[postgis-devel] lwgeom: regress tests
strk strk at keybit.net
Tue Jun 8 02:05:23 PDT 2004
All regress tests run with no problems for me.
Just a note. I do not have a 'postgres' user, so I had
to remove the \c line on top of regres_lots_of_points.sql
If this is not a problem I'd remove the 'You are now connected as...'
line from the expected result.
--strk;
