Here's a piece of code that directly tests the endian of the machine.
Basically, it looks at how the number 1 is stored. In the 4 byte int,
if its NDR, it will be in the 1st byte. If its XDR, it'll be in the
last byte.
int test = 1;
if ( (((char *)(&test))[0]) == 1)
//NDR
else
//XDR
