291260' lat='51.0072667' lon='-0.0941759' />
<node id='1121958357' timestamp='2020-09-14T14:21:14Z' uid='97369' user='fcrump' visible='true' version='2' changeset='90871243' lat='51.0133742' lon='-0.0749074' />
<node id='1121958359' timestamp='2011-01-26T16:00:33Z' uid='396049' user='DaveMorey' visible='true' version='1' changeset='7094684' lat='51.0124392' lon='-0.0735357' />
<node id='1121958362' timestamp='2011-01-26T16:00:33Z' uid='396049' user='DaveMorey' visible='true' version='1' changeset='7094684' lat='51.0114102' lon='-0.073996' />
<node id='1121958365' timestamp='2011-01-26T16:00:33Z' uid='396049' user='DaveMorey' visible='true' version='1' changeset='7094684' lat='51.0112529' lon='-0.0743833' />
<node id='1133659106' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='117291260' lat='51.0048653' lon='-0.0945084' />
<node id='1133659144' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='117291260' lat='51.0047685' lon='-0.0940604' />
<node id='1133675172' timestamp='2018-05-10T10:48:42Z' uid='890751' user='extua' visible='true' version='2' changeset='58846161' lat='51.0045696' lon='-0.1024585' />
<node id='1133675178' timestamp='2018-05-10T10:48:42Z' uid='890751' user='extua' visible='true' version='2' changeset='58846161' lat='51.0049428' lon='-0.1022067' />
<node id='1133675183' timestamp='2017-03-09T22:38:47Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='46724100' lat='51.0046089' lon='-0.1030155' />
<node id='1133675189' timestamp='2017-03-09T22:38:47Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='46724100' lat='51.004655' lon='-0.1031093' />
<node id='1133675191' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='2' changeset='58846161' lat='51.0045281' lon='-0.1028505' />
<node id='1133675194' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0051557' lon='-0.1034295' />
<node id='1133675196' timestamp='2017-03-09T22:38:47Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='46724100' lat='51.0046365' lon='-0.1029001' />
<node id='1133675198' timestamp='2013-09-09T19:38:00Z' uid='481116' user='bigalxyz123' visible='true' version='2' changeset='17756059' lat='51.0046879' lon='-0.1034665' />
<node id='1133675201' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='2' changeset='58846161' lat='51.0048766' lon='-0.102799' />
<node id='1133675212' timestamp='2017-03-09T22:38:47Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='46724100' lat='51.0049099' lon='-0.1030127' />
<node id='1133675222' timestamp='2017-03-09T22:38:47Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='46724100' lat='51.0049115' lon='-0.1028867' />
<node id='1146946377' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='5' changeset='133899701' lat='51.0049614' lon='-0.1034413'>
<tag k='button_operated' v='yes' />
<tag k='crossing' v='traffic_signals' />
<tag k='crossing:island' v='no' />
<tag k='crossing_ref' v='puffin' />
<tag k='highway' v='crossing' />
<tag k='kerb' v='lowered' />
<tag k='tactile_paving' v='yes' />
<tag k='traffic_signals:sound' v='yes' />
</node>
<node id='1321730463' timestamp='2022-12-11T00:10:03Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='129949544' lat='50.9984633' lon='-0.1041583' />
<node id='1415176493' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='4' changeset='82669712' lat='50.9859362' lon='-0.1121478' />
<node id='1905996953' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0058234' lon='-0.1033101' />
<node id='1905996968' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0059441' lon='-0.1036194' />
<node id='1905996976' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0059631' lon='-0.1035848' />
<node id='1905996988' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.005911' lon='-0.1033212' />
<node id='1905996993' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0059551' lon='-0.1033678' />
<node id='1905997032' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0058615' lon='-0.1033004' />
<node id='1905997036' timestamp='2012-09-08T20:42:38Z' uid='481116' user='bigalxyz123' visible='true' version='1' changeset='13038000' lat='51.0063811' lon='-0.1034182' />
<node id='1905997045' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0057427' lon='-0.1034985' />
<node id='1905997062' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0058786' lon='-0.1036748' />
<node id='1905997069' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0057506' lon='-0.1035573' />
<node id='1940132317' timestamp='2012-09-30T17:33:46Z' uid='891697' user='ChrisDunley' visible='true' version='1' changeset='13312639' lat='51.0041587' lon='-0.1020742' />
<node id='1940132318' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0053713' lon='-0.1014353' />
<node id='1940132319' timestamp='2012-09-30T17:33:46Z' uid='891697' user='ChrisDunley' visible='true' version='1' changeset='13312639' lat='51.0049412' lon='-0.1019419' />
<node id='1940132320' timestamp='2012-09-30T17:33:46Z' uid='891697' user='ChrisDunley' visible='true' version='1' changeset='13312639' lat='51.0051073' lon='-0.1018059' />
<node id='1940132321' timestamp='2012-09-30T17:33:46Z' uid='891697' user='ChrisDunley' visible='true' version='1' changeset='13312639' lat='51.0046576' lon='-0.1019956' />
<node id='1940132322' timestamp='2012-09-30T17:33:46Z' uid='891697' user='ChrisDunley' visible='true' version='1' changeset='13312639' lat='51.0052659' lon='-0.1015753' />
<node id='1940132324' timestamp='2012-09-30T17:33:46Z' uid='891697' user='ChrisDunley' visible='true' version='1' changeset='13312639' lat='51.0041216' lon='-0.1014412' />
<node id='1940132341' timestamp='2012-09-30T17:33:47Z' uid='891697' user='ChrisDunley' visible='true' version='1' changeset='13312639' lat='51.004179' lon='-0.1009905' />
<node id='1940132343' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0054693' lon='-0.1013446' />
<node id='1940132345' timestamp='2012-09-30T17:33:47Z' uid='891697' user='ChrisDunley' visible='true' version='1' changeset='13312639' lat='51.004125' lon='-0.1019025' />
<node id='1941113391' timestamp='2012-10-01T08:03:04Z' uid='891697' user='ChrisDunley' visible='true' version='1' changeset='13318962' lat='51.0044457' lon='-0.0995175' />
<node id='1941154644' timestamp='2022-12-05T18:28:37Z' uid='10573400' user='PeterMapit' visible='true' version='3' changeset='129752271' lat='51.0026251' lon='-0.1010401' />
<node id='1941154658' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='3' changeset='83117492' lat='51.0041233' lon='-0.1021087' />
<node id='1941154659' timestamp='2012-10-01T09:03:21Z' uid='891697' user='ChrisDunley' visible='true' version='1' changeset='13319561' lat='51.0044319' lon='-0.1020578' />
<node id='1941154660' timestamp='2012-10-01T09:03:21Z' uid='891697' user='ChrisDunley' visible='true' version='1' changeset='13319561' lat='51.0049518' lon='-0.1019825' />
<node id='1941154661' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0051307' lon='-0.1018301' />
<node id='1941154662' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0052934' lon='-0.1015918' />
<node id='1941154663' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0053838' lon='-0.1014607' />
<node id='1941154664' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0054612' lon='-0.101397' />
<node id='1941154666' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0056492' lon='-0.101248' />
<node id='1941154668' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059181' lon='-0.1010403' />
<node id='1941154670' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0062819' lon='-0.0986221' />
<node id='2229437995' timestamp='2017-09-10T17:01:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='51913813' lat='51.017183' lon='-0.0787478'>
<tag k='barrier' v='kissing_gate' />
</node>
<node id='2245310439' timestamp='2013-04-02T20:16:45Z' uid='10983' user='Guy' visible='true' version='1' changeset='15586495' lat='51.0014514' lon='-0.1052393' />
<node id='2452194964' timestamp='2013-09-09T19:37:58Z' uid='481116' user='bigalxyz123' visible='true' version='1' changeset='17756059' lat='51.005694' lon='-0.1034079' />
<node id='2452246893' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0058974' lon='-0.1053818' />
<node id='2452246895' timestamp='2013-09-09T20:45:50Z' uid='481116' user='bigalxyz123' visible='true' version='1' changeset='17757325' lat='51.0070728' lon='-0.1036473' />
<node id='2452246986' timestamp='2013-09-09T20:45:51Z' uid='481116' user='bigalxyz123' visible='true' version='1' changeset='17757325' lat='51.0067451' lon='-0.1021658' />
<node id='2452247013' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.007482' lon='-0.1038097' />
<node id='2452247135' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.005999' lon='-0.1001116' />
<node id='2452247137' timestamp='2013-09-09T20:45:54Z' uid='481116' user='bigalxyz123' visible='true' version='1' changeset='17757325' lat='51.0077263' lon='-0.1038092' />
<node id='2452247140' timestamp='2013-09-09T20:45:54Z' uid='481116' user='bigalxyz123' visible='true' version='1' changeset='17757325' lat='51.0082222' lon='-0.1037012' />
<node id='2532049765' timestamp='2013-11-14T12:08:39Z' uid='1158381' user='wh68' visible='true' version='1' changeset='18891415' lat='50.987056' lon='-0.1118083' />
<node id='2532049778' timestamp='2013-11-14T12:08:40Z' uid='1158381' user='wh68' visible='true' version='1' changeset='18891415' lat='50.9880341' lon='-0.1115535' />
<node id='3015579859' timestamp='2014-08-14T02:02:53Z' uid='2260503' user='p3corion' visible='true' version='1' changeset='24735610' lat='51.0043778' lon='-0.0834061' />
<node id='3398845309' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0080818' lon='-0.0975817' />
<node id='3398845549' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0081017' lon='-0.1037327' />
<node id='4425489528' timestamp='2022-10-28T19:13:20Z' uid='13666626' user='RedAuburn' visible='true' version='5' changeset='128188126' lat='51.0065166' lon='-0.1035968'>
<tag k='amenity' v='post_box' />
<tag k='brand' v='Royal Mail' />
<tag k='brand:wikidata' v='Q638098' />
<tag k='brand:wikipedia' v='en:Royal Mail' />
<tag k='note' v='Haywards Heath Delivery Office. just slots in wall' />
<tag k='operator' v='Royal Mail' />
<tag k='operator:wikidata' v='Q638098' />
<tag k='post_box:apertures' v='3' />
<tag k='post_box:type' v='wall' />
<tag k='ref' v='RH16 601' />
</node>
<node id='4475878707' timestamp='2016-11-01T21:05:32Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0051506' lon='-0.1019858' />
<node id='4475878711' timestamp='2016-11-01T21:05:32Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0051616' lon='-0.1026054' />
<node id='4475878712' timestamp='2016-11-01T21:05:32Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0051834' lon='-0.1030946' />
<node id='4475878713' timestamp='2016-11-01T21:05:32Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0051918' lon='-0.1032971' />
<node id='4475878717' timestamp='2016-11-01T21:05:32Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0052974' lon='-0.1030826' />
<node id='4475878718' timestamp='2016-11-01T21:05:32Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0053059' lon='-0.1032851' />
<node id='4475878724' timestamp='2016-11-01T21:05:32Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0055464' lon='-0.1019681' />
<node id='4475878725' timestamp='2016-11-01T21:05:32Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0055573' lon='-0.1025877' />
<node id='4475878727' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0055414' lon='-0.1043841' />
<node id='4475878732' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0056723' lon='-0.1043261' />
<node id='4475878738' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057966' lon='-0.1023882' />
<node id='4475878739' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057984' lon='-0.1026209' />
<node id='4475878742' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058857' lon='-0.1023865' />
<node id='4475878743' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058875' lon='-0.1026191' />
<node id='4475878746' timestamp='2016-11-01T21:05:33Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0059553' lon='-0.1037982' />
<node id='4475878747' timestamp='2016-11-01T21:05:33Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.005956' lon='-0.103881' />
<node id='4475878748' timestamp='2016-11-01T21:05:33Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0060055' lon='-0.1039582' />
<node id='4475878750' timestamp='2016-11-01T21:05:33Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0060345' lon='-0.1036374' />
<node id='4475878751' timestamp='2016-11-01T21:05:33Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0060268' lon='-0.1036785' />
<node id='4475878755' timestamp='2016-11-01T21:05:33Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0060817' lon='-0.103586' />
<node id='4475878756' timestamp='2016-11-01T21:05:33Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0060936' lon='-0.1037742' />
<node id='4475878762' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0061055' lon='-0.1035663' />
<node id='4475878763' timestamp='2016-11-01T21:05:33Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0061043' lon='-0.1038026' />
<node id='4475878764' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0061442' lon='-0.1037171' />
<node id='4475878765' timestamp='2016-11-01T21:05:33Z' uid='3729377' user='deptho' visible='true' version='1' changeset='43337434' lat='51.0061408' lon='-0.1037228' />
<node id='4475878766' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0061715' lon='-0.1035235' />
<node id='4475878767' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0061739' lon='-0.1035325' />
<node id='4475878769' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.00622' lon='-0.103505' />
<node id='4475878770' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0062103' lon='-0.103674' />
<node id='4475878779' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0062557' lon='-0.1036462' />
<node id='4475878780' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='5' changeset='96827214' lat='51.0062837' lon='-0.1035687' />
<node id='4475878781' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='5' changeset='96827214' lat='51.0063631' lon='-0.1035396' />
<node id='4475878782' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='5' changeset='96827214' lat='51.0063684' lon='-0.1035785' />
<node id='4475878783' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='5' changeset='96827214' lat='51.0063772' lon='-0.1041393' />
<node id='4475878784' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='5' changeset='96827214' lat='51.0064158' lon='-0.1035614' />
<node id='4475878785' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='5' changeset='96827214' lat='51.0064211' lon='-0.1035986' />
<node id='4475878786' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='5' changeset='96827214' lat='51.0064714' lon='-0.1035807'>
<tag k='entrance' v='yes' />
</node>
<node id='4475878787' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='5' changeset='96827214' lat='51.0064756' lon='-0.1036105' />
<node id='4475878788' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='5' changeset='96827214' lat='51.0065514' lon='-0.1035836' />
<node id='4475878789' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='5' changeset='96827214' lat='51.0065894' lon='-0.1040526' />
<node id='4475878790' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='3' changeset='96827214' lat='51.0066749' lon='-0.1036284' />
<node id='4475878791' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='3' changeset='96827214' lat='51.0066774' lon='-0.1038115' />
<node id='4475878792' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='2' changeset='59239902' lat='51.00668' lon='-0.1039003' />
<node id='4475878793' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='2' changeset='59239902' lat='51.0067083' lon='-0.1042892' />
<node id='4475878794' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='2' changeset='59239902' lat='51.0068099' lon='-0.1038085' />
<node id='4475878795' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='2' changeset='59239902' lat='51.006747' lon='-0.1038511' />
<node id='4475878796' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='3' changeset='96827214' lat='51.0068413' lon='-0.1036795' />
<node id='4475878797' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='3' changeset='96827214' lat='51.0068423' lon='-0.1037414' />
<node id='4475878798' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='2' changeset='59239902' lat='51.0069388' lon='-0.1039172' />
<node id='4475878799' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='2' changeset='59239902' lat='51.0069755' lon='-0.1037605' />
<node id='4475878800' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='2' changeset='59239902' lat='51.0069685' lon='-0.1041766' />
<node id='4475878801' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='2' changeset='59239902' lat='51.0069917' lon='-0.1039019' />
<node id='4524988024' timestamp='2016-11-27T17:08:23Z' uid='97369' user='fcrump' visible='true' version='1' changeset='43987250' lat='50.9947429' lon='-0.0724707' />
<node id='4524988031' timestamp='2021-05-19T18:14:46Z' uid='5443821' user='Thomas Jarvis' visible='true' version='9' changeset='104978865' lat='50.9879784' lon='-0.083678' />
<node id='4724171773' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0048728' lon='-0.1042825' />
<node id='4724171774' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0048263' lon='-0.1034523' />
<node id='4725832492' timestamp='2017-03-09T11:32:04Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='46706981' lat='51.005151' lon='-0.1028077' />
<node id='4725832493' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.005444' lon='-0.1028436' />
<node id='4725832494' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0056628' lon='-0.1026325' />
<node id='4725832496' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0063518' lon='-0.1025818' />
<node id='4725832497' timestamp='2017-03-09T11:32:04Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='46706981' lat='51.0063805' lon='-0.1029306' />
<node id='4726864937' timestamp='2017-03-09T22:38:44Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='46724100' lat='51.0046283' lon='-0.1031837' />
<node id='4726864938' timestamp='2017-03-09T22:38:44Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='46724100' lat='51.0045371' lon='-0.1031033' />
<node id='4726864939' timestamp='2018-05-10T10:48:42Z' uid='890751' user='extua' visible='true' version='2' changeset='58846161' lat='51.0042936' lon='-0.1031259' />
<node id='4726864942' timestamp='2017-03-09T22:38:44Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='46724100' lat='51.0044578' lon='-0.1021323' />
<node id='4726864943' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='2' changeset='58846161' lat='51.0045174' lon='-0.1026676' />
<node id='4726864944' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='2' changeset='58846161' lat='51.0048935' lon='-0.1025824' />
<node id='4726864945' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='2' changeset='58846161' lat='51.0049666' lon='-0.1025816' />
<node id='4726864946' timestamp='2017-03-09T22:38:45Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='46724100' lat='51.0049878' lon='-0.1030469' />
<node id='4726864947' timestamp='2018-05-10T10:48:42Z' uid='890751' user='extua' visible='true' version='2' changeset='58846161' lat='51.004751' lon='-0.1030899' />
<node id='4726864948' timestamp='2018-05-10T10:48:42Z' uid='890751' user='extua' visible='true' version='2' changeset='58846161' lat='51.0046904' lon='-0.1031654' />
<node id='4726864949' timestamp='2017-03-09T22:38:45Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='46724100' lat='51.0048899' lon='-0.1026132' />
<node id='4780063045' timestamp='2022-12-11T18:18:45Z' uid='10573400' user='PeterMapit' visible='true' version='6' changeset='129971525' lat='50.9884333' lon='-0.0844818' />
<node id='4788289295' timestamp='2017-04-11T12:57:32Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='47656595' lat='50.9880406' lon='-0.0877567' />
<node id='4788289311' timestamp='2017-04-11T12:57:32Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='47656595' lat='50.988499' lon='-0.0864717' />
<node id='4827447171' timestamp='2017-04-30T17:46:03Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='48287755' lat='51.0048606' lon='-0.1050746' />
<node id='4827447172' timestamp='2017-04-30T17:46:03Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='48287755' lat='51.0054436' lon='-0.1048952' />
<node id='4827447173' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0055609' lon='-0.1047651' />
<node id='4827447174' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.005484' lon='-0.1044031' />
<node id='4827447175' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0053106' lon='-0.1044821' />
<node id='4827447176' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0052947' lon='-0.1043842' />
<node id='4827447177' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0056393' lon='-0.1042298' />
<node id='4827447178' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0055556' lon='-0.1037107' />
<node id='4827447179' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='3' changeset='109282190' lat='51.0051086' lon='-0.1039878' />
<node id='4827447180' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0051745' lon='-0.1043641' />
<node id='4827447182' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0044819' lon='-0.1047267' />
<node id='4827447183' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0055197' lon='-0.1043908' />
<node id='4827447184' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0056054' lon='-0.1038966' />
<node id='4827447185' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0057041' lon='-0.1038071' />
<node id='4827447186' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0056376' lon='-0.1035859' />
<node id='4827447187' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='3' changeset='109282190' lat='51.0051524' lon='-0.1035961' />
<node id='4827447188' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='3' changeset='109282190' lat='51.0051954' lon='-0.1038677' />
<node id='4827447189' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='3' changeset='109282190' lat='51.0050609' lon='-0.1039294' />
<node id='4827447190' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='3' changeset='109282190' lat='51.0050748' lon='-0.1039997' />
<node id='4839481970' timestamp='2019-12-29T00:10:10Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='78968416' lat='51.0055568' lon='-0.103929'>
<tag k='amenity' v='cafe' />
<tag k='cuisine' v='coffee_shop' />
<tag k='description' v='This cafe is inside the Waitrose store.' />
<tag k='operator' v='Waitrose & Partners' />
</node>
<node id='4862042007' timestamp='2017-05-18T14:38:28Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='48794092' lat='50.9893963' lon='-0.0844742' />
<node id='4862042008' timestamp='2017-05-18T14:38:28Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='48794092' lat='50.9891997' lon='-0.0863835' />
<node id='4862042009' timestamp='2017-05-18T14:38:28Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='48794092' lat='50.9895616' lon='-0.0853619' />
<node id='4957970415' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.009162' lon='-0.1012045' />
<node id='4957970418' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0087017' lon='-0.1008973' />
<node id='4957974171' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133895069' lat='51.0074081' lon='-0.1036781' />
<node id='4957974172' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0073929' lon='-0.1037798' />
<node id='4957974173' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0081977' lon='-0.102862' />
<node id='4957974174' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0080633' lon='-0.1028634' />
<node id='4957974175' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0080068' lon='-0.1030726' />
<node id='4957974176' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133895069' lat='51.0075381' lon='-0.1031286' />
<node id='4957974177' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0078894' lon='-0.1022659' />
<node id='4957974178' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0082945' lon='-0.1006231' />
<node id='4989674333' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='3' changeset='133398000' lat='50.9987679' lon='-0.0935601' />
<node id='5000274190' timestamp='2020-06-03T12:35:45Z' uid='97369' user='fcrump' visible='true' version='2' changeset='86136781' lat='51.0067584' lon='-0.0785306' />
<node id='5000274191' timestamp='2020-06-03T12:35:45Z' uid='97369' user='fcrump' visible='true' version='2' changeset='86136781' lat='51.0065931' lon='-0.0782116' />
<node id='5000274193' timestamp='2022-12-04T18:19:16Z' uid='10573400' user='PeterMapit' visible='true' version='3' changeset='129713813' lat='51.0056481' lon='-0.0785421' />
<node id='5009289224' timestamp='2020-09-05T13:56:54Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='90454183' lat='50.9867419' lon='-0.1095211' />
<node id='5012711782' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0075832' lon='-0.1031484' />
<node id='5012711783' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0078109' lon='-0.1024903' />
<node id='5012711784' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0078383' lon='-0.1025209'>
<tag k='bicycle' v='no' />
<tag k='foot' v='no' />
</node>
<node id='5012711785' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.007857' lon='-0.1025402' />
<node id='5012711786' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0076883' lon='-0.1029445'>
</node>
<node id='5012711791' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0079122' lon='-0.1030818' />
<node id='5012711792' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0077314' lon='-0.1031144' />
<node id='5012711793' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0077226' lon='-0.1029919' />
<node id='5012711794' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0079035' lon='-0.1029593' />
<node id='5095440367' timestamp='2017-09-10T17:01:00Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='51913813' lat='51.0179289' lon='-0.0766873' />
<node id='5095440368' timestamp='2017-09-10T17:01:00Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='51913813' lat='51.0189488' lon='-0.0771169' />
<node id='5095440369' timestamp='2017-09-10T17:01:00Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='51913813' lat='51.0188116' lon='-0.0776935' />
<node id='5126868640' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057629' lon='-0.1033831' />
<node id='5126868641' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059754' lon='-0.1035174' />
<node id='5144677541' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133940215' lat='51.0181437' lon='-0.0916916' />
<node id='5159517404' timestamp='2022-12-06T15:41:51Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='129788169' lat='51.0031106' lon='-0.0730733' />
<node id='5371299979' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0045665' lon='-0.1051948' />
<node id='5371299980' timestamp='2022-07-06T10:29:59Z' uid='10866372' user='hogwashburrito' visible='true' version='3' changeset='123271397' lat='51.0058606' lon='-0.1035575'>
<tag k='camera:mount' v='pole' />
<tag k='camera:type' v='panning' />
<tag k='check_date' v='2022-07-06' />
<tag k='installed' v='1997' />
<tag k='man_made' v='surveillance' />
<tag k='surveillance' v='outdoor' />
<tag k='surveillance:type' v='camera' />
<tag k='surveillance:zone' v='police' />
</node>
<node id='5379052900' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='3' changeset='109282190' lat='51.0056651' lon='-0.1042751'>
</node>
<node id='5379052901' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0052974' lon='-0.1044012' />
<node id='5379052905' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058743' lon='-0.1055201' />
<node id='5379052906' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.005935' lon='-0.1052527' />
<node id='5379052907' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059618' lon='-0.105117' />
<node id='5379052908' timestamp='2018-02-01T20:17:22Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='55976716' lat='51.0059911' lon='-0.1049144' />
<node id='5379052909' timestamp='2018-02-01T20:17:22Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='55976716' lat='51.0060065' lon='-0.1046827' />
<node id='5379052910' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060219' lon='-0.1044195' />
<node id='5379052911' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059588' lon='-0.1040822' />
<node id='5379052912' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.005928' lon='-0.1038972' />
<node id='5379052913' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059441' lon='-0.1037445' />
<node id='5379052914' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059917' lon='-0.1036477' />
<node id='5379052915' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.006034' lon='-0.103594' />
<node id='5379052916' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060842' lon='-0.1035457' />
<node id='5379052917' timestamp='2018-02-01T20:17:22Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='55976716' lat='51.0061817' lon='-0.1034793' />
<node id='5379052918' timestamp='2018-02-01T20:17:22Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='55976716' lat='51.0062738' lon='-0.1034752' />
<node id='5516649771' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='4' changeset='96827214' lat='51.0065942' lon='-0.1038691' />
<node id='5516649772' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='4' changeset='96827214' lat='51.0065812' lon='-0.1038742' />
<node id='5516649773' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='4' changeset='96827214' lat='51.0065891' lon='-0.1039414' />
<node id='5516649774' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='4' changeset='96827214' lat='51.0065718' lon='-0.1039458' />
<node id='5516649775' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='4' changeset='96827214' lat='51.006544' lon='-0.104078' />
<node id='5516649776' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='4' changeset='96827214' lat='51.0065436' lon='-0.1040686' />
<node id='5516649778' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='3' changeset='96827214' lat='51.0063075' lon='-0.1036428' />
<node id='5516649781' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='3' changeset='96827214' lat='51.0062955' lon='-0.1036471' />
<node id='5516649782' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0062054' lon='-0.1035143' />
<node id='5516649783' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0061856' lon='-0.1035259' />
<node id='5516649784' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0061996' lon='-0.1035086' />
<node id='5516649785' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0061859' lon='-0.103518' />
<node id='5601978633' timestamp='2018-05-07T10:53:50Z' uid='890751' user='extua' visible='true' version='1' changeset='58754444' lat='51.0061849' lon='-0.1040133' />
<node id='5601978638' timestamp='2018-07-30T21:00:45Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='61208369' lat='51.0063993' lon='-0.1043368' />
<node id='5601978639' timestamp='2018-05-07T10:53:50Z' uid='890751' user='extua' visible='true' version='1' changeset='58754444' lat='51.0062652' lon='-0.1035454' />
<node id='5601978640' timestamp='2018-05-07T10:53:50Z' uid='890751' user='extua' visible='true' version='1' changeset='58754444' lat='51.0062962' lon='-0.1036429' />
<node id='5601978641' timestamp='2018-05-07T10:53:50Z' uid='890751' user='extua' visible='true' version='1' changeset='58754444' lat='51.0062719' lon='-0.1035872' />
<node id='5608933595' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220' lat='51.0048162' lon='-0.1040912' />
<node id='5608933596' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220' lat='51.0046799' lon='-0.10411' />
<node id='5608933597' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220' lat='51.0046714' lon='-0.1039536' />
<node id='5608933598' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220' lat='51.0046953' lon='-0.1039503' />
<node id='5608933599' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220' lat='51.004794' lon='-0.1036814' />
<node id='5608933600' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220' lat='51.0047872' lon='-0.1035555' />
<node id='5608933601' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220' lat='51.0046744' lon='-0.103571' />
<node id='5608933602' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220' lat='51.0046812' lon='-0.1036969' />
<node id='5608933603' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220' lat='51.0051043' lon='-0.1032721' />
<node id='5608933604' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220' lat='51.0050098' lon='-0.1032767' />
<node id='5608933605' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220' lat='51.0050009' lon='-0.102819' />
<node id='5608933606' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220' lat='51.0050954' lon='-0.1028144' />
<node id='5608965468' timestamp='2021-01-11T12:27:53Z' uid='63012' user='stthomse' visible='true' version='3' changeset='97306594' lat='51.0061575' lon='-0.1036056'>
<tag k='addr:city' v='Haywards Heath' />
<tag k='addr:housename' v='Fern House' />
<tag k='addr:housenumber' v='1' />
<tag k='addr:postcode' v='RH16 1EA' />
<tag k='addr:street' v='Commercial Square' />
<tag k='name' v='Hair Venture' />
<tag k='opening_hours' v='Mo-Fr 09:30-19:00; Sa 08:00-16:00' />
<tag k='shop' v='hairdresser' />
</node>
<node id='5609081544' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0048642' lon='-0.1025868' />
<node id='5609081545' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0048921' lon='-0.1025577' />
<node id='5609081546' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0049627' lon='-0.1025473' />
<node id='5609081547' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.004869' lon='-0.1024775' />
<node id='5609081548' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0048099' lon='-0.1024863' />
<node id='5609081549' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0047957' lon='-0.1022443' />
<node id='5609081550' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.004559' lon='-0.1022794' />
<node id='5609081551' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0045067' lon='-0.1024678' />
<node id='5609081552' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0045102' lon='-0.1025272' />
<node id='5609081553' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0045705' lon='-0.1026598' />
<node id='5609081554' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0045623' lon='-0.1025195' />
<node id='5609081555' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0047721' lon='-0.1026202' />
<node id='5609081556' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0047765' lon='-0.1026834' />
<node id='5609081557' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0047147' lon='-0.1026945' />
<node id='5609081558' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0047102' lon='-0.1026313' />
<node id='5609081559' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0049257' lon='-0.1022092' />
<node id='5609081560' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0048239' lon='-0.1022261' />
<node id='5609081561' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0048232' lon='-0.1022161' />
<node id='5609081562' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0047945' lon='-0.1022209' />
<node id='5609081563' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0047896' lon='-0.1021468' />
<node id='5609081564' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0048173' lon='-0.1021422' />
<node id='5609081565' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0048112' lon='-0.1020498' />
<node id='5609081566' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0049141' lon='-0.1020328' />
<node id='5609081567' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0048538' lon='-0.1022199' />
<node id='5609081568' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0045041' lon='-0.1025442' />
<node id='5609081569' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0044736' lon='-0.1025205' />
<node id='5609081570' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0044721' lon='-0.1024036' />
<node id='5609081571' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0049588' lon='-0.10257' />
<node id='5609081572' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0048165' lon='-0.1031464' />
<node id='5609081573' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0047913' lon='-0.1030845' />
<node id='5609081574' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0049286' lon='-0.1031303' />
<node id='5609081575' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161' lat='51.0043248' lon='-0.1031548' />
<node id='5629424537' timestamp='2018-05-19T20:54:15Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='59111286' lat='50.9908036' lon='-0.0800649' />
<node id='5639697434' timestamp='2018-05-24T12:15:29Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0072844' lon='-0.1040707' />
<node id='5639697435' timestamp='2018-05-24T12:15:29Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0072783' lon='-0.1040325' />
<node id='5639697436' timestamp='2018-05-24T12:15:29Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0071904' lon='-0.1040681' />
<node id='5639697437' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0071871' lon='-0.1040478' />
<node id='5639697438' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0070775' lon='-0.1040923' />
<node id='5639697439' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0070804' lon='-0.1041099' />
<node id='5639697440' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0070464' lon='-0.1041237' />
<node id='5639697441' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.007053' lon='-0.1041646' />
<node id='5639697442' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0075416' lon='-0.1039607' />
<node id='5639697443' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0070711' lon='-0.1037501' />
<node id='5639697444' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0070512' lon='-0.1037564' />
<node id='5639697445' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0070085' lon='-0.1038975' />
<node id='5639697446' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0068126' lon='-0.1038321' />
<node id='5639697447' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0067503' lon='-0.1038799' />
<node id='5639697448' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0066971' lon='-0.1040484' />
<node id='5639697449' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0066811' lon='-0.104053' />
<node id='5639697450' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0069296' lon='-0.1041879' />
<node id='5639697451' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0069321' lon='-0.1042094' />
<node id='5639697452' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.006758' lon='-0.1042596' />
<node id='5639697453' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0067596' lon='-0.1042744' />
<node id='5639697454' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0070507' lon='-0.1041505' />
<node id='5639697455' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0069457' lon='-0.1037157' />
<node id='5639697456' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0069332' lon='-0.1037216' />
<node id='5639697457' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0069386' lon='-0.1037712' />
<node id='5639697458' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='2' changeset='96827214' lat='51.0068119' lon='-0.1037426' />
<node id='5639697459' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='2' changeset='96827214' lat='51.0068122' lon='-0.1037653' />
<node id='5639697460' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='2' changeset='96827214' lat='51.006705' lon='-0.1037694' />
<node id='5639697461' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='2' changeset='96827214' lat='51.0067056' lon='-0.1038104' />
<node id='5639697462' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0065522' lon='-0.1030243' />
<node id='5639697463' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0064785' lon='-0.1029997' />
<node id='5639697464' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0064613' lon='-0.1031297' />
<node id='5639697465' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0064254' lon='-0.1031177' />
<node id='5639697466' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0064106' lon='-0.10323' />
<node id='5639697467' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0065817' lon='-0.1032872' />
<node id='5639697468' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.006596' lon='-0.103179' />
<node id='5639697469' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0065344' lon='-0.1031584' />
<node id='5639697470' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0067633' lon='-0.1032147' />
<node id='5639697471' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.006583' lon='-0.1032777' />
<node id='5639697472' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0065982' lon='-0.1031606' />
<node id='5639697473' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0067481' lon='-0.1033318' />
<node id='5639697474' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0071137' lon='-0.1033694' />
<node id='5639697475' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0068082' lon='-0.1032572' />
<node id='5639697476' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0067893' lon='-0.1033818' />
<node id='5639697477' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0070945' lon='-0.1034966' />
<node id='5639697478' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0070109' lon='-0.1033576' />
<node id='5639697479' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0069923' lon='-0.1034844' />
<node id='5639697480' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0069096' lon='-0.1033188' />
<node id='5639697481' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0068903' lon='-0.1034454' />
<node id='5639697482' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0070147' lon='-0.1033315' />
<node id='5639697483' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0069128' lon='-0.1032972' />
<node id='5639697484' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0068939' lon='-0.1034217' />
<node id='5639697485' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.006996' lon='-0.103459' />
<node id='5639697486' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0067193' lon='-0.1025621' />
<node id='5639697487' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0066484' lon='-0.1026782' />
<node id='5639697488' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0066605' lon='-0.1026967' />
<node id='5639697489' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0065879' lon='-0.1028155' />
<node id='5639697490' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0065778' lon='-0.1028' />
<node id='5639697491' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0065028' lon='-0.1029227' />
<node id='5639697492' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0065606' lon='-0.103012' />
<node id='5639697493' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0066356' lon='-0.1028893' />
<node id='5639697494' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0066466' lon='-0.1029063' />
<node id='5639697495' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0067197' lon='-0.1027867' />
<node id='5639697496' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0067078' lon='-0.1027687' />
<node id='5639697497' timestamp='2018-05-24T12:15:30Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0067783' lon='-0.1026533' />
<node id='5639697498' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0071799' lon='-0.1035185' />
<node id='5639697499' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0071047' lon='-0.103492' />
<node id='5639697500' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0071164' lon='-0.1034083' />
<node id='5639697501' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902' lat='51.0071916' lon='-0.1034349' />
