[pgrouting-users] Dynamic costs question
Vicky Vergara
vicky at erosion.dev
Thu Sep 7 20:20:14 PDT 2023
Sure, we can start a discussion.
Normally pgRouting meetings are at 13:00 CMT hours, allowing other project
members from other parts of the world to join.
What about on Monday?
Regards
Vicky
On Mon, Sep 4, 2023 at 7:06 AM Alex D. <kmortyk at gmail.com> wrote:
> Thank you for your reply.
> Is it possible to find someone here who can develop this feature for a
> fee, with the intention of releasing the final solution as open source?
> I am currently considering two potential approaches for implementation:
> 1. Implementing the Bellman-Ford Based Algorithm as described in the
> following paper:
> https://www.researchgate.net/publication/221103374_Finding_time-dependent_shortest_paths_over_large_graphs (Finding
> time-dependent shortest paths over large graphs) and
> https://essay.utwente.nl/92401/ (Solving time-dependent shortest path
> problems in a database context).
> 2. Implementing callbacks for
> https://docs.pgrouting.org/latest/en/pgr_bellmanFord.html, as discussed
> in the issue https://github.com/pgRouting/pgrouting/issues/243.
> вс, 3 сент. 2023 г. в 04:50, Vicky Vergara <vicky at erosion.dev>:
>> Hello,
>> No, we do not have an implementation where costs can vary while executing
>> the algorithm.
>> If you can point out a paper of such an algorithm you describe, it would
>> be nice.
>> Regards
>> Vicky
>> On Fri, Sep 1, 2023 at 1:00 AM Alex D. <kmortyk at gmail.com> wrote:
>>> Dear pgRouting users,
>>> I am currently working on my project and would like to learn more about
>>> the library. Specifically, I am using it to find the most profitable paths
>>> between two tokens.
>>> The graph I am working with represents tokens between which transfers on
>>> the Ethereum blockchain are possible.
>>> Could you please help me with the following questions:
>>> 1. Is it possible to use dynamic costs in path finding algorithms,
>>> specifically in pgr_bellmanFord? By dynamic costs, I mean modifying the
>>> cost of an edge as the algorithm passes through the graph based on
>>> previously added edges in the path.
>>> 2. If dynamic costs are not possible, is it correct to say that this is
>>> the problem of finding paths in time-dependent graphs? I am unsure because
>>> in my case, it is possible for the weight to decrease as the algorithm
>>> travels along the edges.
>>> Thank you very much.
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20230907/e291d7ab/attachment.htm>
More information about the Pgrouting-users
