[postgis-devel] RPM development process
Jean David TECHER davidtecher at yahoo.fr
Fri Apr 15 05:51:22 PDT 2005
If it's the only error, could you try the installation after having created
the symbolic link to pgsql (with the command ln -s /usr/share/pgsql
/usr/share/postgresql) ? I purpose this solution cause the spec file was
auto-generated with the portage system (Gentoo.org).
----- Original Message -----
To: "PostGIS Development Discussion" <postgis-devel at postgis.refractions.net>
Sent: Friday, April 15, 2005 1:57 PM
Subject: Re: [postgis-devel] RPM development process
> Hi,
> On Fri, 15 Apr 2005, Jean David TECHER wrote:
> > We have just updated our rpm repository at http://01map.net/redhat
> > or
> > http://01map.net/redhat/RPMS/i386/postgis-cvs-1.0.0-r0.i386.rpm
> > this is the last rpm we have done today...
> > we've done it with proj 4.4.9 and geos 2.1.1
> > can U try it and send feedback or comment???
> I'm using PostgreSQL 8.0.2 (latest stable) right now.
> PostgreSQL has bumped of libpq 'major' version in 8.0.2, from 3 to 4. My
> buildfarm is working with libpq.so.4.
> Anyway, temporarily solved this problem but:
> template1=# \i /usr/share/postgresql/contrib/lwpostgis.sql
> BEGIN
> psql:/usr/share/postgresql/contrib/lwpostgis.sql:36: NOTICE:  type
> "histogram2d" is not yet defined
> DETAIL:  Creating a shell type definition.
> psql:/usr/share/postgresql/contrib/lwpostgis.sql:36: ERROR:  could not
> access file "$libdir/liblwgeom.so.1.0": No such file or directory
> psql:/usr/share/postgresql/contrib/lwpostgis.sql:41: ERROR:  current
> transaction is aborted, commands ignored until end of transaction block
> $libdir is /usr/share/pgsql in PostgreSQL RPM installations. So, you
> should edit the spec file and make the relevant changes...
> That's what we did in our packages:
> http://gisappserv.tdmsoft.com.tr/files/postgis.spec.postgis
> Regards,
> Devrim GUNDUZ
> Teknik Müdür
> Teknoloji Destek Merkezi - http://www.TDMSoft.com
> Tel : (312) 405 40 16        Fax: (312) 428 19 02
> PGP Key: www.TDMSoft.com/devrimgunduz-tdmsoft.asc
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