<node id='5713967021' timestamp='2018-06-23T18:23:20Z' uid='88448' user='Ted Pottage' visible='true' version='4' changeset='60105973' lat='51.0047925' lon='-0.1027859'>
<tag k='addr:street' v='Perrymount Road' />
<tag k='amenity' v='community_centre' />
<tag k='name' v='Clair Hall' />
<tag k='toilets:wheelchair' v='no' />
<tag k='wheelchair' v='yes' />
<tag k='wheelchair:description' v='Four Blue Badge spaces opposite ramped entrance to Clare Hall. Narrow, so called "Accessible WC" inside hall - go to left after entrance doors. All rooms on a single level. (Photos shortly)' />
</node>
<node id='5790082246' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0051982' lon='-0.103998' />
<node id='5790082247' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0054924' lon='-0.1038699' />
<node id='5790082248' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0055325' lon='-0.1041387' />
<node id='5790082249' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.005244' lon='-0.1042759' />
<node id='5790082251' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0052669' lon='-0.1015773' />
<node id='5790082252' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0053268' lon='-0.1013381' />
<node id='5790082253' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.004472' lon='-0.1007157' />
<node id='5790082254' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0043992' lon='-0.1009341' />
<node id='5790082255' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0053335' lon='-0.101081' />
<node id='5790082256' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0052862' lon='-0.1008348' />
<node id='5790082257' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0051902' lon='-0.1006275' />
<node id='5790082258' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0050564' lon='-0.1004824' />
<node id='5790082259' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0048999' lon='-0.1004161' />
<node id='5790082260' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0047384' lon='-0.1004359' />
<node id='5790082261' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0045902' lon='-0.1005397' />
<node id='5790082262' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.004374' lon='-0.101178' />
<node id='5790082263' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.004399' lon='-0.1014219' />
<node id='5790082264' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0044717' lon='-0.1016404' />
<node id='5790082265' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0045843' lon='-0.1018108' />
<node id='5790082266' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0047252' lon='-0.1019153' />
<node id='5790082267' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0048798' lon='-0.101943' />
<node id='5790082268' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0050318' lon='-0.1018909' />
<node id='5790082269' timestamp='2018-07-27T15:21:13Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61123339' lat='51.0051655' lon='-0.1017647' />
<node id='5796943735' timestamp='2019-06-30T14:55:44Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758238' lat='51.0059175' lon='-0.102734' />
<node id='5796943738' timestamp='2019-06-30T14:55:44Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758238' lat='51.0058131' lon='-0.1027069' />
<node id='5796943739' timestamp='2019-06-30T14:55:44Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758238' lat='51.0059082' lon='-0.1028283' />
<node id='5796943742' timestamp='2019-06-30T14:55:44Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758238' lat='51.0058037' lon='-0.1028023' />
<node id='5796943743' timestamp='2019-06-30T14:55:44Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758238' lat='51.005899' lon='-0.102921' />
<node id='5796943744' timestamp='2019-06-30T14:55:44Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758238' lat='51.0057945' lon='-0.102895' />
<node id='5796943745' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0058708' lon='-0.1030933' />
<node id='5796943746' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0058258' lon='-0.1031542' />
<node id='5796943747' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0057572' lon='-0.1030262' />
<node id='5796943748' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0057854' lon='-0.1029873' />
<node id='5796943749' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0058251' lon='-0.1031535' />
<node id='5796943750' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0057801' lon='-0.1032143' />
<node id='5796943751' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0057115' lon='-0.1030863' />
<node id='5796943755' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0056859' lon='-0.1030759' />
<node id='5796943756' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0056347' lon='-0.1032498' />
<node id='5796943759' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0056268' lon='-0.1030821' />
<node id='5796943760' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0055762' lon='-0.103256' />
<node id='5796943761' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0055173' lon='-0.1032629' />
<node id='5796943762' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0055094' lon='-0.1030953' />
<node id='5796943763' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0055684' lon='-0.1030883' />
<node id='5796943765' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0054577' lon='-0.1032709' />
<node id='5796943766' timestamp='2018-07-30T21:00:38Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0054499' lon='-0.1031033' />
<node id='5796943768' timestamp='2018-07-30T21:00:39Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0056906' lon='-0.1031767' />
<node id='5796943769' timestamp='2018-07-30T21:00:39Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0056937' lon='-0.1032436' />
<node id='5796943770' timestamp='2018-07-30T21:00:39Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0058189' lon='-0.1029959' />
<node id='5796943771' timestamp='2018-07-30T21:00:39Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0057503' lon='-0.1031585' />
<node id='5796943772' timestamp='2018-07-30T21:00:39Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369' lat='51.0058899' lon='-0.1030143' />
<node id='5802124813' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='3' changeset='83117492' lat='51.0041902' lon='-0.1007185' />
<node id='5802124814' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0045758' lon='-0.1003534' />
<node id='5802124815' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.005091' lon='-0.1001322' />
<node id='5802124816' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0051869' lon='-0.1002036' />
<node id='5802124817' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0054257' lon='-0.1004216' />
<node id='5802124818' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0054881' lon='-0.1005733' />
<node id='5802124819' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0054943' lon='-0.1007291' />
<node id='5802124820' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0055182' lon='-0.1013543' />
<node id='5805163460' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0056261' lon='-0.1010881' />
<node id='5805163461' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0056233' lon='-0.1009669' />
<node id='5805163462' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0055718' lon='-0.1009699' />
<node id='5805163463' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0055746' lon='-0.1010911' />
<node id='5805163466' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0055171' lon='-0.1009731' />
<node id='5805163467' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0055199' lon='-0.1010943' />
<node id='5805163468' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0056728' lon='-0.1010549' />
<node id='5805163469' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.00567' lon='-0.1009331' />
<node id='5805163470' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0056225' lon='-0.1009359' />
<node id='5805163471' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0056254' lon='-0.1010577' />
<node id='5805163472' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057245' lon='-0.1010519' />
<node id='5805163473' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057217' lon='-0.1009301' />
<node id='5805163476' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057748' lon='-0.1010135' />
<node id='5805163477' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.005772' lon='-0.1008924' />
<node id='5805163478' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057209' lon='-0.1008954' />
<node id='5805163479' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057237' lon='-0.1010165' />
<node id='5805163480' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058255' lon='-0.1010105' />
<node id='5805163481' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058227' lon='-0.1008894' />
<node id='5805163484' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0058809' lon='-0.1014516' />
<node id='5805163485' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0058756' lon='-0.1012122' />
<node id='5805163486' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0057884' lon='-0.1012171' />
<node id='5805163487' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0057938' lon='-0.1014565' />
<node id='5805163488' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0058692' lon='-0.1019222' />
<node id='5805163489' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0058798' lon='-0.1017836' />
<node id='5805163490' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0057923' lon='-0.1017668' />
<node id='5805163491' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0057818' lon='-0.1019054' />
<node id='5805163492' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0058376' lon='-0.1021177' />
<node id='5805163493' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0058481' lon='-0.1019791' />
<node id='5805163494' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0057607' lon='-0.1019623' />
<node id='5805163495' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0057501' lon='-0.102101' />
<node id='5805163496' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0058241' lon='-0.1023323' />
<node id='5805163497' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0058346' lon='-0.1021937' />
<node id='5805163498' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0057472' lon='-0.1021769' />
<node id='5805163499' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0057366' lon='-0.1023155' />
<node id='5805163500' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0062653' lon='-0.1027942' />
<node id='5805163501' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.006251' lon='-0.1029371' />
<node id='5805163502' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060739' lon='-0.1028921' />
<node id='5805163503' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060882' lon='-0.1027492' />
<node id='5805163504' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060607' lon='-0.1030233' />
<node id='5805163505' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0062406' lon='-0.1030401' />
<node id='5805163506' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0062281' lon='-0.1030649' />
<node id='5805163507' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0061596' lon='-0.1031905' />
<node id='5805163508' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.006047' lon='-0.1031675' />
<node id='5805163509' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0061045' lon='-0.1032909' />
<node id='5805163510' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.006057' lon='-0.103278' />
<node id='5805163511' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0060454' lon='-0.103261' />
<node id='5805163512' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0060406' lon='-0.1032325' />
<node id='5805163513' timestamp='2018-08-02T21:16:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062858' lon='-0.103044'>
<tag k='addr:housename' v='Palmerston House' />
<tag k='addr:postcode' v='RH16 1DR' />
</node>
<node id='5805163514' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0062468' lon='-0.1025845' />
<node id='5805163515' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0061141' lon='-0.1025824' />
<node id='5805163516' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0061135' lon='-0.1026757' />
<node id='5805163517' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.006246' lon='-0.1027224' />
<node id='5805163518' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0062476' lon='-0.1024608' />
<node id='5805163519' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0061147' lon='-0.102492' />
<node id='5805163522' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.006252' lon='-0.1022497' />
<node id='5805163523' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0061128' lon='-0.1022532' />
<node id='5805163524' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.006114' lon='-0.1023667' />
<node id='5805163525' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062531' lon='-0.1023632' />
<node id='5805163526' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062505' lon='-0.1021353' />
<node id='5805163527' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0061114' lon='-0.1021388' />
<node id='5805163528' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0061125' lon='-0.1022523' />
<node id='5805163529' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062517' lon='-0.1022488' />
<node id='5805163530' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0063748' lon='-0.1018726' />
<node id='5805163531' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0061185' lon='-0.101874' />
<node id='5805163532' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0061188' lon='-0.1020089' />
<node id='5805163533' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.006375' lon='-0.1020076' />
<node id='5805163534' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0063142' lon='-0.1017728' />
<node id='5805163535' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0063112' lon='-0.1015798' />
<node id='5805163536' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0063574' lon='-0.101578' />
<node id='5805163537' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0063551' lon='-0.1014342' />
<node id='5805163538' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0063016' lon='-0.1014364' />
<node id='5805163539' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062995' lon='-0.1013039' />
<node id='5805163540' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062098' lon='-0.1013075' />
<node id='5805163541' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062117' lon='-0.1014325' />
<node id='5805163542' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0061705' lon='-0.1014341' />
<node id='5805163543' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0061726' lon='-0.1015687' />
<node id='5805163544' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062072' lon='-0.1015674' />
<node id='5805163545' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062105' lon='-0.1017769' />
<node id='5805163546' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0064094' lon='-0.1017476' />
<node id='5805163547' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0064309' lon='-0.101544' />
<node id='5805163548' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0063654' lon='-0.1015265' />
<node id='5805163549' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0063439' lon='-0.1017301' />
<node id='5805163550' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060009' lon='-0.1016701' />
<node id='5805163551' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0060658' lon='-0.1016728' />
<node id='5805163552' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0061198' lon='-0.1016178' />
<node id='5805163553' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0061333' lon='-0.1015078' />
<node id='5805163554' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0061223' lon='-0.1014046' />
<node id='5805163555' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0060818' lon='-0.1013442' />
<node id='5805163556' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.005996' lon='-0.1013415' />
<node id='5805163557' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062362' lon='-0.1010425' />
<node id='5805163558' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0061067' lon='-0.1010417' />
<node id='5805163559' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0061064' lon='-0.1012141' />
<node id='5805163560' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062358' lon='-0.1012148' />
<node id='5805163561' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062353' lon='-0.1008708' />
<node id='5805163562' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0061059' lon='-0.1008701' />
<node id='5805163563' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0061055' lon='-0.1010424' />
<node id='5805163564' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062349' lon='-0.1010431' />
<node id='5805163565' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062229' lon='-0.1008559' />
<node id='5805163566' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0062213' lon='-0.1006502' />
<node id='5805163567' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0061129' lon='-0.1006523' />
<node id='5805163568' timestamp='2018-08-02T21:16:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0061144' lon='-0.100858' />
<node id='5805163599' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0066679' lon='-0.1019181' />
<node id='5805163600' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065355' lon='-0.1018805' />
<node id='5805163601' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065282' lon='-0.1019458' />
<node id='5805163602' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0066606' lon='-0.1019834' />
<node id='5805163603' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0066762' lon='-0.1018517' />
<node id='5805163604' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065438' lon='-0.1018141' />
<node id='5805163605' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065364' lon='-0.1018794' />
<node id='5805163606' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0066688' lon='-0.1019171' />
<node id='5805163607' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0066986' lon='-0.1016697' />
<node id='5805163608' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065662' lon='-0.1016321' />
<node id='5805163609' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065588' lon='-0.1016974' />
<node id='5805163610' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0066912' lon='-0.101735' />
<node id='5805163611' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0067064' lon='-0.1016087' />
<node id='5805163612' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.006574' lon='-0.101571' />
<node id='5805163613' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065666' lon='-0.1016364' />
<node id='5805163614' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.006699' lon='-0.101674' />
<node id='5805163615' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0067181' lon='-0.1014264' />
<node id='5805163616' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065857' lon='-0.1013888' />
<node id='5805163617' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065783' lon='-0.1014541' />
<node id='5805163618' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0067107' lon='-0.1014917' />
<node id='5805163619' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0067253' lon='-0.10136' />
<node id='5805163620' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065929' lon='-0.1013224' />
<node id='5805163621' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065856' lon='-0.1013877' />
<node id='5805163622' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.006718' lon='-0.1014253' />
<node id='5805163623' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0067465' lon='-0.1011627' />
<node id='5805163624' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0066141' lon='-0.1011251' />
<node id='5805163625' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0066067' lon='-0.1011904' />
<node id='5805163626' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0067391' lon='-0.101228' />
<node id='5805163627' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0067532' lon='-0.1010972' />
<node id='5805163628' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0066207' lon='-0.1010596' />
<node id='5805163629' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0066134' lon='-0.1011249' />
<node id='5805163630' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0067458' lon='-0.1011626' />
<node id='5805163631' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.006771' lon='-0.1009008' />
<node id='5805163632' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0066386' lon='-0.1008632' />
<node id='5805163633' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0066312' lon='-0.1009285' />
<node id='5805163634' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0067636' lon='-0.1009661' />
<node id='5805163635' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0067788' lon='-0.1008353' />
<node id='5805163636' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0066464' lon='-0.1007977' />
<node id='5805163637' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.006639' lon='-0.100863' />
<node id='5805163638' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0067714' lon='-0.1009007' />
<node id='5805163639' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065598' lon='-0.1023305' />
<node id='5805163640' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065929' lon='-0.1020665' />
<node id='5805163641' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065416' lon='-0.1020502' />
<node id='5805163642' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065313' lon='-0.1021329' />
<node id='5805163643' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065084' lon='-0.1021256' />
<node id='5805163644' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0064856' lon='-0.102307' />
<node id='5805163645' timestamp='2018-08-02T21:16:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0065659' lon='-0.1024602' />
<node id='5805163646' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0065063' lon='-0.1024336' />
<node id='5805163647' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.006491' lon='-0.1024613' />
<node id='5805163648' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0064702' lon='-0.1024313' />
<node id='5805163649' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0064329' lon='-0.1024709' />
<node id='5805163650' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0064998' lon='-0.1025723' />
<node id='5805163858' timestamp='2018-08-02T21:16:55Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562' lat='51.0073092' lon='-0.0985127' />
<node id='5805163883' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='117291260' lat='51.0066633' lon='-0.0965349' />
<node id='5810812245' timestamp='2018-08-05T19:42:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0078037' lon='-0.1005618' />
<node id='5810812249' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.007003' lon='-0.1021456' />
<node id='5810812250' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0068686' lon='-0.1020935' />
<node id='5810812251' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0068455' lon='-0.1022437' />
<node id='5810812252' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0068879' lon='-0.1022601' />
<node id='5810813753' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0068762' lon='-0.1023363' />
<node id='5810813754' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070759' lon='-0.1024138' />
<node id='5810813755' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070885' lon='-0.1023316' />
<node id='5810813756' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069809' lon='-0.1022899' />
<node id='5810813757' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069774' lon='-0.1019474' />
<node id='5810813758' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0068937' lon='-0.1019219' />
<node id='5810813759' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0068802' lon='-0.1020339' />
<node id='5810813760' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069639' lon='-0.1020594' />
<node id='5810813761' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069923' lon='-0.1018352' />
<node id='5810813762' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069086' lon='-0.1018097' />
<node id='5810813763' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0068951' lon='-0.1019217' />
<node id='5810813764' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069788' lon='-0.1019472' />
<node id='5810813765' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070079' lon='-0.1016778' />
<node id='5810813766' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069242' lon='-0.1016524' />
<node id='5810813767' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069107' lon='-0.1017644' />
<node id='5810813768' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069944' lon='-0.1017898' />
<node id='5810813769' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070214' lon='-0.1015638' />
<node id='5810813770' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069377' lon='-0.1015384' />
<node id='5810813771' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069242' lon='-0.1016504' />
<node id='5810813772' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070079' lon='-0.1016758' />
<node id='5810813773' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070348' lon='-0.1013639' />
<node id='5810813774' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069499' lon='-0.1013506' />
<node id='5810813775' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069429' lon='-0.1014641' />
<node id='5810813776' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070277' lon='-0.1014774' />
<node id='5810813777' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070415' lon='-0.1012486' />
<node id='5810813778' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069567' lon='-0.1012353' />
<node id='5810813779' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069496' lon='-0.1013487' />
<node id='5810813780' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070345' lon='-0.101362' />
<node id='5810813781' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070584' lon='-0.1011709' />
<node id='5810813782' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069482' lon='-0.1011505' />
<node id='5810813783' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069434' lon='-0.101216' />
<node id='5810813784' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070536' lon='-0.1012364' />
<node id='5810813785' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070629' lon='-0.1011052' />
<node id='5810813786' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069527' lon='-0.1010848' />
<node id='5810813787' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069479' lon='-0.1011503' />
<node id='5810813788' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070581' lon='-0.1011707' />
<node id='5810813789' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070699' lon='-0.1009964' />
<node id='5810813790' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069597' lon='-0.100976' />
<node id='5810813791' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069549' lon='-0.1010416' />
<node id='5810813792' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070651' lon='-0.101062' />
<node id='5810813793' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.007075' lon='-0.1009294' />
<node id='5810813794' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069648' lon='-0.100909' />
<node id='5810813795' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.00696' lon='-0.1009745' />
<node id='5810813796' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070702' lon='-0.1009949' />
<node id='5810813797' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070897' lon='-0.1008074' />
<node id='5810813798' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069795' lon='-0.100787' />
<node id='5810813799' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0069747' lon='-0.1008525' />
<node id='5810813800' timestamp='2018-08-05T19:42:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905' lat='51.0070849' lon='-0.1008729' />
<node id='5815820021' timestamp='2018-08-07T17:20:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0073756' lon='-0.1020483' />
<node id='5815820022' timestamp='2018-08-07T17:20:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0072856' lon='-0.1020025' />
<node id='5815820023' timestamp='2018-08-07T17:20:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0072591' lon='-0.1021336' />
<node id='5815820024' timestamp='2018-08-07T17:20:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0073492' lon='-0.1021795' />
<node id='5815820025' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0073952' lon='-0.1019188' />
<node id='5815820026' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.007307' lon='-0.1018718' />
<node id='5815820027' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0072886' lon='-0.1019596' />
<node id='5815820028' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.007377' lon='-0.1020059' />
<node id='5815820029' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0074136' lon='-0.1018319' />
<node id='5815820030' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0073254' lon='-0.1017849' />
<node id='5815820033' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0074416' lon='-0.1016581' />
<node id='5815820034' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0073516' lon='-0.1016123' />
<node id='5815820035' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0073251' lon='-0.1017435' />
<node id='5815820036' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0074151' lon='-0.1017893' />
<node id='5815820037' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0075167' lon='-0.1013201' />
<node id='5815820038' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0074267' lon='-0.1012743' />
<node id='5815820039' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0074002' lon='-0.1014055' />
<node id='5815820040' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0074902' lon='-0.1014513' />
<node id='5815820041' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0074603' lon='-0.1015517' />
<node id='5815820042' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.007372' lon='-0.101505' />
<node id='5815820043' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0073537' lon='-0.1015927' />
<node id='5815820044' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0074421' lon='-0.1016389' />
<node id='5815820045' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0074786' lon='-0.1014644' />
<node id='5815820046' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0073903' lon='-0.1014177' />
<node id='5815820049' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0075503' lon='-0.1012208' />
<node id='5815820050' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0074617' lon='-0.1011756' />
<node id='5815820051' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.007444' lon='-0.1012628' />
<node id='5815820052' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0075324' lon='-0.101309' />
<node id='5815821353' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0075678' lon='-0.101134' />
<node id='5815821354' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0074792' lon='-0.1010888' />
<node id='5815821357' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0075991' lon='-0.1009963' />
<node id='5815821358' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0075079' lon='-0.1009507' />
<node id='5815821359' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0074955' lon='-0.1010134' />
<node id='5815821360' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0075864' lon='-0.1010609' />
<node id='5815821361' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0076116' lon='-0.1009332' />
<node id='5815821362' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0075204' lon='-0.1008875' />
<node id='5815821365' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0076311' lon='-0.1008305' />
<node id='5815821366' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0075403' lon='-0.100783' />
<node id='5815821367' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0075271' lon='-0.1008464' />
<node id='5815821368' timestamp='2018-08-07T17:20:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.007618' lon='-0.1008939' />
<node id='5815821445' timestamp='2018-08-07T17:20:53Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.007334' lon='-0.1022355' />
<node id='5815821446' timestamp='2018-08-07T17:20:53Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0072724' lon='-0.1022145' />
<node id='5815821447' timestamp='2018-08-07T17:20:53Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.007255' lon='-0.1023431' />
<node id='5815821448' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0071487' lon='-0.1023067' />
<node id='5815821449' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0071339' lon='-0.1024161' />
<node id='5815821450' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0073018' lon='-0.1024735' />
<node id='5815821451' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0076486' lon='-0.1024167' />
<node id='5815821452' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0074957' lon='-0.1023343' />
<node id='5815821453' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.007429' lon='-0.1026469' />
<node id='5815821454' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0075819' lon='-0.1027293' />
<node id='5815821455' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.007532' lon='-0.1021894' />
<node id='5815821456' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0076444' lon='-0.1022489' />
<node id='5815821457' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0076299' lon='-0.1023176' />
<node id='5815821458' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0075176' lon='-0.1022581' />
<node id='5815821459' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0075452' lon='-0.1021182' />
<node id='5815821460' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0076576' lon='-0.1021777' />
<node id='5815821461' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0076432' lon='-0.1022464' />
<node id='5815821462' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0075308' lon='-0.1021869' />
<node id='5815821463' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0075721' lon='-0.1020342' />
<node id='5815821464' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0076847' lon='-0.1020928' />
<node id='5815821465' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0076705' lon='-0.1021617' />
<node id='5815821466' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0075579' lon='-0.102103' />
<node id='5815821467' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0075865' lon='-0.1019647' />
<node id='5815821468' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0076991' lon='-0.102023' />
<node id='5815821471' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0076055' lon='-0.1018677' />
<node id='5815821472' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0077182' lon='-0.1019255' />
<node id='5815821473' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0077042' lon='-0.1019944' />
<node id='5815821474' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0075915' lon='-0.1019366' />
<node id='5815821475' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0076193' lon='-0.1017998' />
<node id='5815821476' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489' lat='51.0077322' lon='-0.101857' />
<node id='5815821479' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0076418' lon='-0.1017047' />
<node id='5815821480' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0077542' lon='-0.1017643' />
<node id='5815821481' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0077398' lon='-0.101833' />
<node id='5815821482' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0076274' lon='-0.1017734' />
<node id='5815821483' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0076552' lon='-0.1016346' />
<node id='5815821484' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0077676' lon='-0.1016941' />
<node id='5815821485' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0077532' lon='-0.1017628' />
<node id='5815821486' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0076408' lon='-0.1017033' />
<node id='5815821487' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0077038' lon='-0.1013866' />
<node id='5815821488' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0078162' lon='-0.1014461' />
<node id='5815821489' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0078018' lon='-0.1015148' />
<node id='5815821490' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0076894' lon='-0.1014553' />
<node id='5815821491' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0077186' lon='-0.1013165' />
<node id='5815821492' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.007831' lon='-0.101376' />
<node id='5815821493' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0078165' lon='-0.1014447' />
<node id='5815821494' timestamp='2018-08-07T17:20:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0077041' lon='-0.1013852' />
<node id='5815821531' timestamp='2018-08-07T17:20:55Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0077529' lon='-0.1011805' />
<node id='5815821532' timestamp='2018-08-07T17:20:55Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0078302' lon='-0.101225' />
<node id='5815821533' timestamp='2018-08-07T17:20:55Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0078074' lon='-0.1013252' />
<node id='5815821534' timestamp='2018-08-07T17:20:55Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0077301' lon='-0.1012807' />
<node id='5815821535' timestamp='2018-08-07T17:20:55Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0077026' lon='-0.1015085' />
<node id='5815821536' timestamp='2018-08-07T17:20:55Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0077799' lon='-0.101553' />
<node id='5815821537' timestamp='2018-08-07T17:20:55Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.007757' lon='-0.1016532' />
<node id='5815821538' timestamp='2018-08-07T17:20:55Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0076798' lon='-0.1016087' />
<node id='5815821539' timestamp='2018-08-07T17:20:55Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.00778' lon='-0.1010562' />
<node id='5815821540' timestamp='2018-08-07T17:20:55Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0078573' lon='-0.1011007' />
<node id='5815821541' timestamp='2018-08-07T17:20:55Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0078344' lon='-0.1012009' />
<node id='5815821542' timestamp='2018-08-07T17:20:55Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0077571' lon='-0.1011564' />
<node id='5815821688' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0081259' lon='-0.0991181' />
<node id='5815821695' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0072715' lon='-0.1027267' />
<node id='5815821696' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0070678' lon='-0.1026514' />
<node id='5815821697' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.007064' lon='-0.1026774' />
<node id='5815821698' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0069518' lon='-0.1026359' />
<node id='5815821699' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0069334' lon='-0.1027613' />
<node id='5815821700' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0070452' lon='-0.1028026' />
<node id='5815821701' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0070484' lon='-0.1027808' />
<node id='5815821702' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0072526' lon='-0.1028563' />
<node id='5815821703' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0069038' lon='-0.1027092' />
<node id='5815821704' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0069225' lon='-0.1025777' />
<node id='5815821705' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0068154' lon='-0.1025392' />
<node id='5815821706' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0067966' lon='-0.1026707' />
<node id='5815821707' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0075286' lon='-0.1027603' />
<node id='5815821708' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0074465' lon='-0.1026943' />
<node id='5815821711' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0075131' lon='-0.1028088' />
<node id='5815821712' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.007431' lon='-0.1027428' />
<node id='5815821713' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0074159' lon='-0.10279' />
<node id='5815821714' timestamp='2018-08-07T17:20:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.007498' lon='-0.102856' />
<node id='5815821717' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0074016' lon='-0.1028383' />
<node id='5815821718' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0074837' lon='-0.1029043' />
<node id='5815821719' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0073822' lon='-0.103617' />
<node id='5815821720' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.007407' lon='-0.1034145' />
<node id='5815821721' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0073701' lon='-0.1034031' />
<node id='5815821722' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0073453' lon='-0.1036056' />
<node id='5815821725' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0073331' lon='-0.1033921' />
<node id='5815821726' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0073084' lon='-0.1035945' />
<node id='5815821727' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0072946' lon='-0.10359' />
<node id='5815821728' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0073194' lon='-0.1033876' />
<node id='5815821731' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0072568' lon='-0.1035785' />
<node id='5815821732' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0072815' lon='-0.1033761' />
<node id='5815821733' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0072446' lon='-0.1033646' />
<node id='5815821734' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0072198' lon='-0.1035671' />
<node id='5815821735' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849' lat='51.0075045' lon='-0.1032736' />
<node id='5815821736' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0074695' lon='-0.1033783' />
<node id='5815932322' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0095384' lon='-0.0992547' />
<node id='5815932323' timestamp='2023-03-20T12:36:23Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133897367' lat='51.0087699' lon='-0.0987109' />
<node id='5815932324' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0086554' lon='-0.0986383' />
<node id='5815932325' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0086068' lon='-0.09975' />
<node id='5815932326' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0082173' lon='-0.0964387' />
<node id='5815932327' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0086821' lon='-0.098313' />
<node id='5815932328' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0086407' lon='-0.0981925' />
<node id='5815932329' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0085531' lon='-0.0980778' />
<node id='5815932330' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.008449' lon='-0.097959' />
<node id='5815932331' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0080912' lon='-0.0975367' />
<node id='5815932332' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0077373' lon='-0.0972295' />
<node id='5815932333' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0072961' lon='-0.0968849' />
<node id='5815932334' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0072489' lon='-0.0966931' />
<node id='5815932335' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0075075' lon='-0.0965476' />
<node id='5815932336' timestamp='2023-03-20T12:36:23Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133897367' lat='51.0076693' lon='-0.0959937' />
