[postgis-devel] lwgeom: regress tests
strk
strk at keybit.net
Tue Jun 8 05:34:47 PDT 2004
On Tue, Jun 08, 2004 at 11:13:33AM +0000, Carl Anderson wrote:
> On 06/08/2004 05:05:23 AM, strk wrote:
> >All regress tests run with no problems for me.
> >Just a note. I do not have a 'postgres' user, so I had
> >to remove the \c line on top of regres_lots_of_points.sql
> >If this is not a problem I'd remove the 'You are now connected as...'
> >line from the expected result.
> >--strk;
> Another problem for me was on createdb
> createdb -T template0 lwgeom_reg
> will derive from template0 not the usual template1.
> template0 is always clean whilst template1 may have localizations
> tsearch, plpgsql, postgis, ...
plpgsql and postgis are loaded by regression tests.
did localizations or other thikngs make regress fail ?
--strk;
> C.
> >_______________________________________________
> >postgis-devel mailing list
> >postgis-devel at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-devel
