[postgis-devel] Re: debian postgis
alex bodnaru
alexbodn at 012.net.il
Fri Apr 15 03:47:12 PDT 2005
hi markus,
woody has postgresql 7.2.1, with pg_config equally good.
alex
On Fri, 2005-04-15 at 10:53 +0200, Markus Schaber wrote:
> Hi, alex,
> alex bodnaru schrieb:
> > postgresql-dev package is been really used for the postgres api headers,
> > while the configuration files are been needed because they are been
> > included by the makefile.global and makefile.shlib, required in the
> > postgis build process.
> > if you could finaly decide to selectively ask for locations of
> > postgresql files such as libdir, datadir and bindir, you will find all
> > those values using pg_config, instead of including the makefiles from
> > postgresql.
> I think this is a good idea, and should be integrated with the autoconf
> work, but IMHO this clearly should be delayed after 1.0.0 final.
> BTW, does pg_config exist on woody?
> Markus
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