<node id='5815932337' timestamp='2023-03-20T12:36:23Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133897367' lat='51.0077219' lon='-0.0959418' />
<node id='5815932338' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.007914' lon='-0.0961576' />
<node id='5815932339' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0087893' lon='-0.0968814' />
<node id='5815932340' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0092004' lon='-0.0972403' />
<node id='5815932341' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0094444' lon='-0.0975647' />
<node id='5815932342' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0095409' lon='-0.0978992' />
<node id='5815932343' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0096317' lon='-0.098605' />
<node id='5815932344' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0092469' lon='-0.1008352' />
<node id='5815934455' timestamp='2018-08-07T17:56:41Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.007473' lon='-0.1034261' />
<node id='5815934456' timestamp='2018-08-07T17:56:41Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0074778' lon='-0.1036322' />
<node id='5815934457' timestamp='2018-08-07T17:56:41Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0075543' lon='-0.1036277' />
<node id='5815934458' timestamp='2018-08-07T17:56:41Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0075495' lon='-0.1034215' />
<node id='5815934459' timestamp='2018-08-07T17:56:41Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0075119' lon='-0.1034237' />
<node id='5815934460' timestamp='2018-08-07T17:56:41Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0075167' lon='-0.1036299' />
<node id='5815934463' timestamp='2018-08-07T17:56:41Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0075751' lon='-0.1034307' />
<node id='5815934464' timestamp='2018-08-07T17:56:41Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0075799' lon='-0.1036369' />
<node id='5815934465' timestamp='2018-08-07T17:56:41Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0076564' lon='-0.1036312' />
<node id='5815934466' timestamp='2018-08-07T17:56:41Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0076516' lon='-0.103425' />
<node id='5815934467' timestamp='2018-08-07T17:56:41Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.007614' lon='-0.1034272' />
<node id='5815934468' timestamp='2018-08-07T17:56:42Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0076188' lon='-0.1036334' />
<node id='5815934471' timestamp='2018-08-07T17:56:42Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0076706' lon='-0.1034249' />
<node id='5815934472' timestamp='2018-08-07T17:56:42Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0076754' lon='-0.103631' />
<node id='5815934473' timestamp='2018-08-07T17:56:42Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0077526' lon='-0.1036265' />
<node id='5815934474' timestamp='2018-08-07T17:56:42Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0077478' lon='-0.1034203' />
<node id='5815934475' timestamp='2018-08-07T17:56:42Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.0077102' lon='-0.1034226' />
<node id='5815934476' timestamp='2018-08-07T17:56:42Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827' lat='51.007715' lon='-0.1036287' />
<node id='5821269446' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='133398000' lat='50.998292' lon='-0.0934213' />
<node id='5821269447' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='133398000' lat='50.9982669' lon='-0.093241' />
<node id='5821269448' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='133398000' lat='50.9984063' lon='-0.0931806' />
<node id='5821269449' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='133398000' lat='50.9983873' lon='-0.0930468' />
<node id='5821269450' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='133398000' lat='50.9985614' lon='-0.0929904' />
<node id='5821269451' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='133398000' lat='50.9985829' lon='-0.0929484' />
<node id='5821270653' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='133398000' lat='50.998599' lon='-0.092614' />
<node id='5821270654' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='133398000' lat='50.9986566' lon='-0.0925687' />
<node id='5833330951' timestamp='2018-08-14T20:47:23Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61669755' lat='51.0053941' lon='-0.0704736' />
<node id='5833330952' timestamp='2018-08-14T20:47:23Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61669755' lat='51.0051481' lon='-0.0699864' />
<node id='5833330953' timestamp='2018-08-14T20:47:23Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61669755' lat='51.004836' lon='-0.069567' />
<node id='5833330954' timestamp='2018-08-14T20:47:23Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61669755' lat='51.004762' lon='-0.0695628' />
<node id='5833330955' timestamp='2018-08-14T20:47:23Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61669755' lat='51.0047286' lon='-0.0700828' />
<node id='5833330956' timestamp='2018-08-14T20:47:23Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61669755' lat='51.004864' lon='-0.0706048' />
<node id='5833330957' timestamp='2018-12-01T17:32:16Z' uid='280348' user='Fightingfifth' visible='true' version='2' changeset='65078028' lat='51.0046883' lon='-0.0708092' />
<node id='5833330958' timestamp='2018-08-14T20:47:23Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61669755' lat='51.005465' lon='-0.0708826' />
<node id='5833330959' timestamp='2022-12-05T11:16:20Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='129737282' lat='51.0050274' lon='-0.0715222' />
<node id='5833330961' timestamp='2018-08-14T20:47:23Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61669755' lat='51.0053948' lon='-0.0728886' />
<node id='5833330962' timestamp='2021-05-19T18:14:46Z' uid='5443821' user='Thomas Jarvis' visible='true' version='3' changeset='104978865' lat='51.00564' lon='-0.0733728' />
<node id='5908876440' timestamp='2022-12-11T18:18:45Z' uid='10573400' user='PeterMapit' visible='true' version='6' changeset='129971525' lat='50.9876206' lon='-0.081573' />
<node id='5912511728' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057984' lon='-0.1036486' />
<node id='5912511732' timestamp='2018-09-17T20:00:45Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='62676066' lat='51.0061455' lon='-0.1035006' />
<node id='5912511733' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059604' lon='-0.1036998' />
<node id='5912511743' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059147' lon='-0.1038723' />
<node id='5912511744' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059218' lon='-0.1037905' />
<node id='5912511745' timestamp='2018-09-17T20:00:46Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='62676066' lat='51.0059324' lon='-0.1037402' />
<node id='5912511746' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059552' lon='-0.1036856' />
<node id='5912511747' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059828' lon='-0.1036372' />
<node id='5912511748' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060436' lon='-0.1035651' />
<node id='5912511749' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060811' lon='-0.1035327' />
<node id='5912511751' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059082' lon='-0.1035924' />
<node id='5912511752' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058818' lon='-0.1036141' />
<node id='5912511754' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058213' lon='-0.1033767' />
<node id='5912511755' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058522' lon='-0.1036191' />
<node id='5912511756' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058235' lon='-0.1036069' />
<node id='5912511757' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057995' lon='-0.1035789' />
<node id='5912511758' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057835' lon='-0.1035391' />
<node id='5912511759' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057776' lon='-0.1034928' />
<node id='5912511760' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057826' lon='-0.1034462' />
<node id='5912511761' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057979' lon='-0.1034057' />
<node id='5912511762' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058498' lon='-0.1033631' />
<node id='5912511763' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058795' lon='-0.1033667' />
<node id='5912511764' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059063' lon='-0.1033872' />
<node id='5912511765' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059266' lon='-0.1034216' />
<node id='5912511766' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059378' lon='-0.1034654' />
<node id='5912511768' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059382' lon='-0.1035127' />
<node id='5912511769' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059279' lon='-0.103557' />
<node id='5912511770' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058371' lon='-0.1036731' />
<node id='5912511774' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058337' lon='-0.1037831' />
<node id='5912511775' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058982' lon='-0.1037422' />
<node id='5912511776' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060531' lon='-0.1035008' />
<node id='5912511777' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060417' lon='-0.1033881' />
<node id='5912511781' timestamp='2018-09-17T20:00:46Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='62676066' lat='51.0060025' lon='-0.1027288' />
<node id='5912511782' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.005957' lon='-0.1032281' />
<node id='5912511783' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059035' lon='-0.1032154' />
<node id='5912511784' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059742' lon='-0.1030796' />
<node id='5912515085' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059461' lon='-0.1030601' />
<node id='5941057441' timestamp='2018-09-30T17:54:31Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='63071292' lat='50.9940221' lon='-0.0741688' />
<node id='5941057442' timestamp='2018-09-30T17:54:31Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='63071292' lat='50.9935143' lon='-0.0741335' />
<node id='5941057443' timestamp='2018-09-30T17:54:31Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='63071292' lat='50.9937434' lon='-0.0742413' />
<node id='5941057444' timestamp='2018-09-30T17:54:31Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='63071292' lat='50.993466' lon='-0.0750673' />
<node id='5941057445' timestamp='2018-09-30T17:54:31Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='63071292' lat='50.9930347' lon='-0.0764062' />
<node id='5941057446' timestamp='2018-09-30T17:54:31Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='63071292' lat='50.9925511' lon='-0.0762302' />
<node id='5941057447' timestamp='2018-09-30T17:54:31Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='63071292' lat='50.9928712' lon='-0.0770988' />
<node id='5984011621' timestamp='2018-10-14T20:36:34Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='63519752' lat='50.9951011' lon='-0.068347' />
<node id='5984011622' timestamp='2018-10-14T20:36:34Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='63519752' lat='50.9945696' lon='-0.068336' />
<node id='5984011623' timestamp='2018-10-14T20:36:34Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='63519752' lat='50.9945596' lon='-0.069101' />
<node id='5984011624' timestamp='2018-10-14T20:36:34Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='63519752' lat='50.9954422' lon='-0.0692126' />
<node id='5984011625' timestamp='2018-10-14T20:36:34Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='63519752' lat='50.9953603' lon='-0.0707442' />
<node id='6015612341' timestamp='2018-10-26T14:45:43Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='63903315' lat='51.0043015' lon='-0.1035262' />
<node id='6048868808' timestamp='2018-11-09T12:19:45Z' uid='280348' user='Fightingfifth' visible='true' version='1' changeset='64323289' lat='51.0090344' lon='-0.0739526' />
<node id='6109624545' timestamp='2018-12-01T17:32:16Z' uid='280348' user='Fightingfifth' visible='true' version='1' changeset='65078028' lat='51.0045665' lon='-0.0709546' />
<node id='6109624546' timestamp='2018-12-01T17:32:16Z' uid='280348' user='Fightingfifth' visible='true' version='1' changeset='65078028' lat='51.0043362' lon='-0.0713907' />
<node id='6149927014' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0054545' lon='-0.1043138' />
<node id='6149927016' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0054355' lon='-0.1041863' />
<node id='6150007642' timestamp='2018-12-20T15:49:31Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='65644321' lat='51.0044192' lon='-0.103508' />
<node id='6150248168' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.005082' lon='-0.1039129' />
<node id='6150248169' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='3' changeset='109282190' lat='51.0050341' lon='-0.1036045' />
<node id='6150248170' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.004934' lon='-0.1036115' />
<node id='6169441193' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0056326' lon='-0.1034959' />
<node id='6169441194' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.005686' lon='-0.1035654' />
<node id='6169441195' timestamp='2018-12-28T22:35:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='65854474' lat='51.0057338' lon='-0.1036415' />
<node id='6169441196' timestamp='2018-12-28T22:35:50Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='65854474' lat='51.0057801' lon='-0.1037396' />
<node id='6169441214' timestamp='2018-12-28T22:35:51Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='65854474' lat='51.0057099' lon='-0.1034187' />
<node id='6169441220' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.005152' lon='-0.1033415' />
<node id='6169441224' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060086' lon='-0.1036033' />
<node id='6169441229' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058925' lon='-0.1032532' />
<node id='6169441231' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0059554' lon='-0.1032769' />
<node id='6321959979' timestamp='2022-12-11T00:10:03Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='129949544' lat='50.9984056' lon='-0.1040562' />
<node id='6321959986' timestamp='2022-12-11T00:10:03Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='129949544' lat='50.9984721' lon='-0.1039621' />
<node id='6449624748' timestamp='2020-06-03T13:06:37Z' uid='5443821' user='Thomas Jarvis' visible='true' version='3' changeset='86138162' lat='50.9878072' lon='-0.0810058' />
<node id='6705056132' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0062244' lon='-0.1034773' />
<node id='6705056133' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0062269' lon='-0.1035046' />
<node id='6705056134' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0062567' lon='-0.1036267' />
<node id='6705056135' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0062934' lon='-0.1037658' />
<node id='6705056136' timestamp='2019-08-13T06:29:31Z' uid='10221076' user='MrJeeves' visible='true' version='1' changeset='73291853' lat='51.0062451' lon='-0.1040843' />
<node id='6705056137' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060075' lon='-0.1042801' />
<node id='6705056141' timestamp='2019-08-13T06:29:31Z' uid='10221076' user='MrJeeves' visible='true' version='1' changeset='73291853' lat='51.0060152' lon='-0.1045431'>
<tag k='highway' v='crossing' />
</node>
<node id='6746333690' timestamp='2021-05-19T18:14:46Z' uid='5443821' user='Thomas Jarvis' visible='true' version='3' changeset='104978865' lat='51.0057478' lon='-0.0736293' />
<node id='6746333735' timestamp='2022-12-06T15:41:51Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='129788169' lat='51.0057004' lon='-0.0867671' />
<node id='6880967899' timestamp='2019-10-15T08:38:12Z' uid='10252560' user='rkkapilk' visible='true' version='1' changeset='75706274' lat='51.0051373' lon='-0.101986' />
<node id='6880967900' timestamp='2019-10-15T08:38:12Z' uid='10252560' user='rkkapilk' visible='true' version='1' changeset='75706274' lat='51.0053202' lon='-0.1017432' />
<node id='6880967901' timestamp='2019-10-15T08:38:12Z' uid='10252560' user='rkkapilk' visible='true' version='1' changeset='75706274' lat='51.005511' lon='-0.1015038' />
<node id='6880967902' timestamp='2019-10-15T08:38:12Z' uid='10252560' user='rkkapilk' visible='true' version='1' changeset='75706274' lat='51.0056092' lon='-0.1015056' />
<node id='6880967903' timestamp='2019-10-15T08:38:12Z' uid='10252560' user='rkkapilk' visible='true' version='1' changeset='75706274' lat='51.0056097' lon='-0.1018925' />
<node id='6880967904' timestamp='2019-10-15T08:38:12Z' uid='10252560' user='rkkapilk' visible='true' version='1' changeset='75706274' lat='51.005628' lon='-0.1020016' />
<node id='6880967905' timestamp='2019-10-15T08:38:12Z' uid='10252560' user='rkkapilk' visible='true' version='1' changeset='75706274' lat='51.0056313' lon='-0.1024665' />
<node id='6880967906' timestamp='2019-10-15T08:38:12Z' uid='10252560' user='rkkapilk' visible='true' version='1' changeset='75706274' lat='51.0054623' lon='-0.1015649' />
<node id='6880967907' timestamp='2019-10-15T08:38:12Z' uid='10252560' user='rkkapilk' visible='true' version='1' changeset='75706274' lat='51.005469' lon='-0.1018831' />
<node id='7017078481' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.006369' lon='-0.0981803' />
<node id='7017078484' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.00632' lon='-0.0984288' />
<node id='7092049865' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0065508' lon='-0.1027709' />
<node id='7092049867' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0064486' lon='-0.1044553' />
<node id='7092049868' timestamp='2019-12-29T00:10:10Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='78968416' lat='51.0049081' lon='-0.1050916' />
<node id='7092049869' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0048364' lon='-0.1045659' />
<node id='7092049870' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0048765' lon='-0.1035661' />
<node id='7099196113' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0060044' lon='-0.1020668' />
<node id='7099196114' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0063406' lon='-0.1020624'>
<tag k='noexit' v='yes' />
</node>
<node id='7099196115' timestamp='2020-01-01T05:30:41Z' uid='10252551' user='amanura' visible='true' version='1' changeset='79073737' lat='51.0071319' lon='-0.1036712' />
<node id='7099196116' timestamp='2020-01-01T05:30:41Z' uid='10252551' user='amanura' visible='true' version='1' changeset='79073737' lat='51.0070975' lon='-0.1039313' />
<node id='7099196117' timestamp='2020-01-01T05:30:41Z' uid='10252551' user='amanura' visible='true' version='1' changeset='79073737' lat='51.007199' lon='-0.1039264' />
<node id='7099196118' timestamp='2020-01-01T05:30:41Z' uid='10252551' user='amanura' visible='true' version='1' changeset='79073737' lat='51.0073127' lon='-0.1039753' />
<node id='7099196119' timestamp='2020-01-01T05:30:41Z' uid='10252551' user='amanura' visible='true' version='1' changeset='79073737' lat='51.0066378' lon='-0.1042025' />
<node id='7110693266' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='133398000' lat='50.9989987' lon='-0.0930209' />
<node id='7110693277' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='133398000' lat='50.9988182' lon='-0.0932754' />
<node id='7110693278' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='133398000' lat='50.9987648' lon='-0.0935379' />
<node id='7112424250' timestamp='2022-02-03T23:15:02Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='116983495' lat='51.0114377' lon='-0.0946015' />
<node id='7112424251' timestamp='2022-02-03T23:15:02Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='116983495' lat='51.0112495' lon='-0.0946405' />
<node id='7112424252' timestamp='2022-02-03T23:15:02Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='116983495' lat='51.0109036' lon='-0.094639' />
<node id='7114415813' timestamp='2020-01-07T12:24:36Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='79293460' lat='51.0057183' lon='-0.1029751'>
<tag k='addr:city' v='Haywards Heath' />
<tag k='addr:postcode' v='RH16 1DP' />
<tag k='addr:street' v='Commercial Square' />
</node>
<node id='7121817725' timestamp='2020-01-10T09:40:39Z' uid='10219384' user='chepurb' visible='true' version='1' changeset='79410602' lat='50.9955937' lon='-0.0683297' />
<node id='7295746977' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0028378' lon='-0.1038679' />
<node id='7295746978' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9985532' lon='-0.1017428' />
<node id='7295746979' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9976472' lon='-0.0992863' />
<node id='7295746980' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9952945' lon='-0.0982366' />
<node id='7295746981' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9976247' lon='-0.0992735' />
<node id='7295746982' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.995641' lon='-0.1015083' />
<node id='7295746983' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0010628' lon='-0.1048487' />
<node id='7295746984' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9934069' lon='-0.1009807' />
<node id='7295760585' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.003699' lon='-0.1026625' />
<node id='7295760586' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9980015' lon='-0.098318' />
<node id='7295760587' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9947492' lon='-0.1012408' />
<node id='7295760588' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0034231' lon='-0.1031976' />
<node id='7295760589' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0013963' lon='-0.1048487' />
<node id='7295760590' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9936234' lon='-0.1001806' />
<node id='7295760591' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0041273' lon='-0.102552' />
<node id='7295760592' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9954983' lon='-0.0998138' />
<node id='7295760593' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9994319' lon='-0.1040539' />
<node id='7295760594' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0039458' lon='-0.1035341' />
<node id='7295760595' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9993053' lon='-0.1027364' />
<node id='7295760596' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9986976' lon='-0.1036589' />
<node id='7295760597' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9985564' lon='-0.0973242' />
<node id='7295760598' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9958205' lon='-0.1045686' />
<node id='7295760599' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9988419' lon='-0.0979893' />
<node id='7295760600' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9951646' lon='-0.1086683' />
<node id='7295760601' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9963532' lon='-0.107155' />
<node id='7295760602' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9952031' lon='-0.1088212' />
<node id='7295760603' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9933572' lon='-0.1001552' />
<node id='7295760604' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0056626' lon='-0.1018293' />
<node id='7295760605' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.996656' lon='-0.1010827' />
<node id='7295760606' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0012712' lon='-0.1048973' />
<node id='7295760608' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9966529' lon='-0.1009987' />
<node id='7295760609' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0010965' lon='-0.105091' />
<node id='7295760610' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9962183' lon='-0.1003795' />
<node id='7295760611' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9942233' lon='-0.0994367' />
<node id='7295760612' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9958495' lon='-0.1044869' />
<node id='7295760613' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9957676' lon='-0.0985959' />
<node id='7295760615' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0010372' lon='-0.0979358' />
<node id='7295760618' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.994329' lon='-0.0991971' />
<node id='7295760619' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0056467' lon='-0.1012233' />
<node id='7295760620' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.998449' lon='-0.1017528' />
<node id='7295760621' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9938014' lon='-0.0997857' />
<node id='7295760622' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9986125' lon='-0.100861' />
<node id='7295760623' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9937052' lon='-0.1010879' />
<node id='7295760624' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9985773' lon='-0.1003947' />
<node id='7295760625' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0011767' lon='-0.1026269' />
<node id='7295760626' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9983944' lon='-0.0972454' />
<node id='7295760627' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9948904' lon='-0.0991767' />
<node id='7295760628' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0055239' lon='-0.1013197' />
<node id='7295760629' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.001436' lon='-0.1025881' />
<node id='7295760631' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0002049' lon='-0.1053737' />
<node id='7295760632' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0037743' lon='-0.1035798' />
<node id='7295760633' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.999456' lon='-0.1053635' />
<node id='7295760634' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9975445' lon='-0.099345' />
<node id='7295760635' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9963513' lon='-0.1029147' />
<node id='7295760636' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.003383' lon='-0.1027543' />
<node id='7295760637' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.993941' lon='-0.0999233' />
<node id='7295760638' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0007999' lon='-0.0977574' />
<node id='7295760639' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9933396' lon='-0.1006216' />
<node id='7295760640' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0058398' lon='-0.0983727' />
<node id='7295760641' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0004855' lon='-0.098736' />
<node id='7295760642' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9960723' lon='-0.1056079' />
<node id='7295760643' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0016257' lon='-0.1029225' />
<node id='7295760644' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9962905' lon='-0.1009401' />
<node id='7295760645' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9987151' lon='-0.0978696' />
<node id='7295760646' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9981095' lon='-0.1009892' />
<node id='7295760647' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0017103' lon='-0.1025303' />
<node id='7295760649' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0031631' lon='-0.1023969' />
<node id='7295760650' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9954325' lon='-0.1012942' />
<node id='7295760651' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9955976' lon='-0.1013096' />
<node id='7295760652' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9956105' lon='-0.0991079' />
<node id='7295760653' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9959119' lon='-0.1028716' />
<node id='7295760654' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9986269' lon='-0.1004254' />
<node id='7295760655' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9980673' lon='-0.1016509' />
<node id='7295760656' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9975574' lon='-0.099248' />
<node id='7295760658' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0003011' lon='-0.0973497' />
<node id='7295760659' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9987408' lon='-0.1029147' />
<node id='7295760660' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9960034' lon='-0.1000711' />
<node id='7295760661' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9942072' lon='-0.0999412' />
<node id='7295760662' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0056418' lon='-0.102306' />
<node id='7295760663' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0010098' lon='-0.0982339' />
<node id='7295760664' timestamp='2022-12-11T00:10:03Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='129949544' lat='50.9989158' lon='-0.1041162' />
<node id='7295760666' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9957629' lon='-0.1019057' />
<node id='7295760667' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0063559' lon='-0.1033264' />
<node id='7295760668' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9991497' lon='-0.1015744' />
<node id='7295760669' timestamp='2022-12-11T00:10:03Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='129949544' lat='50.9989223' lon='-0.104833' />
<node id='7295760670' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9997656' lon='-0.099006' />
<node id='7295760671' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9961317' lon='-0.1024688' />
<node id='7295760672' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9994544' lon='-0.1046755' />
<node id='7295760673' timestamp='2022-12-11T00:10:03Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='129949544' lat='50.9985684' lon='-0.1038241' />
<node id='7295760674' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.0040954' lon='-0.1021531' />
<node id='7295760676' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9945231' lon='-0.0984302' />
<node id='7295760677' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9955431' lon='-0.10226' />
<node id='7295760678' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9947429' lon='-0.1014216' />
<node id='7295760679' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9963818' lon='-0.1034524' />
<node id='7295760680' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9968293' lon='-0.1011336' />
<node id='7295760683' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9966641' lon='-0.1042296' />
<node id='7295760684' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9952833' lon='-0.0996151' />
<node id='7295760685' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9968694' lon='-0.1006216' />
<node id='7295760686' timestamp='2022-12-11T00:10:03Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='129949544' lat='50.998889' lon='-0.1048333' />
<node id='7295760687' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9973345' lon='-0.0993117' />
<node id='7295760688' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9950251' lon='-0.0978338' />
<node id='7295760689' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9946257' lon='-0.0986798' />
<node id='7295760690' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0038608' lon='-0.1026015' />
<node id='7295760691' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0003604' lon='-0.099029' />
<node id='7295760692' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9961798' lon='-0.1059596' />
<node id='7295760693' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9931903' lon='-0.1009578' />
<node id='7295760694' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9990808' lon='-0.0983793' />
<node id='7295760695' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.997814' lon='-0.0981346' />
<node id='7295760696' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9960081' lon='-0.1043979' />
<node id='7295760697' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9985757' lon='-0.1003055' />
<node id='7295760698' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0025139' lon='-0.1040157' />
<node id='7295760699' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0034905' lon='-0.103297' />
<node id='7295760700' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.002182' lon='-0.1041913' />
<node id='7295760701' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9996629' lon='-0.0990697' />
<node id='7295760702' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0019367' lon='-0.1043824' />
<node id='7295760703' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9996052' lon='-0.0967764' />
<node id='7295760704' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0018565' lon='-0.1042805' />
<node id='7295760705' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9972046' lon='-0.1006802' />
<node id='7295760707' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.995596' lon='-0.1014115' />
<node id='7295760708' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9960034' lon='-0.1000023' />
<node id='7295760709' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0012263' lon='-0.1029428' />
<node id='7295760710' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0005544' lon='-0.1053049' />
<node id='7295760711' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9976824' lon='-0.0991819' />
<node id='7295760712' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9959553' lon='-0.1029759' />
<node id='7295760713' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0063003' lon='-0.1032035' />
<node id='7295760714' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83117492' lat='51.001701' lon='-0.1023623' />
<node id='7295760715' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9994593' lon='-0.0972376' />
<node id='7295760717' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9986078' lon='-0.1010852' />
<node id='7295760718' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9991386' lon='-0.098606' />
<node id='7295760719' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0031954' lon='-0.1037021' />
<node id='7295760721' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9953987' lon='-0.1020204' />
<node id='7295760722' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9954196' lon='-0.1015262' />
<node id='7295760723' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.999456' lon='-0.1050883' />
<node id='7295760724' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9958591' lon='-0.0999081' />
<node id='7295760725' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='51.0035146' lon='-0.1036129' />
<node id='7295760726' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9959087' lon='-0.1084084' />
<node id='7295760727' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9946306' lon='-0.0995616' />
<node id='7295760728' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9961879' lon='-0.1081738' />
<node id='7295760729' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9966128' lon='-0.1034169' />
<node id='7295760730' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9963868' lon='-0.1073991' />
<node id='7295760731' timestamp='2020-03-15T01:47:45Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82207395' lat='50.9963096' lon='-0.107868' />
<node id='7296507358' timestamp='2020-03-15T10:33:09Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9884792' lon='-0.0892803' />
<node id='7296512106' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9903508' lon='-0.0949575' />
<node id='7296512107' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.990885' lon='-0.0873186' />
<node id='7296512108' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9890356' lon='-0.0950035' />
<node id='7296512111' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9894205' lon='-0.0944453' />
<node id='7296512115' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9907068' lon='-0.0958953' />
<node id='7296512116' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9902435' lon='-0.0879658' />
<node id='7296512117' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9906315' lon='-0.0954443' />
<node id='7296512118' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9902818' lon='-0.095197' />
<node id='7296512119' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9919178' lon='-0.0866917' />
<node id='7296512120' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9922995' lon='-0.0903709' />
<node id='7296512121' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9922385' lon='-0.0895147' />
<node id='7296512122' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9922514' lon='-0.0898055' />
<node id='7296512123' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9896146' lon='-0.0884598' />
<node id='7296512124' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9916996' lon='-0.0936225' />
<node id='7296512125' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9910711' lon='-0.0871911' />
<node id='7296512127' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9908913' lon='-0.0961092' />
<node id='7296512128' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9924374' lon='-0.0870074' />
<node id='7296512129' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9922964' lon='-0.0892243' />
<node id='7296512130' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9921648' lon='-0.0924782' />
<node id='7296512131' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9912757' lon='-0.0949821' />
<node id='7296512132' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9920589' lon='-0.0883273' />
<node id='7296512133' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9925466' lon='-0.0884499' />
<node id='7296512134' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9923893' lon='-0.0875119' />
<node id='7296512135' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9917126' lon='-0.0870686' />
<node id='7296512136' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9895393' lon='-0.0943561' />
<node id='7296512137' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9922097' lon='-0.0926897' />
<node id='7296512138' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9918344' lon='-0.0869666' />
<node id='7296512139' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9923348' lon='-0.0884397' />
<node id='7296512140' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9920348' lon='-0.0924221' />
<node id='7296512141' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9887918' lon='-0.0956278' />
<node id='7296512142' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9893483' lon='-0.0944963' />
<node id='7296512143' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.9887902' lon='-0.0890663' />
<node id='7296512144' timestamp='2020-03-15T10:42:33Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82213103' lat='50.988418' lon='-0.09681' />
<node id='7320688564' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0015048' lon='-0.0834328' />
<node id='7320688565' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0059624' lon='-0.0803445' />
<node id='7320688566' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0017854' lon='-0.0832163' />
<node id='7320688567' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0063745' lon='-0.0806604' />
<node id='7320688568' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0065155' lon='-0.0818325' />
<node id='7320688569' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9959371' lon='-0.0866994' />
<node id='7320688570' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9953532' lon='-0.0897571' />
<node id='7320688571' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0036728' lon='-0.0822352' />
<node id='7320688572' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0051895' lon='-0.0874461' />
<node id='7320688573' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.002823' lon='-0.082653' />
<node id='7320688574' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9992085' lon='-0.0870077' />
<node id='7320688575' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0050084' lon='-0.0875453' />
<node id='7320688576' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0066343' lon='-0.0790501' />
<node id='7320688577' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9961872' lon='-0.0881289' />
<node id='7320688578' timestamp='2022-12-04T18:19:16Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='129713813' lat='51.0062613' lon='-0.0794965' />
<node id='7320688579' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.00539' lon='-0.0841106' />
<node id='7320688580' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0054381' lon='-0.0812006' />
<node id='7320688581' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9982383' lon='-0.0876345' />
<node id='7320688582' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0062863' lon='-0.0810376' />
<node id='7320688583' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0064995' lon='-0.0803215' />
<node id='7320688584' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0055071' lon='-0.0812491' />
<node id='7320722985' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9992566' lon='-0.0869848' />
<node id='7320722986' timestamp='2021-12-06T19:46:36Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='114632226' lat='50.9958956' lon='-0.0890552' />
<node id='7320722987' timestamp='2021-12-06T19:46:36Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='114632226' lat='50.9958223' lon='-0.0890642' />
<node id='7320722988' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9969248' lon='-0.0884627' />
<node id='7320722989' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9964615' lon='-0.0879734' />
<node id='7320722990' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.006368' lon='-0.0796693' />
<node id='7320722991' timestamp='2021-12-06T19:46:36Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='114632226' lat='50.9960948' lon='-0.087612' />
<node id='7320722992' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0064306' lon='-0.07945' />
<node id='7320722993' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9930311' lon='-0.0904196' />
<node id='7320722994' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0059463' lon='-0.0861948' />
<node id='7320722995' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0065235' lon='-0.0780003' />
<node id='7320722996' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.000453' lon='-0.0847094' />
<node id='7320722997' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9993866' lon='-0.0864955' />
<node id='7320722998' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9951383' lon='-0.0896042' />
<node id='7320722999' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.00611' lon='-0.082936' />
<node id='7320723000' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0067448' lon='-0.0787953' />
<node id='7320723001' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0054942' lon='-0.0838761' />
<node id='7320723002' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0024253' lon='-0.0828289' />
<node id='7320723003' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.004521' lon='-0.0817612' />
<node id='7320723004' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9990434' lon='-0.0871785' />
<node id='7320723005' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0026321' lon='-0.0825232' />
<node id='7320723006' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0055535' lon='-0.0854508' />
<node id='7320723007' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9947983' lon='-0.0896297' />
<node id='7320723008' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0020292' lon='-0.0829384' />
<node id='7320723009' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0024429' lon='-0.082602' />
<node id='7320723010' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0020227' lon='-0.0830658' />
<node id='7320723011' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9942179' lon='-0.0894462' />
<node id='7320723012' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0026049' lon='-0.0826761' />
<node id='7320723013' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0056545' lon='-0.0835907' />
<node id='7320723014' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9983826' lon='-0.0877619' />
