[postgis-devel] Re: debian postgis
strk at refractions.net
Fri Apr 15 03:44:16 PDT 2005
On Fri, Apr 15, 2005 at 01:47:12PM +0300, alex bodnaru wrote:
> hi markus,
> woody has postgresql 7.2.1, with pg_config equally good.
Does it have --pkglibdir ?
--strk;
> alex
> On Fri, 2005-04-15 at 10:53 +0200, Markus Schaber wrote:
> > Hi, alex,
> > alex bodnaru schrieb:
> > > postgresql-dev package is been really used for the postgres api headers,
> > > while the configuration files are been needed because they are been
> > > included by the makefile.global and makefile.shlib, required in the
> > > postgis build process.
> > > if you could finaly decide to selectively ask for locations of
> > > postgresql files such as libdir, datadir and bindir, you will find all
> > > those values using pg_config, instead of including the makefiles from
> > > postgresql.
> > I think this is a good idea, and should be integrated with the autoconf
> > work, but IMHO this clearly should be delayed after 1.0.0 final.
> > BTW, does pg_config exist on woody?
> > Markus
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
