[postgis-devel] postgis.sql.in
strk
strk at keybit.net
Fri Mar 26 22:54:31 PST 2004
On Fri, Mar 26, 2004 at 12:59:10PM -0800, Paul Ramsey wrote:
> I still cannot use the cpp version in OS/X 10.2, unfortunately. The
> stdout fix helped one major problem, but the another problem remains. I
> simply cannot get the $libdir variable to go into the file, and I cannot
> get the '' marks to go into the file. cpp generally complains that it
> has the wrong number of arguments on the command line. I tried every
> combination I could think of... it was/is cpp 2.96.
> Paul
It works for me with:
GNU CPP version 2.95.4 20011002 (Debian prerelease) (i386 Linux/ELF)
Did you try manually running it (without the intervention of make) ?
Also try changing the shell.
--strk;