<node id='7320723015' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0063296' lon='-0.0799316' />
<node id='7320723016' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0065925' lon='-0.0792998' />
<node id='7320723017' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0065203' lon='-0.0793914' />
<node id='7320723018' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.996678' lon='-0.0879455' />
<node id='7320723019' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9995582' lon='-0.0865337' />
<node id='7320723020' timestamp='2022-12-04T18:19:16Z' uid='10573400' user='PeterMapit' visible='true' version='3' changeset='129713813' lat='51.0056318' lon='-0.0786017' />
<node id='7320723021' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9955683' lon='-0.0889672' />
<node id='7320723022' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9962739' lon='-0.0857821' />
<node id='7320723023' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9961745' lon='-0.0847988' />
<node id='7320723024' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0059176' lon='-0.0868881' />
<node id='7320723025' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0066727' lon='-0.0816568' />
<node id='7320723026' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.99595' lon='-0.0871175' />
<node id='7320723027' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0067898' lon='-0.0786015' />
<node id='7320723028' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9949557' lon='-0.0895637' />
<node id='7320723029' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9957415' lon='-0.0861184' />
<node id='7320723030' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.005903' lon='-0.0832163' />
<node id='7320723031' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.005297' lon='-0.0845056' />
<node id='7320723032' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0067737' lon='-0.0820823' />
<node id='7320723033' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0060442' lon='-0.0863605' />
<node id='7320723034' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9999719' lon='-0.0851731' />
<node id='7320723035' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0068362' lon='-0.0818912' />
<node id='7320723036' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0059431' lon='-0.0866382' />
<node id='7320723037' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.006283' lon='-0.0801458' />
<node id='7320723038' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9998724' lon='-0.0852342' />
<node id='7320723039' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9984838' lon='-0.0873187' />
<node id='7320723040' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9957768' lon='-0.0851348' />
<node id='7320723041' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9976209' lon='-0.0861897' />
<node id='7320723042' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9998596' lon='-0.0855605' />
<node id='7320723043' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9933809' lon='-0.0893188' />
<node id='7320723044' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0065043' lon='-0.0813866' />
<node id='7320723045' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0055472' lon='-0.0891787' />
<node id='7320723046' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0066246' lon='-0.0791748' />
<node id='7320723047' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9980603' lon='-0.0880753' />
<node id='7320723048' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9991508' lon='-0.0871071' />
<node id='7320723049' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0050277' lon='-0.0812439' />
<node id='7320723050' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0066872' lon='-0.0789124' />
<node id='7320723051' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0049731' lon='-0.0879607' />
<node id='7320723052' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9976258' lon='-0.0866382' />
<node id='7320723053' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0053708' lon='-0.0848928' />
<node id='7320723054' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0050452' lon='-0.0883023' />
<node id='7320723055' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0058421' lon='-0.0892933' />
<node id='7320723056' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0068299' lon='-0.0786934' />
<node id='7320723057' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.006041' lon='-0.0798145' />
<node id='7320723058' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9968576' lon='-0.0879073' />
<node id='7320723059' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9964182' lon='-0.0887557' />
<node id='7320723060' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9973612' lon='-0.0873951' />
<node id='7320723061' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9931017' lon='-0.089895' />
<node id='7320723062' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9989279' lon='-0.0872752' />
<node id='7320723063' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9960045' lon='-0.0849262' />
<node id='7320723064' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9975151' lon='-0.0853412' />
<node id='7320723065' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9975617' lon='-0.0856369' />
<node id='7320723066' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9975808' lon='-0.0870155' />
<node id='7320723067' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9970485' lon='-0.0877035' />
<node id='7320723068' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.000214' lon='-0.0849133' />
<node id='7320723069' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0062206' lon='-0.0825283' />
<node id='7320723070' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9961007' lon='-0.0859502' />
<node id='7320723071' timestamp='2022-12-04T18:19:16Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='129713813' lat='51.0060014' lon='-0.0791419' />
<node id='7320723072' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0053596' lon='-0.0814248' />
<node id='7320723073' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9954624' lon='-0.089844' />
<node id='7320723074' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9942981' lon='-0.0897826' />
<node id='7320723075' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9979882' lon='-0.0879965' />
<node id='7320723076' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0053628' lon='-0.081267' />
<node id='7320723077' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9963043' lon='-0.0865543' />
<node id='7320723078' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9944232' lon='-0.0897061' />
<node id='7320723079' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0059095' lon='-0.080589' />
<node id='7320723080' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0041939' lon='-0.0818912' />
<node id='7320723081' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9946251' lon='-0.089686' />
<node id='7320723082' timestamp='2022-12-04T18:19:16Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='129713813' lat='51.0062355' lon='-0.0797105' />
<node id='7320723083' timestamp='2022-12-04T18:19:16Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='129713813' lat='51.0061537' lon='-0.0799323' />
<node id='7320723084' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0012708' lon='-0.0837996' />
<node id='7320723085' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0052922' lon='-0.0886869' />
<node id='7320723086' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0054317' lon='-0.0872472' />
<node id='7320723087' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9976835' lon='-0.0885673' />
<node id='7320723088' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9960396' lon='-0.0858282' />
<node id='7320723089' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0056946' lon='-0.0857617' />
<node id='7320723090' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0051607' lon='-0.0814681' />
<node id='7320723091' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9988301' lon='-0.0873287' />
<node id='7320723093' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9971688' lon='-0.089171' />
<node id='7320723094' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9974286' lon='-0.0889366' />
<node id='7320723095' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9962611' lon='-0.0852368' />
<node id='7320723096' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.996229' lon='-0.0855833' />
<node id='7320723097' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0006678' lon='-0.0845462' />
<node id='7320723098' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0047792' lon='-0.0815828' />
<node id='7320723099' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0007929' lon='-0.0844188' />
<node id='7320723100' timestamp='2020-03-23T00:54:22Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0063921' lon='-0.0812439' />
<node id='7320723101' timestamp='2021-12-06T19:46:36Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='114632226' lat='50.9962697' lon='-0.0887872' />
<node id='7320723275' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0010719' lon='-0.0865058' />
<node id='7320723276' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0010959' lon='-0.0866866' />
<node id='7320723277' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9993096' lon='-0.087897' />
<node id='7320723278' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9990882' lon='-0.0906083' />
<node id='7320723279' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0066583' lon='-0.0902361' />
<node id='7320723280' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0043414' lon='-0.0901828' />
<node id='7320723281' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0044199' lon='-0.0903535' />
<node id='7320723282' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0007078' lon='-0.085145' />
<node id='7320723283' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0043109' lon='-0.0834811' />
<node id='7320723284' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.000756' lon='-0.0860854' />
<node id='7320725386' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0041586' lon='-0.0935233' />
<node id='7320725388' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.003413' lon='-0.0922415' />
<node id='7320725389' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0038106' lon='-0.0916352' />
<node id='7320725390' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0045018' lon='-0.0844011' />
<node id='7320725391' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0025327' lon='-0.0837716' />
<node id='7320725392' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0035973' lon='-0.0871276' />
<node id='7320725393' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0022103' lon='-0.0837104' />
<node id='7320725395' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0023306' lon='-0.0837614' />
<node id='7320725396' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0083705' lon='-0.091613' />
<node id='7320725397' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0041009' lon='-0.0936276' />
<node id='7320725398' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9996592' lon='-0.0875123' />
<node id='7320725399' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0009388' lon='-0.086256' />
<node id='7320725400' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0035718' lon='-0.0868091' />
<node id='7320725401' timestamp='2021-12-09T16:05:35Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='114750425' lat='51.0045265' lon='-0.0929396' />
<node id='7320725402' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.000594' lon='-0.087874' />
<node id='7320725403' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9996639' lon='-0.0871249' />
<node id='7320725404' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0037866' lon='-0.0929576' />
<node id='7320725405' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0043094' lon='-0.0907433' />
<node id='7320725406' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9997554' lon='-0.0872345' />
<node id='7320725408' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0042132' lon='-0.0931308' />
<node id='7320725409' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0074743' lon='-0.0910974' />
<node id='7320725410' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0040303' lon='-0.0865363' />
<node id='7320725411' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0006149' lon='-0.0859757' />
<node id='7320725413' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0004834' lon='-0.0883762' />
<node id='7320725414' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0042067' lon='-0.0847731' />
<node id='7320725415' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9990562' lon='-0.0902412' />
<node id='7320725416' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0004417' lon='-0.0855987' />
<node id='7320725417' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0077501' lon='-0.0913039' />
<node id='7320725418' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9997617' lon='-0.0881366' />
<node id='7320725419' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0020147' lon='-0.0843449' />
<node id='7320725420' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0038877' lon='-0.0826888' />
<node id='7320725421' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0040095' lon='-0.0915715' />
<node id='7320725422' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0037176' lon='-0.0931615' />
<node id='7320725425' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0041553' lon='-0.0826761' />
<node id='7320725426' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0042164' lon='-0.0913218' />
<node id='7320725427' timestamp='2020-03-26T13:45:41Z' uid='115894' user='DaveF' visible='true' version='2' changeset='82665633' lat='51.0039943' lon='-0.0936677' />
<node id='7320725428' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0073926' lon='-0.0908986' />
<node id='7320725429' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9992375' lon='-0.0912402' />
<node id='7320725430' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0037482' lon='-0.0867376' />
<node id='7320725431' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.000477' lon='-0.0853616' />
<node id='7320725432' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0010816' lon='-0.0867809' />
<node id='7320725433' timestamp='2020-03-26T13:45:41Z' uid='115894' user='DaveF' visible='true' version='2' changeset='82665633' lat='51.0038856' lon='-0.093634' />
<node id='7320725434' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0024877' lon='-0.0839856' />
<node id='7320725435' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0038091' lon='-0.0871658' />
<node id='7320725436' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='117291260' lat='51.0072393' lon='-0.0942243' />
<node id='7320725437' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9991461' lon='-0.0906438' />
<node id='7320725439' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.001702' lon='-0.0841106' />
<node id='7320725440' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0021319' lon='-0.0837514' />
<node id='7320725441' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9997747' lon='-0.0879328' />
<node id='7320725442' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0020405' lon='-0.084192' />
<node id='7320725443' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0020757' lon='-0.083866' />
<node id='7320725444' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0045273' lon='-0.0840571' />
<node id='7320725445' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.999271' lon='-0.0915153' />
<node id='7320725446' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0030361' lon='-0.0832951' />
<node id='7320725447' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0039501' lon='-0.0843194' />
<node id='7320725448' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0039228' lon='-0.0847094' />
<node id='7320725449' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9998516' lon='-0.0877391' />
<node id='7320725450' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0043317' lon='-0.0878181' />
<node id='7320725451' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0025375' lon='-0.0836213' />
<node id='7320725452' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0042164' lon='-0.0933728' />
<node id='7320725453' timestamp='2020-03-23T01:00:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='51.0061675' lon='-0.089686' />
<node id='7320725455' timestamp='2020-03-26T13:45:41Z' uid='115894' user='DaveF' visible='true' version='2' changeset='82665633' lat='51.003731' lon='-0.0933925' />
<node id='7320746591' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9963203' lon='-0.0930264' />
<node id='7320746592' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9966411' lon='-0.0911076' />
<node id='7320746593' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9936791' lon='-0.0907508' />
<node id='7320746594' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9967502' lon='-0.0910515' />
<node id='7320746595' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9959547' lon='-0.0918747' />
<node id='7320746596' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9970998' lon='-0.0921193' />
<node id='7320746597' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.993926' lon='-0.0907051' />
<node id='7320746598' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9959243' lon='-0.0917013' />
<node id='7320746599' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9940784' lon='-0.0904833' />
<node id='7320746600' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9970532' lon='-0.0919612' />
<node id='7320746601' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9960462' lon='-0.0920938' />
<node id='7320746602' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9945002' lon='-0.0900195' />
<node id='7320746603' timestamp='2023-03-07T12:08:57Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='133400562' lat='50.9987448' lon='-0.0921168' />
<node id='7320746605' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9960093' lon='-0.0923256' />
<node id='7320746610' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9959852' lon='-0.0929677' />
<node id='7320746611' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9967052' lon='-0.092481' />
<node id='7320746612' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9958088' lon='-0.0925218' />
<node id='7320746614' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9981518' lon='-0.0917395' />
<node id='7320746615' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9965208' lon='-0.0915815' />
<node id='7320746616' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9968144' lon='-0.092216' />
<node id='7320746617' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9983699' lon='-0.0922722' />
<node id='7320746618' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9969747' lon='-0.09176' />
<node id='7320746619' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9972955' lon='-0.0919943' />
<node id='7320746620' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.99446' lon='-0.0914898' />
<node id='7320746621' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9946573' lon='-0.0912171' />
<node id='7320746622' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9958618' lon='-0.0931053' />
<node id='7320746623' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9975103' lon='-0.0918797' />
<node id='7320746624' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9944199' lon='-0.090672' />
<node id='7320746626' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9966668' lon='-0.0926747' />
<node id='7320746627' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9973195' lon='-0.0913955' />
<node id='7320746628' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9976547' lon='-0.0902794' />
<node id='7320746629' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9960253' lon='-0.0908376' />
<node id='7320746630' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.997969' lon='-0.0907152' />
<node id='7320746631' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9954705' lon='-0.0907433' />
<node id='7320746632' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9967743' lon='-0.0926417' />
<node id='7320746633' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9981855' lon='-0.091263' />
<node id='7320746634' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.995634' lon='-0.0906592' />
<node id='7320746635' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9961617' lon='-0.0908018' />
<node id='7320746636' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9980764' lon='-0.0916299' />
<node id='7320746639' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9962321' lon='-0.0908477' />
<node id='7320746641' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9966957' lon='-0.0927384' />
<node id='7320746642' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9946861' lon='-0.0904299' />
<node id='7320746643' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9952266' lon='-0.0931563' />
<node id='7320746644' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9956756' lon='-0.0927129' />
<node id='7320746645' timestamp='2023-03-07T12:08:57Z' uid='10573400' user='PeterMapit' visible='true' version='3' changeset='133400562' lat='50.9990778' lon='-0.0930589' />
<node id='7320746646' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9957736' lon='-0.0915357' />
<node id='7320746647' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9935203' lon='-0.0911025' />
<node id='7320746648' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9966428' lon='-0.0907381' />
<node id='7320746649' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9964438' lon='-0.0911025' />
<node id='7320746651' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9969859' lon='-0.090333' />
<node id='7320746653' timestamp='2020-03-23T01:05:37Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9936807' lon='-0.090942' />
<node id='7320758735' timestamp='2020-03-23T01:06:03Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9922709' lon='-0.0926799' />
<node id='7320758736' timestamp='2020-03-23T01:06:03Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82497427' lat='50.9922999' lon='-0.0927511' />
<node id='7323148267' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='117291260' lat='51.0075971' lon='-0.0952166' />
<node id='7323148268' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133895069' lat='51.00779' lon='-0.0949014' />
<node id='7323148274' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0070957' lon='-0.0961652' />
<node id='7323148275' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.008152' lon='-0.1012056' />
<node id='7323148278' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0071231' lon='-0.0959571' />
<node id='7323148282' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0081446' lon='-0.1011254' />
<node id='7323148284' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.008225' lon='-0.1007858' />
<node id='7323150588' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0070248' lon='-0.0965808' />
<node id='7323150597' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='117291260' lat='51.0070118' lon='-0.0957448' />
<node id='7323150606' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0073003' lon='-0.0956847' />
<node id='7323150608' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133895069' lat='51.0072089' lon='-0.0957851' />
<node id='7323150618' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='117291260' lat='51.0067733' lon='-0.0959612' />
<node id='7331861144' timestamp='2020-03-26T13:45:41Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0038069' lon='-0.0935529' />
<node id='7331870812' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0020375' lon='-0.0767502' />
<node id='7331870813' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9997588' lon='-0.0784217' />
<node id='7331870817' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9998069' lon='-0.0785619' />
<node id='7331870818' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9985336' lon='-0.0784575' />
<node id='7331870819' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0014746' lon='-0.0768726' />
<node id='7331870820' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9984136' lon='-0.0771721' />
<node id='7331870821' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9996227' lon='-0.078521' />
<node id='7331870822' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.999738' lon='-0.0786409' />
<node id='7331870823' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0007049' lon='-0.0777646' />
<node id='7331870824' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9963596' lon='-0.0725195' />
<node id='7331870825' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0011058' lon='-0.0773719' />
<node id='7331870826' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0015565' lon='-0.0768344' />
<node id='7331870827' timestamp='2020-06-02T18:32:59Z' uid='97369' user='fcrump' visible='true' version='2' changeset='86093467' lat='51.001253' lon='-0.0751867' />
<node id='7331870828' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0010536' lon='-0.0754905' />
<node id='7331870829' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9971673' lon='-0.0745894' />
<node id='7331870830' timestamp='2020-06-02T18:32:59Z' uid='97369' user='fcrump' visible='true' version='2' changeset='86093467' lat='51.0014244' lon='-0.0748685' />
<node id='7331870831' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9981074' lon='-0.0792383' />
<node id='7331870832' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9981375' lon='-0.0795811' />
<node id='7331870834' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0011379' lon='-0.0774894' />
<node id='7331870835' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0022122' lon='-0.0737307' />
<node id='7331870836' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0018885' lon='-0.0770916' />
<node id='7331870837' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0015838' lon='-0.077163' />
<node id='7331870838' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9975688' lon='-0.0753425' />
<node id='7331870839' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9973341' lon='-0.0749005' />
<node id='7331870843' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9980465' lon='-0.0789988' />
<node id='7331870844' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9979276' lon='-0.0787734' />
<node id='7331870845' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0013896' lon='-0.0768674' />
<node id='7331870848' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0020583' lon='-0.0770483' />
<node id='7331870849' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.996839' lon='-0.0742061' />
<node id='7331870850' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0019717' lon='-0.0765845' />
<node id='7331870852' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9989524' lon='-0.0788014' />
<node id='7331870853' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0001951' lon='-0.0781774' />
<node id='7331870854' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9963051' lon='-0.0737453' />
<node id='7331870855' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9988161' lon='-0.0787477' />
<node id='7331870856' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9967332' lon='-0.0735669' />
<node id='7331870857' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.996366' lon='-0.073322' />
<node id='7331870858' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9982323' lon='-0.0769237' />
<node id='7331870861' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='51.0013433' lon='-0.0772346' />
<node id='7331870862' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9981299' lon='-0.0798688' />
<node id='7331870863' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9984801' lon='-0.0777604' />
<node id='7331870866' timestamp='2020-06-02T18:32:59Z' uid='97369' user='fcrump' visible='true' version='2' changeset='86093467' lat='51.0011404' lon='-0.0754154' />
<node id='7331870868' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9984947' lon='-0.0774103' />
<node id='7331870870' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9985988' lon='-0.0783273' />
<node id='7331870871' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9977386' lon='-0.0758393' />
<node id='7331870873' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9984641' lon='-0.0772471' />
<node id='7331870876' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9994269' lon='-0.0785109' />
<node id='7331870880' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9990863' lon='-0.0787987' />
<node id='7331870882' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.998416' lon='-0.0798204' />
<node id='7331870883' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9993739' lon='-0.0786563' />
<node id='7331870884' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9985202' lon='-0.0797466' />
<node id='7331895985' timestamp='2020-03-26T14:00:19Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82665633' lat='50.9985363' lon='-0.0780663' />
<node id='7332052407' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9890104' lon='-0.1001035' />
<node id='7332052409' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9884105' lon='-0.0980779' />
<node id='7332052410' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9873358' lon='-0.1034058' />
<node id='7332052411' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9872364' lon='-0.1037651' />
<node id='7332052412' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9884524' lon='-0.0979251' />
<node id='7332052413' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9883784' lon='-0.0974458' />
<node id='7332052414' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9875411' lon='-0.101826' />
<node id='7332052415' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9868964' lon='-0.1079617' />
<node id='7332052416' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9874738' lon='-0.102417' />
<node id='7332052417' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9883688' lon='-0.0970891' />
<node id='7332052421' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.986481' lon='-0.1105913' />
<node id='7332052424' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9887426' lon='-0.0986538' />
<node id='7332052426' timestamp='2020-09-05T13:56:54Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='90454183' lat='50.9868225' lon='-0.1095919' />
<node id='7332052427' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9867792' lon='-0.1088333' />
<node id='7332052429' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9870007' lon='-0.1063029' />
<node id='7332052430' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9875637' lon='-0.1018133' />
<node id='7332052431' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9866284' lon='-0.1096487' />
<node id='7332052432' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9869813' lon='-0.1052277' />
<node id='7332052433' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9869428' lon='-0.1069579' />
<node id='7332052434' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9886078' lon='-0.1004372' />
<node id='7332052435' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9867487' lon='-0.1112081' />
<node id='7332052436' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9887169' lon='-0.0995275' />
<node id='7332052437' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9880239' lon='-0.1009213' />
<node id='7332052440' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.986112' lon='-0.111812' />
<node id='7332052441' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9863029' lon='-0.1113889' />
<node id='7332052442' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9891804' lon='-0.0988423' />
<node id='7332052444' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9883912' lon='-0.0983122' />
<node id='7332052453' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9885067' lon='-0.0993391' />
<node id='7332052454' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9869893' lon='-0.1065959' />
<node id='7332052455' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9865034' lon='-0.1110782' />
<node id='7332052460' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9859788' lon='-0.1120235' />
<node id='7332052462' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9864072' lon='-0.1114908' />
<node id='7332052466' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.987716' lon='-0.1014284' />
<node id='7332052467' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9878668' lon='-0.1012603' />
<node id='7332052468' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9867953' lon='-0.1073476' />
<node id='7332052474' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.986683' lon='-0.1093351' />
<node id='7332052475' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9890137' lon='-0.0987708' />
<node id='7332052476' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9891403' lon='-0.0994588' />
<node id='7332052477' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9873776' lon='-0.1031204' />
<node id='7332052478' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9867824' lon='-0.107898' />
<node id='7332052484' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.986845' lon='-0.1070624' />
<node id='7332064585' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9880223' lon='-0.1011915' />
<node id='7332064588' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9893296' lon='-0.0990535' />
<node id='7332064590' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9869797' lon='-0.105903' />
<node id='7332064591' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9893007' lon='-0.0998384' />
<node id='7332064592' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9868178' lon='-0.1107036' />
<node id='7332064593' timestamp='2020-03-26T15:17:24Z' uid='115894' user='DaveF' visible='true' version='1' changeset='82669712' lat='50.9892623' lon='-0.0993059' />
<node id='7370507193' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0048074' lon='-0.1014987' />
<node id='7370507194' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.004716' lon='-0.1008971' />
<node id='7370507195' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0049215' lon='-0.1008183' />
<node id='7370507196' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0050128' lon='-0.1014199' />
<node id='7370510203' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0017113' lon='-0.1022203' />
<node id='7370510229' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.005644' lon='-0.0994056' />
<node id='7370510234' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0051807' lon='-0.1017898'>
<tag k='amenity' v='waste_basket' />
<tag k='waste' v='trash' />
</node>
<node id='7370510235' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0048111' lon='-0.1020259'>
</node>
<node id='7370510238' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0054102' lon='-0.1014519'>
<tag k='amenity' v='bench' />
<tag k='backrest' v='yes' />
<tag k='material' v='wood' />
</node>
<node id='7370510239' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0053182' lon='-0.10159'>
</node>
<node id='7370510240' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0052203' lon='-0.1017308'>
</node>
<node id='7370510241' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0051436' lon='-0.1018421'>
</node>
<node id='7370510242' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0050634' lon='-0.1019333'>
</node>
<node id='7370510243' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0049452' lon='-0.1020058'>
</node>
<node id='7370510287' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0054699' lon='-0.1013162' />
<node id='7370510288' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0054414' lon='-0.1013024' />
<node id='7370510289' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0054357' lon='-0.1013322' />
<node id='7370510290' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0054642' lon='-0.1013459' />
<node id='7370510291' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0052883' lon='-0.1003274' />
<node id='7370510292' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.005395' lon='-0.1005419' />
<node id='7370510293' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0054832' lon='-0.1013446' />
<node id='7370510300' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0052432' lon='-0.100255' />
<node id='7370510310' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0052297' lon='-0.1002426' />
<node id='7370510313' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.005725' lon='-0.0985014' />
<node id='7370510318' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0042321' lon='-0.1007532' />
<node id='7370510319' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0043343' lon='-0.1006137' />
<node id='7370510325' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0042862' lon='-0.1005895' />
<node id='7370510326' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0043832' lon='-0.1004796' />
<node id='7370510327' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0049554' lon='-0.1001376' />
<node id='7370510328' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0054966' lon='-0.1008202' />
<node id='7370510330' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492' lat='51.0041832' lon='-0.1022002' />
<node id='7423464005' timestamp='2020-04-19T21:15:17Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83785878' lat='51.0012475' lon='-0.1053365' />
<node id='7423464006' timestamp='2020-04-19T21:15:17Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83785878' lat='51.0012885' lon='-0.1054282' />
<node id='7423464007' timestamp='2020-04-19T21:15:17Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83785878' lat='51.0016928' lon='-0.1049133' />
<node id='7423464008' timestamp='2020-04-19T21:15:17Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83785878' lat='51.0019907' lon='-0.104586' />
<node id='7423464009' timestamp='2020-04-19T21:15:17Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83785878' lat='51.0022675' lon='-0.1043527' />
<node id='7423464010' timestamp='2020-04-19T21:15:17Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83785878' lat='51.0025924' lon='-0.1041448' />
<node id='7423464011' timestamp='2020-04-19T21:15:17Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83785878' lat='51.0029357' lon='-0.1039942' />
<node id='7423464012' timestamp='2020-04-19T21:15:17Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83785878' lat='51.0035994' lon='-0.1037695' />
<node id='7423464013' timestamp='2020-04-19T21:15:17Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83785878' lat='51.0039891' lon='-0.103666' />
<node id='7423464014' timestamp='2020-04-19T21:15:17Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83785878' lat='51.0043117' lon='-0.103607' />
<node id='7423464015' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0048324' lon='-0.1035493' />
<node id='7423464016' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0051034' lon='-0.103544' />
<node id='7423464017' timestamp='2020-04-19T21:15:17Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83785878' lat='51.005476' lon='-0.1035158' />
<node id='7423464018' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058324' lon='-0.1039805' />
<node id='7580824945' timestamp='2020-06-02T18:32:59Z' uid='97369' user='fcrump' visible='true' version='2' changeset='86093467' lat='51.0018514' lon='-0.0742226' />
<node id='7581015817' timestamp='2020-06-02T19:24:39Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='86095027' lat='51.0090211' lon='-0.1036218'>
<tag k='direction' v='forward' />
<tag k='highway' v='give_way' />
</node>
<node id='7589480570' timestamp='2020-06-03T12:35:45Z' uid='97369' user='fcrump' visible='true' version='1' changeset='86136781' lat='51.0011736' lon='-0.0773327' />
<node id='7589526131' timestamp='2022-12-11T18:18:45Z' uid='10573400' user='PeterMapit' visible='true' version='4' changeset='129971525' lat='50.9876121' lon='-0.0813637' />
<node id='7589526132' timestamp='2021-05-19T18:14:46Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='104978865' lat='50.9877018' lon='-0.0811026' />
<node id='7878450231' timestamp='2020-09-05T13:56:54Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='90454183' lat='50.9868004' lon='-0.1097246' />
<node id='7878450240' timestamp='2020-09-05T13:56:54Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='90454183' lat='50.9867208' lon='-0.1093506' />
<node id='7878450241' timestamp='2020-09-05T13:56:54Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='90454183' lat='50.9867084' lon='-0.1094258' />
<node id='7878450242' timestamp='2020-09-05T13:56:54Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='90454183' lat='50.9867518' lon='-0.1094399' />
<node id='7905471597' timestamp='2022-03-26T18:26:34Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='118958266' lat='51.0152746' lon='-0.0762594' />
<node id='7905471604' timestamp='2020-09-14T14:21:14Z' uid='97369' user='fcrump' visible='true' version='1' changeset='90871243' lat='51.0138915' lon='-0.0764055' />
<node id='7905471605' timestamp='2020-09-14T14:21:14Z' uid='97369' user='fcrump' visible='true' version='1' changeset='90871243' lat='51.0148208' lon='-0.0766402' />
<node id='7905471606' timestamp='2020-09-14T14:21:14Z' uid='97369' user='fcrump' visible='true' version='1' changeset='90871243' lat='51.0151887' lon='-0.0763292' />
<node id='8235869916' timestamp='2020-12-16T22:49:06Z' uid='84263' user='Robert Whittaker' visible='true' version='1' changeset='95966529' lat='51.0066921' lon='-0.1043084' />
<node id='8235905417' timestamp='2020-12-16T22:49:06Z' uid='84263' user='Robert Whittaker' visible='true' version='1' changeset='95966529' lat='51.0066727' lon='-0.1042011' />
<node id='8284982162' timestamp='2021-01-02T21:45:31Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827459' lat='51.0071788' lon='-0.1036901' />
<node id='8284982163' timestamp='2021-01-02T21:45:31Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827459' lat='51.0072174' lon='-0.1033926' />
<node id='8284982164' timestamp='2021-01-02T21:45:31Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827459' lat='51.0066763' lon='-0.1039022' />
<node id='8284982165' timestamp='2021-01-02T21:45:31Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827459' lat='51.0068056' lon='-0.103803' />
<node id='8284994716' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827214' lat='51.006655' lon='-0.1036487'>
<tag k='power' v='substation' />
</node>
<node id='8285025017' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827214' lat='51.0066431' lon='-0.1036205' />
<node id='8285025018' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827214' lat='51.0065925' lon='-0.1036004' />
<node id='8285025019' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827214' lat='51.006619' lon='-0.1036183'>
<tag k='barrier' v='gate' />
</node>
<node id='8285037320' timestamp='2021-01-02T21:48:26Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827459' lat='51.0067971' lon='-0.10317' />
<node id='8285037321' timestamp='2021-01-02T21:48:26Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827459' lat='51.0067459' lon='-0.103533' />
<node id='8285037322' timestamp='2021-01-02T21:48:26Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827459' lat='51.0068976' lon='-0.1037831'>
<tag k='entrance' v='yes' />
</node>
<node id='8285037323' timestamp='2021-01-02T21:48:26Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827459' lat='51.0068732' lon='-0.1037902'>
<tag k='defibrillator:location' v='outside Haywards Heath Fire Station - to left of entrance' />
<tag k='emergency' v='defibrillator' />
<tag k='indoor' v='no' />
</node>
<node id='8311271378' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190' lat='51.0053064' lon='-0.1035804' />
<node id='8311271379' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.006116' lon='-0.1035595' />
<node id='8900242829' timestamp='2021-07-07T07:52:40Z' uid='10455633' user='tnayini' visible='true' version='1' changeset='107542674' lat='51.0072084' lon='-0.0970819' />
