[postgis-devel] Little error in pgsql2shp (version 0.7.3)
Paul Ramsey pramsey at refractions.net
Mon Nov 4 13:21:57 PST 2002
Committed.
P.
Silke Reimer wrote:
> Hallo!
> I found a little error in pgsql2shp. The problem was, that the array
> conn_string was printed to stdout although it was empty at that
> moment. Therefor using pgsql2shp always led to binary code on
> stdout. The solution is to remove one line in pgsql2shp.c (probably
> included for debugging purposes). You find the patch attached to
> this email.
> Greetings,
> 	Silke
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
