[pgrouting-users] osm_relations table does not get populated
Vicky Vergara
vicky at erosion.dev
Mon Jun 5 16:10:13 PDT 2023
Hi Tokura San:
Yes it is possible, you have to make your own.
There is are 2 examples here:
https://workshop.pgrouting.org/2.8/en/un_sdg/data.html#appendix
One is incorporating buildings the other one incorporates waterways
Regards
Vicky
On Mon, Jun 5, 2023 at 4:45 AM Imre Samu <pella.samu at gmail.com> wrote:
> > 1. It seems that by default osm2pgrouting will only store those
> osm_relations that are related to routes and that contain "highway"-tagged
> ways, is this correct?
> In my opinion, yes. (But please note that I'm just a user.)
> > 2. Is it possible to edit mapconfig.xml to include other, non-highway
> relations?
> check the
> https://github.com/pgRouting/osm2pgrouting/blob/main/mapconfig_for_bicycles.xml
> - cycleway
> - cycleway:right
> - cycleway:left
> - tracktype
> - highway
> If you want to include non-route related data, such as Points of Interest
> (POIs), borders, and so on, I recommend using https://osm2pgsql.org/.
> This tool can also be a useful way to verify the functioning of the
> osm2pgrouting program.
> If you're finding that a route is present in the osm2pgsql tables but not
> in the osm2pgrouting ones, it's likely that you need to adjust the
> configuration.
> There can be a wide variety of 'highway=' values, as OSM editors can use
> any key-value pair.
> You can see a list of these values at
> https://taginfo.openstreetmap.org/keys/highway#values.
> Sometimes, an extract might not contain all parts of an extremely long
> relation, which means it won't be imported.
> In such cases, osm2pgsql also won't import it. This situation can help you
> identify potential data issues.
> Be aware that there's a known issue with osm2pgrouting ;
> If you're using it, consider increasing the value of the "--chunk"
> parameter. ( --chunk 10000000 )
> https://github.com/pgRouting/osm2pgrouting/issues/296
> Regards,
> Imre
> Tokura Gou <tokura.gou at gmail.com> ezt írta (időpont: 2023. jún. 5., H,
> 11:20):
>> Hello Imre,
>> Thanks for your comment.
>> I will test with another data set.
>> Meanwhile, may I ask:
>> relations?
>> Thank you.
>> On Sun, Jun 4, 2023 at 4:21 PM Imre Samu <pella.samu at gmail.com> wrote:
>>> Hello,
>>> In the data file you've provided, named
>>> 'haywards-heath-uk-small-extract.txt',
>>> there are 8 OpenStreetMap (OSM) relation objects [2]
>>> that are marked as either 'boundary=*' or 'landuse=residential'.
>>> It appears that none of these are related to routes or are included in
>>> the 'mapconfig.xml' [1] file.
>>> Could you please specify which OSM relation you're missing from your
>>> table?
>>> Could you also test it with another input data set? Specifically, one
>>> that includes a 'highway=*' osm relation in the extract.
>>> [1] https://github.com/pgRouting/osm2pgrouting/blob/main/mapconfig.xml
>>> [2] osmium cat haywards-heath-uk-small-extract.osm.xml -t relation -f
>>> opl | cut -d' ' -f8
>>> [3] https://taginfo.openstreetmap.org/keys/highway#overview
>>> Regards,
>>> Imre
>>> Tokura Gou <tokura.gou at gmail.com> ezt írta (időpont: 2023. jún. 3.,
>>> Szo, 19:11):
>>>> Hello Vicky and thanks for your response,
>>>> Maybe due to formatting issues the data and the command were not
>>>> visible.
>>>> 1. Data:
>>>> https://github.com/pgRouting/osm2pgrouting/files/11598959/haywards-heath-uk-small-extract.txt
>>>> 2. Exact command: osm2pgrouting -f home/map.osm -c
>>>> "/usr/local/share/osm2pgrouting/mapconfig.xml" -d city_routing -U
>>>> [username] -W [password] --clean --tags --addnodes
>>>> On Fri, Jun 2, 2023 at 6:25 PM Vicky Vergara <vicky at erosion.dev> wrote:
>>>>> Hello,
>>>>> I can not reproduce your problem:
>>>>> What is needed:
>>>>> 1) The exact data that has been used, can be in the form of a link to
>>>>> a shared file, the wget command to download from osm.