<node id='8986589696' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.0049931' lon='-0.1039589' />
<node id='8986589697' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.004966' lon='-0.1037997' />
<node id='8986589698' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.0049163' lon='-0.103811' />
<node id='8986589699' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.0049272' lon='-0.1039885' />
<node id='8986589708' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.0050986' lon='-0.1039063' />
<node id='8986589709' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.0053889' lon='-0.1042097' />
<node id='8986589710' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.0053429' lon='-0.1039349' />
<node id='8986589711' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.0055815' lon='-0.1046889' />
<node id='8986589712' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.005206' lon='-0.1044194' />
<node id='8986589713' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.005197' lon='-0.1043542' />
<node id='8986589714' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.0049339' lon='-0.1045302' />
<node id='8986609619' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.0055747' lon='-0.103529' />
<node id='8986609620' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.0056203' lon='-0.103552' />
<node id='8986609621' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.0055992' lon='-0.1035324' />
<node id='8986609622' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190' lat='51.0053176' lon='-0.1036332' />
<node id='9098954900' timestamp='2021-09-16T20:01:07Z' uid='97369' user='fcrump' visible='true' version='1' changeset='111307912' lat='51.0063873' lon='-0.0746472' />
<node id='9116717590' timestamp='2021-09-23T11:20:38Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='111586932' lat='51.0062633' lon='-0.1026426'>
<tag k='addr:city' v='Haywards Heath' />
<tag k='addr:housenumber' v='3' />
<tag k='addr:postcode' v='RH16 1QH' />
<tag k='addr:street' v='Sydney Road' />
<tag k='name' v='Chapman & Stacey' />
<tag k='office' v='insurance' />
</node>
<node id='9116717591' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0061571' lon='-0.1026764' />
<node id='9116717592' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0061569' lon='-0.1027209' />
<node id='9116717593' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0061996' lon='-0.1024934' />
<node id='9116717594' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0061999' lon='-0.10246' />
<node id='9270176980' timestamp='2021-11-20T18:11:57Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='114036454' lat='51.0180066' lon='-0.0918504' />
<node id='9316228586' timestamp='2021-12-06T19:46:36Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='114632226' lat='50.9961284' lon='-0.0889526' />
<node id='9316228587' timestamp='2021-12-06T19:46:36Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='114632226' lat='50.9960696' lon='-0.0883011' />
<node id='9316228588' timestamp='2021-12-06T19:46:36Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='114632226' lat='50.9957817' lon='-0.0884025' />
<node id='9316228589' timestamp='2021-12-06T19:46:36Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='114632226' lat='50.9958005' lon='-0.0880297' />
<node id='9324901743' timestamp='2021-12-09T16:05:35Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='114750425' lat='51.0034858' lon='-0.0921305' />
<node id='9498274875' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='117291260' lat='51.0077591' lon='-0.0949589' />
<node id='9498274882' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='117291260' lat='51.0071832' lon='-0.0956006' />
<node id='9498274883' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='117291260' lat='51.0075241' lon='-0.0952949' />
<node id='9498274884' timestamp='2022-02-11T14:55:30Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='117291260' lat='51.0077089' lon='-0.0950441' />
<node id='9739969181' timestamp='2022-05-14T17:20:22Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='120987247' lat='51.0141079' lon='-0.0771163' />
<node id='9942355377' timestamp='2022-08-09T11:13:47Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='124680413' lat='50.9956732' lon='-0.0665105' />
<node id='9942355378' timestamp='2022-08-09T11:13:47Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='124680413' lat='50.9957012' lon='-0.0671346' />
<node id='9942355379' timestamp='2022-08-09T11:13:47Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='124680413' lat='50.9951026' lon='-0.0672895' />
<node id='9945279689' timestamp='2022-08-10T14:21:06Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='124734455' lat='50.9958421' lon='-0.0705475' />
<node id='9945279690' timestamp='2022-08-10T14:21:06Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='124734455' lat='50.9958256' lon='-0.0702144' />
<node id='10034296654' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701' lat='51.0059115' lon='-0.1046899' />
<node id='10034296655' timestamp='2022-09-18T17:30:03Z' uid='37137' user='Derick Rethans' visible='true' version='1' changeset='126339955' lat='51.005779' lon='-0.1047242' />
<node id='10034296656' timestamp='2022-09-18T17:30:03Z' uid='37137' user='Derick Rethans' visible='true' version='1' changeset='126339955' lat='51.0057503' lon='-0.1047014' />
<node id='10034296678' timestamp='2022-09-18T17:30:03Z' uid='37137' user='Derick Rethans' visible='true' version='1' changeset='126339955' lat='51.0057225' lon='-0.1045594' />
<node id='10034296682' timestamp='2022-09-18T17:30:03Z' uid='37137' user='Derick Rethans' visible='true' version='1' changeset='126339955' lat='51.0056782' lon='-0.1042724' />
<node id='10034296683' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0056622' lon='-0.1041314' />
<node id='10034296684' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0056735' lon='-0.1040684' />
<node id='10034296685' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0057969' lon='-0.1038052' />
<node id='10034296686' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701' lat='51.0058246' lon='-0.1037363' />
<node id='10239952974' timestamp='2022-12-05T11:16:20Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='129737282' lat='51.0054411' lon='-0.0707447' />
<node id='10240733800' timestamp='2022-12-05T18:28:37Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='129752271' lat='51.0039471' lon='-0.0999572' />
<node id='10242646875' timestamp='2022-12-06T15:41:51Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='129788169' lat='51.0034307' lon='-0.0729847' />
<node id='10251774909' timestamp='2022-12-11T00:10:03Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='129949544' lat='50.9993246' lon='-0.1041046' />
<node id='10251774910' timestamp='2022-12-11T00:10:03Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='129949544' lat='50.9988595' lon='-0.1047396' />
<node id='10251774911' timestamp='2022-12-11T00:10:03Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='129949544' lat='50.9988291' lon='-0.1047255' />
<node id='10251774912' timestamp='2022-12-11T00:10:03Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='129949544' lat='50.9988051' lon='-0.104747' />
<node id='10253559000' timestamp='2022-12-11T18:18:45Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='129971525' lat='50.9876624' lon='-0.0821857' />
<node id='10253629011' timestamp='2022-12-11T18:18:45Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='129971525' lat='50.9877312' lon='-0.0826089' />
<node id='10253629012' timestamp='2022-12-11T18:18:45Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='129971525' lat='50.9880473' lon='-0.0839542' />
<node id='10253629013' timestamp='2022-12-11T18:18:45Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='129971525' lat='50.98815' lon='-0.084034' />
<node id='10718741229' timestamp='2023-03-07T12:08:57Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='133400562' lat='50.9988868' lon='-0.0929676' />
<node id='10718741231' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='133398000' lat='50.9992132' lon='-0.092362' />
<node id='10718741232' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='133398000' lat='50.9991543' lon='-0.092164' />
<node id='10718741233' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='133398000' lat='50.9991248' lon='-0.0923166' />
<node id='10718741235' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='133398000' lat='50.9984816' lon='-0.0930124' />
<node id='10718741238' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='133398000' lat='50.9983471' lon='-0.0932016' />
<node id='10718741239' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='133398000' lat='50.9984833' lon='-0.0933853' />
<node id='10718741240' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='133398000' lat='50.9985195' lon='-0.0934419' />
<node id='10718741247' timestamp='2023-03-07T10:51:00Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='133398000' lat='50.9986497' lon='-0.0926263' />
<node id='10718860971' timestamp='2023-03-07T12:08:57Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='133400562' lat='50.9986768' lon='-0.0924685' />
<node id='10718860973' timestamp='2023-03-07T12:08:57Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='133400562' lat='50.9986607' lon='-0.0925467' />
<node id='10718860976' timestamp='2023-03-07T12:08:57Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='133400562' lat='50.9990543' lon='-0.0930496' />
<node id='10718860978' timestamp='2023-03-07T12:08:57Z' uid='10573400' user='PeterMapit' visible='true' version='1' changeset='133400562' lat='50.9991056' lon='-0.0929081' />
<node id='10748269791' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0074891' lon='-0.1032355' />
<node id='10748269792' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0074376' lon='-0.1033844' />
<node id='10748269793' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0074089' lon='-0.1035132' />
<node id='10748269794' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0074553' lon='-0.1034836' />
<node id='10748269795' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0074372' lon='-0.1035829' />
<node id='10748269796' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0074693' lon='-0.1034267' />
<node id='10748269797' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0074372' lon='-0.1036969' />
<node id='10748269798' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0073811' lon='-0.1036821' />
<node id='10748269811' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0081258' lon='-0.1013607' />
<node id='10748269812' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0080599' lon='-0.1014881' />
<node id='10748269813' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0079861' lon='-0.1017992' />
<node id='10748269814' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0080823' lon='-0.1015002' />
<node id='10748269815' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0080051' lon='-0.1018133' />
<node id='10748269816' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0074363' lon='-0.1034957' />
<node id='10748269817' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.007887' lon='-0.1029184'>
<tag k='noexit' v='yes' />
</node>
<node id='10748269818' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0076646' lon='-0.1029284' />
<node id='10748269833' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0080621' lon='-0.1036587' />
<node id='10748269848' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0075363' lon='-0.0970826' />
<node id='10748269849' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.007541' lon='-0.0970685' />
<node id='10748269850' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0084308' lon='-0.0979516' />
<node id='10748269852' timestamp='2023-03-20T12:36:23Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133897367' lat='51.0087464' lon='-0.0991438' />
<node id='10748269853' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0087126' lon='-0.0992853' />
<node id='10748269854' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0085131' lon='-0.1000853' />
<node id='10748269855' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0076697' lon='-0.1028413' />
<node id='10748269856' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0081865' lon='-0.1028701' />
<node id='10748269857' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0080612' lon='-0.1029311' />
<node id='10748269858' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0080275' lon='-0.1029962' />
<node id='10748269859' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0076482' lon='-0.1031343' />
<node id='10748269860' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0079583' lon='-0.1030813' />
<node id='10748269893' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0094286' lon='-0.0999787' />
<node id='10748269894' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0092371' lon='-0.1009892' />
<node id='10748269895' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0092088' lon='-0.1010951' />
<node id='10748269896' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0084916' lon='-0.1017241' />
<node id='10748269970' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0071043' lon='-0.0963054' />
<node id='10748269971' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0071203' lon='-0.0964368' />
<node id='10748269972' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0071026' lon='-0.0960546' />
<node id='10748269973' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0071549' lon='-0.0958736' />
<node id='10748269974' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0075819' lon='-0.0954243' />
<node id='10748270016' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0096088' lon='-0.0988374' />
<node id='10748270017' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0095788' lon='-0.098488' />
<node id='10748270018' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.009575' lon='-0.098132' />
<node id='10748270043' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0080384' lon='-0.0963061' />
<node id='10748270057' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0069321' lon='-0.096634' />
<node id='10748270058' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0067165' lon='-0.0965615' />
<node id='10748270059' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0085662' lon='-0.0966387' />
<node id='10748270060' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0084093' lon='-0.0965099' />
<node id='10748270061' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0083101' lon='-0.0964804' />
<node id='10748270062' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0086156' lon='-0.096699' />
<node id='10748270064' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0089536' lon='-0.0970872' />
<node id='10748270065' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0088565' lon='-0.0969706' />
<node id='10748270067' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0091337' lon='-0.0971738' />
<node id='10748270068' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069' lat='51.0089966' lon='-0.0971261' />
<node id='10748366425' timestamp='2023-03-20T12:36:23Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133897367' lat='51.0080486' lon='-0.0994641' />
<node id='10748366440' timestamp='2023-03-20T12:36:23Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133897367' lat='51.008692' lon='-0.099117' />
<node id='10748366479' timestamp='2023-03-20T12:36:23Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133897367' lat='51.0078152' lon='-0.0960586' />
<node id='10748466929' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0049587' lon='-0.1033616' />
<node id='10748466930' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.004803' lon='-0.103542' />
<node id='10748466931' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0060056' lon='-0.1035393' />
<node id='10748466932' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0048642' lon='-0.1035453' />
<node id='10748466933' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0058229' lon='-0.1039311' />
<node id='10748466934' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0058756' lon='-0.1039115' />
<node id='10748466935' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0059144' lon='-0.1039021' />
<node id='10748466939' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0058583' lon='-0.1056696' />
<node id='10748466940' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0058647' lon='-0.1055785' />
<node id='10748466949' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0050347' lon='-0.1035313' />
<node id='10748466950' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0049634' lon='-0.103536' />
<node id='10748466951' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0056596' lon='-0.1035266' />
<node id='10748466952' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0058912' lon='-0.1038095' />
<node id='10748466953' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0058533' lon='-0.1039188'>
<tag k='crossing' v='unmarked' />
<tag k='crossing:island' v='no' />
<tag k='crossing:markings' v='no' />
<tag k='highway' v='crossing' />
<tag k='kerb' v='lowered' />
<tag k='tactile_paving' v='yes' />
</node>
<node id='10748466954' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0058976' lon='-0.1039061'>
</node>
<node id='10748466955' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0063752' lon='-0.10349' />
<node id='10748466956' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0066984' lon='-0.1043446' />
<node id='10748466957' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.006695' lon='-0.1043259' />
<node id='10748466958' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0065575' lon='-0.1035514' />
<node id='10748466959' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0068317' lon='-0.1036392' />
<node id='10748466960' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0070642' lon='-0.1037418' />
<node id='10748466961' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0075629' lon='-0.1039597' />
<node id='10748466962' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0064545' lon='-0.1024319' />
<node id='10748466963' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0065509' lon='-0.1024376' />
<node id='10748466964' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0065895' lon='-0.1024362' />
<node id='10748466965' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0062933' lon='-0.1032449' />
<node id='10748466966' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0062984' lon='-0.1032758' />
<node id='10748466967' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0062277' lon='-0.1032104' />
<node id='10748466968' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0058499' lon='-0.1041301' />
<node id='10748466969' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0059052' lon='-0.1046041' />
<node id='10748466970' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0059022' lon='-0.1044063' />
<node id='10748466971' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0059301' lon='-0.1038162' />
<node id='10748466972' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0060136' lon='-0.1043125' />
<node id='10748466973' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0059693' lon='-0.1040825' />
<node id='10748466974' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0060111' lon='-0.1042581' />
<node id='10748466975' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0060305' lon='-0.1043795' />
<node id='10748466976' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0060305' lon='-0.1044526' />
<node id='10748466977' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0059028' lon='-0.1047439' />
<node id='10748466978' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.006026' lon='-0.1046151' />
<node id='10748466979' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0057431' lon='-0.1037197' />
<node id='10748466980' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0058195' lon='-0.1039852' />
<node id='10748466981' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.005949' lon='-0.1039698' />
<node id='10748466982' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0059372' lon='-0.103892' />
<node id='10748466983' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0059398' lon='-0.1038142' />
<node id='10748466984' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0059533' lon='-0.1037505' />
<node id='10748466985' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0060237' lon='-0.1036339' />
<node id='10748466986' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0060832' lon='-0.1035648' />
<node id='10748466987' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0061655' lon='-0.1035071' />
<node id='10748466988' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0061035' lon='-0.1034716' />
<node id='10748466989' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0061039' lon='-0.1033931' />
<node id='10748466990' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0061942' lon='-0.1034159' />
<node id='10748466991' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.006195' lon='-0.1033294' />
<node id='10748466992' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0062608' lon='-0.1031363' />
<node id='10748466993' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0060317' lon='-0.1032785' />
<node id='10748466994' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0060216' lon='-0.1032342' />
<node id='10748466995' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0062284' lon='-0.1034877' />
<node id='10748466996' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0057938' lon='-0.1038531' />
<node id='10748466997' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0056334' lon='-0.1035125' />
<node id='10748466998' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0051976' lon='-0.1033214' />
<node id='10748466999' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0055866' lon='-0.1032986' />
<node id='10748467000' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0054558' lon='-0.103308' />
<node id='10748467001' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0057499' lon='-0.1032771' />
<node id='10748467002' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0057988' lon='-0.1032516' />
<node id='10748467003' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0058406' lon='-0.1032107' />
<node id='10748467004' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0058798' lon='-0.1031537' />
<node id='10748482705' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0059254' lon='-0.1029398' />
<node id='10748482706' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0059009' lon='-0.10308' />
<node id='10748482707' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0056988' lon='-0.1032852' />
<node id='10748482708' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0055157' lon='-0.1013251' />
<node id='10748482709' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0056482' lon='-0.1021057' />
<node id='10748482710' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0063689' lon='-0.1035024' />
<node id='10748482711' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0061094' lon='-0.1032939' />
<node id='10748482712' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0063524' lon='-0.1024168' />
<node id='10748482713' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0049216' lon='-0.1045304' />
<node id='10748482714' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0051035' lon='-0.1035601' />
<node id='10748482715' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0051862' lon='-0.1032986' />
<node id='10748482716' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0051701' lon='-0.1026548' />
<node id='10748482717' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0053338' lon='-0.1026455' />
<node id='10748482718' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0053436' lon='-0.1028486' />
<node id='10748482719' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0060587' lon='-0.1025838' />
<node id='10748482720' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0059404' lon='-0.1026961' />
<node id='10748482736' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0066528' lon='-0.0966011'>
</node>
<node id='10748482737' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0065794' lon='-0.0970309' />
<node id='10748482739' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.006022' lon='-0.0999653' />
<node id='10748482740' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0059819' lon='-0.1004018' />
<node id='10748482742' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701' lat='51.0055769' lon='-0.1008658' />
<node id='10750370110' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0078581' lon='-0.0947715' />
<node id='10750370111' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0079433' lon='-0.0948882' />
<node id='10750370112' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0079287' lon='-0.0949354' />
<node id='10750370113' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0079323' lon='-0.0949492' />
<node id='10750370114' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0079443' lon='-0.0949639' />
<node id='10750370115' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0079351' lon='-0.0949016' />
<node id='10750370116' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0079292' lon='-0.0949187' />
<node id='10750370117' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0079652' lon='-0.0949663' />
<node id='10750370118' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0061334' lon='-0.09664' />
<node id='10750370119' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0060836' lon='-0.0965045' />
<node id='10750370120' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.006433' lon='-0.0964844' />
<node id='10750370121' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0063562' lon='-0.0964737' />
<node id='10750370122' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0064929' lon='-0.0965501' />
<node id='10750370123' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0066326' lon='-0.0960781' />
<node id='10750370124' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0063191' lon='-0.0981635' />
<node id='10750370125' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0062203' lon='-0.0986289' />
<node id='10750370126' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0059233' lon='-0.1001483' />
<node id='10750370127' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0059081' lon='-0.1004273' />
<node id='10750370128' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0082498' lon='-0.094796' />
<node id='10750370129' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0085173' lon='-0.0946806' />
<node id='10750370130' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0090384' lon='-0.0944808' />
<node id='10750370131' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.009251' lon='-0.0944607' />
<node id='10750370132' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0088751' lon='-0.0945331' />
<node id='10750370133' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0097455' lon='-0.094507' />
<node id='10750370134' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0099001' lon='-0.0945241' />
<node id='10750370135' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0106074' lon='-0.0946431' />
<node id='10750370136' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0094535' lon='-0.0944882' />
<node id='10750370137' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0124334' lon='-0.0943467' />
<node id='10750370138' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0127211' lon='-0.0941831' />
<node id='10750370139' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0128658' lon='-0.0942193' />
<node id='10750370140' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0128616' lon='-0.0943212' />
<node id='10750370141' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0128628' lon='-0.0943849' />
<node id='10750370142' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0129071' lon='-0.0944875' />
<node id='10750370143' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0129434' lon='-0.094511' />
<node id='10750370145' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0128831' lon='-0.0944547' />
<node id='10750370147' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0126675' lon='-0.0943024' />
<node id='10750370149' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0120343' lon='-0.0944392' />
<node id='10750370176' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0079874' lon='-0.0949569' />
<node id='10750370182' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0065444' lon='-0.0968318' />
<node id='10750370183' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0065258' lon='-0.096644' />
<node id='10750370184' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0065047' lon='-0.097104' />
<node id='10750370185' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0060128' lon='-0.0996441' />
<node id='10750370186' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0059157' lon='-0.1008926' />
<node id='10750370187' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0059284' lon='-0.101071' />
<node id='10750370188' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0059393' lon='-0.1023772' />
<node id='10750379349' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0079591' lon='-0.1036835' />
<node id='10750379350' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0078121' lon='-0.1037113' />
<node id='10750379351' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.007665' lon='-0.1037254' />
<node id='10750379352' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0075621' lon='-0.1037224' />
<node id='10750379353' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0075131' lon='-0.1037163' />
<node id='10750379354' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0071975' lon='-0.1036191' />
<node id='10750379355' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0067705' lon='-0.1034582' />
<node id='10750379356' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0063189' lon='-0.1033023' />
<node id='10750379357' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0066701' lon='-0.102565' />
<node id='10750379358' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0060457' lon='-0.1021332' />
<node id='10750379359' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0060381' lon='-0.1008685' />
<node id='10750379360' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0060457' lon='-0.100261' />
<node id='10750379361' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0060507' lon='-0.1001041' />
<node id='10750379362' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0060659' lon='-0.1000035' />
<node id='10750379363' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0061258' lon='-0.0996816' />
<node id='10750379364' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0063115' lon='-0.0987335' />
<node id='10750379365' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0064237' lon='-0.0981528' />
<node id='10750379366' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0065857' lon='-0.0972945' />
<node id='10750379367' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0076043' lon='-0.0955899' />
<node id='10750379368' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.007622' lon='-0.0957173' />
<node id='10750379369' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0076393' lon='-0.0958058' />
<node id='10750379370' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0076604' lon='-0.0958581' />
<node id='10750379371' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731' lat='51.0086054' lon='-0.099755' />
<node id='10750848750' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0182963' lon='-0.0917356' />
<node id='10750848751' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0184641' lon='-0.0918187' />
<node id='10750848752' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0186362' lon='-0.0919729' />
<node id='10750848753' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0188084' lon='-0.0921996' />
<node id='10750848754' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0189433' lon='-0.0924611' />
<node id='10750848755' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0190471' lon='-0.0927924' />
<node id='10750848756' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.019096' lon='-0.0931424' />
<node id='10750848757' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0190969' lon='-0.0933315' />
<node id='10750848758' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.018767' lon='-0.0934656' />
<node id='10750848759' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.018551' lon='-0.0934978' />
<node id='10750848776' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0179449' lon='-0.0935199' />
<node id='10750848777' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0177664' lon='-0.0935327' />
<node id='10750848778' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0177588' lon='-0.0935729' />
<node id='10750848779' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0169903' lon='-0.0937687' />
<node id='10750848780' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0170299' lon='-0.0937901' />
<node id='10750848781' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0174602' lon='-0.0936359' />
<node id='10750848782' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.016101' lon='-0.094218' />
<node id='10750848783' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0162714' lon='-0.0941415' />
<node id='10750848784' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0159213' lon='-0.0942448' />
<node id='10750848785' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0166933' lon='-0.0939095' />
<node id='10750848786' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.015405' lon='-0.0941549' />
<node id='10750848787' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0150354' lon='-0.0943843' />
<node id='10750848788' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0148296' lon='-0.0945076' />
<node id='10750848789' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0152185' lon='-0.0942582' />
<node id='10750848790' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0143495' lon='-0.0945546' />
<node id='10750848791' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0140955' lon='-0.0945412' />
<node id='10750848792' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0134408' lon='-0.094513' />
<node id='10750848793' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0137833' lon='-0.094521' />
<node id='10750848794' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0131434' lon='-0.0945485' />
<node id='10750848795' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0130004' lon='-0.0945365' />
<node id='10750848796' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.014611' lon='-0.0945345' />
<node id='10750848799' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0132801' lon='-0.0945385' />
<node id='10750848801' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133940215' lat='51.0155661' lon='-0.0941308' />
<way id='4916875' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='11' changeset='133899701'>
<nd ref='32197198' />
<nd ref='5912511781' />
<nd ref='38904596' />
<nd ref='7099196113' />
<nd ref='5805163550' />
<nd ref='5805163556' />
<nd ref='32197199' />
<nd ref='38904427' />
<nd ref='10748482740' />
<nd ref='32197200' />
<nd ref='2452247135' />
<nd ref='10748482739' />
<nd ref='38904423' />
<nd ref='1941154670' />
<nd ref='7017078484' />
<nd ref='7017078481' />
<nd ref='32197202' />
<nd ref='10748482737' />
<nd ref='10748482736' />
<nd ref='5805163883' />
<tag k='highway' v='secondary' />
<tag k='lanes' v='2' />
<tag k='lit' v='yes' />
<tag k='maxspeed' v='30 mph' />
<tag k='name' v='Sydney Road' />
<tag k='ref' v='B2028' />
<tag k='sidewalk' v='both' />
<tag k='surface' v='asphalt' />
</way>
<way id='4916876' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='14' changeset='133899701'>
<nd ref='32197195' />
<nd ref='1905997045' />
<nd ref='1905997069' />
<nd ref='32197196' />
<nd ref='5912511728' />
<nd ref='5912511770' />
<nd ref='1905997062' />
<nd ref='32197197' />
<nd ref='1905996968' />
<nd ref='1905996976' />
<nd ref='5126868641' />
<nd ref='32197193' />
<nd ref='1905996993' />
<tag k='junction' v='roundabout' />
<tag k='lanes' v='1' />
<tag k='maxspeed:type' v='sign' />
<tag k='name' v='Commercial Square' />
<tag k='oneway' v='yes' />
</way>
<way id='4916877' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='18' changeset='133899701'>
<nd ref='32197185' />
<nd ref='7581015817' />
<nd ref='32197190' />
<nd ref='38906017' />
<nd ref='2452247140' />
<nd ref='3398845549' />
<nd ref='2452247137' />
<nd ref='32197191' />
<nd ref='2452247013' />
<nd ref='4957974172' />
<nd ref='8284982162' />
<nd ref='7099196115' />
<nd ref='2452246895' />
<nd ref='8285037321' />
<nd ref='32197192' />
<nd ref='1905997036' />
<nd ref='10748466990' />
<nd ref='34696068' />
<tag k='highway' v='tertiary' />
<tag k='highway_authority_ref' v='C309' />
<tag k='name' v='Mill Green Road' />
<tag k='source:maxspeed' v='sign' />
</way>
<way id='5089208' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='9' changeset='133899701'>
<nd ref='10748466991' />
<nd ref='34696070' />
<nd ref='10748466967' />
<nd ref='10748466992' />
<nd ref='34696071' />
<nd ref='4725832497' />
<nd ref='34696072' />
<nd ref='38904420' />
<nd ref='2452246986' />
<nd ref='34696074' />
<nd ref='34696075' />
<nd ref='5805163858' />
<nd ref='38904407' />
<nd ref='34696079' />
<nd ref='8900242829' />
<nd ref='38904403' />
<tag k='access' v='yes' />
<tag k='goods' v='destination' />
<tag k='hgv' v='designated' />
<tag k='highway' v='residential' />
<tag k='maxweight' v='7.5' />
<tag k='motor_vehicle' v='yes' />
<tag k='motorcycle' v='yes' />
<tag k='name' v='Queens Road' />
<tag k='note' v='7.5 tonne limit and speed bumps on Church Avenue, Queens Road and Gordon Road. Scheme introduced Q3 2019' />
<tag k='vehicle' v='yes' />
</way>
<way id='5406854' timestamp='2023-03-20T12:36:23Z' uid='577089' user='JodaStephen' visible='true' version='7' changeset='133897367'>
<nd ref='38904551' />
<nd ref='38904554' />
<nd ref='55300265' />
<nd ref='38904557' />
<nd ref='38904560' />
<nd ref='5815821688' />
<nd ref='10748366425' />
<nd ref='38904563' />
<nd ref='5810812245' />
<nd ref='38904566' />
<nd ref='38904569' />
<tag k='cycleway:both' v='no' />
<tag k='name' v='Gordon Road' />
</way>
<way id='5406858' timestamp='2020-01-01T10:36:00Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='79077564'>
<nd ref='38904571' />
<nd ref='38904572' />
<nd ref='38904574' />
<nd ref='38904582' />
<nd ref='38904580' />
<nd ref='38904576' />
<tag k='name' v='Gordon Close' />
</way>
<way id='5406860' timestamp='2022-09-12T10:28:24Z' uid='15223574' user='Newdice' visible='true' version='3' changeset='126082913'>
<nd ref='38904583' />
<tag k='highway' v='service' />
<tag k='service' v='parking_aisle' />
</way>
<way id='5406862' timestamp='2018-08-07T17:21:07Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='61441849'>
<nd ref='38904589' />
</way>
<way id='5406865' timestamp='2018-08-07T17:21:07Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='61441849'>
<nd ref='38904578' />
</way>
<way id='95936155' timestamp='2019-10-17T10:02:20Z' uid='10252560' user='rkkapilk' visible='true' version='7' changeset='75825363'>
<nd ref='1133675194' />
<nd ref='6169441220' />
<nd ref='4725832492' />
<nd ref='1111572408' />
</way>
<way id='97948087' timestamp='2017-03-23T07:52:45Z' uid='322785' user='BCNorwich' visible='true' version='3' changeset='47088358'>
<nd ref='1133675189' />
<nd ref='1133675183' />
<nd ref='1133675196' />
<nd ref='1133675222' />
<nd ref='1133675212' />
</way>
<way id='97948089' timestamp='2018-05-10T10:48:42Z' uid='890751' user='extua' visible='true' version='3' changeset='58846161'>
<nd ref='1133675201' />
<nd ref='5609081544' />
<nd ref='4726864944' />
<nd ref='5609081545' />
<nd ref='5609081546' />
<nd ref='1133675178' />
<nd ref='5609081559' />
<nd ref='5609081567' />
<nd ref='5609081547' />
<nd ref='5609081548' />
<nd ref='5609081549' />
<nd ref='5609081550' />
<nd ref='1133675172' />
<nd ref='5609081551' />
<nd ref='5609081552' />
<nd ref='5609081554' />
<nd ref='5609081553' />
<nd ref='4726864943' />
<nd ref='1133675191' />
</way>
<way id='183605834' timestamp='2021-01-11T12:27:53Z' uid='63012' user='stthomse' visible='true' version='6' changeset='97306594'>
<nd ref='1940132318' />
<nd ref='1940132343' />
<nd ref='731383118' />
<nd ref='731383122' />
<nd ref='731383131' />
<nd ref='731383137' />
<nd ref='731383145' />
<nd ref='7370510319' />
<nd ref='7370510318' />
<nd ref='1940132341' />
<nd ref='1940132324' />
<nd ref='1940132345' />
<nd ref='1940132317' />
<nd ref='1940132321' />
<nd ref='1940132319' />
<nd ref='1940132320' />
<nd ref='1940132322' />
<tag k='landuse' v='recreation_ground' />
<tag k='name' v='Haywards Heath Recreation Ground' />
</way>
<way id='450667711' timestamp='2022-10-28T19:15:37Z' uid='13666626' user='RedAuburn' visible='true' version='7' changeset='128188196'>
<nd ref='4475878780' />
<nd ref='5516649781' />
<nd ref='5516649778' />
<nd ref='4475878783' />
<nd ref='5516649775' />
<nd ref='5516649776' />
<nd ref='4475878789' />
<nd ref='5516649774' />
<nd ref='5516649773' />
<nd ref='5516649772' />
<nd ref='5516649771' />
<nd ref='4475878788' />
<nd ref='4475878787' />
<nd ref='4475878786' />
<nd ref='4475878785' />
<nd ref='4475878784' />
<nd ref='4475878782' />
<nd ref='4475878781' />
<tag k='addr:postcode' v='RH16 1AA' />
<tag k='addr:street' v='Mill Green Road' />
<tag k='amenity' v='post_depot' />
<tag k='brand' v='Royal Mail' />
<tag k='brand:wikidata' v='Q638098' />
<tag k='brand:wikipedia' v='en:Royal Mail' />
<tag k='building' v='warehouse' />
<tag k='name' v='Haywards Heath Delivery Office' />
<tag k='opening_hours' v='Mo-Fr 08:00-14:00,15:00-17:30; We 08:00-14:00,15:00-20:00; Sa 09:00-14:00' />
<tag k='operator' v='Royal Mail' />
<tag k='operator:type' v='private' />
<tag k='operator:wikidata' v='Q638098' />
</way>
<way id='450667718' timestamp='2018-08-01T19:07:09Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='61273373'>
<nd ref='4475878725' />
<nd ref='4475878724' />
<nd ref='4475878707' />
<nd ref='4475878711' />
<tag k='addr:housename' v='Sussex House' />
<tag k='addr:postcode' v='RH16 1DN' />
<tag k='addr:street' v='Perrymount Road' />
<tag k='building' v='yes' />
</way>
<way id='450667727' timestamp='2020-01-07T12:24:36Z' uid='5443821' user='Thomas Jarvis' visible='true' version='4' changeset='79293460'>
<nd ref='4475878769' />
<nd ref='5516649782' />
<nd ref='5516649784' />
<nd ref='5516649785' />
<nd ref='5516649783' />
<nd ref='4475878767' />
<nd ref='4475878770' />
<nd ref='4475878779' />
<tag k='addr:housename' v='LGM House' />
<tag k='addr:postcode' v='RH16 1XL' />
<tag k='building' v='house' />
<tag k='building:levels' v='3' />
</way>
<way id='450667738' timestamp='2018-05-10T10:02:07Z' uid='890751' user='extua' visible='true' version='2' changeset='58844740'>
<nd ref='4475878755' />
<nd ref='4475878750' />
<nd ref='4475878756' />
<nd ref='4475878765' />
<tag k='addr:city' v='Haywards Heath' />
<tag k='addr:housenumber' v='58' />
<tag k='addr:postcode' v='RH16 1EA' />
<tag k='addr:street' v='Commercial Square' />
<tag k='amenity' v='restaurant' />
<tag k='cuisine' v='indian' />
<tag k='delivery' v='yes' />
<tag k='name' v='Curry Inn' />
<tag k='opening_hours' v='12:00-14:00,17:30-23:00; Tu off' />
<tag k='outdoor_seating' v='no' />
<tag k='takeaway' v='yes' />
</way>
<way id='450667741' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='4' changeset='109282190'>
<nd ref='4475878718' />
<nd ref='4475878717' />
<nd ref='4475878712' />
<nd ref='4475878713' />
<tag k='addr:housenumber' v='54-56' />
<tag k='addr:postcode' v='RH16 3DT' />
<tag k='brand' v='Spar' />
<tag k='brand:wikidata' v='Q610492' />
<tag k='brand:wikipedia' v='en:SPAR (retailer)' />
<tag k='name' v='Spar' />
<tag k='opening_hours' v='07:00-23:00' />
<tag k='shop' v='supermarket' />
</way>
<way id='450667746' timestamp='2018-07-30T21:00:46Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='61208369'>
<nd ref='4475878743' />
<nd ref='4475878742' />
<nd ref='4475878738' />
<nd ref='4475878739' />
<tag k='addr:housename' v='Clive Court' />
<tag k='addr:postcode' v='RH16 1PY' />
<tag k='addr:street' v='Sydney Road' />
</way>
