[postgis-devel] lwgeom: regress tests
Carl Anderson carl.anderson at vadose.org
Tue Jun 8 04:13:33 PDT 2004
On 06/08/2004 05:05:23 AM, strk wrote:
> All regress tests run with no problems for me.
> Just a note. I do not have a 'postgres' user, so I had
> to remove the \c line on top of regres_lots_of_points.sql
> If this is not a problem I'd remove the 'You are now connected as...'
> line from the expected result.
> --strk;
Another problem for me was on createdb
createdb -T template0 lwgeom_reg
will derive from template0 not the usual template1.
template0 is always clean whilst template1 may have localizations
tsearch, plpgsql, postgis, ...
C.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
