[postgis-devel] strange problem with operators
David Blasby
dblasby at gmail.com
Tue Aug 10 11:20:17 PDT 2004
By converting from geometry->text->geometry you're probably moving
around your vertices "just a little bit" (ie. < 10^-8).
The new location of the vertices gives a geometry that interacts
"better" and doesnt throw the error.
At least that what it looks like,
dave
On Tue, 10 Aug 2004 13:58:29 -0400, Carl Anderson
<carl.anderson at co.fulton.ga.us> wrote:
> Working with postgresql-7.4.3 and GEOS (cvs) and PostGIS (cvs)
> I have found a condition where
> select difference (geometry(shp1),geometry(shp2)) from zoning_test.bad;
> NOTICE: TopologyException: no outgoing dirEdge found
> (2.23561e+06,1.42152e+06)
> ERROR: GEOS difference() threw an error!
> BUT
> select difference (geometry(astext(shp1)),geometry(astext(shp2))) from
> zoning_test.bad;
> succeeds
> Any hints as how to extract the geometries for analysis
> I got there by
> shp1 = difference (shp1,shp0)
> then
> shp2 = difference( shp1,shp2) -- fails
> BTW
> PostGIS (cvs) depends on Proj 4.4.8 (pj_get_release)
> Can a note be added to the Makefile or CHANGES
> C.
> Carl Anderson
> GIS Manager Fulton County, Georgia
> 404.730.8026
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
