[postgis-devel] 1.0 branch
strk at refractions.net
Mon Apr 18 16:29:14 PDT 2005
On Mon, Apr 18, 2005 at 10:44:04AM -0700, Paul Ramsey wrote:
> Rather than maintain two sections (one in docs and one in CHANGES) lets
> just get rid of the one in docs. (lazy solution...)
I added an 1.0.0 section in the CREDITS file (lazier solution).
--strk;
> P
> strk at refractions.net wrote:
> >On Fri, Apr 15, 2005 at 03:34:48PM +0200, Jean David TECHER wrote:
> >>Hi again Sandro
> >>When I compiled in Windows (with TeXLive latex) the doc by
> >>pdfxmltex postgis.fo
> >>in postgis/doc/postgis.pdf (see attached file)
> >>there are others contributors..;Great to see Klaus has been added :-)
> >Unfortunately the contributors section is flattened out, but
> >I think we really should evidence Mark Cave Ayland and Markus Shaber...
> >Paul, can you find a formula for this ?
> >--strk;
> >>----- Original Message -----
> >>From: <strk at refractions.net>
> >>To: <postgis-devel at postgis.refractions.net>
> >>Cc: "Paul Ramsey" <pramsey at refractions.net>
> >>Sent: Friday, April 15, 2005 1:51 PM
> >>Subject: [postgis-devel] 1.0 branch
> >>>pgis_1_0 branch is set. 1.0.0 will come out from there.
> >>>HEAD is open for changes. Here's a brief list of items
> >>>for 1.1 that I've in mind and are not present in the TODO:
> >>>- PGsql sources dependency drop
> >>>- Full autoconf support
> >>>- Special threatment of SRID=-1, dims=-1, type=GEOMETRY
> >>> in geometry_columns
> >>>- Better upgrade mechanism
> >>>- Pre-8.0 port of new estimator code
> >>>- Better regression tests (single load, multi operations)
> >>>- contrib/ dir with WFSLocks and packaging files ?
> >>>- <your feature-request here>
> >>>Actual items to be work on will obviously require a scan of the TODO,
> >>>and priority assignment, we have most notably:
> >>>- network operations
> >>>- multi-dimensional indexing
> >>>--strk;
> >>>_______________________________________________
> >>>postgis-devel mailing list
> >>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