>>>>> 2) the exact command that is been used (use mylogin and mypass instead
>>>>> of the real ones when posting the command)
>>>>> Regards
>>>>> Vicky
>>>>> On Fri, Jun 2, 2023 at 3:52 AM Tokura Gou <tokura.gou at gmail.com>
>>>>> wrote:
>>>>>> *Problem*
>>>>>> When running osm2pgrouting on a typical .osm file with the --addnodes
>>>>>> option, osm_relations table stays empty.
>>>>>> *To Reproduce*
>>>>>> osm2pgrouting -f home/map.osm -c "/usr/local/share/osm2pgrouting/mapconfig.xml" -d city_routing -U [username] -W [password] --clean --tags --addnodes
>>>>>> *Expectation*
>>>>>> I use the --addnodes flag as per the documentation and I can see that
>>>>>> osm_nodes and osm_ways tables do get populated. However,
>>>>>> osm_relations has 0 records after running osm2pgrouting and "Final
>>>>>> osm_relations:" is never mentioned in the output:
>>>>>> Creating tables...
>>>>>> TABLE: ways_vertices_pgr created ... OK.
>>>>>> TABLE: ways created ... OK.
>>>>>> TABLE: pointsofinterest created ... OK.
>>>>>> TABLE: configuration created ... OK.
>>>>>> TABLE: osm_nodes created ... OK.
>>>>>> TABLE: osm_ways created ... OK.
>>>>>> TABLE: osm_relations created ... OK.
>>>>>> Opening configuration file: /usr/local/share/osm2pgrouting/mapconfig.xml
>>>>>> Parsing configuration
>>>>>> Exporting configuration ...
>>>>>> - Done
>>>>>> Counting lines ...
>>>>>> - Done
>>>>>> Opening data file: home/map.osm total lines: 175957
>>>>>> Parsing data
>>>>>> Current osm_nodes: 48000
>>>>>> Final osm_nodes: 48375
>>>>>> Current osm_ways: 6000
>>>>>> Final osm_ways: 6320
>>>>>> End Of file
>>>>>> Finish Parsing data
>>>>>> Adding auxiliary tables to database...
>>>>>> Export Ways ...
>>>>>> Creating indexes ...
>>>>>> Processing Points of Interest ...
>>>>>> Adding functions for processing Points of Interest ...
>>>>>> To process pointsOfInterest table:
>>>>>> osm2pgr_pois_update(radius default 200, within default 50)
>>>>>> - Using areas of (radius)mts on POIS
>>>>>> - Using edges that are at least (within) mts of each POI
>>>>>> POIS that do not have a closest edge is considered as too far
>>>>>> size of streets: 6320
>>>>>> Execution started at: Tue May 30 10:07:09 2023
>>>>>> Execution ended at: Tue May 30 10:07:21 2023
>>>>>> Elapsed time: 11.767 Seconds.
>>>>>> User CPU time: -> 1.12268 seconds
>>>>>> *Sample Data*
>>>>>> A sample .osm file is attached (please rename from txt to osm if
>>>>>> needed), however I have tried other .osm exports that contain osm relations
>>>>>> with the same result.
>>>>>> <https://github.com/pgRouting/osm2pgrouting/files/11598959/haywards-heath-uk-small-extract.txt>
>>>>>> *Platform/versions*
>>>>>> SELECT version();
>>>>>> PostgreSQL 15.3 (Debian 15.3-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
>>>>>> SELECT postgis_full_version();
>>>>>> POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="150" GEOS="3.9.0-CAPI-1.16.2" PROJ="7.2.1" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
>>>>>> SELECT pgr_version();
>>>>>> 3.4.1
>>>>>> _______________________________________________
>>>>>> Pgrouting-users mailing list
>>>>>> Pgrouting-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20230605/03242e0e/attachment-0001.htm>
More information about the Pgrouting-users
