[postgis-devel] USE_GEOS and USE_PROJ
strk at refractions.net strk at refractions.net
Thu Dec 30 02:25:21 PST 2004
I've switched USE_GEOS and USE_PROJ defaults back to 0.
They can be overridden setting the appropriate environment
variables. This way we are consistent with documentation.
--strk;
For standing up against patentability of software,
  Thank You, Poland!
Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
Send your thanks:         thankyoupoland.info
Read/do more:		  http://www.noepatents.org/
