[pgrouting-users] Dynamic costs question
Alex D.
kmortyk at gmail.com
Sun Sep 10 02:09:38 PDT 2023
Hello,
I would like to attend the pgRouting meeting on Monday.
Could you tell me the platform where the meetings will take place?
Also, I would like to confirm the timezone. Is it UTC-6? Please let me know
if I am mistaken.
пт, 8 сент. 2023 г. в 06:20, Vicky Vergara <vicky at erosion.dev>:
> Hi,
> Sure, we can start a discussion.
> Normally pgRouting meetings are at 13:00 CMT hours, allowing other project
> members from other parts of the world to join.
> What about on Monday?
> Regards
> Vicky
> On Mon, Sep 4, 2023 at 7:06 AM Alex D. <kmortyk at gmail.com> wrote:
>> Thank you for your reply.
>> Is it possible to find someone here who can develop this feature for a
>> fee, with the intention of releasing the final solution as open source?
>> I am currently considering two potential approaches for implementation:
>> 1. Implementing the Bellman-Ford Based Algorithm as described in the
>> following paper:
>> https://www.researchgate.net/publication/221103374_Finding_time-dependent_shortest_paths_over_large_graphs (Finding
>> time-dependent shortest paths over large graphs) and
>> https://essay.utwente.nl/92401/ (Solving time-dependent shortest path
>> problems in a database context).
>> 2. Implementing callbacks for
>> https://docs.pgrouting.org/latest/en/pgr_bellmanFord.html, as discussed
>> in the issue https://github.com/pgRouting/pgrouting/issues/243.
>> вс, 3 сент. 2023 г. в 04:50, Vicky Vergara <vicky at erosion.dev>:
>>> Hello,
>>> No, we do not have an implementation where costs can vary while
>>> executing the algorithm.
>>> If you can point out a paper of such an algorithm you describe, it would
>>> be nice.
>>> Regards
>>> Vicky
>>> On Fri, Sep 1, 2023 at 1:00 AM Alex D. <kmortyk at gmail.com> wrote:
>>>> Dear pgRouting users,
>>>> I am currently working on my project and would like to learn more about
>>>> the library. Specifically, I am using it to find the most profitable paths
>>>> between two tokens.
>>>> The graph I am working with represents tokens between which transfers
>>>> on the Ethereum blockchain are possible.
>>>> Could you please help me with the following questions:
>>>> 1. Is it possible to use dynamic costs in path finding algorithms,
>>>> specifically in pgr_bellmanFord? By dynamic costs, I mean modifying the
>>>> cost of an edge as the algorithm passes through the graph based on
>>>> previously added edges in the path.
>>>> 2. If dynamic costs are not possible, is it correct to say that this is
>>>> the problem of finding paths in time-dependent graphs? I am unsure because
>>>> in my case, it is possible for the weight to decrease as the algorithm
>>>> travels along the edges.
>>>> Thank you very much.
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20230910/3516212c/attachment.htm>
More information about the Pgrouting-users
