[postgis-devel] autoconf paths
strk at refractions.net
Fri Apr 15 13:00:22 PDT 2005
I'm not sure we should keep relying on pgsql layout, although
your solution is viable. Actually I was thinking that allowing
storage of extension lib itself in a postgis-specific directory
would permit using different postgis versions for different
databases of the same cluster (does it make any sense?).
Anyway I'll make some tests with --configure parsing to at least
be able to keep current layout.
--strk;
On Fri, Apr 15, 2005 at 10:56:13PM +0300, alex bodnaru wrote:
> hi markus, strk,
> please run pg_config --configure, and see an example of parsing it in
> debian/postgresql.vars.mk
> alex
> On Fri, 2005-04-15 at 20:19 +0200, Markus Schaber wrote:
> > Hi, Strk,
> > alex bodnaru schrieb:
> > > this paths problem is quite easily solvable: run pg_config --help for
> > > the various options
> > Unfortunately, there is no --mandir or --sharedir.
> > Markus
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