<way id='450667751' timestamp='2021-01-11T12:27:53Z' uid='63012' user='stthomse' visible='true' version='5' changeset='97306594'>
<nd ref='4475878762' />
<nd ref='4475878764' />
<nd ref='4475878766' />
<nd ref='8311271379' />
<tag k='addr:housename' v='Fern House' />
</way>
<way id='450667753' timestamp='2021-01-02T21:45:31Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='4' changeset='96827459'>
<nd ref='4475878796' />
<nd ref='4475878790' />
<nd ref='4475878791' />
<nd ref='5639697461' />
<nd ref='5639697460' />
<nd ref='5639697459' />
<nd ref='5639697458' />
<nd ref='4475878797' />
<tag k='addr:postcode' v='RH16 1XJ' />
<tag k='name' v='Mill Green House' />
</way>
<way id='450667757' timestamp='2018-05-10T10:02:07Z' uid='890751' user='extua' visible='true' version='2' changeset='58844740'>
<nd ref='4475878751' />
<nd ref='4475878746' />
<nd ref='4475878747' />
<nd ref='4475878748' />
<nd ref='4475878763' />
<tag k='amenity' v='pub' />
<tag k='name' v='The Burrell Arms' />
<tag k='opening_hours' v='Mo-Sa 11:00-00:00; Su 12:00-23:00' />
<tag k='outdoor_seating' v='yes' />
</way>
<way id='450667774' timestamp='2021-01-02T21:48:26Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='5' changeset='96827459'>
<nd ref='4475878800' />
<nd ref='4475878798' />
<nd ref='4475878801' />
<nd ref='4475878799' />
<nd ref='5639697457' />
<nd ref='8285037322' />
<nd ref='8285037323' />
<nd ref='4475878794' />
<nd ref='5639697446' />
<nd ref='4475878795' />
<nd ref='5639697447' />
<nd ref='4475878792' />
<nd ref='5639697448' />
<nd ref='5639697449' />
<nd ref='4475878793' />
<nd ref='5639697453' />
<nd ref='5639697452' />
<nd ref='5639697451' />
<nd ref='5639697450' />
<tag k='building' v='fire_station' />
</way>
<way id='479287543' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='7' changeset='133899701'>
<nd ref='6015612341' />
<nd ref='6150007642' />
<nd ref='1133675198' />
<nd ref='4724171774' />
<nd ref='1146946377' />
<nd ref='34696066' />
<nd ref='2452194964' />
<nd ref='6169441214' />
<tag k='name' v='Perrymount Road' />
<tag k='oneway' v='no' />
</way>
<way id='479493877' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='6' changeset='133932731'>
<nd ref='10748466993' />
<nd ref='10748466994' />
<nd ref='10748482719' />
<nd ref='5805163515' />
<nd ref='5805163514' />
<nd ref='4725832496' />
<nd ref='10748482712' />
<nd ref='10748466964' />
<nd ref='10748482711' />
<tag k='landuse' v='retail' />
</way>
<way id='479611944' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='8' changeset='83117492'>
<nd ref='4726864937' />
<nd ref='4726864938' />
<nd ref='5609081575' />
<nd ref='4726864939' />
<nd ref='7370510330' />
<nd ref='4726864942' />
<nd ref='5609081570' />
<nd ref='5609081569' />
<nd ref='5609081568' />
<nd ref='5609081571' />
<nd ref='4726864945' />
<nd ref='4726864946' />
<nd ref='5609081574' />
<nd ref='5609081572' />
<nd ref='5609081573' />
<nd ref='4726864947' />
<nd ref='4726864948' />
<tag k='amenity' v='parking' />
<tag k='fee' v='yes' />
<tag k='name' v='Clair Hall' />
<tag k='toilets:wheelchair' v='no' />
<tag k='wheelchair' v='yes' />
<tag k='wheelchair:description' v='Four Blue Badge spaces opposite step free entrance to Clare Hall. Narrow, so called "Accessible WC" inside hall - go to left after entrance doors.' />
</way>
<way id='479611945' timestamp='2017-03-09T22:38:46Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='46724100'>
<nd ref='4726864949' />
</way>
<way id='490557201' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='6' changeset='109282190'>
<nd ref='5371299979' />
<nd ref='4827447171' />
<nd ref='4827447172' />
<nd ref='4827447173' />
<nd ref='8986589711' />
<nd ref='4475878727' />
<nd ref='4827447183' />
<nd ref='4827447174' />
<nd ref='4827447175' />
<nd ref='5379052901' />
<nd ref='4827447176' />
<nd ref='6149927014' />
<nd ref='4827447177' />
<nd ref='4827447178' />
<nd ref='4827447188' />
<nd ref='8986589708' />
<nd ref='4827447179' />
<nd ref='4827447180' />
<nd ref='8986589713' />
<nd ref='8986589712' />
<nd ref='8986589714' />
<nd ref='4827447182' />
<tag k='access' v='customers' />
<tag k='level' v='1' />
<tag k='maxstay' v='2 hr' />
<tag k='name' v='Waitrose Carpark' />
</way>
<way id='490557204' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='17' changeset='109282190'>
<nd ref='4475878732' />
<nd ref='5379052900' />
<nd ref='4827447184' />
<nd ref='4827447185' />
<nd ref='4827447186' />
<nd ref='8986609620' />
<nd ref='8986609621' />
<nd ref='8986609619' />
<nd ref='8986609622' />
<nd ref='8311271378' />
<nd ref='4827447187' />
<nd ref='6150248168' />
<nd ref='4827447189' />
<nd ref='4827447190' />
<tag k='addr:housename' v='Waitrose' />
<tag k='addr:housenumber' v='6' />
<tag k='addr:postcode' v='RH16 3DP' />
<tag k='addr:street' v='Clair Road' />
<tag k='brand' v='Waitrose' />
<tag k='brand:wikidata' v='Q771734' />
<tag k='brand:wikipedia' v='en:Waitrose' />
<tag k='building' v='commercial' />
<tag k='building:levels' v='2' />
<tag k='layer' v='1' />
<tag k='name' v='Waitrose' />
<tag k='official_name' v='Waitrose & Partners' />
<tag k='opening_hours' v='Mo-Sa 07:00-21:00; Su 10:00-16:00' />
<tag k='operator' v='Waitrose & Partners' />
<tag k='phone' v='+44 1444 441251' />
<tag k='website' v='https://www.waitrose.com/bf_home/bf/873.html' />
</way>
<way id='505989343' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='7' changeset='133895069'>
<nd ref='4957974171' />
<nd ref='10748269816' />
<nd ref='5815821736' />
<nd ref='5815821735' />
<nd ref='10748269818' />
<nd ref='5012711784' />
<tag k='access' v='destination' />
<tag k='hgv' v='no' />
</way>
<way id='505989344' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='6' changeset='133932731'>
<nd ref='4957970418' />
<nd ref='4957970415' />
<nd ref='10748269895' />
<nd ref='10748269894' />
<nd ref='5815932344' />
<nd ref='10748269893' />
<nd ref='5815932322' />
<nd ref='10748270016' />
<nd ref='5815932343' />
<nd ref='10748270017' />
<nd ref='10748270018' />
<nd ref='5815932342' />
<nd ref='5815932341' />
<nd ref='5815932340' />
<nd ref='10748270067' />
<nd ref='10748270068' />
<nd ref='10748270064' />
<nd ref='10748270065' />
<nd ref='5815932339' />
<nd ref='10748270062' />
<nd ref='10748270059' />
<nd ref='10748270060' />
<nd ref='10748270061' />
<nd ref='5815932326' />
<nd ref='10748270043' />
<nd ref='5815932338' />
<nd ref='10748366479' />
<nd ref='5815932337' />
<nd ref='5815932336' />
<nd ref='5815932335' />
<nd ref='5815932334' />
<nd ref='5815932333' />
<nd ref='10748269848' />
<nd ref='10748269849' />
<nd ref='5815932332' />
<nd ref='5815932331' />
<nd ref='3398845309' />
<nd ref='10748269850' />
<nd ref='5815932330' />
<nd ref='5815932329' />
<nd ref='5815932328' />
<nd ref='5815932327' />
<nd ref='5815932324' />
<nd ref='5815932323' />
<nd ref='10748366440' />
<nd ref='10748269852' />
<nd ref='10748269853' />
<nd ref='5815932325' />
<nd ref='10750379371' />
<nd ref='10748269854' />
<nd ref='4957974178' />
<nd ref='7323148284' />
<nd ref='7323148282' />
<nd ref='7323148275' />
<nd ref='10748269811' />
<nd ref='10748269814' />
<nd ref='10748269812' />
<nd ref='10748269813' />
<nd ref='10748269815' />
<nd ref='4957974177' />
<nd ref='5012711783' />
<nd ref='10748269855' />
<nd ref='4957974176' />
<nd ref='10748269791' />
<nd ref='10748269792' />
<nd ref='10748269793' />
<nd ref='10748269798' />
<nd ref='10748269797' />
<nd ref='10748269795' />
<nd ref='10748269794' />
<nd ref='10748269796' />
<nd ref='5012711782' />
<nd ref='10748269859' />
<nd ref='10748269860' />
<nd ref='4957974175' />
<nd ref='10748269858' />
<nd ref='10748269857' />
<nd ref='4957974174' />
<nd ref='10748269856' />
<nd ref='4957974173' />
<nd ref='10748269896' />
<tag k='landuse' v='commercial' />
<tag k='name' v='Bridge Road Business Estate' />
</way>
<way id='512654892' timestamp='2017-08-03T19:28:16Z' uid='3729377' user='deptho' visible='true' version='1' changeset='50818454'>
<nd ref='5012711786' />
<nd ref='5012711785' />
<tag k='barrier' v='fence' />
<tag k='fence_type' v='metal' />
<tag k='height' v='2' />
</way>
<way id='512654895' timestamp='2017-08-03T19:28:16Z' uid='3729377' user='deptho' visible='true' version='1' changeset='50818454'>
</way>
<way id='512654901' timestamp='2017-08-03T19:28:16Z' uid='3729377' user='deptho' visible='true' version='1' changeset='50818454'>
<nd ref='5012711794' />
<nd ref='5012711793' />
<nd ref='5012711792' />
<nd ref='5012711791' />
<tag k='addr:housename' v='Finch's Yard' />
<tag k='name' v='Minilabel' />
</way>
<way id='557764622' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='6' changeset='133899701'>
<nd ref='32197206' />
<nd ref='10748466939' />
<nd ref='10748466940' />
<nd ref='5379052905' />
<nd ref='2452246893' />
<nd ref='5379052906' />
<nd ref='5379052907' />
<nd ref='5379052908' />
<nd ref='5379052909' />
<nd ref='6705056141' />
<nd ref='5379052910' />
<nd ref='10748466972' />
<nd ref='6705056137' />
<nd ref='5379052911' />
<nd ref='5379052912' />
<nd ref='10748466971' />
<nd ref='5379052913' />
<nd ref='5912511733' />
<nd ref='5379052914' />
<nd ref='5379052915' />
<nd ref='5379052916' />
<nd ref='5912511732' />
<nd ref='5379052917' />
<nd ref='6705056132' />
<nd ref='5379052918' />
<nd ref='10748466955' />
<tag k='footway' v='sidewalk' />
<tag k='highway' v='footway' />
<tag k='surface' v='paved' />
</way>
<way id='586294801' timestamp='2018-05-07T10:53:50Z' uid='890751' user='extua' visible='true' version='1' changeset='58754444'>
<nd ref='5601978638' />
<nd ref='5601978640' />
<nd ref='5601978641' />
<nd ref='5601978639' />
<tag k='fence_type' v='chain_link:barber_wire' />
</way>
<way id='586294803' timestamp='2018-05-07T10:53:51Z' uid='890751' user='extua' visible='true' version='1' changeset='58754444'>
<nd ref='5601978633' />
<tag k='barrier' v='wall' />
<tag k='wall' v='brick' />
</way>
<way id='587157638' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220'>
<nd ref='5608933602' />
<nd ref='5608933599' />
<nd ref='5608933595' />
<nd ref='5608933596' />
<nd ref='5608933597' />
<nd ref='5608933598' />
<tag k='addr:housenumber' v='59' />
<tag k='addr:postcode' v='RH16 3DR' />
<tag k='amenity' v='childcare' />
<tag k='name' v='Elan Nursery' />
</way>
<way id='587157639' timestamp='2018-05-10T09:44:17Z' uid='890751' user='extua' visible='true' version='1' changeset='58844220'>
<nd ref='5608933600' />
<nd ref='5608933601' />
<tag k='capacity' v='4' />
<tag k='park_ride' v='no' />
</way>
<way id='587157640' timestamp='2021-01-11T12:27:53Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97306594'>
<nd ref='5608933603' />
<nd ref='5608933604' />
<nd ref='5608933605' />
<nd ref='5608933606' />
<tag k='addr:housename' v='Commercial House' />
<tag k='addr:housenumber' v='52' />
<tag k='name' v='Clourschemer Interiors' />
<tag k='shop' v='furniture' />
</way>
<way id='587183993' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161'>
<nd ref='5609081556' />
<nd ref='5609081557' />
<nd ref='5609081558' />
<nd ref='5609081555' />
<tag k='area' v='yes' />
</way>
<way id='587183994' timestamp='2018-05-10T10:48:41Z' uid='890751' user='extua' visible='true' version='1' changeset='58846161'>
<nd ref='5609081560' />
<nd ref='5609081561' />
<nd ref='5609081562' />
<nd ref='5609081563' />
<nd ref='5609081564' />
<nd ref='5609081565' />
<nd ref='5609081566' />
</way>
<way id='590786652' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902'>
<nd ref='5639697442' />
<nd ref='5639697443' />
<nd ref='5639697444' />
<nd ref='5639697445' />
<nd ref='5639697454' />
<nd ref='5639697440' />
<nd ref='5639697439' />
<nd ref='5639697438' />
<nd ref='5639697437' />
<nd ref='5639697436' />
<nd ref='5639697435' />
<nd ref='5639697434' />
<tag k='access' v='private' />
</way>
<way id='590786653' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902'>
<nd ref='5639697455' />
<nd ref='5639697456' />
<tag k='landuse' v='grass' />
</way>
<way id='590786654' timestamp='2018-08-07T17:21:08Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='61441849'>
<nd ref='5639697462' />
<nd ref='5639697463' />
<nd ref='5639697464' />
<nd ref='5639697465' />
<nd ref='5639697466' />
<nd ref='5639697467' />
<nd ref='5639697471' />
<nd ref='5639697473' />
<nd ref='5639697470' />
<nd ref='5639697472' />
<nd ref='5639697468' />
<nd ref='5639697469' />
<tag k='addr:housename' v='17 to 29' />
<tag k='addr:postcode' v='RH16 1ER' />
<tag k='addr:street' v='Gordon Close' />
<tag k='building' v='apartments' />
</way>
<way id='590786655' timestamp='2018-08-07T17:21:08Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='61441849'>
<nd ref='5639697474' />
<nd ref='5639697482' />
<nd ref='5639697478' />
<nd ref='5639697480' />
<nd ref='5639697483' />
<nd ref='5639697475' />
<nd ref='5639697476' />
<nd ref='5639697484' />
<nd ref='5639697481' />
<nd ref='5639697479' />
<nd ref='5639697485' />
<nd ref='5639697477' />
<tag k='addr:housename' v='4 to 16' />
</way>
<way id='590786656' timestamp='2018-08-07T17:21:07Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='61441849'>
<nd ref='5639697486' />
<nd ref='5639697487' />
<nd ref='5639697488' />
<nd ref='5639697489' />
<nd ref='5639697490' />
<nd ref='5639697491' />
<nd ref='5639697492' />
<nd ref='5639697493' />
<nd ref='5639697494' />
<nd ref='5639697495' />
<nd ref='5639697496' />
<nd ref='5639697497' />
<tag k='addr:housename' v='31 to 41' />
</way>
<way id='590786657' timestamp='2018-05-24T12:15:31Z' uid='890751' user='extua' visible='true' version='1' changeset='59239902'>
<nd ref='5639697498' />
<nd ref='5639697499' />
<nd ref='5639697500' />
<nd ref='5639697501' />
<tag k='building' v='garage' />
</way>
<way id='611607806' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='4' changeset='109282190'>
<nd ref='5790082249' />
<nd ref='8986589709' />
<nd ref='6149927016' />
<nd ref='5790082248' />
<nd ref='5790082247' />
<nd ref='8986589710' />
<nd ref='5790082246' />
<tag k='maxheight' v='2.1' />
<tag k='maxweight' v='2.5' />
</way>
<way id='611607808' timestamp='2022-11-30T15:38:49Z' uid='8612764' user='Alan Kemp' visible='true' version='3' changeset='129566680'>
<nd ref='5790082262' />
<nd ref='5790082263' />
<nd ref='5790082264' />
<nd ref='5790082265' />
<nd ref='5790082266' />
<nd ref='5790082267' />
<nd ref='5790082268' />
<nd ref='5790082269' />
<nd ref='5790082251' />
<nd ref='5790082252' />
<nd ref='5790082255' />
<nd ref='5790082256' />
<nd ref='5790082257' />
<nd ref='5790082258' />
<nd ref='5790082259' />
<nd ref='5790082260' />
<nd ref='5790082261' />
<nd ref='5790082253' />
<nd ref='5790082254' />
<tag k='leisure' v='pitch' />
<tag k='lit' v='no' />
<tag k='sport' v='cricket' />
<tag k='surface' v='grass' />
</way>
<way id='612390553' timestamp='2019-06-30T14:55:44Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758238'>
<nd ref='5796943735' />
<nd ref='5796943739' />
<nd ref='5796943742' />
<nd ref='5796943738' />
<tag k='addr:housenumber' v='1' />
<tag k='addr:postcode' v='RH16 1DW' />
<tag k='name' v='Progress Launderette' />
<tag k='shop' v='laundry' />
</way>
<way id='612390555' timestamp='2019-06-30T14:55:44Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758238'>
<nd ref='5796943743' />
<nd ref='5796943744' />
<tag k='addr:housenumber' v='2' />
</way>
<way id='612390558' timestamp='2021-05-15T08:34:41Z' uid='6816132' user='CjMalone' visible='true' version='5' changeset='104721176'>
<nd ref='5796943772' />
<nd ref='5796943770' />
<nd ref='5796943748' />
<tag k='addr:country' v='GB' />
<tag k='addr:housenumber' v='3' />
<tag k='amenity' v='fast_food' />
<tag k='brand' v='Domino's' />
<tag k='brand:wikidata' v='Q839466' />
<tag k='brand:wikipedia' v='en:Domino's Pizza' />
<tag k='contact:website' v='https://www.dominos.co.uk/pizza-near-me/haywards-heath/3-commercial-square' />
<tag k='cuisine' v='pizza' />
<tag k='name' v='Domino's' />
</way>
<way id='612390561' timestamp='2018-07-30T21:00:44Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369'>
<nd ref='5796943745' />
<nd ref='5796943746' />
<nd ref='5796943747' />
<tag k='addr:housenumber' v='4' />
<tag k='craft' v='window_construction' />
<tag k='name' v='Window Wise' />
</way>
<way id='612390562' timestamp='2019-06-30T14:55:44Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758238'>
<nd ref='5796943749' />
<nd ref='5796943750' />
<nd ref='5796943769' />
<nd ref='5796943768' />
<nd ref='5796943771' />
<nd ref='5796943751' />
<tag k='addr:housenumber' v='5' />
<tag k='name' v='JJ Glass' />
</way>
<way id='612390563' timestamp='2019-06-30T14:55:44Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758238'>
<nd ref='5796943756' />
<nd ref='5796943759' />
<nd ref='5796943755' />
<tag k='amenity' v='cafe' />
<tag k='name' v='Peckish Cafe' />
</way>
<way id='612390564' timestamp='2019-06-30T14:55:44Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758238'>
<nd ref='5796943760' />
<nd ref='5796943763' />
<tag k='addr:housenumber' v='7' />
<tag k='name' v='Carousel Music' />
<tag k='shop' v='musical_instrument' />
</way>
<way id='612390565' timestamp='2018-07-30T21:00:44Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61208369'>
<nd ref='5796943761' />
<nd ref='5796943762' />
<tag k='addr:housenumber' v='8' />
<tag k='name' v='Canton Kitchen' />
<tag k='takeaway' v='only' />
</way>
<way id='612390566' timestamp='2021-07-31T16:29:27Z' uid='6913532' user='10992' visible='true' version='4' changeset='108949949'>
<nd ref='5796943765' />
<nd ref='5796943766' />
<tag k='addr:housenumber' v='9' />
<tag k='email' v='info at silkhairboutique.co.uk' />
<tag k='name' v='Silk Hair' />
<tag k='phone' v='+44 1444 450243' />
<tag k='shop' v='hairdresser' />
<tag k='website' v='http://www.silkhairboutique.co.uk' />
</way>
<way id='613107322' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='4' changeset='133899701'>
<nd ref='5802124813' />
<nd ref='7370510325' />
<nd ref='7370510326' />
<nd ref='5802124814' />
<nd ref='7370510327' />
<nd ref='5802124815' />
<nd ref='5802124816' />
<nd ref='7370510310' />
<nd ref='7370510300' />
<nd ref='5802124817' />
<nd ref='5802124818' />
<nd ref='5802124819' />
<nd ref='7370510328' />
<nd ref='10748482708' />
<nd ref='5802124820' />
<tag k='bicycle' v='no' />
</way>
<way id='613545874' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='5805163460' />
<nd ref='5805163471' />
<nd ref='5805163461' />
<nd ref='5805163462' />
<nd ref='5805163463' />
<tag k='addr:postcode' v='RH16 1DF' />
<tag k='addr:street' v='Park View' />
</way>
<way id='613545875' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='5805163466' />
<nd ref='5805163467' />
</way>
<way id='613545876' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='5805163468' />
<nd ref='5805163469' />
<nd ref='5805163470' />
</way>
<way id='613545877' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='5805163472' />
<nd ref='5805163479' />
<nd ref='5805163473' />
</way>
<way id='613545878' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='5805163476' />
<nd ref='5805163477' />
<nd ref='5805163478' />
</way>
<way id='613545879' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='5805163480' />
<nd ref='5805163481' />
</way>
<way id='613545880' timestamp='2018-08-02T21:16:59Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163484' />
<nd ref='5805163485' />
<nd ref='5805163486' />
<nd ref='5805163487' />
<tag k='addr:housenumber' v='16' />
<tag k='addr:postcode' v='RH16 1PZ' />
</way>
<way id='613545881' timestamp='2018-08-02T21:16:59Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163488' />
<nd ref='5805163489' />
<nd ref='5805163490' />
<nd ref='5805163491' />
<tag k='addr:housenumber' v='14' />
</way>
<way id='613545882' timestamp='2018-08-02T21:16:59Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163492' />
<nd ref='5805163493' />
<nd ref='5805163494' />
<nd ref='5805163495' />
<tag k='addr:housenumber' v='12' />
</way>
<way id='613545883' timestamp='2018-08-02T21:16:59Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163496' />
<nd ref='5805163497' />
<nd ref='5805163498' />
<nd ref='5805163499' />
<tag k='addr:housenumber' v='10' />
</way>
<way id='613545884' timestamp='2018-08-02T21:17:00Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163500' />
<nd ref='5805163501' />
<nd ref='5805163502' />
<nd ref='5805163503' />
<tag k='addr:postcode' v='RH16 1DZ' />
</way>
<way id='613545885' timestamp='2018-08-02T21:17:00Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163505' />
<nd ref='5805163506' />
<nd ref='5805163504' />
<tag k='addr:postcode' v='RH16 1DR' />
</way>
<way id='613545886' timestamp='2018-08-02T21:17:00Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163507' />
<nd ref='5805163508' />
<tag k='addr:housenumber' v='2-3' />
</way>
<way id='613545887' timestamp='2018-08-02T21:17:00Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163509' />
<nd ref='5805163510' />
<nd ref='5805163511' />
<nd ref='5805163512' />
</way>
<way id='613545888' timestamp='2021-09-23T11:20:38Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='111586932'>
<nd ref='5805163516' />
<nd ref='9116717591' />
<nd ref='9116717592' />
<nd ref='5805163517' />
<tag k='addr:postcode' v='RH16 1QQ' />
</way>
<way id='613545889' timestamp='2021-09-23T11:20:38Z' uid='10573400' user='PeterMapit' visible='true' version='2' changeset='111586932'>
<nd ref='5805163518' />
<nd ref='9116717594' />
<nd ref='9116717593' />
<nd ref='5805163519' />
</way>
<way id='613545890' timestamp='2018-08-02T21:17:00Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163522' />
<nd ref='5805163523' />
<nd ref='5805163524' />
<nd ref='5805163525' />
</way>
<way id='613545891' timestamp='2018-08-02T21:17:00Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163526' />
<nd ref='5805163527' />
<nd ref='5805163528' />
<nd ref='5805163529' />
</way>
<way id='613545892' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='5805163530' />
<nd ref='5805163531' />
<nd ref='5805163532' />
<nd ref='5805163533' />
<tag k='addr:housename' v='Embnassy Court' />
<tag k='addr:postcode' v='RH16 1QG' />
</way>
<way id='613545893' timestamp='2022-06-08T11:07:10Z' uid='3733993' user='Aleksandar1994' visible='true' version='5' changeset='122112915'>
<nd ref='5805163534' />
<nd ref='5805163535' />
<nd ref='5805163536' />
<nd ref='5805163537' />
<nd ref='5805163538' />
<nd ref='5805163539' />
<nd ref='5805163540' />
<nd ref='5805163541' />
<nd ref='5805163542' />
<nd ref='5805163543' />
<nd ref='5805163544' />
<nd ref='5805163545' />
<tag k='amenity' v='place_of_worship' />
<tag k='denomination' v='anglican' />
<tag k='name' v='St Richards Church' />
<tag k='religion' v='christian' />
<tag k='wikidata' v='Q7595418' />
<tag k='wikipedia' v='en:St Richard's Church, Haywards Heath' />
</way>
<way id='613545894' timestamp='2020-12-16T22:56:53Z' uid='84263' user='Robert Whittaker' visible='true' version='2' changeset='95966720'>
<nd ref='5805163546' />
<nd ref='5805163547' />
<nd ref='5805163548' />
<nd ref='5805163549' />
<tag k='amenity' v='community_centre' />
<tag k='name' v='St Richards Church Hall' />
</way>
<way id='613545895' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='5805163551' />
<nd ref='5805163552' />
<nd ref='5805163553' />
<nd ref='5805163554' />
<nd ref='5805163555' />
</way>
<way id='613545896' timestamp='2018-08-02T21:17:01Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163557' />
<nd ref='5805163558' />
<nd ref='5805163559' />
<nd ref='5805163560' />
<tag k='addr:housenumber' v='19' />
<tag k='addr:postcode' v='RH16 1QE' />
</way>
<way id='613545897' timestamp='2018-08-02T21:17:01Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163561' />
<nd ref='5805163562' />
<nd ref='5805163563' />
<nd ref='5805163564' />
<tag k='addr:housenumber' v='21' />
</way>
<way id='613545898' timestamp='2018-08-02T21:17:01Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163565' />
<nd ref='5805163566' />
<nd ref='5805163567' />
<nd ref='5805163568' />
<tag k='addr:housenumber' v='23' />
</way>
<way id='613545905' timestamp='2018-08-02T21:17:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163599' />
<nd ref='5805163600' />
<nd ref='5805163601' />
<nd ref='5805163602' />
<tag k='addr:postcode' v='RH16 1EB' />
<tag k='addr:street' v='Queens Road' />
</way>
<way id='613545906' timestamp='2018-08-02T21:17:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163603' />
<nd ref='5805163604' />
<nd ref='5805163605' />
<nd ref='5805163606' />
</way>
<way id='613545907' timestamp='2018-08-02T21:17:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163607' />
<nd ref='5805163608' />
<nd ref='5805163609' />
<nd ref='5805163610' />
</way>
<way id='613545908' timestamp='2018-08-02T21:17:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163611' />
<nd ref='5805163612' />
<nd ref='5805163613' />
<nd ref='5805163614' />
</way>
<way id='613545909' timestamp='2018-08-02T21:17:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163615' />
<nd ref='5805163616' />
<nd ref='5805163617' />
<nd ref='5805163618' />
<tag k='addr:housenumber' v='18' />
</way>
<way id='613545910' timestamp='2018-08-02T21:17:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163619' />
<nd ref='5805163620' />
<nd ref='5805163621' />
<nd ref='5805163622' />
<tag k='addr:housenumber' v='20' />
</way>
<way id='613545911' timestamp='2018-08-02T21:17:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163623' />
<nd ref='5805163624' />
<nd ref='5805163625' />
<nd ref='5805163626' />
<tag k='addr:housenumber' v='22' />
</way>
<way id='613545912' timestamp='2018-08-02T21:17:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163627' />
<nd ref='5805163628' />
<nd ref='5805163629' />
<nd ref='5805163630' />
<tag k='addr:housenumber' v='24' />
</way>
<way id='613545913' timestamp='2018-08-02T21:17:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163631' />
<nd ref='5805163632' />
<nd ref='5805163633' />
<nd ref='5805163634' />
<tag k='addr:housenumber' v='26' />
</way>
<way id='613545914' timestamp='2018-08-02T21:17:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163635' />
<nd ref='5805163636' />
<nd ref='5805163637' />
<nd ref='5805163638' />
<tag k='addr:housenumber' v='28' />
</way>
<way id='613545915' timestamp='2018-08-02T21:17:03Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61310562'>
<nd ref='5805163639' />
<nd ref='5805163640' />
<nd ref='5805163641' />
<nd ref='5805163642' />
<nd ref='5805163643' />
<nd ref='5805163644' />
<tag k='addr:housename' v='Vicarage' />
</way>
<way id='613545916' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='5805163645' />
<nd ref='10748466963' />
<nd ref='5805163646' />
<nd ref='5805163647' />
<nd ref='5805163648' />
<nd ref='10748466962' />
<nd ref='5805163649' />
<nd ref='5805163650' />
</way>
<way id='614276048' timestamp='2018-08-05T19:42:53Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905'>
<nd ref='5810812249' />
<nd ref='5810812250' />
<nd ref='5810812251' />
<nd ref='5810812252' />
<nd ref='5810813753' />
<nd ref='5810813754' />
<nd ref='5810813755' />
<nd ref='5810813756' />
<tag k='addr:postcode' v='RH16 1EH' />
</way>
<way id='614276049' timestamp='2018-08-05T19:42:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905'>
<nd ref='5810813757' />
<nd ref='5810813758' />
<nd ref='5810813759' />
<nd ref='5810813760' />
</way>
<way id='614276050' timestamp='2018-08-05T19:42:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905'>
<nd ref='5810813761' />
<nd ref='5810813762' />
<nd ref='5810813763' />
<nd ref='5810813764' />
<tag k='addr:housenumber' v='11' />
</way>
<way id='614276051' timestamp='2018-08-05T19:42:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905'>
<nd ref='5810813765' />
<nd ref='5810813766' />
<nd ref='5810813767' />
<nd ref='5810813768' />
<tag k='addr:housenumber' v='13' />
</way>
<way id='614276052' timestamp='2018-08-05T19:42:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905'>
<nd ref='5810813769' />
<nd ref='5810813770' />
<nd ref='5810813771' />
<nd ref='5810813772' />
<tag k='addr:housenumber' v='15' />
</way>
<way id='614276053' timestamp='2018-08-05T19:42:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905'>
<nd ref='5810813773' />
<nd ref='5810813774' />
<nd ref='5810813775' />
<nd ref='5810813776' />
<tag k='addr:housenumber' v='17' />
</way>
<way id='614276054' timestamp='2018-08-05T19:42:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905'>
<nd ref='5810813777' />
<nd ref='5810813778' />
<nd ref='5810813779' />
<nd ref='5810813780' />
</way>
<way id='614276055' timestamp='2018-08-05T19:42:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905'>
<nd ref='5810813781' />
<nd ref='5810813782' />
<nd ref='5810813783' />
<nd ref='5810813784' />
</way>
<way id='614276056' timestamp='2018-08-05T19:42:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905'>
<nd ref='5810813785' />
<nd ref='5810813786' />
<nd ref='5810813787' />
<nd ref='5810813788' />
</way>
<way id='614276057' timestamp='2018-08-05T19:42:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905'>
<nd ref='5810813789' />
<nd ref='5810813790' />
<nd ref='5810813791' />
<nd ref='5810813792' />
<tag k='addr:housenumber' v='25' />
</way>
<way id='614276058' timestamp='2018-08-05T19:42:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905'>
<nd ref='5810813793' />
<nd ref='5810813794' />
<nd ref='5810813795' />
<nd ref='5810813796' />
<tag k='addr:housenumber' v='27' />
</way>
<way id='614276059' timestamp='2018-08-05T19:42:54Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61381905'>
<nd ref='5810813797' />
<nd ref='5810813798' />
<nd ref='5810813799' />
<nd ref='5810813800' />
<tag k='addr:housenumber' v='29' />
</way>
<way id='614922179' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815820021' />
<nd ref='5815820022' />
<nd ref='5815820023' />
<nd ref='5815820024' />
<tag k='addr:postcode' v='RH16 1EJ' />
<tag k='addr:street' v='Gordon Road' />
</way>
<way id='614922180' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815820025' />
<nd ref='5815820026' />
<nd ref='5815820027' />
<nd ref='5815820028' />
</way>
<way id='614922182' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489'>
<nd ref='5815820029' />
<nd ref='5815820030' />
</way>
<way id='614922183' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815820033' />
<nd ref='5815820034' />
<nd ref='5815820035' />
<nd ref='5815820036' />
</way>
<way id='614922184' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815820037' />
<nd ref='5815820038' />
<nd ref='5815820039' />
<nd ref='5815820040' />
</way>
<way id='614922186' timestamp='2018-08-07T17:20:58Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815820041' />
<nd ref='5815820042' />
<nd ref='5815820043' />
<nd ref='5815820044' />
</way>
<way id='614922187' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489'>
<nd ref='5815820045' />
<nd ref='5815820046' />
</way>
<way id='614922188' timestamp='2018-08-07T17:20:59Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815820049' />
<nd ref='5815820050' />
<nd ref='5815820051' />
<nd ref='5815820052' />
</way>
<way id='614922189' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489'>
<nd ref='5815821353' />
<nd ref='5815821354' />
</way>
<way id='614922190' timestamp='2018-08-07T17:20:59Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821357' />
<nd ref='5815821358' />
<nd ref='5815821359' />
<nd ref='5815821360' />
</way>
<way id='614922191' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489'>
<nd ref='5815821361' />
<nd ref='5815821362' />
<tag k='addr:housenumber' v='30' />
</way>
<way id='614922192' timestamp='2018-08-07T17:20:59Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821365' />
<nd ref='5815821366' />
<nd ref='5815821367' />
<nd ref='5815821368' />
<tag k='addr:housenumber' v='32' />
</way>
<way id='614922212' timestamp='2018-08-07T17:21:01Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821445' />
<nd ref='5815821446' />
<nd ref='5815821447' />
<nd ref='5815821448' />
<nd ref='5815821449' />
<nd ref='5815821450' />
<tag k='addr:housename' v='Keston House' />
</way>
<way id='614922213' timestamp='2018-08-07T17:21:01Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821451' />
<nd ref='5815821452' />
<nd ref='5815821453' />
<nd ref='5815821454' />
<tag k='addr:housename' v='Copythorne House' />
<tag k='addr:postcode' v='RH16 1EL' />
</way>
<way id='614922214' timestamp='2018-08-07T17:21:01Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821455' />
<nd ref='5815821456' />
<nd ref='5815821457' />
<nd ref='5815821458' />
</way>
<way id='614922215' timestamp='2018-08-07T17:21:01Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821459' />
<nd ref='5815821460' />
<nd ref='5815821461' />
<nd ref='5815821462' />
</way>
<way id='614922216' timestamp='2018-08-07T17:21:01Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821463' />
<nd ref='5815821464' />
<nd ref='5815821465' />
<nd ref='5815821466' />
</way>
<way id='614922217' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489'>
<nd ref='5815821467' />
<nd ref='5815821468' />
</way>
<way id='614922218' timestamp='2018-08-07T17:21:01Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821471' />
<nd ref='5815821472' />
<nd ref='5815821473' />
<nd ref='5815821474' />
</way>
<way id='614922219' timestamp='2021-01-13T12:59:25Z' uid='63012' user='stthomse' visible='true' version='2' changeset='97443489'>
<nd ref='5815821475' />
<nd ref='5815821476' />
</way>
<way id='614922220' timestamp='2018-08-07T17:21:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821479' />
<nd ref='5815821480' />
<nd ref='5815821481' />
<nd ref='5815821482' />
</way>
<way id='614922221' timestamp='2018-08-07T17:21:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821483' />
<nd ref='5815821484' />
<nd ref='5815821485' />
<nd ref='5815821486' />
</way>
<way id='614922222' timestamp='2018-08-07T17:21:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821487' />
<nd ref='5815821488' />
<nd ref='5815821489' />
<nd ref='5815821490' />
<tag k='addr:housenumber' v='31' />
</way>
<way id='614922223' timestamp='2018-08-07T17:21:02Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821491' />
<nd ref='5815821492' />
<nd ref='5815821493' />
<nd ref='5815821494' />
<tag k='addr:housenumber' v='33' />
</way>
<way id='614922233' timestamp='2018-08-07T17:21:03Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821531' />
<nd ref='5815821532' />
<nd ref='5815821533' />
<nd ref='5815821534' />
<tag k='addr:housenumber' v='35' />
</way>
<way id='614922234' timestamp='2018-08-07T17:21:03Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821535' />
<nd ref='5815821536' />
<nd ref='5815821537' />
<nd ref='5815821538' />
<tag k='addr:housenumber' v='29A' />
</way>
<way id='614922235' timestamp='2018-08-07T17:21:03Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821539' />
<nd ref='5815821540' />
<nd ref='5815821541' />
<nd ref='5815821542' />
<tag k='addr:housenumber' v='37' />
</way>
<way id='614922266' timestamp='2018-08-07T17:21:06Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821695' />
<nd ref='5815821696' />
<nd ref='5815821697' />
<nd ref='5815821698' />
<nd ref='5815821699' />
<nd ref='5815821700' />
<nd ref='5815821701' />
<nd ref='5815821702' />
<tag k='addr:housename' v='46 to 57' />
</way>
<way id='614922267' timestamp='2018-08-07T17:21:06Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821703' />
<nd ref='5815821704' />
<nd ref='5815821705' />
<nd ref='5815821706' />
<tag k='addr:housename' v='42 to 43' />
</way>
<way id='614922268' timestamp='2019-06-30T15:24:51Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758812'>
<nd ref='5815821707' />
<nd ref='5815821708' />
<nd ref='5815821712' />
<nd ref='5815821711' />
</way>
<way id='614922269' timestamp='2018-08-07T17:21:06Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821713' />
<nd ref='5815821714' />
</way>
<way id='614922270' timestamp='2019-06-30T15:24:51Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758812'>
<nd ref='5815821717' />
<nd ref='5815821718' />
</way>
<way id='614922271' timestamp='2018-08-07T17:21:06Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821719' />
<nd ref='5815821720' />
<nd ref='5815821721' />
<nd ref='5815821722' />
<tag k='addr:postcode' v='RH16 1XQ' />
</way>
<way id='614922272' timestamp='2019-06-30T15:24:51Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758812'>
<nd ref='5815821725' />
<nd ref='5815821726' />
</way>
<way id='614922273' timestamp='2019-06-30T15:24:51Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758812'>
<nd ref='5815821727' />
<nd ref='5815821728' />
<nd ref='5815821732' />
<nd ref='5815821731' />
</way>
<way id='614922274' timestamp='2018-08-07T17:21:06Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61441849'>
<nd ref='5815821733' />
<nd ref='5815821734' />
</way>
<way id='614936171' timestamp='2019-06-30T15:24:51Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758812'>
<nd ref='5815934460' />
<nd ref='5815934459' />
<nd ref='5815934455' />
<nd ref='5815934456' />
</way>
<way id='614936172' timestamp='2022-09-12T10:24:49Z' uid='15223574' user='Newdice' visible='true' version='2' changeset='126082768'>
<nd ref='5815934457' />
<nd ref='5815934458' />
<tag k='roof:levels' v='0' />
</way>
<way id='614936173' timestamp='2019-06-30T15:24:51Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758812'>
<nd ref='5815934468' />
<nd ref='5815934467' />
<nd ref='5815934463' />
<nd ref='5815934464' />
</way>
<way id='614936174' timestamp='2018-08-07T17:56:45Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827'>
<nd ref='5815934465' />
<nd ref='5815934466' />
</way>
<way id='614936175' timestamp='2019-06-30T15:24:51Z' uid='1735800' user='adlid' visible='true' version='2' changeset='71758812'>
<nd ref='5815934476' />
<nd ref='5815934475' />
<nd ref='5815934471' />
<nd ref='5815934472' />
</way>
<way id='614936176' timestamp='2018-08-07T17:56:45Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='61442827'>
<nd ref='5815934473' />
<nd ref='5815934474' />
</way>
<way id='626271432' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<tag k='footway' v='link' />
</way>
<way id='626271435' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701'>
<nd ref='5912511743' />
<nd ref='5912511744' />
<nd ref='5912511745' />
<nd ref='5912511746' />
<nd ref='5912511747' />
<nd ref='6169441224' />
<nd ref='5912511748' />
<nd ref='5912511749' />
<tag k='wall' v='dry_stone' />
</way>
<way id='626271436' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='5912511762' />
<nd ref='5912511763' />
<nd ref='5912511764' />
<nd ref='5912511765' />
<nd ref='5912511766' />
<nd ref='5912511768' />
<nd ref='5912511769' />
<nd ref='5912511751' />
<nd ref='5912511752' />
<nd ref='5912511755' />
<nd ref='5912511756' />
<nd ref='5912511757' />
<nd ref='5912511758' />
<nd ref='5912511759' />
<nd ref='5912511760' />
<nd ref='5912511761' />
<nd ref='5912511754' />
</way>
<way id='626271437' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='5' changeset='133899701'>
<nd ref='10034296686' />
<nd ref='5912511774' />
<nd ref='10748466953' />
<nd ref='937043331' />
<tag k='name' v='Market Place' />
</way>
<way id='626271438' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='10748466931' />
<nd ref='5912511776' />
<nd ref='10748466988' />
</way>
<way id='626271439' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='4' changeset='133899701'>
<nd ref='6169441231' />
<nd ref='5912511782' />
<nd ref='5912511784' />
<tag k='sidewalk' v='left' />
</way>
<way id='641341993' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701'>
<nd ref='10748466954' />
<nd ref='10748466952' />
<nd ref='5912511775' />
<tag k='turn:lanes:forward' v='left;through|right' />
</way>
<way id='641341995' timestamp='2020-04-19T21:15:17Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='83785878'>
<nd ref='4724171773' />
<nd ref='7423464015' />
<tag k='highway' v='unclassified' />
<tag k='lanes:forward' v='2' />
<tag k='name' v='Clair Road' />
<tag k='turn:lanes:forward' v='left|right' />
</way>
<way id='656565191' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='2' changeset='109282190'>
<nd ref='6150248169' />
<tag k='addr:housenumber' v='63' />
<tag k='addr:postcode' v='RH16 3BN' />
<tag k='name' v='The Barber Shop' />
</way>
<way id='656565192' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='5' changeset='109282190'>
<nd ref='8986589696' />
<nd ref='8986589697' />
<nd ref='6150248170' />
<tag k='addr:housenumber' v='61' />
<tag k='amenity' v='dentist' />
<tag k='building:levels' v='1' />
<tag k='contact:website' v='https://www.bupa.co.uk/dental/dental-care/practices/platinum-the-clinic-dental-and-facial-aesthetics' />
<tag k='healthcare' v='dentist' />
<tag k='name' v='The Clinic' />
<tag k='operator' v='Bupa' />
<tag k='operator:wikidata' v='Q931628' />
</way>
<way id='713274121' timestamp='2019-08-13T06:29:31Z' uid='10221076' user='MrJeeves' visible='true' version='1' changeset='73291853'>
<nd ref='6705056133' />
<nd ref='6705056134' />
<nd ref='6705056135' />
<nd ref='6705056136' />
</way>
<way id='734741812' timestamp='2019-10-17T10:02:20Z' uid='10252560' user='rkkapilk' visible='true' version='2' changeset='75825363'>
<nd ref='6880967906' />
<nd ref='6880967907' />
</way>
<way id='734741813' timestamp='2019-10-17T10:02:20Z' uid='10252560' user='rkkapilk' visible='true' version='2' changeset='75825363'>
<nd ref='6880967899' />
<nd ref='6880967900' />
<nd ref='6880967901' />
<nd ref='6880967902' />
<nd ref='6880967903' />
<nd ref='6880967904' />
<nd ref='6880967905' />
</way>
<way id='759263714' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='5912515085' />
<nd ref='5912511783' />
<nd ref='6169441229' />
<nd ref='1905997032' />
</way>
<way id='759956401' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='7099196114' />
</way>
<way id='759956402' timestamp='2020-01-01T05:30:41Z' uid='10252551' user='amanura' visible='true' version='1' changeset='79073737'>
<nd ref='7099196116' />
<nd ref='7099196117' />
<nd ref='7099196118' />
</way>
<way id='759956403' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='2' changeset='96827214'>
<nd ref='8285025019' />
<nd ref='7099196119' />
</way>
<way id='784816393' timestamp='2023-03-21T13:06:15Z' uid='577089' user='JodaStephen' visible='true' version='32' changeset='133940215'>
<nd ref='10750370143' />
<nd ref='10750370142' />
<nd ref='10750370145' />
<nd ref='10750370141' />
<nd ref='10750370140' />
<nd ref='10750370139' />
<nd ref='10750370138' />
<nd ref='10750370147' />
<nd ref='10750370137' />
<nd ref='10750370149' />
<nd ref='7112424250' />
<nd ref='7112424251' />
<nd ref='7112424252' />
<nd ref='10750370135' />
<nd ref='10750370134' />
<nd ref='10750370133' />
<nd ref='10750370136' />
<nd ref='10750370131' />
<nd ref='10750370130' />
<nd ref='10750370132' />
<nd ref='10750370129' />
<nd ref='10750370128' />
<nd ref='10750370176' />
<nd ref='10750370117' />
<nd ref='10750370114' />
<nd ref='10750370113' />
<nd ref='10750370112' />
<nd ref='10750370116' />
<nd ref='10750370115' />
<nd ref='10750370111' />
<nd ref='10750370110' />
<nd ref='7323148268' />
<nd ref='9498274875' />
<nd ref='9498274884' />
<nd ref='7323148267' />
<nd ref='9498274883' />
<nd ref='9498274882' />
<nd ref='7323150597' />
<nd ref='7323150618' />
<nd ref='10750370123' />
<nd ref='10750370119' />
<nd ref='10750370118' />
<nd ref='10750370121' />
<nd ref='10750370120' />
<nd ref='10750370122' />
<nd ref='10750370183' />
<nd ref='10750370182' />
<nd ref='10750370184' />
<nd ref='10750370124' />
<nd ref='10750370125' />
<nd ref='10750370185' />
<nd ref='10750370126' />
<nd ref='10750370127' />
<nd ref='10750370186' />
<nd ref='10750370187' />
<nd ref='10750370188' />
<nd ref='10748482720' />
<nd ref='4725832494' />
<nd ref='7295760662' />
<nd ref='10748482709' />
<nd ref='7295760604' />
<nd ref='7295760619' />
<nd ref='7295760628' />
<nd ref='731383109' />
<nd ref='731383105' />
<nd ref='7370510229' />
<nd ref='7295760640' />
<nd ref='731383100' />
<nd ref='7370510313' />
<nd ref='1941113391' />
<nd ref='10240733800' />
<nd ref='1941154644' />
<nd ref='731383093' />
<nd ref='731383088' />
<nd ref='731383084' />
<nd ref='7370510203' />
<nd ref='7295760714' />
<nd ref='7295760647' />
<nd ref='7295760629' />
<nd ref='7295760625' />
<nd ref='7295760709' />
<nd ref='7295760643' />
<nd ref='731383204' />
<nd ref='731383196' />
<nd ref='7295760649' />
<nd ref='7295760674' />
<nd ref='7295760591' />
<nd ref='7295760690' />
<nd ref='7295760594' />
<nd ref='7295760632' />
<nd ref='7295760585' />
<nd ref='7295760636' />
<nd ref='7295760588' />
<nd ref='7295760699' />
<nd ref='7295760725' />
