[postgis-devel] strange problem with operators
Carl Anderson
carl.anderson at co.fulton.ga.us
Tue Aug 10 10:58:29 PDT 2004
Working with postgresql-7.4.3 and GEOS (cvs) and PostGIS (cvs)
I have found a condition where
select difference (geometry(shp1),geometry(shp2)) from zoning_test.bad;
NOTICE: TopologyException: no outgoing dirEdge found
(2.23561e+06,1.42152e+06)
ERROR: GEOS difference() threw an error!
BUT
select difference (geometry(astext(shp1)),geometry(astext(shp2))) from
zoning_test.bad;
succeeds
Any hints as how to extract the geometries for analysis
I got there by
shp1 = difference (shp1,shp0)
then
shp2 = difference( shp1,shp2) -- fails
BTW
PostGIS (cvs) depends on Proj 4.4.8 (pj_get_release)
Can a note be added to the Makefile or CHANGES
C.
Carl Anderson
GIS Manager Fulton County, Georgia
404.730.8026
