[postgis-devel] automatic BVOL on spatial columns
strk at refractions.net
Thu Dec 23 06:03:51 PST 2004
The bounding box of an LWGEOM geometry is
an optional 'cache', currently absent at
construction time.
Bounding boxes can be added using addBBOX(geom)
and removed using dropBBOX(geom).
Having a bbox cached speeds up bbox operation
like &&, but increases on-disk size.
Note that an index scan does not need to
compute the bbox, but its construction does.
Also note that our GiST index has a RECHECK
clause on each operator, thus practically
needing the bbox check (so it's computation)
for every 'candidate' row returned from the
index scan.
Previous (HWGEOM) geometry type did *always*
have this cache available.
My proposal is to add a RULE on INSERT and
UPDATES of geometry columns from within
AddGeoemtryColumn, so that all geometry
columns exept 'POINT' type (for which bbox
computation is very fast) have a BBOX
computed.
What do you think ?
--strk;