<nd ref='7295760719' />
<nd ref='7295746977' />
<nd ref='7295760698' />
<nd ref='7295760700' />
<nd ref='7295760702' />
<nd ref='7295760704' />
<nd ref='7295760589' />
<nd ref='7295760606' />
<nd ref='7295746983' />
<nd ref='7295760609' />
<nd ref='7295760710' />
<nd ref='7295760631' />
<nd ref='7295760633' />
<nd ref='7295760723' />
<nd ref='7295760672' />
<nd ref='7295760593' />
<nd ref='10251774909' />
<nd ref='7295760664' />
<nd ref='7295760669' />
<nd ref='7295760686' />
<nd ref='10251774910' />
<nd ref='10251774911' />
<nd ref='10251774912' />
<nd ref='1321730463' />
<nd ref='6321959979' />
<nd ref='6321959986' />
<nd ref='7295760673' />
<nd ref='7295760596' />
<nd ref='7295760659' />
<nd ref='7295760595' />
<nd ref='7295760668' />
<nd ref='7295746978' />
<nd ref='7295760620' />
<nd ref='7295760655' />
<nd ref='7295760646' />
<nd ref='7295760717' />
<nd ref='7295760622' />
<nd ref='7295760654' />
<nd ref='7295760624' />
<nd ref='7295760697' />
<nd ref='7295760718' />
<nd ref='7295760701' />
<nd ref='7295760670' />
<nd ref='7295760691' />
<nd ref='7295760641' />
<nd ref='7295760663' />
<nd ref='7295760615' />
<nd ref='7295760638' />
<nd ref='7295760658' />
<nd ref='7295760703' />
<nd ref='7295760715' />
<nd ref='7295760694' />
<nd ref='7295760599' />
<nd ref='7295760645' />
<nd ref='7295760597' />
<nd ref='7295760626' />
<nd ref='7295760586' />
<nd ref='7295760695' />
<nd ref='7295760711' />
<nd ref='7295746979' />
<nd ref='7295746981' />
<nd ref='7295760656' />
<nd ref='7295760634' />
<nd ref='7295760687' />
<nd ref='7295760705' />
<nd ref='7295760685' />
<nd ref='7295760680' />
<nd ref='7295760605' />
<nd ref='7295760608' />
<nd ref='7295760644' />
<nd ref='7295760610' />
<nd ref='7295760660' />
<nd ref='7295760708' />
<nd ref='7295760724' />
<nd ref='7295760592' />
<nd ref='7295760684' />
<nd ref='7295760652' />
<nd ref='7295760613' />
<nd ref='7295746980' />
<nd ref='7295760688' />
<nd ref='7295760676' />
<nd ref='7295760689' />
<nd ref='7295760627' />
<nd ref='7295760727' />
<nd ref='7295760618' />
<nd ref='7295760611' />
<nd ref='7295760661' />
<nd ref='7295760637' />
<nd ref='7295760621' />
<nd ref='7295760590' />
<nd ref='7295760603' />
<nd ref='7295760639' />
<nd ref='7295760693' />
<nd ref='7295746984' />
<nd ref='7295760623' />
<nd ref='7295760587' />
<nd ref='7295760678' />
<nd ref='7295760722' />
<nd ref='7295760650' />
<nd ref='7295760651' />
<nd ref='7295760707' />
<nd ref='7295746982' />
<nd ref='7295760721' />
<nd ref='7295760677' />
<nd ref='7295760666' />
<nd ref='7295760671' />
<nd ref='7295760653' />
<nd ref='7295760712' />
<nd ref='7295760635' />
<nd ref='7295760679' />
<nd ref='7295760729' />
<nd ref='7295760683' />
<nd ref='7295760696' />
<nd ref='7295760612' />
<nd ref='7295760598' />
<nd ref='7295760642' />
<nd ref='7295760692' />
<nd ref='7295760601' />
<nd ref='7295760730' />
<nd ref='7295760731' />
<nd ref='7295760728' />
<nd ref='7295760726' />
<nd ref='7295760600' />
<nd ref='7295760602' />
<nd ref='2532049778' />
<nd ref='2532049765' />
<nd ref='1415176493' />
<nd ref='7332052460' />
<nd ref='7332052440' />
<nd ref='7332052441' />
<nd ref='7332052462' />
<nd ref='7332052455' />
<nd ref='7332052435' />
<nd ref='7332064592' />
<nd ref='7332052421' />
<nd ref='7332052431' />
<nd ref='7878450231' />
<nd ref='7332052426' />
<nd ref='5009289224' />
<nd ref='7878450242' />
<nd ref='7878450241' />
<nd ref='7878450240' />
<nd ref='7332052474' />
<nd ref='7332052427' />
<nd ref='7332052415' />
<nd ref='7332052478' />
<nd ref='7332052468' />
<nd ref='7332052484' />
<nd ref='7332052433' />
<nd ref='7332052454' />
<nd ref='7332052429' />
<nd ref='7332064590' />
<nd ref='7332052432' />
<nd ref='7332052411' />
<nd ref='7332052410' />
<nd ref='7332052477' />
<nd ref='7332052416' />
<nd ref='7332052414' />
<nd ref='7332052430' />
<nd ref='7332052466' />
<nd ref='7332052467' />
<nd ref='7332064585' />
<nd ref='7332052437' />
<nd ref='7332052434' />
<nd ref='7332052407' />
<nd ref='7332064591' />
<nd ref='7332052476' />
<nd ref='7332064593' />
<nd ref='7332064588' />
<nd ref='7332052442' />
<nd ref='7332052475' />
<nd ref='7332052436' />
<nd ref='7332052453' />
<nd ref='7332052424' />
<nd ref='7332052444' />
<nd ref='7332052409' />
<nd ref='7332052412' />
<nd ref='7332052413' />
<nd ref='7332052417' />
<nd ref='7296512144' />
<nd ref='7296512141' />
<nd ref='7296512108' />
<nd ref='7296512142' />
<nd ref='7296512111' />
<nd ref='7296512136' />
<nd ref='7296512106' />
<nd ref='7296512118' />
<nd ref='7296512117' />
<nd ref='7296512115' />
<nd ref='7296512127' />
<nd ref='7296512131' />
<nd ref='7296512124' />
<nd ref='7296512140' />
<nd ref='7296512130' />
<nd ref='7296512137' />
<nd ref='7320758735' />
<nd ref='7320758736' />
<nd ref='7320746647' />
<nd ref='7320746653' />
<nd ref='7320746593' />
<nd ref='7320746597' />
<nd ref='7320746599' />
<nd ref='7320746602' />
<nd ref='7320746642' />
<nd ref='7320746624' />
<nd ref='7320746621' />
<nd ref='7320746620' />
<nd ref='7320746643' />
<nd ref='7320746644' />
<nd ref='7320746622' />
<nd ref='7320746610' />
<nd ref='7320746612' />
<nd ref='7320746605' />
<nd ref='7320746591' />
<nd ref='7320746626' />
<nd ref='7320746641' />
<nd ref='7320746632' />
<nd ref='7320746611' />
<nd ref='7320746596' />
<nd ref='7320746619' />
<nd ref='7320746623' />
<nd ref='7320746627' />
<nd ref='7320746618' />
<nd ref='7320746600' />
<nd ref='7320746616' />
<nd ref='7320746615' />
<nd ref='7320746601' />
<nd ref='7320746595' />
<nd ref='7320746598' />
<nd ref='7320746646' />
<nd ref='7320746631' />
<nd ref='7320746634' />
<nd ref='7320746629' />
<nd ref='7320746635' />
<nd ref='7320746639' />
<nd ref='7320746649' />
<nd ref='7320746592' />
<nd ref='7320746594' />
<nd ref='7320746648' />
<nd ref='7320746651' />
<nd ref='7320746628' />
<nd ref='7320746630' />
<nd ref='7320746633' />
<nd ref='7320746636' />
<nd ref='7320746614' />
<nd ref='7320746617' />
<nd ref='7320746603' />
<nd ref='10718860971' />
<nd ref='10718860973' />
<nd ref='5821270654' />
<nd ref='10718741247' />
<nd ref='5821270653' />
<nd ref='5821269451' />
<nd ref='5821269450' />
<nd ref='10718741235' />
<nd ref='5821269449' />
<nd ref='5821269448' />
<nd ref='10718741238' />
<nd ref='5821269447' />
<nd ref='5821269446' />
<nd ref='10718741239' />
<nd ref='10718741240' />
<nd ref='4989674333' />
<nd ref='7110693278' />
<nd ref='7110693277' />
<nd ref='10718741229' />
<nd ref='7110693266' />
<nd ref='10718860976' />
<nd ref='7320746645' />
<nd ref='10718860978' />
<nd ref='10718741231' />
<nd ref='10718741233' />
<nd ref='10718741232' />
<nd ref='7320725445' />
<nd ref='7320725429' />
<nd ref='7320725437' />
<nd ref='7320723278' />
<nd ref='7320725415' />
<nd ref='7320723277' />
<nd ref='7320725403' />
<nd ref='7320725406' />
<nd ref='7320725398' />
<nd ref='7320725449' />
<nd ref='7320725441' />
<nd ref='7320725418' />
<nd ref='7320725413' />
<nd ref='7320725402' />
<nd ref='7320725432' />
<nd ref='7320723276' />
<nd ref='7320723275' />
<nd ref='7320725399' />
<nd ref='7320723284' />
<nd ref='7320725411' />
<nd ref='7320725416' />
<nd ref='7320725431' />
<nd ref='7320723282' />
<nd ref='7320725439' />
<nd ref='7320725419' />
<nd ref='7320725442' />
<nd ref='7320725443' />
<nd ref='7320725440' />
<nd ref='7320725393' />
<nd ref='7320725395' />
<nd ref='7320725434' />
<nd ref='7320725391' />
<nd ref='7320725451' />
<nd ref='7320725446' />
<nd ref='7320725420' />
<nd ref='7320725425' />
<nd ref='3015579859' />
<nd ref='7320723283' />
<nd ref='7320725444' />
<nd ref='7320725390' />
<nd ref='7320725447' />
<nd ref='7320725448' />
<nd ref='7320725414' />
<nd ref='7320725410' />
<nd ref='7320725430' />
<nd ref='7320725400' />
<nd ref='7320725392' />
<nd ref='7320725435' />
<nd ref='7320725450' />
<nd ref='7320723280' />
<nd ref='7320723281' />
<nd ref='7320725405' />
<nd ref='7320725426' />
<nd ref='7320725421' />
<nd ref='7320725389' />
<nd ref='9324901743' />
<nd ref='7320725388' />
<nd ref='7320725404' />
<nd ref='7320725422' />
<nd ref='7320725455' />
<nd ref='7331861144' />
<nd ref='7320725433' />
<nd ref='7320725427' />
<nd ref='7320725397' />
<nd ref='7320725386' />
<nd ref='7320725452' />
<nd ref='7320725408' />
<nd ref='7320725401' />
<nd ref='1133659144' />
<nd ref='1133659106' />
<nd ref='1111591512' />
<nd ref='1111591535' />
<nd ref='1111591522' />
<nd ref='1111591540' />
<nd ref='1111591518' />
<nd ref='7320725436' />
<nd ref='1111591549' />
<nd ref='1111591514' />
<nd ref='7320725396' />
<nd ref='7320725417' />
<nd ref='7320725409' />
<nd ref='7320725428' />
<nd ref='7320723279' />
<nd ref='7320725453' />
<nd ref='7320723055' />
<nd ref='7320723045' />
<nd ref='7320723085' />
<nd ref='7320723054' />
<nd ref='7320723051' />
<nd ref='7320688575' />
<nd ref='7320688572' />
<nd ref='7320723086' />
<nd ref='6746333735' />
<nd ref='7320723024' />
<nd ref='7320723036' />
<nd ref='7320723033' />
<nd ref='7320722994' />
<nd ref='7320723089' />
<nd ref='7320723006' />
<nd ref='7320723053' />
<nd ref='7320723031' />
<nd ref='7320688579' />
<nd ref='7320723001' />
<nd ref='7320723013' />
<nd ref='7320723030' />
<nd ref='7320722999' />
<nd ref='7320723069' />
<nd ref='7320688568' />
<nd ref='7320723032' />
<nd ref='7320723035' />
<nd ref='7320723025' />
<nd ref='7320723044' />
<nd ref='7320723100' />
<nd ref='7320688582' />
<nd ref='7320688567' />
<nd ref='7320688583' />
<nd ref='7320723037' />
<nd ref='7320723015' />
<nd ref='7320722990' />
<nd ref='7320722992' />
<nd ref='7320723017' />
<nd ref='7320723016' />
<nd ref='7320723046' />
<nd ref='7320688576' />
<nd ref='7320723050' />
<nd ref='7320723000' />
<nd ref='7320723056' />
<nd ref='7320723027' />
<nd ref='5000274190' />
<nd ref='5000274191' />
<nd ref='7320722995' />
<nd ref='5000274193' />
<nd ref='7320723020' />
<nd ref='7320723071' />
<nd ref='7320688578' />
<nd ref='7320723082' />
<nd ref='7320723083' />
<nd ref='7320723057' />
<nd ref='7320688565' />
<nd ref='7320723079' />
<nd ref='7320688584' />
<nd ref='7320688580' />
<nd ref='7320723076' />
<nd ref='7320723072' />
<nd ref='7320723090' />
<nd ref='7320723049' />
<nd ref='7320723098' />
<nd ref='7320723003' />
<nd ref='7320723080' />
<nd ref='7320688571' />
<nd ref='7320688573' />
<nd ref='7320723005' />
<nd ref='7320723012' />
<nd ref='7320723009' />
<nd ref='7320723002' />
<nd ref='7320723008' />
<nd ref='7320723010' />
<nd ref='7320688566' />
<nd ref='7320688564' />
<nd ref='7320723084' />
<nd ref='7320723099' />
<nd ref='7320723097' />
<nd ref='7320722996' />
<nd ref='7320723068' />
<nd ref='7320723034' />
<nd ref='7320723038' />
<nd ref='7320723042' />
<nd ref='7320723019' />
<nd ref='7320722997' />
<nd ref='7320722985' />
<nd ref='7320688574' />
<nd ref='7320723048' />
<nd ref='7320723004' />
<nd ref='7320723062' />
<nd ref='7320723091' />
<nd ref='7320723039' />
<nd ref='7320723014' />
<nd ref='7320688581' />
<nd ref='7320723047' />
<nd ref='7320723075' />
<nd ref='7320723087' />
<nd ref='7320723094' />
<nd ref='7320723093' />
<nd ref='7320722988' />
<nd ref='7320723059' />
<nd ref='7320723101' />
<nd ref='7320688577' />
<nd ref='7320722989' />
<nd ref='7320723018' />
<nd ref='7320723058' />
<nd ref='7320723067' />
<nd ref='7320723060' />
<nd ref='7320723066' />
<nd ref='7320723052' />
<nd ref='7320723041' />
<nd ref='7320723065' />
<nd ref='7320723064' />
<nd ref='7320723077' />
<nd ref='7320723070' />
<nd ref='7320723022' />
<nd ref='7320723096' />
<nd ref='7320723095' />
<nd ref='7320723023' />
<nd ref='7320723063' />
<nd ref='7320723040' />
<nd ref='7320723088' />
<nd ref='7320723029' />
<nd ref='7320688569' />
<nd ref='7320723026' />
<nd ref='7320722991' />
<nd ref='9316228589' />
<nd ref='9316228588' />
<nd ref='9316228587' />
<nd ref='9316228586' />
<nd ref='7320722986' />
<nd ref='7320722987' />
<nd ref='7320723021' />
<nd ref='7320723073' />
<nd ref='7320688570' />
<nd ref='7320722998' />
<nd ref='7320723028' />
<nd ref='7320723007' />
<nd ref='7320723081' />
<nd ref='7320723078' />
<nd ref='7320723074' />
<nd ref='7320723011' />
<nd ref='7320723043' />
<nd ref='7320723061' />
<nd ref='7320722993' />
<nd ref='7296512120' />
<nd ref='7296512122' />
<nd ref='7296512121' />
<nd ref='7296512129' />
<nd ref='7296512133' />
<nd ref='7296512139' />
<nd ref='7296512132' />
<nd ref='7296512134' />
<nd ref='7296512128' />
<nd ref='7296512119' />
<nd ref='7296512138' />
<nd ref='7296512135' />
<nd ref='7296512125' />
<nd ref='7296512107' />
<nd ref='7296512116' />
<nd ref='7296512123' />
<nd ref='7296512143' />
<nd ref='7296507358' />
<nd ref='4788289295' />
<nd ref='384953329' />
<nd ref='727569195' />
<nd ref='384953331' />
<nd ref='4788289311' />
<nd ref='384953332' />
<nd ref='4862042008' />
<nd ref='4862042009' />
<nd ref='4862042007' />
<nd ref='4780063045' />
<nd ref='384953334' />
<nd ref='10253629013' />
<nd ref='10253629012' />
<nd ref='4524988031' />
<nd ref='10253629011' />
<nd ref='10253559000' />
<nd ref='5908876440' />
<nd ref='7589526131' />
<nd ref='7589526132' />
<nd ref='6449624748' />
<nd ref='727575929' />
<nd ref='727576880' />
<nd ref='727576911' />
<nd ref='5629424537' />
<nd ref='384953335' />
<nd ref='384953337' />
<nd ref='727570008' />
<nd ref='727570012' />
<nd ref='5941057447' />
<nd ref='5941057446' />
<nd ref='5941057445' />
<nd ref='5941057444' />
<nd ref='5941057442' />
<nd ref='5941057443' />
<nd ref='5941057441' />
<nd ref='4524988024' />
<nd ref='384953339' />
<nd ref='5984011625' />
<nd ref='5984011624' />
<nd ref='5984011623' />
<nd ref='5984011622' />
<nd ref='5984011621' />
<nd ref='9942355379' />
<nd ref='384953340' />
<nd ref='9942355378' />
<nd ref='9942355377' />
<nd ref='729896815' />
<nd ref='36292811' />
<nd ref='7121817725' />
<nd ref='384953342' />
<nd ref='9945279690' />
<nd ref='9945279689' />
<nd ref='727570035' />
<nd ref='7331870824' />
<nd ref='7331870857' />
<nd ref='7331870854' />
<nd ref='7331870856' />
<nd ref='7331870849' />
<nd ref='7331870829' />
<nd ref='7331870839' />
<nd ref='7331870838' />
<nd ref='7331870871' />
<nd ref='7331870858' />
<nd ref='7331870820' />
<nd ref='7331870873' />
<nd ref='7331870868' />
<nd ref='7331870863' />
<nd ref='7331895985' />
<nd ref='7331870870' />
<nd ref='7331870818' />
<nd ref='7331870844' />
<nd ref='7331870843' />
<nd ref='7331870831' />
<nd ref='7331870832' />
<nd ref='7331870862' />
<nd ref='7331870882' />
<nd ref='7331870884' />
<nd ref='7331870855' />
<nd ref='7331870852' />
<nd ref='7331870880' />
<nd ref='7331870883' />
<nd ref='7331870876' />
<nd ref='7331870821' />
<nd ref='7331870822' />
<nd ref='7331870817' />
<nd ref='7331870813' />
<nd ref='7331870853' />
<nd ref='7331870823' />
<nd ref='7331870834' />
<nd ref='7331870825' />
<nd ref='7589480570' />
<nd ref='7331870861' />
<nd ref='7331870837' />
<nd ref='7331870836' />
<nd ref='7331870848' />
<nd ref='7331870812' />
<nd ref='7331870850' />
<nd ref='7331870826' />
<nd ref='7331870819' />
<nd ref='7331870845' />
<nd ref='7331870828' />
<nd ref='7331870866' />
<nd ref='7331870827' />
<nd ref='7331870830' />
<nd ref='7580824945' />
<nd ref='7331870835' />
<nd ref='5159517404' />
<nd ref='10242646875' />
<nd ref='6109624546' />
<nd ref='6109624545' />
<nd ref='5833330957' />
<nd ref='5833330956' />
<nd ref='5833330955' />
<nd ref='5833330954' />
<nd ref='5833330953' />
<nd ref='5833330952' />
<nd ref='5833330951' />
<nd ref='10239952974' />
<nd ref='5833330958' />
<nd ref='5833330959' />
<nd ref='5833330961' />
<nd ref='5833330962' />
<nd ref='6746333690' />
<nd ref='9098954900' />
<nd ref='384953359' />
<nd ref='727570096' />
<nd ref='6048868808' />
<nd ref='384953362' />
<nd ref='384953364' />
<nd ref='384953365' />
<nd ref='1121958365' />
<nd ref='1121958362' />
<nd ref='384953366' />
<nd ref='384953367' />
<nd ref='1121958359' />
<nd ref='1121958357' />
<nd ref='384953369' />
<nd ref='7905471604' />
<nd ref='9739969181' />
<nd ref='384953371' />
<nd ref='7905471605' />
<nd ref='7905471606' />
<nd ref='7905471597' />
<nd ref='384953373' />
<nd ref='384953375' />
<nd ref='384953377' />
<nd ref='384953379' />
<nd ref='5095440367' />
<nd ref='5095440368' />
<nd ref='5095440369' />
<nd ref='384953381' />
<nd ref='2229437995' />
<nd ref='727570119' />
<nd ref='384953383' />
<nd ref='727570124' />
<nd ref='384953385' />
<nd ref='384953387' />
<nd ref='384953388' />
<nd ref='384953391' />
<nd ref='384953392' />
<nd ref='384953394' />
<nd ref='384953396' />
<nd ref='384953397' />
<nd ref='9270176980' />
<nd ref='5144677541' />
<nd ref='10750848750' />
<nd ref='10750848751' />
<nd ref='10750848752' />
<nd ref='10750848753' />
<nd ref='10750848754' />
<nd ref='10750848755' />
<nd ref='10750848756' />
<nd ref='10750848757' />
<nd ref='10750848758' />
<nd ref='10750848759' />
<nd ref='727570144' />
<nd ref='10750848776' />
<nd ref='10750848777' />
<nd ref='10750848778' />
<nd ref='10750848781' />
<nd ref='10750848780' />
<nd ref='10750848779' />
<nd ref='10750848785' />
<nd ref='10750848783' />
<nd ref='10750848782' />
<nd ref='10750848784' />
<nd ref='10750848801' />
<nd ref='10750848786' />
<nd ref='10750848789' />
<nd ref='10750848787' />
<nd ref='10750848788' />
<nd ref='10750848796' />
<nd ref='10750848790' />
<nd ref='10750848791' />
<nd ref='10750848793' />
<nd ref='10750848792' />
<nd ref='10750848799' />
<nd ref='10750848794' />
<nd ref='10750848795' />
</way>
<way id='788327982' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492'>
<nd ref='7370507196' />
<nd ref='7370507195' />
<nd ref='7370507194' />
<nd ref='7370507193' />
<tag k='fence_type' v='rope' />
<tag k='height' v='1' />
</way>
<way id='788328013' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492'>
<nd ref='7370510290' />
<nd ref='7370510287' />
<nd ref='7370510288' />
<nd ref='7370510289' />
<tag k='building' v='yes' />
</way>
<way id='788328014' timestamp='2020-04-06T03:07:52Z' uid='5443821' user='Thomas Jarvis' visible='true' version='1' changeset='83117492'>
<nd ref='7370510293' />
<nd ref='7370510292' />
<nd ref='7370510291' />
<tag k='fence_type' v='chain_link' />
<tag k='height' v='3' />
</way>
<way id='793625759' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='3' changeset='133899701'>
<nd ref='10748466930' />
<nd ref='7423464014' />
<nd ref='7423464013' />
<nd ref='7423464012' />
<nd ref='7423464011' />
<nd ref='7423464010' />
<nd ref='7423464009' />
<nd ref='7423464008' />
<nd ref='7423464007' />
<nd ref='2245310439' />
<nd ref='7423464006' />
<nd ref='7423464005' />
<tag k='bicycle' v='designated' />
<tag k='foot' v='designated' />
<tag k='highway' v='proposed' />
<tag k='lit' v='yes' />
<tag k='proposed' v='path' />
<tag k='segregated' v='no' />
<tag k='surface' v='asphalt' />
<tag k='width' v='3' />
</way>
<way id='793625762' timestamp='2021-03-16T16:32:56Z' uid='5443821' user='Thomas Jarvis' visible='true' version='4' changeset='101133298'>
<nd ref='1941154658' />
<nd ref='1941154659' />
<nd ref='1941154660' />
<nd ref='1941154661' />
<nd ref='1941154662' />
<nd ref='1941154663' />
<nd ref='1941154664' />
<nd ref='1941154666' />
<nd ref='1941154668' />
<nd ref='32197199' />
<tag k='designation' v='public_footpath' />
<tag k='proposed:bicycle' v='designated' />
<tag k='proposed:foot' v='designated' />
<tag k='proposed:highway' v='path' />
<tag k='proposed:lit' v='yes' />
<tag k='proposed:note' v='Due to be made into a lit shared cycleway / footway in 2020/2021. Listed in approved Highways Budget' />
<tag k='proposed:segregated' v='no' />
<tag k='prow_ref' v='35bCU' />
<tag k='width' v='2' />
</way>
<way id='842430897' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='1905996953' />
<nd ref='32197230' />
<nd ref='5126868640' />
<nd ref='32197195' />
<tag k='highway' v='secondary' />
<tag k='junction' v='roundabout' />
<tag k='lanes' v='1' />
<tag k='maxspeed' v='30 mph' />
<tag k='maxspeed:type' v='sign' />
<tag k='name' v='Commercial Square' />
<tag k='oneway' v='yes' />
</way>
<way id='842430898' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='1905996993' />
<nd ref='1905996988' />
</way>
<way id='885697612' timestamp='2021-01-02T21:48:26Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='3' changeset='96827459'>
<nd ref='8284982164' />
<nd ref='8235905417' />
<nd ref='8235869916' />
<nd ref='5639697441' />
<nd ref='8285037323' />
<nd ref='8284982165' />
<tag k='addr:city' v='Haywards Heath' />
<tag k='addr:street' v='Mill Green Road' />
<tag k='amenity' v='fire_station' />
<tag k='name' v='Haywards Heath Community Fire Station' />
</way>
<way id='891360567' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827214'>
<nd ref='4475878788' />
<nd ref='8285025018' />
<tag k='barrier' v='fence' />
</way>
<way id='891360568' timestamp='2021-01-02T21:37:49Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827214'>
<nd ref='4475878790' />
<nd ref='8285025017' />
<tag k='barrier' v='wall' />
</way>
<way id='891361909' timestamp='2022-09-12T10:28:05Z' uid='15223574' user='Newdice' visible='true' version='2' changeset='126082905'>
<nd ref='8284982162' />
<nd ref='8284982163' />
<nd ref='38904583' />
<tag k='highway' v='footway' />
</way>
<way id='891362301' timestamp='2021-01-02T21:48:26Z' uid='493595' user='Yorvik Prestigitator' visible='true' version='1' changeset='96827459'>
<nd ref='8285037321' />
<nd ref='8285037320' />
<nd ref='38904578' />
</way>
<way id='971002777' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190'>
<nd ref='8986589698' />
<nd ref='8986589699' />
</way>
<way id='971002782' timestamp='2021-08-06T19:55:52Z' uid='1485723' user='OrangeHurst97' visible='true' version='1' changeset='109282190'>
<tag k='highway' v='service' />
<tag k='service' v='parking_aisle' />
</way>
<way id='1095677939' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='2' changeset='133899701'>
<nd ref='10034296685' />
<nd ref='10034296684' />
<nd ref='10034296683' />
<nd ref='10034296682' />
<nd ref='10034296678' />
<nd ref='10034296656' />
<nd ref='10034296655' />
<nd ref='10034296654' />
</way>
<way id='1155768317' timestamp='2023-03-20T11:40:28Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133895069'>
<nd ref='10748269818' />
<nd ref='5012711786' />
<nd ref='10748269817' />
<tag k='access' v='destination' />
<tag k='hgv' v='no' />
</way>
<way id='1155793085' timestamp='2023-04-02T12:51:12Z' uid='616774' user='mueschel' visible='true' version='2' changeset='134412876'>
<nd ref='10748466950' />
<nd ref='1146946377' />
<nd ref='10748466929' />
<tag k='footway' v='crossing' />
<tag k='proposed' v='cycleway' />
</way>
<way id='1155793086' timestamp='2023-04-02T12:51:12Z' uid='616774' user='mueschel' visible='true' version='2' changeset='134412876'>
<nd ref='10748466932' />
</way>
<way id='1155793090' timestamp='2023-04-02T12:51:12Z' uid='616774' user='mueschel' visible='true' version='2' changeset='134412876'>
<nd ref='7423464018' />
<nd ref='10748466933' />
<nd ref='6169441196' />
<nd ref='6169441195' />
<nd ref='6169441194' />
<nd ref='10748466951' />
<nd ref='6169441193' />
<nd ref='7423464017' />
<nd ref='7423464016' />
<nd ref='10748466949' />
<tag k='footway' v='sidewalk' />
</way>
<way id='1155793091' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701'>
<nd ref='5379052912' />
<nd ref='10748466935' />
<nd ref='10748466934' />
<tag k='surface' v='paved' />
</way>
<way id='1155793097' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701'>
<nd ref='10748466955' />
<nd ref='1905997036' />
</way>
<way id='1155793098' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701'>
<nd ref='10748466977' />
<nd ref='7092049868' />
<nd ref='7092049869' />
<nd ref='10748482713' />
<nd ref='7092049870' />
<nd ref='10748482714' />
<nd ref='10748466997' />
<nd ref='10748466979' />
<nd ref='10748466996' />
<nd ref='10748466980' />
<nd ref='10748466968' />
<nd ref='10748466970' />
<nd ref='10748466969' />
<tag k='landuse' v='retail' />
</way>
<way id='1155793099' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701'>
<nd ref='10748466981' />
<nd ref='10748466982' />
<nd ref='10748466983' />
<nd ref='10748466984' />
<nd ref='10748466985' />
<nd ref='10748466986' />
<nd ref='10748466987' />
<nd ref='10748466995' />
<nd ref='10748482710' />
<nd ref='10748466958' />
<nd ref='10748466959' />
<nd ref='10748466960' />
<nd ref='10748466961' />
<nd ref='10748466957' />
<nd ref='10748466956' />
<nd ref='7092049867' />
<nd ref='10748466978' />
<nd ref='10748466976' />
<nd ref='10748466975' />
<nd ref='10748466974' />
<nd ref='10748466973' />
<tag k='landuse' v='commercial' />
</way>
<way id='1155793100' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701'>
<nd ref='10748482715' />
<nd ref='10748482716' />
<nd ref='10748482717' />
<nd ref='10748482718' />
<nd ref='4725832493' />
<nd ref='10748482705' />
<nd ref='10748482706' />
<nd ref='10748467004' />
<nd ref='10748467003' />
<nd ref='10748467002' />
<nd ref='10748467001' />
<nd ref='10748482707' />
<nd ref='10748466999' />
<nd ref='10748467000' />
<nd ref='10748466998' />
</way>
<way id='1155793101' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701'>
<nd ref='34696068' />
<nd ref='10748466989' />
<nd ref='5912511777' />
<tag k='highway' v='tertiary' />
<tag k='name' v='Mill Green Road' />
</way>
<way id='1155793104' timestamp='2023-03-20T13:35:27Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133899701'>
<nd ref='10748482742' />
<nd ref='38904585' />
<nd ref='38904587' />
</way>
<way id='1155996045' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731'>
<nd ref='10748269833' />
<nd ref='4957974175' />
<nd ref='10748269860' />
<nd ref='10748269859' />
<nd ref='5012711782' />
<nd ref='10748269796' />
<nd ref='10748269794' />
<nd ref='10748269795' />
<nd ref='10748269797' />
<nd ref='10750379353' />
<nd ref='10750379352' />
<nd ref='10750379351' />
<nd ref='10750379350' />
<nd ref='10750379349' />
<tag k='landuse' v='residential' />
</way>
<way id='1155996046' timestamp='2023-03-21T09:58:54Z' uid='577089' user='JodaStephen' visible='true' version='1' changeset='133932731'>
<nd ref='10748269798' />
<nd ref='10748269793' />
<nd ref='10748269792' />
<nd ref='10748269791' />
<nd ref='4957974176' />
<nd ref='10748269855' />
<nd ref='5012711783' />
<nd ref='4957974177' />
<nd ref='10748269815' />
<nd ref='10748269813' />
<nd ref='10748269812' />
<nd ref='10748269814' />
<nd ref='10748269811' />
<nd ref='7323148275' />
<nd ref='7323148282' />
<nd ref='7323148284' />
<nd ref='4957974178' />
<nd ref='10748269854' />
<nd ref='10750379371' />
<nd ref='10748269853' />
<nd ref='10748269852' />
<nd ref='10748366440' />
<nd ref='5815932323' />
<nd ref='5815932324' />
<nd ref='5815932327' />
<nd ref='5815932328' />
<nd ref='5815932330' />
<nd ref='10748269850' />
<nd ref='3398845309' />
<nd ref='5815932331' />
<nd ref='5815932332' />
<nd ref='10748269849' />
<nd ref='10748269848' />
<nd ref='5815932333' />
<nd ref='5815932334' />
<nd ref='5815932335' />
<nd ref='5815932336' />
<nd ref='5815932337' />
<nd ref='10750379370' />
<nd ref='10750379369' />
<nd ref='10750379368' />
<nd ref='10750379367' />
<nd ref='10748269974' />
<nd ref='7323150606' />
<nd ref='7323150608' />
<nd ref='10748269973' />
<nd ref='7323148278' />
<nd ref='10748269972' />
<nd ref='7323148274' />
<nd ref='10748269970' />
<nd ref='10748269971' />
<nd ref='7323150588' />
<nd ref='10748270057' />
<nd ref='10748270058' />
<nd ref='10750379366' />
<nd ref='10750379365' />
<nd ref='10750379364' />
<nd ref='10750379363' />
<nd ref='10750379362' />
<nd ref='10750379361' />
<nd ref='10750379360' />
<nd ref='10750379359' />
<nd ref='10750379358' />
<nd ref='10748482719' />
<nd ref='5805163515' />
<nd ref='5805163514' />
<nd ref='4725832496' />
<nd ref='10748482712' />
<nd ref='10748466964' />
<nd ref='10750379357' />
<nd ref='7092049865' />
<nd ref='7295760713' />
<nd ref='10748466965' />
<nd ref='10748466966' />
<nd ref='10750379356' />
<nd ref='7295760667' />
<nd ref='10750379355' />
<nd ref='10750379354' />
</way>
<relation id='330284' timestamp='2020-08-30T16:42:32Z' uid='3381552' user='tubbai11' visible='true' version='3' changeset='90150546'>
<member type='node' ref='565764715' role='platform' />
<member type='node' ref='565764716' role='platform' />
<tag k='name' v='Perrymount Road' />
<tag k='naptan:StopAreaCode' v='440GEG0050' />
<tag k='naptan:StopAreaType' v='GPBS' />
<tag k='naptan:verified' v='no' />
<tag k='public_transport' v='stop_area' />
<tag k='public_transport:version' v='2' />
<tag k='source' v='naptan_import' />
<tag k='type' v='public_transport' />
</relation>
<relation id='7006002' timestamp='2023-06-01T18:48:08Z' uid='10703654' user='Aaro Hart' visible='true' version='124' changeset='136842960'>
<member type='node' ref='565765059' role='platform_entry_only' />
<member type='node' ref='565764986' role='platform' />
<member type='node' ref='565765502' role='platform' />
<member type='node' ref='565764973' role='platform' />
<member type='node' ref='565764969' role='platform' />
<member type='node' ref='565764852' role='platform' />
<member type='node' ref='565765508' role='platform' />
<member type='node' ref='565764839' role='platform' />
<member type='node' ref='565764836' role='platform' />
<member type='node' ref='565764834' role='platform' />
<member type='node' ref='565764833' role='platform' />
<member type='node' ref='565764830' role='platform' />
<member type='node' ref='4701838878' role='platform' />
<member type='node' ref='4701838875' role='platform' />
<member type='node' ref='671062602' role='platform' />
<member type='node' ref='4701838873' role='platform' />
<member type='node' ref='4701838871' role='platform' />
<member type='node' ref='4701838870' role='platform' />
<member type='node' ref='4701838869' role='platform' />
<member type='node' ref='4701838865' role='platform' />
<member type='node' ref='4701838863' role='platform' />
<member type='node' ref='2818833724' role='platform' />
<member type='node' ref='565764675' role='platform' />
<member type='node' ref='565764676' role='platform' />
<member type='node' ref='7859074322' role='platform' />
<member type='node' ref='565764674' role='platform' />
<member type='node' ref='565764672' role='platform' />
<member type='node' ref='565764806' role='platform' />
<member type='node' ref='565764707' role='platform' />
<member type='node' ref='565764706' role='platform' />
<member type='node' ref='565764704' role='platform' />
<member type='node' ref='565764747' role='platform' />
<member type='node' ref='565764703' role='platform' />
<member type='node' ref='565764753' role='platform' />
<member type='node' ref='565765525' role='platform' />
<member type='node' ref='565764756' role='platform' />
<member type='node' ref='565764678' role='platform' />
<member type='node' ref='565765529' role='platform' />
<member type='node' ref='565764682' role='platform' />
<member type='node' ref='6635493121' role='platform' />
<member type='node' ref='565768646' role='platform' />
<member type='node' ref='565768644' role='platform' />
<member type='node' ref='565768642' role='platform' />
<member type='node' ref='7570072952' role='platform' />
<member type='node' ref='565768629' role='platform' />
<member type='node' ref='565768627' role='platform' />
<member type='node' ref='565768737' role='platform' />
<member type='node' ref='565768604' role='platform' />
<member type='node' ref='565768605' role='platform' />
<member type='node' ref='565768607' role='platform' />
<member type='node' ref='565768609' role='platform' />
<member type='node' ref='565768865' role='platform' />
<member type='node' ref='565768751' role='platform' />
<member type='node' ref='565768748' role='platform' />
<member type='node' ref='4701838860' role='platform' />
<member type='node' ref='565768918' role='platform' />
<member type='node' ref='565768811' role='platform' />
<member type='node' ref='565768809' role='platform' />
<member type='node' ref='565768808' role='platform' />
<member type='node' ref='565768874' role='platform' />
<member type='node' ref='565768803' role='platform' />
<member type='node' ref='1628364419' role='platform' />
<member type='node' ref='6188233309' role='platform' />
<member type='node' ref='1629672050' role='platform' />
<member type='node' ref='6071095400' role='platform' />
<member type='node' ref='200658915' role='platform' />
<member type='node' ref='6187930326' role='platform' />
<member type='node' ref='6187930327' role='platform' />
<member type='node' ref='6187930328' role='platform' />
<member type='node' ref='6187930329' role='platform' />
<member type='node' ref='6187460318' role='platform' />
<member type='node' ref='6187460317' role='platform' />
<member type='node' ref='447319725' role='platform' />
<member type='node' ref='892734268' role='platform' />
<member type='node' ref='6187460316' role='platform' />
<member type='node' ref='2282613949' role='platform' />
<member type='node' ref='2282613951' role='platform' />
<member type='node' ref='4735268236' role='platform' />
<member type='node' ref='4735268237' role='platform' />
<member type='node' ref='6757297464' role='stop' />
<member type='node' ref='2479360885' role='platform' />
<member type='node' ref='2497173679' role='platform_exit_only' />
<member type='way' ref='842430906' role='' />
<member type='way' ref='499496457' role='' />
<member type='way' ref='4575974' role='' />
<member type='way' ref='244436866' role='' />
<member type='way' ref='751253896' role='' />
<member type='way' ref='499496455' role='' />
<member type='way' ref='26628768' role='' />
<member type='way' ref='684568356' role='' />
<member type='way' ref='179276380' role='' />
<member type='way' ref='26628773' role='' />
<member type='way' ref='159475695' role='' />
<member type='way' ref='201658303' role='' />
<member type='way' ref='643213376' role='' />
<member type='way' ref='643219890' role='' />
<member type='way' ref='159475700' role='' />
<member type='way' ref='279400227' role='' />
<member type='way' ref='159475690' role='' />
<member type='way' ref='840957764' role='' />
<member type='way' ref='840817545' role='' />
<member type='way' ref='61689729' role='' />
<member type='way' ref='840957761' role='' />
<member type='way' ref='840957760' role='' />
<member type='way' ref='840957762' role='' />
<member type='way' ref='61689728' role='' />
<member type='way' ref='643216096' role='' />
<member type='way' ref='197425665' role='' />
<member type='way' ref='1092931517' role='' />
<member type='way' ref='499064442' role='' />
<member type='way' ref='197425664' role='' />
<member type='way' ref='182026413' role='' />
<member type='way' ref='639382396' role='' />
<member type='way' ref='1092933399' role='' />
<member type='way' ref='476686242' role='' />
<member type='way' ref='1009617582' role='' />
<member type='way' ref='26993401' role='' />
<member type='way' ref='476686244' role='' />
<member type='way' ref='171697857' role='' />
<member type='way' ref='171697859' role='' />
<member type='way' ref='135158061' role='' />
<member type='way' ref='171697860' role='' />
<member type='way' ref='677620656' role='' />
<member type='way' ref='677620655' role='' />
<member type='way' ref='98106565' role='' />
<member type='way' ref='98106566' role='' />
<member type='way' ref='4118977' role='' />
<member type='way' ref='1104643672' role='' />
<member type='way' ref='44936094' role='' />
<member type='way' ref='135158060' role='' />
<member type='way' ref='182835693' role='' />
<member type='way' ref='171697854' role='' />
<member type='way' ref='171700928' role='' />
<member type='way' ref='171700927' role='' />
<member type='way' ref='1102573477' role='' />
<member type='way' ref='1102573475' role='' />
<member type='way' ref='476686245' role='' />
<member type='way' ref='476686246' role='' />
<member type='way' ref='106624549' role='' />
<member type='way' ref='1074451695' role='' />
<member type='way' ref='1050620869' role='' />
<member type='way' ref='31529757' role='' />
<member type='way' ref='842430905' role='' />
<member type='way' ref='255726158' role='' />
<member type='way' ref='842430873' role='' />
<member type='way' ref='279303796' role='' />
<member type='way' ref='106624537' role='' />
<member type='way' ref='24271124' role='' />
<member type='way' ref='443455557' role='' />
<member type='way' ref='443455558' role='' />
<member type='way' ref='9929944' role='' />
<member type='way' ref='209171344' role='' />
<member type='way' ref='209171345' role='' />
<member type='way' ref='842430904' role='' />
<member type='way' ref='9929943' role='' />
<member type='way' ref='648230058' role='' />
<member type='way' ref='648230057' role='' />
<member type='way' ref='489672013' role='' />
<member type='way' ref='23414093' role='' />
<member type='way' ref='978395983' role='' />
<member type='way' ref='9929946' role='' />
<member type='way' ref='842430903' role='' />
<member type='way' ref='5131223' role='' />
<member type='way' ref='374074749' role='' />
<member type='way' ref='374074747' role='' />
<member type='way' ref='640979785' role='' />
<member type='way' ref='640979786' role='' />
<member type='way' ref='5131221' role='' />
<member type='way' ref='5131220' role='' />
<member type='way' ref='4776888' role='' />
<member type='way' ref='775139572' role='' />
<member type='way' ref='775139571' role='' />
<member type='way' ref='793659802' role='' />
<member type='way' ref='636843850' role='' />
<member type='way' ref='213205533' role='' />
<member type='way' ref='213205532' role='' />
<member type='way' ref='5089654' role='' />
<member type='way' ref='775217956' role='' />
<member type='way' ref='5047542' role='' />
<member type='way' ref='479382005' role='' />
<member type='way' ref='613545984' role='' />
<member type='way' ref='1030399781' role='' />
<member type='way' ref='4680734' role='' />
<member type='way' ref='613545976' role='' />
<member type='way' ref='4916875' role='' />
<member type='way' ref='759263714' role='' />
<member type='way' ref='842430897' role='' />
<member type='way' ref='479287543' role='' />
<member type='way' ref='9336793' role='' />
<member type='way' ref='479315601' role='' />
<member type='way' ref='5089207' role='' />
<member type='way' ref='95516510' role='' />
<member type='way' ref='479315605' role='' />
<member type='way' ref='675640362' role='' />
<member type='way' ref='675644690' role='' />
<member type='way' ref='479320596' role='' />
<member type='way' ref='4916890' role='' />
<member type='way' ref='4680737' role='' />
<member type='way' ref='479320607' role='' />
<member type='way' ref='95799176' role='' />
<member type='way' ref='6282394' role='' />
<member type='way' ref='631289973' role='' />
<member type='way' ref='6282392' role='' />
<member type='way' ref='842895304' role='' />
<member type='way' ref='631289972' role='' />
<member type='way' ref='478162377' role='' />
<member type='way' ref='5047450' role='' />
<member type='way' ref='296063939' role='' />
<member type='way' ref='127971368' role='' />
<member type='way' ref='127971371' role='' />
<member type='way' ref='842895305' role='' />
<member type='way' ref='842716417' role='' />
<member type='way' ref='842716416' role='' />
<member type='way' ref='296063945' role='' />
<member type='way' ref='296063935' role='' />
<member type='way' ref='477345278' role='' />
<member type='way' ref='297177673' role='' />
<member type='way' ref='477345279' role='' />
<member type='way' ref='297177675' role='' />
<member type='way' ref='448730092' role='' />
<member type='way' ref='297177671' role='' />
<member type='way' ref='297177677' role='' />
<member type='way' ref='506043351' role='' />
<member type='way' ref='842430884' role='' />
<member type='way' ref='506043355' role='' />
<member type='way' ref='346028750' role='' />
<member type='way' ref='644864683' role='' />
<member type='way' ref='644864687' role='' />
<member type='way' ref='804291789' role='' />
<member type='way' ref='804291785' role='' />
<member type='way' ref='804291784' role='' />
<member type='way' ref='874772757' role='' />
<member type='way' ref='5060590' role='' />
<member type='way' ref='874772756' role='' />
<member type='way' ref='842716414' role='' />
<member type='way' ref='675059111' role='' />
<member type='way' ref='374085778' role='' />
<member type='way' ref='374085779' role='' />
<member type='way' ref='9411997' role='' />
<member type='way' ref='4784578' role='' />
<member type='way' ref='842430883' role='' />
<member type='way' ref='1131903059' role='' />
<member type='way' ref='842430882' role='' />
<member type='way' ref='4776492' role='' />
<member type='way' ref='4784554' role='' />
<member type='way' ref='4784555' role='' />
<member type='way' ref='4784553' role='' />
<member type='way' ref='910597068' role='' />
<member type='way' ref='4784557' role='' />
<member type='way' ref='910989908' role='' />
<member type='way' ref='4784571' role='' />
<member type='way' ref='777261535' role='' />
<member type='way' ref='777261536' role='' />
<member type='way' ref='777261532' role='' />
<member type='way' ref='4776510' role='' />
<member type='way' ref='842430874' role='' />
<member type='way' ref='4776506' role='' />
<member type='way' ref='1059594178' role='' />
<member type='way' ref='777261537' role='' />
<member type='way' ref='18090729' role='' />
<member type='way' ref='3709359' role='' />
<member type='way' ref='793706417' role='' />
<member type='way' ref='698327390' role='' />
<member type='way' ref='764591095' role='' />
<member type='way' ref='39932725' role='' />
<member type='way' ref='793706420' role='' />
<member type='way' ref='793706419' role='' />
<member type='way' ref='743406338' role='' />
<member type='way' ref='743406337' role='' />
<member type='way' ref='166151125' role='' />
<member type='way' ref='793706422' role='' />
<member type='way' ref='793706423' role='' />
<member type='way' ref='940709995' role='' />
<member type='way' ref='529442365' role='' />
<member type='way' ref='114290704' role='' />
<member type='way' ref='793706424' role='' />
<member type='way' ref='529442364' role='' />
<member type='way' ref='246311085' role='' />
<member type='way' ref='246311088' role='' />
<member type='way' ref='4661403' role='' />
<member type='way' ref='23097194' role='' />
<member type='way' ref='23097193' role='' />
<member type='way' ref='369541096' role='' />
<member type='way' ref='198590665' role='' />
<member type='way' ref='102148392' role='' />
<member type='way' ref='842430880' role='' />
<member type='way' ref='111678384' role='' />
<member type='way' ref='111678429' role='' />
<member type='way' ref='638278563' role='' />
<member type='way' ref='938406534' role='' />
<member type='way' ref='938406533' role='' />
<member type='way' ref='476690174' role='' />
<member type='way' ref='131766099' role='' />
<member type='way' ref='348388472' role='' />
<member type='way' ref='345949119' role='' />
<member type='way' ref='348388464' role='' />
<member type='way' ref='151069892' role='' />
<member type='way' ref='40167179' role='' />
<member type='way' ref='988007597' role='' />
<member type='way' ref='988007596' role='' />
<member type='way' ref='988007595' role='' />
<member type='way' ref='111685130' role='' />
<member type='way' ref='793744332' role='' />
<member type='way' ref='988007599' role='' />
<member type='way' ref='812960028' role='' />
<member type='way' ref='24186090' role='' />
<member type='way' ref='150128380' role='' />
<member type='way' ref='25198541' role='' />
<member type='way' ref='239581073' role='' />
<member type='way' ref='812960026' role='' />
<member type='way' ref='812960024' role='' />
<member type='way' ref='987792641' role='' />
<member type='way' ref='812960022' role='' />
<member type='way' ref='155578216' role='' />
<member type='way' ref='987792647' role='' />
<member type='way' ref='987792648' role='' />
<member type='way' ref='812960019' role='' />
<member type='way' ref='987792650' role='' />
<member type='way' ref='812960018' role='' />
<member type='way' ref='812960017' role='' />
<member type='way' ref='812960013' role='' />
<member type='way' ref='987515471' role='' />
<member type='way' ref='812960014' role='' />
<member type='way' ref='987515473' role='' />
<member type='way' ref='987515472' role='' />
<member type='way' ref='651714195' role='' />
<member type='way' ref='812960010' role='' />
<member type='way' ref='191506007' role='' />
<member type='way' ref='155578217' role='' />
<member type='way' ref='4040718' role='' />
<member type='way' ref='987515476' role='' />
<member type='way' ref='722556913' role='' />
<member type='way' ref='4040927' role='' />
<member type='way' ref='722879129' role='' />
<member type='way' ref='793744331' role='' />
