[postgis-devel] 1.0 branch
Paul Ramsey pramsey at refractions.net
Mon Apr 18 10:44:04 PDT 2005
Rather than maintain two sections (one in docs and one in CHANGES) lets
just get rid of the one in docs. (lazy solution...)
P
strk at refractions.net wrote:
> On Fri, Apr 15, 2005 at 03:34:48PM +0200, Jean David TECHER wrote:
>>Hi again Sandro
>>When I compiled in Windows (with TeXLive latex) the doc by
>>pdfxmltex postgis.fo
>>in postgis/doc/postgis.pdf  (see attached file)
>>there are others contributors..;Great to see Klaus has been added :-)
> Unfortunately the contributors section is flattened out, but
> I think we really should evidence Mark Cave Ayland and Markus Shaber...
> Paul, can you find a formula for this ?
> --strk;
>>----- Original Message -----
>>From: <strk at refractions.net>
>>To: <postgis-devel at postgis.refractions.net>
>>Cc: "Paul Ramsey" <pramsey at refractions.net>
>>Sent: Friday, April 15, 2005 1:51 PM
>>Subject: [postgis-devel] 1.0 branch
>>>pgis_1_0 branch is set. 1.0.0 will come out from there.
>>>HEAD is open for changes. Here's a brief list of items
>>>for 1.1 that I've in mind and are not present in the TODO:
>>>- PGsql sources dependency drop
>>>- Full autoconf support
>>>- Special threatment of SRID=-1, dims=-1, type=GEOMETRY
>>>  in geometry_columns
>>>- Better upgrade mechanism
>>>- Pre-8.0 port of new estimator code
>>>- Better regression tests (single load, multi operations)
>>>- contrib/ dir with WFSLocks and packaging files ?
>>>- <your feature-request here>
>>>Actual items to be work on will obviously require a scan of the TODO,
>>>and priority assignment, we have most notably:
>>>- network operations
>>>- multi-dimensional indexing
>>>--strk;
>>>_______________________________________________
>>>postgis-devel mailing list
>>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
