[postgis-devel] Little error in pgsql2shp (version 0.7.3)
Silke Reimer
silke at intevation.de
Fri Nov 1 04:19:50 PST 2002
Hallo!
I found a little error in pgsql2shp. The problem was, that the array
conn_string was printed to stdout although it was empty at that
moment. Therefor using pgsql2shp always led to binary code on
stdout. The solution is to remove one line in pgsql2shp.c (probably
included for debugging purposes). You find the patch attached to
this email.
Greetings,
Silke
Silke Reimer
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
--- pgsql2shp.c.orig Fri Nov 1 13:09:10 2002
+++ pgsql2shp.c Fri Nov 1 13:06:40 2002
@@ -160,7 +160,7 @@
- printf(conn_string);
+/* printf(conn_string);*/
/* make a connection to the specified database */
sprintf(conn_string,"host=%s %s port=%s dbname=%s",pghost,pgoptions,pgport,dbName);
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20021101/b0f14bb0/attachment.sig>