<member type='way' ref='719574503' role='' />
<member type='way' ref='726087465' role='' />
<member type='way' ref='1178166665' role='' />
<member type='way' ref='719549073' role='' />
<member type='way' ref='728069487' role='' />
<member type='way' ref='947460456' role='' />
<member type='way' ref='480534858' role='' />
<member type='way' ref='366113358' role='' />
<member type='way' ref='986987776' role='' />
<member type='way' ref='191506003' role='' />
<member type='way' ref='837437375' role='' />
<member type='way' ref='813465994' role='' />
<member type='way' ref='137403283' role='' />
<member type='way' ref='723788014' role='' />
<member type='way' ref='137403090' role='' />
<member type='way' ref='188584709' role='' />
<member type='way' ref='723821019' role='' />
<member type='way' ref='137403094' role='' />
<member type='way' ref='719598322' role='' />
<member type='way' ref='3995559' role='' />
<member type='way' ref='721310903' role='' />
<member type='way' ref='986987780' role='' />
<member type='way' ref='894677439' role='' />
<member type='way' ref='719574499' role='' />
<member type='way' ref='480534859' role='' />
<member type='way' ref='3819112' role='' />
<member type='way' ref='358118596' role='' />
<member type='way' ref='137831853' role='' />
<member type='way' ref='843923123' role='' />
<member type='way' ref='3819093' role='' />
<member type='way' ref='239984355' role='' />
<member type='way' ref='986987786' role='' />
<member type='way' ref='3819094' role='' />
<member type='way' ref='1059195954' role='' />
<member type='way' ref='964335847' role='' />
<member type='way' ref='330714673' role='' />
<member type='way' ref='330714667' role='' />
<member type='way' ref='330714671' role='' />
<member type='way' ref='330715465' role='' />
<member type='way' ref='330715464' role='' />
<member type='way' ref='286274183' role='' />
<member type='way' ref='3819092' role='' />
<member type='way' ref='74172229' role='' />
<member type='way' ref='895100615' role='' />
<member type='way' ref='165293659' role='' />
<tag k='from' v='East Grinstead Station' />
<tag k='name' v='270 East Grinstead ��� Brighton' />
<tag k='network' v='West Sussex' />
<tag k='note' v='Intricate relation - do not auto-sort' />
<tag k='operator' v='Metrobus' />
<tag k='ref' v='270' />
<tag k='route' v='bus' />
<tag k='to' v='Imperial Arcade' />
<tag k='type' v='route' />
</relation>
<relation id='7051050' timestamp='2018-12-20T15:49:32Z' uid='5443821' user='Thomas Jarvis' visible='true' version='2' changeset='65644321'>
<member type='way' ref='479287543' role='from' />
<member type='way' ref='185605910' role='to' />
<tag k='restriction' v='no_left_turn' />
<tag k='type' v='restriction' />
</relation>
<relation id='8286996' timestamp='2021-08-24T19:54:50Z' uid='242345' user='confusedbuffalo' visible='true' version='3' changeset='110191479'>
<member type='way' ref='97948089' role='outer' />
<member type='way' ref='587183993' role='inner' />
<tag k='addr:housename' v='Clair Hall' />
<tag k='addr:postcode' v='RH16 3DN' />
<tag k='addr:street' v='Perrymount Road' />
<tag k='type' v='multipolygon' />
</relation>
<relation id='8786190' timestamp='2022-12-22T12:21:08Z' uid='577089' user='JodaStephen' visible='true' version='22' changeset='130373423'>
<member type='way' ref='641341989' role='' />
<member type='way' ref='675640363' role='' />
<member type='way' ref='5089206' role='' />
<member type='way' ref='4916876' role='' />
<member type='way' ref='626271439' role='' />
<member type='way' ref='613545982' role='' />
<member type='way' ref='613545978' role='' />
<member type='way' ref='613545980' role='' />
<member type='way' ref='4776758' role='' />
<member type='way' ref='1044788148' role='' />
<member type='way' ref='160536519' role='' />
<member type='way' ref='160536520' role='' />
<member type='way' ref='417954100' role='' />
<member type='way' ref='4776756' role='' />
<member type='way' ref='180702401' role='' />
<member type='way' ref='4776757' role='' />
<member type='way' ref='417954101' role='' />
<member type='way' ref='180702395' role='' />
<member type='way' ref='24792973' role='' />
<member type='way' ref='305514624' role='' />
<member type='way' ref='22792101' role='' />
<member type='way' ref='639396376' role='' />
<member type='way' ref='4661174' role='' />
<member type='way' ref='4776736' role='' />
<member type='way' ref='892271997' role='' />
<member type='way' ref='892271998' role='' />
<member type='way' ref='408911445' role='' />
<member type='way' ref='170153116' role='' />
<member type='way' ref='170153117' role='' />
<member type='way' ref='842895303' role='' />
<member type='way' ref='810838540' role='' />
<member type='way' ref='181594061' role='' />
<member type='way' ref='1124142165' role='' />
<member type='way' ref='1124142164' role='' />
<member type='way' ref='408911442' role='' />
<member type='way' ref='886024655' role='' />
<member type='way' ref='24912287' role='' />
<member type='way' ref='181619410' role='' />
<member type='way' ref='181619413' role='' />
<member type='way' ref='4661182' role='' />
<member type='way' ref='844391823' role='' />
<member type='way' ref='170370662' role='' />
<member type='way' ref='273529638' role='' />
<member type='way' ref='170370656' role='' />
<member type='way' ref='170370660' role='' />
<member type='way' ref='24912289' role='' />
<member type='way' ref='181619412' role='' />
<member type='way' ref='24912288' role='' />
<member type='way' ref='273529640' role='' />
<member type='way' ref='273529628' role='' />
<member type='way' ref='34198861' role='' />
<member type='way' ref='844391822' role='' />
<member type='way' ref='4661183' role='' />
<member type='way' ref='886020115' role='' />
<member type='way' ref='24912286' role='' />
<member type='way' ref='886024654' role='' />
<member type='way' ref='34198864' role='' />
<member type='way' ref='886020116' role='' />
<member type='way' ref='231271180' role='' />
<member type='way' ref='231271182' role='' />
<member type='way' ref='26167961' role='' />
<member type='way' ref='499061881' role='' />
<member type='way' ref='273529633' role='' />
<member type='way' ref='499065735' role='' />
<member type='way' ref='4118688' role='' />
<member type='way' ref='220027104' role='' />
<member type='way' ref='886339994' role='' />
<member type='way' ref='220027494' role='' />
<member type='way' ref='220027254' role='' />
<member type='way' ref='4661539' role='' />
<member type='way' ref='41589481' role='' />
<member type='way' ref='26167962' role='' />
<member type='way' ref='643214805' role='' />
<member type='way' ref='23978044' role='' />
<member type='way' ref='138715910' role='' />
<member type='way' ref='181446670' role='' />
<member type='way' ref='885309203' role='' />
<member type='way' ref='26166565' role='' />
<member type='way' ref='258132965' role='' />
<member type='way' ref='284598210' role='' />
<member type='way' ref='639138723' role='' />
<member type='way' ref='639138722' role='' />
<member type='way' ref='39504463' role='' />
<member type='way' ref='207779523' role='' />
<member type='way' ref='207779525' role='' />
<member type='way' ref='103966709' role='' />
<member type='way' ref='103966708' role='' />
<member type='way' ref='639138725' role='' />
<member type='way' ref='23994578' role='' />
<member type='way' ref='181439679' role='' />
<member type='way' ref='39504279' role='' />
<member type='way' ref='184255902' role='' />
<member type='way' ref='284598212' role='' />
<member type='way' ref='184255901' role='' />
<member type='way' ref='293403366' role='' />
<member type='way' ref='293403367' role='' />
<tag k='name' v='B2028 Road (Great Britain)' />
<tag k='ref' v='B2028' />
<tag k='route' v='road' />
</relation>
<relation id='9415292' timestamp='2023-06-01T18:16:49Z' uid='15542580' user='DavidInglesfield' visible='true' version='37' changeset='136841933'>
<member type='way' ref='784816393' role='outer' />
<member type='way' ref='1120877223' role='outer' />
<member type='way' ref='1120877221' role='outer' />
<member type='way' ref='785737219' role='outer' />
<member type='way' ref='1120877222' role='outer' />
<member type='way' ref='1120877220' role='outer' />
<member type='way' ref='783769332' role='inner' />
<member type='way' ref='783961698' role='inner' />
<member type='way' ref='783964077' role='inner' />
<member type='way' ref='784793416' role='inner' />
<member type='way' ref='784798971' role='inner' />
<member type='way' ref='784801325' role='inner' />
<member type='way' ref='784802441' role='inner' />
<member type='way' ref='785736142' role='inner' />
<member type='way' ref='785736141' role='inner' />
<member type='way' ref='785736187' role='inner' />
<tag k='source' v='Local knowledge' />
</relation>
<relation id='11561226' timestamp='2023-01-14T06:03:48Z' uid='10221076' user='MrJeeves' visible='true' version='37' changeset='131252909'>
<member type='node' ref='4013090729' role='platform_entry_only' />
<member type='node' ref='6769233047' role='platform' />
<member type='node' ref='1831966818' role='platform' />
<member type='node' ref='2282613948' role='platform' />
<member type='node' ref='2282613950' role='platform' />
<member type='node' ref='6757422138' role='platform' />
<member type='node' ref='6769079857' role='platform' />
<member type='node' ref='2282613947' role='platform' />
<member type='node' ref='6769079858' role='platform' />
<member type='node' ref='6423294285' role='platform' />
<member type='node' ref='6757422139' role='platform' />
<member type='node' ref='6375785189' role='platform' />
<member type='node' ref='6375783184' role='platform' />
<member type='node' ref='207108802' role='platform' />
<member type='node' ref='207108722' role='platform' />
<member type='node' ref='6178946497' role='platform' />
<member type='node' ref='6372251530' role='platform' />
<member type='node' ref='1629672078' role='platform' />
<member type='node' ref='1628364361' role='platform' />
<member type='node' ref='565768806' role='platform' />
<member type='node' ref='565768875' role='platform' />
<member type='node' ref='565768807' role='platform' />
<member type='node' ref='565768810' role='platform' />
<member type='node' ref='565768812' role='platform' />
<member type='node' ref='565768919' role='platform' />
<member type='node' ref='565768747' role='platform' />
<member type='node' ref='565768749' role='platform' />
<member type='node' ref='565768750' role='platform' />
<member type='node' ref='565768866' role='platform' />
<member type='node' ref='565768610' role='platform' />
<member type='node' ref='565768608' role='platform' />
<member type='node' ref='565768606' role='platform' />
<member type='node' ref='7570072949' role='platform' />
<member type='node' ref='565768628' role='platform' />
<member type='node' ref='7612553628' role='platform' />
<member type='node' ref='565768630' role='platform' />
<member type='node' ref='565768643' role='platform' />
<member type='node' ref='565768645' role='platform' />
<member type='node' ref='4701838861' role='platform' />
<member type='node' ref='6635493122' role='platform' />
<member type='node' ref='565764683' role='platform' />
<member type='node' ref='565765530' role='platform' />
<member type='node' ref='565764757' role='platform' />
<member type='node' ref='565765524' role='platform' />
<member type='node' ref='565764754' role='platform' />
<member type='node' ref='565764750' role='platform' />
<member type='node' ref='565764749' role='platform' />
<member type='node' ref='565764748' role='platform' />
<member type='node' ref='565764705' role='platform' />
<member type='node' ref='565765307' role='platform' />
<member type='node' ref='565764708' role='platform' />
<member type='node' ref='565764807' role='platform' />
<member type='node' ref='565764671' role='platform' />
<member type='node' ref='565764673' role='platform' />
<member type='node' ref='4541750733' role='platform' />
<member type='node' ref='4701838862' role='platform' />
<member type='node' ref='4701838864' role='platform' />
<member type='node' ref='4701838866' role='platform' />
<member type='node' ref='4701838867' role='platform' />
<member type='node' ref='4701838872' role='platform' />
<member type='node' ref='4701838874' role='platform' />
<member type='node' ref='671062603' role='platform' />
<member type='node' ref='4701838876' role='platform' />
<member type='node' ref='4701838877' role='platform' />
<member type='node' ref='565764831' role='platform' />
<member type='node' ref='565764832' role='platform' />
<member type='node' ref='565764835' role='platform' />
<member type='node' ref='565764837' role='platform' />
<member type='node' ref='565764838' role='platform' />
<member type='node' ref='565764840' role='platform' />
<member type='node' ref='565764961' role='platform' />
<member type='node' ref='565764965' role='platform' />
<member type='node' ref='565764978' role='platform' />
<member type='node' ref='565765315' role='platform' />
<member type='node' ref='565765144' role='platform' />
<member type='node' ref='565765059' role='platform_exit_only' />
<member type='way' ref='960935109' role='' />
<member type='way' ref='954035172' role='' />
<member type='way' ref='954241918' role='' />
<member type='way' ref='3807763' role='' />
<member type='way' ref='843923122' role='' />
<member type='way' ref='964331211' role='' />
<member type='way' ref='986987784' role='' />
<member type='way' ref='3995557' role='' />
<member type='way' ref='986987785' role='' />
<member type='way' ref='165441577' role='' />
<member type='way' ref='4378508' role='' />
<member type='way' ref='137403281' role='' />
<member type='way' ref='137403098' role='' />
<member type='way' ref='638278559' role='' />
<member type='way' ref='719574502' role='' />
<member type='way' ref='793744330' role='' />
<member type='way' ref='25198544' role='' />
<member type='way' ref='188317529' role='' />
<member type='way' ref='812960012' role='' />
<member type='way' ref='812960016' role='' />
<member type='way' ref='812960011' role='' />
<member type='way' ref='812960023' role='' />
<member type='way' ref='812960025' role='' />
<member type='way' ref='326076814' role='' />
<member type='way' ref='988007593' role='' />
<member type='way' ref='842430879' role='' />
<member type='way' ref='3663033' role='' />
<member type='way' ref='40167180' role='' />
<member type='way' ref='793744333' role='' />
<member type='way' ref='131766103' role='' />
<member type='way' ref='988007550' role='' />
<member type='way' ref='5052062' role='' />
<member type='way' ref='39629194' role='' />
<member type='way' ref='39629189' role='' />
<member type='way' ref='988007549' role='' />
<member type='way' ref='688163991' role='' />
<member type='way' ref='793706426' role='' />
<member type='way' ref='4661402' role='' />
<member type='way' ref='793706421' role='' />
<member type='way' ref='39932726' role='' />
<member type='way' ref='764591093' role='' />
<member type='way' ref='764591094' role='' />
<member type='way' ref='4661405' role='' />
<member type='way' ref='764591092' role='' />
<member type='way' ref='764591090' role='' />
<member type='way' ref='39932723' role='' />
<member type='way' ref='777261538' role='' />
<member type='way' ref='1113159477' role='' />
<member type='way' ref='4776490' role='' />
<member type='way' ref='1131903060' role='' />
<member type='way' ref='4784543' role='' />
<member type='way' ref='777342318' role='' />
<member type='way' ref='4776493' role='' />
<member type='way' ref='506043356' role='' />
<member type='way' ref='506043348' role='' />
<member type='way' ref='506043350' role='' />
<member type='way' ref='477345277' role='' />
<member type='way' ref='842430887' role='' />
<member type='way' ref='477345276' role='' />
<member type='way' ref='692312917' role='' />
<member type='way' ref='5060589' role='' />
<member type='way' ref='842430891' role='' />
<member type='way' ref='692313079' role='' />
<member type='way' ref='479320611' role='' />
<member type='way' ref='842430895' role='' />
<member type='way' ref='479320599' role='' />
<member type='way' ref='479315603' role='' />
<member type='way' ref='641341990' role='' />
<member type='way' ref='505923249' role='' />
<member type='way' ref='601996658' role='' />
<member type='way' ref='601996657' role='' />
<member type='way' ref='641341992' role='' />
<member type='way' ref='842430901' role='' />
<member type='way' ref='9929945' role='' />
<member type='way' ref='103126550' role='' />
<member type='way' ref='61689733' role='' />
<member type='way' ref='476412827' role='' />
<member type='way' ref='4315700' role='' />
<member type='way' ref='885310680' role='' />
<member type='way' ref='159475694' role='' />
<member type='way' ref='1092932755' role='' />
<member type='way' ref='464204267' role='' />
<member type='way' ref='4315682' role='' />
<member type='way' ref='170370665' role='' />
<member type='way' ref='751253895' role='' />
<member type='way' ref='210466667' role='' />
<member type='way' ref='210466666' role='' />
<member type='way' ref='27150710' role='' />
<member type='way' ref='189219232' role='' />
<tag k='from' v='Churchill Square' />
<tag k='name' v='270 Brighton ��� East Grinstead' />
<tag k='to' v='East Grinstead Station' />
</relation>
<relation id='11561227' timestamp='2020-08-30T16:42:32Z' uid='3381552' user='tubbai11' visible='true' version='1' changeset='90150546'>
<member type='way' ref='23687403' role='depot' />
<member type='relation' ref='7006002' role='' />
<member type='relation' ref='11561226' role='' />
<tag k='name' v='Route 270' />
<tag k='route_master' v='bus' />
<tag k='type' v='route_master' />
<tag k='wheelchair' v='yes' />
</relation>
<relation id='11564142' timestamp='2023-06-01T18:48:08Z' uid='10703654' user='Aaro Hart' visible='true' version='49' changeset='136842960'>
<member type='node' ref='565764480' role='platform_entry_only' />
<member type='node' ref='565764329' role='platform' />
<member type='node' ref='565764614' role='platform' />
<member type='node' ref='565764234' role='platform' />
<member type='node' ref='565764665' role='platform' />
<member type='node' ref='565766884' role='platform' />
<member type='node' ref='565766886' role='platform' />
<member type='node' ref='565766417' role='platform' />
<member type='node' ref='565766416' role='platform' />
<member type='node' ref='565766414' role='platform' />
<member type='node' ref='565766412' role='platform' />
<member type='node' ref='565766883' role='platform' />
<member type='node' ref='565766881' role='platform' />
<member type='node' ref='565766879' role='platform' />
<member type='node' ref='565766466' role='platform' />
<member type='node' ref='565766421' role='platform' />
<member type='node' ref='565766423' role='platform' />
<member type='node' ref='565766431' role='platform' />
<member type='node' ref='565764727' role='platform' />
<member type='node' ref='565764724' role='platform' />
<member type='node' ref='565764722' role='platform' />
<member type='node' ref='565764720' role='platform' />
<member type='node' ref='565764732' role='platform' />
<member type='node' ref='565764736' role='platform' />
<member type='node' ref='565764738' role='platform' />
<member type='node' ref='565764699' role='platform' />
<member type='node' ref='565764700' role='platform' />
<member type='node' ref='565764680' role='platform' />
<member type='node' ref='565768683' role='platform' />
<member type='node' ref='565768696' role='platform' />
<member type='node' ref='565768699' role='platform' />
<member type='node' ref='565768704' role='platform' />
<member type='node' ref='565768625' role='platform' />
<member type='node' ref='2461640251' role='platform' />
<member type='node' ref='2282612242' role='platform' />
<member type='node' ref='1274482925' role='platform' />
<member type='node' ref='8820961594' role='platform' />
<member type='node' ref='7861627044' role='platform_exit_only' />
<member type='way' ref='977441865' role='' />
<member type='way' ref='17755202' role='' />
<member type='way' ref='1006626628' role='' />
<member type='way' ref='18095514' role='' />
<member type='way' ref='784804120' role='' />
<member type='way' ref='14396186' role='' />
<member type='way' ref='35967883' role='' />
<member type='way' ref='504004285' role='' />
<member type='way' ref='35967886' role='' />
<member type='way' ref='842716430' role='' />
<member type='way' ref='18097415' role='' />
<member type='way' ref='692875265' role='' />
<member type='way' ref='628594487' role='' />
<member type='way' ref='718993902' role='' />
<member type='way' ref='628594490' role='' />
<member type='way' ref='638290761' role='' />
<member type='way' ref='718993901' role='' />
<member type='way' ref='8302543' role='' />
<member type='way' ref='1106760424' role='' />
<member type='way' ref='13853910' role='' />
<member type='way' ref='720362265' role='' />
<member type='way' ref='891111007' role='' />
<member type='way' ref='242001964' role='' />
<member type='way' ref='8224115' role='' />
<member type='way' ref='793536973' role='' />
<member type='way' ref='24751569' role='' />
<member type='way' ref='793536969' role='' />
<member type='way' ref='814689356' role='' />
<member type='way' ref='505641227' role='' />
<member type='way' ref='842716428' role='' />
<member type='way' ref='814689355' role='' />
<member type='way' ref='22768263' role='' />
<member type='way' ref='723015140' role='' />
<member type='way' ref='814689358' role='' />
<member type='way' ref='5730957' role='' />
<member type='way' ref='814625419' role='' />
<member type='way' ref='977518941' role='' />
<member type='way' ref='717379957' role='' />
<member type='way' ref='717379956' role='' />
<member type='way' ref='13838367' role='' />
<member type='way' ref='882405812' role='' />
<member type='way' ref='886060333' role='' />
<member type='way' ref='882405819' role='' />
<member type='way' ref='977518940' role='' />
<member type='way' ref='886060332' role='' />
<member type='way' ref='886060331' role='' />
<member type='way' ref='885168003' role='' />
<member type='way' ref='886060334' role='' />
<member type='way' ref='886060335' role='' />
<member type='way' ref='882405816' role='' />
<member type='way' ref='13853820' role='' />
<member type='way' ref='13853822' role='' />
<member type='way' ref='58967119' role='' />
<member type='way' ref='210555025' role='' />
<member type='way' ref='24700168' role='' />
<member type='way' ref='591394887' role='' />
<member type='way' ref='718997434' role='' />
<member type='way' ref='718997435' role='' />
<member type='way' ref='882405814' role='' />
<member type='way' ref='882405820' role='' />
<member type='way' ref='638278599' role='' />
<member type='way' ref='638278596' role='' />
<member type='way' ref='13838318' role='' />
<member type='way' ref='419934309' role='' />
<member type='way' ref='842716425' role='' />
<member type='way' ref='419934310' role='' />
<member type='way' ref='798938826' role='' />
<member type='way' ref='419932860' role='' />
<member type='way' ref='24707986' role='' />
<member type='way' ref='874656594' role='' />
<member type='way' ref='23968036' role='' />
<member type='way' ref='15579723' role='' />
<member type='way' ref='211264953' role='' />
<member type='way' ref='214706604' role='' />
<member type='way' ref='793706388' role='' />
<member type='way' ref='799143479' role='' />
<member type='way' ref='602101843' role='' />
<member type='way' ref='24186130' role='' />
<member type='way' ref='799143442' role='' />
<member type='way' ref='507593009' role='' />
<member type='way' ref='793706389' role='' />
<member type='way' ref='198493053' role='' />
<member type='way' ref='777502378' role='' />
<member type='way' ref='777502379' role='' />
<member type='way' ref='198493056' role='' />
<member type='way' ref='96993714' role='' />
<member type='way' ref='602089520' role='' />
<member type='way' ref='793706390' role='' />
<member type='way' ref='96993712' role='' />
<member type='way' ref='793706391' role='' />
<member type='way' ref='635311800' role='' />
<member type='way' ref='635311797' role='' />
<member type='way' ref='164535071' role='' />
<member type='way' ref='164535073' role='' />
<member type='way' ref='5469761' role='' />
<member type='way' ref='616717572' role='' />
<member type='way' ref='114290706' role='' />
<member type='way' ref='672674908' role='' />
<member type='way' ref='598179109' role='' />
<member type='way' ref='120296124' role='' />
<member type='way' ref='510494561' role='' />
<member type='way' ref='1050309958' role='' />
<member type='way' ref='5469745' role='' />
<member type='way' ref='448730089' role='' />
<member type='way' ref='612046823' role='' />
<member type='way' ref='5469731' role='' />
<member type='way' ref='513638514' role='' />
<member type='way' ref='842716422' role='' />
<member type='way' ref='513638517' role='' />
<member type='way' ref='479382001' role='' />
<member type='way' ref='4916999' role='' />
<member type='way' ref='842716419' role='' />
<member type='way' ref='479382003' role='' />
<member type='way' ref='95517240' role='' />
<member type='way' ref='641679749' role='' />
<member type='way' ref='641679750' role='' />
<member type='way' ref='616335419' role='' />
<member type='way' ref='641679746' role='' />
<member type='way' ref='1061896893' role='' />
<member type='way' ref='641679748' role='' />
<member type='way' ref='1061896892' role='' />
<member type='way' ref='641679747' role='' />
<member type='way' ref='509808653' role='' />
<member type='way' ref='1121085940' role='' />
<member type='way' ref='509808651' role='' />
<member type='way' ref='830108807' role='' />
<member type='way' ref='509808655' role='' />
<member type='way' ref='95517239' role='' />
<member type='way' ref='5089204' role='' />
<member type='way' ref='842430898' role='' />
<member type='way' ref='127971367' role='' />
<member type='way' ref='4776912' role='' />
<member type='way' ref='626745234' role='' />
<member type='way' ref='519160557' role='' />
<member type='way' ref='519160556' role='' />
<member type='way' ref='888670061' role='' />
<member type='way' ref='4661167' role='' />
<member type='way' ref='888670060' role='' />
<member type='way' ref='1044584091' role='' />
<member type='way' ref='519160554' role='' />
<member type='way' ref='519160553' role='' />
<member type='way' ref='644567000' role='' />
<member type='way' ref='644567001' role='' />
<member type='way' ref='18090705' role='' />
<member type='way' ref='4788826' role='' />
<member type='way' ref='510494554' role='' />
<member type='way' ref='875341254' role='' />
<member type='way' ref='875341252' role='' />
<member type='way' ref='4764002' role='' />
<member type='way' ref='4777223' role='' />
<member type='way' ref='875650935' role='' />
<member type='way' ref='4772690' role='' />
<member type='way' ref='4775875' role='' />
<member type='way' ref='4775873' role='' />
<member type='way' ref='4776497' role='' />
<member type='way' ref='4776491' role='' />
<member type='way' ref='239985391' role='' />
<member type='way' ref='74171478' role='' />
<member type='way' ref='952716371' role='' />
<member type='way' ref='986987783' role='' />
<member type='way' ref='813899721' role='' />
<member type='way' ref='112015919' role='' />
<member type='way' ref='476989476' role='' />
<member type='way' ref='806204669' role='' />
<member type='way' ref='137389386' role='' />
<member type='way' ref='937338217' role='' />
<member type='way' ref='937338218' role='' />
<member type='way' ref='937338219' role='' />
<member type='way' ref='937338220' role='' />
<member type='way' ref='937338228' role='' />
<member type='way' ref='937338221' role='' />
<member type='way' ref='937338222' role='' />
<member type='way' ref='937338226' role='' />
<member type='way' ref='4385356' role='' />
<member type='way' ref='937338230' role='' />
<member type='way' ref='937338232' role='' />
<member type='way' ref='937338223' role='' />
<member type='way' ref='4393146' role='' />
<member type='way' ref='441533273' role='' />
<member type='way' ref='60906025' role='' />
<member type='way' ref='842716411' role='' />
<tag k='from' v='Crawley Bus Station' />
<tag k='name' v='271 Crawley ��� Brighton' />
<tag k='ref' v='271' />
<tag k='to' v='County Hospital' />
</relation>
<relation id='11564143' timestamp='2023-01-14T06:03:48Z' uid='10221076' user='MrJeeves' visible='true' version='44' changeset='131252909'>
<member type='node' ref='2282544378' role='platform_entry_only' />
<member type='node' ref='2282544380' role='platform' />
<member type='node' ref='2282544365' role='platform' />
<member type='node' ref='2477533709' role='platform' />
<member type='node' ref='2477533708' role='platform' />
<member type='node' ref='565768626' role='platform' />
<member type='node' ref='565768705' role='platform' />
<member type='node' ref='565768702' role='platform' />
<member type='node' ref='565768693' role='platform' />
<member type='node' ref='565768690' role='platform' />
<member type='node' ref='565768648' role='platform' />
<member type='node' ref='565768687' role='platform' />
<member type='node' ref='565764681' role='platform' />
<member type='node' ref='565764702' role='platform' />
<member type='node' ref='565764701' role='platform' />
<member type='node' ref='565764698' role='platform' />
<member type='node' ref='565764737' role='platform' />
<member type='node' ref='565764735' role='platform' />
<member type='node' ref='565764731' role='platform' />
<member type='node' ref='565764733' role='platform' />
<member type='node' ref='565764721' role='platform' />
<member type='node' ref='565764723' role='platform' />
<member type='node' ref='565764728' role='platform' />
<member type='node' ref='565766430' role='platform' />
<member type='node' ref='565766424' role='platform' />
<member type='node' ref='565766422' role='platform' />
<member type='node' ref='565766420' role='platform' />
<member type='node' ref='565766465' role='platform' />
<member type='node' ref='565766418' role='platform' />
<member type='node' ref='565766878' role='platform' />
<member type='node' ref='565766880' role='platform' />
<member type='node' ref='565766882' role='platform' />
<member type='node' ref='565766411' role='platform' />
<member type='node' ref='565766413' role='platform' />
<member type='node' ref='565766415' role='platform' />
<member type='node' ref='6752998664' role='platform' />
<member type='node' ref='565764233' role='platform' />
<member type='node' ref='565764278' role='platform' />
<member type='node' ref='565764283' role='platform' />
<member type='node' ref='565764330' role='platform' />
<member type='node' ref='565764480' role='platform_exit_only' />
<member type='way' ref='842716432' role='' />
<member type='way' ref='338125035' role='' />
<member type='way' ref='338125036' role='' />
<member type='way' ref='338125034' role='' />
<member type='way' ref='986987782' role='' />
<member type='way' ref='721989304' role='' />
<member type='way' ref='842716413' role='' />
<member type='way' ref='296072985' role='' />
<member type='way' ref='842430892' role='' />
<member type='way' ref='842430890' role='' />
<member type='way' ref='187629011' role='' />
<member type='way' ref='448730087' role='' />
<member type='way' ref='296063947' role='' />
<member type='way' ref='187475942' role='' />
<member type='way' ref='448730088' role='' />
<member type='way' ref='890878042' role='' />
<member type='way' ref='187629009' role='' />
<member type='way' ref='186602398' role='' />
<member type='way' ref='186611147' role='' />
<member type='way' ref='296072984' role='' />
<member type='way' ref='631289977' role='' />
<member type='way' ref='641341991' role='' />
<member type='way' ref='839844424' role='' />
<member type='way' ref='479382004' role='' />
<member type='way' ref='4916894' role='' />
<member type='way' ref='891951858' role='' />
<member type='way' ref='891951857' role='' />
<member type='way' ref='479382002' role='' />
<member type='way' ref='513638518' role='' />
<member type='way' ref='4916997' role='' />
<member type='way' ref='842716409' role='' />
<member type='way' ref='513638513' role='' />
<member type='way' ref='793536967' role='' />
<member type='way' ref='10266642' role='' />
<member type='way' ref='13858710' role='' />
<member type='way' ref='793536966' role='' />
<member type='way' ref='882405815' role='' />
<member type='way' ref='882405813' role='' />
<member type='way' ref='814625417' role='' />
<member type='way' ref='717379955' role='' />
<member type='way' ref='743595493' role='' />
<member type='way' ref='814625418' role='' />
<member type='way' ref='814625406' role='' />
<member type='way' ref='743595186' role='' />
<member type='way' ref='814625403' role='' />
<member type='way' ref='639396390' role='' />
<member type='way' ref='22768266' role='' />
<member type='way' ref='723015142' role='' />
<member type='way' ref='814625393' role='' />
<member type='way' ref='723015139' role='' />
<member type='way' ref='814689357' role='' />
<member type='way' ref='5213891' role='' />
<member type='way' ref='505641221' role='' />
<member type='way' ref='505641224' role='' />
<member type='way' ref='24751581' role='' />
<member type='way' ref='793536971' role='' />
<member type='way' ref='793536972' role='' />
<member type='way' ref='182162054' role='' />
<member type='way' ref='505641218' role='' />
<member type='way' ref='350640225' role='' />
<member type='way' ref='785256637' role='' />
<member type='way' ref='843961696' role='' />
<member type='way' ref='242001965' role='' />
<member type='way' ref='843961695' role='' />
<member type='way' ref='8302541' role='' />
<member type='way' ref='18097451' role='' />
<member type='way' ref='13853942' role='' />
<member type='way' ref='8302551' role='' />
<member type='way' ref='504004299' role='' />
<member type='way' ref='8302552' role='' />
<member type='way' ref='504004301' role='' />
<member type='way' ref='784804117' role='' />
<member type='way' ref='504004303' role='' />
<member type='way' ref='14396086' role='' />
<member type='way' ref='153899192' role='' />
<tag k='from' v='County Hospital' />
<tag k='name' v='271 Brighton ��� Crawley' />
<tag k='to' v='Crawley Bus Station' />
</relation>
<relation id='11564144' timestamp='2021-01-29T12:53:56Z' uid='63012' user='stthomse' visible='true' version='3' changeset='98366061'>
<member type='relation' ref='11564142' role='' />
<member type='relation' ref='11564143' role='' />
<member type='node' ref='565766881' role='stop' />
<member type='node' ref='565766880' role='' />
<member type='node' ref='565766885' role='stop' />
<member type='node' ref='565766884' role='stop' />
<member type='node' ref='565766887' role='bus_stop' />
<member type='node' ref='565766886' role='stop' />
<tag k='name' v='Route 271' />
</relation>
<relation id='11566101' timestamp='2023-06-01T18:48:08Z' uid='10703654' user='Aaro Hart' visible='true' version='42' changeset='136842960'>
<member type='node' ref='565764478' role='platform_entry_only' />
<member type='node' ref='6753719558' role='platform' />
<member type='node' ref='6753719559' role='platform' />
<member type='node' ref='565764394' role='platform' />
<member type='node' ref='565764630' role='platform' />
<member type='node' ref='565764656' role='platform' />
<member type='node' ref='565764373' role='platform' />
<member type='node' ref='565764878' role='platform' />
<member type='node' ref='565764880' role='platform' />
<member type='node' ref='565764882' role='platform' />
<member type='node' ref='565764885' role='platform' />
<member type='node' ref='565764887' role='platform' />
<member type='node' ref='565764889' role='platform' />
<member type='node' ref='565764891' role='platform' />
<member type='node' ref='565764892' role='platform' />
<member type='node' ref='565765521' role='platform' />
<member type='node' ref='565764903' role='platform' />
<member type='node' ref='565764901' role='platform' />
<member type='node' ref='565765291' role='platform' />
<member type='node' ref='565764909' role='platform' />
<member type='node' ref='565765254' role='platform' />
<member type='node' ref='565765246' role='platform' />
<member type='node' ref='565765242' role='platform' />
<member type='node' ref='565765406' role='platform' />
<member type='node' ref='565765437' role='platform' />
<member type='node' ref='565765444' role='platform' />
<member type='node' ref='565764828' role='platform' />
<member type='node' ref='565765535' role='platform' />
<member type='node' ref='565764812' role='platform' />
<member type='node' ref='565765494' role='platform' />
<member type='node' ref='565765496' role='platform' />
<member type='node' ref='565765497' role='platform' />
<member type='way' ref='515109740' role='' />
<member type='way' ref='153899182' role='' />
<member type='way' ref='170363601' role='' />
<member type='way' ref='15258929' role='' />
<member type='way' ref='350631430' role='' />
<member type='way' ref='350607493' role='' />
<member type='way' ref='719414638' role='' />
<member type='way' ref='15090818' role='' />
<member type='way' ref='900708176' role='' />
<member type='way' ref='784804115' role='' />
<member type='way' ref='719414631' role='' />
<member type='way' ref='719414630' role='' />
<member type='way' ref='13854261' role='' />
<member type='way' ref='1032698368' role='' />
<member type='way' ref='171530452' role='' />
<member type='way' ref='27359978' role='' />
<member type='way' ref='27359980' role='' />
<member type='way' ref='13854268' role='' />
<member type='way' ref='170370670' role='' />
<member type='way' ref='16300861' role='' />
<member type='way' ref='154355598' role='' />
<member type='way' ref='13835326' role='' />
<member type='way' ref='24751772' role='' />
<member type='way' ref='4315342' role='' />
<member type='way' ref='345800357' role='' />
<member type='way' ref='154355592' role='' />
<member type='way' ref='345800364' role='' />
<member type='way' ref='141693734' role='' />
<member type='way' ref='1107383505' role='' />
<member type='way' ref='154355594' role='' />
<member type='way' ref='140416779' role='' />
<member type='way' ref='345800365' role='' />
<member type='way' ref='1036117982' role='' />
<member type='way' ref='139108764' role='' />
<member type='way' ref='899845155' role='' />
<member type='way' ref='899845154' role='' />
<member type='way' ref='16119356' role='' />
<member type='way' ref='349593665' role='' />
<member type='way' ref='140416787' role='' />
<member type='way' ref='43011278' role='' />
<member type='way' ref='345800356' role='' />
<member type='way' ref='43011279' role='' />
<member type='way' ref='344742355' role='' />
<member type='way' ref='333541347' role='' />
<member type='way' ref='15577796' role='' />
<member type='way' ref='155554328' role='' />
<member type='way' ref='344742369' role='' />
<member type='way' ref='155554327' role='' />
<member type='way' ref='23553254' role='' />
<member type='way' ref='408034901' role='' />
<member type='way' ref='23553255' role='' />
<member type='way' ref='885872194' role='' />
<member type='way' ref='885872193' role='' />
<member type='way' ref='155554208' role='' />
<member type='way' ref='697018027' role='' />
<member type='way' ref='4088140' role='' />
<member type='way' ref='182833777' role='' />
<member type='way' ref='226995624' role='' />
<member type='way' ref='4088141' role='' />
<member type='way' ref='181619411' role='' />
<member type='way' ref='20863249' role='' />
<member type='way' ref='751617137' role='' />
<member type='way' ref='20863252' role='' />
<member type='way' ref='1124142166' role='' />
<member type='way' ref='1124142167' role='' />
<member type='way' ref='159596938' role='' />
<member type='way' ref='181594063' role='' />
<member type='way' ref='5016277' role='' />
<member type='way' ref='24912426' role='' />
<member type='way' ref='24912425' role='' />
<member type='way' ref='63547410' role='' />
<member type='way' ref='198491296' role='' />
<member type='way' ref='24325866' role='' />
<member type='way' ref='8114212' role='' />
<member type='way' ref='305512782' role='' />
<tag k='name' v='272 Crawley ��� Brighton' />
<tag k='ref' v='272' />
</relation>
<relation id='11566102' timestamp='2023-01-14T06:03:48Z' uid='10221076' user='MrJeeves' visible='true' version='35' changeset='131252909'>
<member type='node' ref='565765498' role='platform' />
<member type='node' ref='565765495' role='platform' />
<member type='node' ref='565764829' role='platform' />
<member type='node' ref='565765534' role='platform' />
<member type='node' ref='565764827' role='platform' />
<member type='node' ref='7863175436' role='platform' />
<member type='node' ref='565765447' role='platform' />
<member type='node' ref='565765440' role='platform' />
<member type='node' ref='565765410' role='platform' />
<member type='node' ref='565765250' role='platform' />
<member type='node' ref='565764908' role='platform' />
<member type='node' ref='565765287' role='platform' />
<member type='node' ref='565764902' role='platform' />
<member type='node' ref='565764893' role='platform' />
<member type='node' ref='565765311' role='platform' />
<member type='node' ref='565764890' role='platform' />
<member type='node' ref='565764888' role='platform' />
<member type='node' ref='565764886' role='platform' />
<member type='node' ref='565764883' role='platform' />
<member type='node' ref='565764881' role='platform' />
<member type='node' ref='565764879' role='platform' />
<member type='node' ref='565765523' role='platform' />
<member type='node' ref='565764372' role='platform' />
<member type='node' ref='565764629' role='platform' />
<member type='node' ref='565764393' role='platform' />
<member type='node' ref='565764427' role='platform' />
<member type='node' ref='565764425' role='platform' />
<member type='node' ref='6574571862' role='platform_exit_only' />
<member type='way' ref='787997918' role='' />
<member type='way' ref='20863253' role='' />
<member type='way' ref='4088142' role='' />
<member type='way' ref='170370664' role='' />
<member type='way' ref='155554207' role='' />
<member type='way' ref='226995625' role='' />
<member type='way' ref='344742370' role='' />
<member type='way' ref='4315343' role='' />
<member type='way' ref='333541348' role='' />
<member type='way' ref='344742356' role='' />
<member type='way' ref='345800360' role='' />
<member type='way' ref='345800355' role='' />
<member type='way' ref='43011280' role='' />
<member type='way' ref='345800363' role='' />
<member type='way' ref='594724903' role='' />
<member type='way' ref='140416786' role='' />
<member type='way' ref='349593669' role='' />
<member type='way' ref='349593663' role='' />
<member type='way' ref='182973582' role='' />
<member type='way' ref='899845153' role='' />
<member type='way' ref='899845152' role='' />
<member type='way' ref='345800361' role='' />
<member type='way' ref='154355591' role='' />
<member type='way' ref='345800359' role='' />
<member type='way' ref='345800358' role='' />
<member type='way' ref='141693733' role='' />
<member type='way' ref='345800362' role='' />
<member type='way' ref='16300863' role='' />
<member type='way' ref='13854228' role='' />
<member type='way' ref='347756658' role='' />
<member type='way' ref='345800374' role='' />
<member type='way' ref='345800375' role='' />
<member type='way' ref='345800373' role='' />
<member type='way' ref='13854264' role='' />
<member type='way' ref='171530461' role='' />
<member type='way' ref='181754659' role='' />
<member type='way' ref='13865820' role='' />
<member type='way' ref='900708175' role='' />
<member type='way' ref='348388479' role='' />
<member type='way' ref='20226414' role='' />
<member type='way' ref='15258930' role='' />
<member type='way' ref='718991683' role='' />
<member type='way' ref='14396123' role='' />
<member type='way' ref='153899205' role='' />
<member type='way' ref='223616400' role='' />
<member type='way' ref='145426967' role='' />
<tag k='name' v='272 Brighton ��� Crawley' />
<tag k='public_transport:version' v='2' />
</relation>
<relation id='11566103' timestamp='2020-09-01T00:25:10Z' uid='3381552' user='tubbai11' visible='true' version='1' changeset='90214531'>
<member type='relation' ref='11566101' role='' />
<member type='relation' ref='11566102' role='' />
<tag k='name' v='Route 272' />
</relation>
</osm>
More information about the Pgrouting-users
