[postgis-devel] collect() and geom_union()
strk strk at keybit.net
Wed Nov 5 10:33:40 PST 2003
I've committed changes to postgis enabler script to
include "fast" aggregates support. Now we have:
GeomUnion()    <-- "fast" aggregate
MemGeomUnion() <-- "memory saving" aggregate
Collect()      <-- "fast" aggregate
MemCollect()   <-- "memory saving" aggregate
I'd like to remove quick-memory-release code from "fast" versions.
I think in this way they will be faster and less faulty.
Please let me know how do these work for you.
--strk;
strk wrote:
> pramsey wrote:
> > strk wrote:
> > > Ok, since nobody answered calls about them,
> > > I'll consider current behaviour accepted.
> > > ... dust has been posed ...
> > > That said - as suggested by Paul I'll rename collect() to
> > > mem_collect() and will add new fastcollect() to postgis enabler
> > > script with the name collect(). Then I'll add fastunion()
> > > aggregate as geom_union() and rename unite() aggregate to
> > > mem_geom_union().
> > Could you please enumerate all the names for "things that union",
> > existing and proposed, so we can see the whole namespace at once?
> EXISTING IN CURRENT CVS SQL ENABLER:
> a) geometry GeomUnion(geometry, geometry); -- function
> b) geometry Unite(geomerty set);           -- dumb (memory saving)
>                                               aggregate
> PROPOSED THINGS:
> A) geometry GeomUnion(geometry, geometry); -- (a) untouched
> B) geometry MemGeomUnion(geometry set);    -- (b) renamed
> C) geometry GeomUnion(geometry set);       -- fast (memory consuming)
>                                               aggregate somebody knows
>                                               this as fastunion()
> PS: there is also a: geometry geometry_union(geometry, geometry)
>     listed in section "7.2 RTREE support functions", but what
>     it does is actually a box3d union.
> --strk;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
