[postgis-devel] Re: sql files proliferation
strk
strk at keybit.net
Sat Feb 28 06:52:33 PST 2004
I've added an experimental source sql file and a corresponding rule
in the Makefile. CPP call is with -traditional-cpp flag, which
is nicer with multiline strings and '--' comments.
If you can give it a try we can test for compatibility.
Run make postgis_new.sql (it's not built by default) to
get postgis_new.sql generated from postgis.sql.in.
The source file (postgis.sql.in) is not optimized to use
cpp features, it just a copy of all the files previously
used wrapped in #if USE_VERSION == <ver> blocks.
Runnign a diff between postgis.sql and postgis_new.sql should
give you just comments, blank lines and the postgis_version()
function with double quotes ('') instead of slash escaped (/')
quote inside the SQL function.
--strk;
strk wrote:
> pramsey wrote:
> > I wonder if we can use cpp and simple #ifdef stuff to do the
> > preprocessing. Would be nice.
> > P.
> I made some use of cpp with languages other then C.
> The main problem is that cpp thinks #-lines are overlooked byt
> the compilers. GNU cpp version accepts -P to omit linemarkers
> -P Inhibit generation of linemarkers in the output from
> the preprocessor. This might be useful when running
> the preprocessor on something that is not C code, and
> will be sent to a program which might be confused by
> the linemarkers.
> ... but that could not be always the case.
> Can people try that (or similar) to solve the linemark problem ?
> --strk;
> > strk wrote:
> > > The postgis*sql* files are becoming a major part
> > > of the distribution (as number of files).
> > > What about having a single sql for each postgres version ?
> > > Or - better - use some preprocessing to keep in common
> > > things that are common and spilt things that need to be
> > > splitted ?
> > > I need to move geometry_column creation out of _common_
> > > into each of version-specific files because for PG75 there
> > > is no need of attrelid oid, varattnum int and stats histogram2d;
> > > this already happended for schema support changes (addGeometryColumn,
> > > dropGeoemtryColumn, fix_geometry_columns) and is getting boring.
> > > --strk;
> > __
> > | Paul Ramsey
> > | Refractions Research
> > | Email: pramsey at refractions.net
> > | Phone: (250) 885-0632
> > \_
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
