[postgis-devel] geos / postgis version
Paul Ramsey
pramsey at refractions.net
Thu Jul 22 11:25:09 PDT 2004
Every file has a different CVS $Id... are you thinking like
"postgis_file_version('postgis_fn.c') -> '1.35 2004/04/28'" or something
else?
(Incidentally, you could do this quite cleanly in mappostgis.c for your
mapserver version flag...)
From the shp2pgsql.c file:
static char rcsid[] =
"$Id: shp2pgsql.c,v 1.59 2004/07/19 16:24:47 strk Exp $";
... blah blah ...
printf("RCSID: %s\n", rcsid);
David Blasby wrote:
> Good idea on this logging.
> One thing I've always wanted to see what the ability to get the CVS
> log information for the ".c" file displayable inside postgresql. A
> lot of people think they're using one version, but actually using
> another - this could help clear it up.
> For example, the top of "postgis_fn.c" looks like this:
> * $Log: postgis_fn.c,v $
> * Revision 1.35 2004/04/28 22:26:02 pramsey
> * Fixed spelling mistake in header text.
> * Revision 1.34 2004/03/26 00:54:09 dblasby
> * added full support for fluffType(<geom>)
> * postgis09=# select fluffType('POINT(0 0)');
> * flufftype
> * SRID=-1;MULTIPOINT(0 0)
> * Revision 1.33 2004/03/25 00:43:41 dblasby
> * added function fluffType() that takes POINT LINESTRING or POLYGON
> It would be good to know that the compiled version is "1.35 2004/04/28".
> I dont know if this is easy or not.
> dave
> On Thu, 22 Jul 2004 19:12:09 +0200, strk <strk at keybit.net> wrote:
>>Ok, geos::version() has been split in geos::geosversion()
>>and geos::jtsport().
>>Postgis postgis_geos_version() will report geos version only
>>(I don't think we need to know JTS equivalent...)
>>I won't make the postgis_scripts_version() function now, as
>>I think it requires a deeper though about how it is supposed
>>to be used... If we need it to detect an incongruency between
>>pl/pgsql,sql functions and library functionalities we need to
>>understand what makes an incongruency and what does not.
>>--strk;
>>On Thu, Jul 22, 2004 at 06:20:45PM +0200, strk wrote:
>>>I've added postgis_lib_version() and postgis_geos_version().
>>>Before proceeding it might be worth changing geos::version()
>>>output (and maybe name) to be able to get GEOS version only
>>>(and geos::jtsport() addition...).
>>>Any hint on proj4 version string extraction is appreciated
>>>(with back-compatibility in mind).
>>>NOTE that postgis_lib_version also reports micro version
>>>which is actually not used in library file name (this is
>>>built using postgresql rule, which do not take a micro version
>>>number). Remember to upgrade SO_MICRO_VERSION between releases.
>>>--strk;
>>>On Thu, Jul 22, 2004 at 08:24:59AM -0700, Paul Ramsey wrote:
>>>>I think it is wise, and you should look at one of the emails today,
>>>>which suggested reporting out versions of the libraries we are using
>>>>(geos,proj) in addition to whether we have them.
>>>>strk wrote:
>>>>>Current postgis_version() function is implemented as a pl/pgsql
>>>>>function. Sometimes people upgrade postgis library w/out upgrading
>>>>>pl/pgsql functions, and this is *sometimes* a problem.
>>>>>I think it would be useful to have the following informations
>>>>>retrivable:
>>>>> postgis_scripts_version(); // pl/pgsql function
>>>>> postgis_lib_version(); // C function
>>>>> postgis_geos_version(); // C function
>>>>>Our postgis_version() would then be a wrapper, retriving the above
>>>>>informations and warning user in case
>>>>>postgis_scripts_version() != postgis_lib_version()
>>>>>What do you think ?
>>>>>--strk;
>>>>>_______________________________________________
>>>>>postgis-devel mailing list
>>>>>postgis-devel at postgis.refractions.net
>>>>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
