[postgis-devel] EWKB proposal for OGC
Paul Selormey paul at toolscenter.org
Mon Dec 27 08:45:09 PST 2004
Unfortunately, the 99-402r2 is not yet available to some of us
the non-OGC members, and therefore commenting on these extensions
may not be right.
I have just these:
1. You have used "misure" in the documents, do you mean "measure"?
2. I wish the presence of the SRID in the geometry WKT is a suffix, since
    it can be considered optional and should not break existing codes:
    "POINT(1 2);SRID=4326"
BTW, any plan to define WTK for triangle, rectangle, circle and other
geometries defined in GML 3.x?
Best regards,
Paul.
----- Original Message -----
To: "PostGIS Development Discussion" <postgis-devel at postgis.refractions.net>
Cc: "Paul Ramsey" <pramsey at refractions.net>
Sent: Monday, December 27, 2004 9:01 PM
Subject: [postgis-devel] EWKB proposal for OGC
> As suggested by Martin Daly I've made a draft proposal for ZM and
> SRID inclusion in WKB and WKT.
> Differently to the Z-Geometry proposal I did not specify semantic
> of the M values, as I don't see any "standardizable" behaviour
> for them. For example, M(isures) could represent temperature
> (linear interpolation meaningful) as well as time (meaningless
> linear interpolation).
> Draft attached, comments expected.
> --strk;
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
