[postgis-devel] WKB type
strk at refractions.net
Fri Sep 10 09:46:20 PDT 2004
On Fri, Sep 10, 2004 at 09:16:22AM -0700, David Blasby wrote:
> > The 'WKB' postgresql datatype will no more be needed,
> > does it sound Dave ?
> I dont think you should take the WKB type away. If anything, I've had
> requests to add extra support from it (so you can put it in group
> by/order by/distinct clauses).
isn't this the missing btree operator class problem ?
> It also provides tagging so you can differenciate ordinary BYTEA
> binary data and WKB data.
> It also means that external applications can automatically recognize
> WKB data comming towards them (instead just seeing text or bytea).
mmm... can you make a few examples ?
I think the development direction is providing
an API to clients willing to work with geometries, so that
the GEOMETRY type is used directly (instead of WKB).
--strk;
