[postgis-devel] EWKB proposal for OGC
strk at refractions.net
Mon Dec 27 04:01:04 PST 2004
As suggested by Martin Daly I've made a draft proposal for ZM and
SRID inclusion in WKB and WKT.
Differently to the Z-Geometry proposal I did not specify semantic
of the M values, as I don't see any "standardizable" behaviour
for them. For example, M(isures) could represent temperature
(linear interpolation meaningful) as well as time (meaningless
linear interpolation).
Draft attached, comments expected.
--strk;
TITLE: ZM values and SRID for Simple Features
AUTHOR: Name: Sandro Santilli
Email: strk at refractions.net
DATE: 27 December 2005
CATEGORY: Simple Features Revision Proposal
1. Background
OpenGIS document 99-402r2 introduces semantic and well-known
representations for Z-geometries. This proposal extend the well-known
representations to optionally also hold a misure (M) and a SRID.
Misures, as Z values, are attributes of 2D vertexes, but their
semantic is unspecified in this document, as they could be used
for any kind 'misurement'. SRID is an attribute of the whole feature.
This document defines how geometry can have Z,M or both values and SRID
in a way which is compatible to the existing 2D OpenGIS Simple Features
specification AND to the Z-Geometry documented in OpenGIS 99-402r2.
2. Proposal
2.1. Definition of ZM-Geometry
a) A geometry can have either 2, 3 or 4 dimensions.
b) 3rd dimension of a 3d geometry can either represent Z or M (3DZ or 3DM).
c) 4d geometries contain both Z and M (in this order).
d) M and Z values are associated with every vertex.
e) M and Z values are undefined within surface interiors.
Any ZM-Geometry can be converted into a 2D geometry by discarding all its
Z and M values. The resulting 2D geometry is the "shadow" of the ZM-Geometry.
2D geometries cannot be safely converted into ZM-Geometries, since their Z
and M values are undefined, and not necessarily zero.
2.2. Extensions to Well-Known-Binary format
The 2d OpenGIS Simple Features specification has the following geometry types:
enum wkbGeometryType {
wkbPoint = 1,
wkbLineString = 2,
wkbPolygon = 3,
wkbMultiPoint = 4,
wkbMultiLineString = 5,
wkbMultiPolygon = 6,
wkbGeometryCollection = 7
Document 99-402r2 introduces a Z-presence flag (wkbZ) which OR'ed
to the type specifies the presence of Z coordinate:
wkbZ = 0x80000000
This proposal suggest the use of an M-presence flag (wkbM) to
allow for XY, XYM, XYZ and XYZM geometryes, and SRID-presence
flag to allow for embedded SRID:
wkbM = 0x40000000
wkbSRID = 0x20000000
Possible resulting geometry types are:
enum wkbGeometryTypeZ {
wkbPoint = 1,
wkbLineString = 2,
wkbPolygon = 3,
wkbMultiPoint = 4,
wkbGeometryCollection = 7,
// | 0x80000000
wkbPointZ = 0x80000001,
wkbLineStringZ = 0x80000002,
wkbPolygonZ = 0x80000003,
wkbMultiPointZ = 0x80000004,
wkbMultiLineStringZ = 0x80000005,
wkbMultiPolygonZ = 0x80000006,
wkbGeometryCollectionZ = 0x80000007,
// | 0x40000000
wkbPointM = 0x40000001,
wkbLineStringM = 0x40000002,
wkbPolygonM = 0x40000003,
wkbMultiPointM = 0x40000004,
wkbMultiLineStringM = 0x40000005,
wkbMultiPolygonM = 0x40000006,
wkbGeometryCollectionM = 0x40000007,
// | 0x40000000 | 0x80000000
wkbPointZM = 0xC0000001,
wkbLineStringZM = 0xC0000002,
wkbPolygonZM = 0xC0000003,
wkbMultiPointZM = 0xC0000004,
wkbMultiLineStringZM = 0xC0000005,
wkbMultiPolygonZM = 0xC0000006,
wkbGeometryCollectionZM = 0xC0000007,
// | 0x20000000
wkbPointS = 0x20000001,
wkbLineStringS = 0x20000002,
wkbPolygonS = 0x20000003,
wkbMultiPointS = 0x20000004,
wkbMultiLineStringS = 0x20000005,
wkbMultiPolygonS = 0x20000006,
wkbGeometryCollectionS = 0x20000007,
// | 0x20000000 | 0x80000000
wkbPointZS = 0xA0000001,
wkbLineStringZS = 0xA0000002,
wkbPolygonZS = 0xA0000003,
wkbMultiPointZS = 0xA0000004,
wkbMultiLineStringZS = 0xA0000005,
wkbMultiPolygonZS = 0xA0000006,
wkbGeometryCollectionZS = 0xA0000007,
// | 0x20000000 | 0x40000000
wkbPointMS = 0x60000001,
wkbLineStringMS = 0x60000002,
wkbPolygonMS = 0x60000003,
wkbMultiPointMS = 0x60000004,
wkbMultiLineStringMS = 0x60000005,
wkbMultiPolygonMS = 0x60000006,
wkbGeometryCollectionMS = 0x60000007,
// | 0x20000000 | 0x40000000 | 0x80000000
wkbPointZMS = 0xE0000001,
wkbLineStringZMS = 0xE0000002,
wkbPolygonZMS = 0xE0000003,
wkbMultiPointZMS = 0xE0000004,
wkbMultiLineStringZMS = 0xE0000005,
wkbMultiPolygonZMS = 0xE0000006,
wkbGeometryCollectionZMS = 0xE0000007,
If the SRID flag is set it's value is encoded as a 4byte integer
right after the type integer.
If only wkbZ or wkbM flags are set Point coordinates will
be XYZ or XYM, if both wkbZ and wkbM flags are set Point
coordinates will be XYZM (Z first).
For example, a ZM-Point geometry at the location (10,20) with Z==30,
M==40 and SRID=4326 would be:
WKBPoint {
byte byteOrder; // wkbXDR or wkbNDR
uint32 wkbType; // (wkbPoint+wkbZ+wkbM+wkbSRID) =
// 0xE0000001
uint32 SRID; // 4326
Point {
Double x; // 10.0
Double y; // 20.0
Double z; // 30.0
Double m; // 40.0
2.3. Extensions to Well-Known-Text format
Geometry SRID presence and value would be represented using a
"SRID=#;" prefix to the WKT text:
"SRID=4326;POINT(1 2)"
3DZ geometry will be represented as:
"POINT(1 2 3)"
4D geometry will be represented as:
"POINT(1 2 3 4)"
3DM geometry will be represented as:
"POINTM(1 2 3)"
or
"GEOMETRYCOLLECTIONM(POINTM(1 2 3), LINESTRINGM(1 2 3, 4 5 6))"
Note that the coordinates structure of a geometry must be consistent,
you can't mix dimensions in a single geometry.
