[postgis-devel] Segfault with Intersects() in 1.0.6-CVS
Benj Carson benjcarson at digitaljunkies.ca
Fri Dec 2 16:20:13 PST 2005
Hello,
I am getting segfaults with PostGIS 1.0.6-CVS (updated as of 2005-12-02) and
PostgreSQL 8.1 (from Debian) when calling Intersects():
# select intersects(
    polygonfromtext('POLYGON((0.0 0.0,1.0 0.0,1.0 1.0,1.0 0.0,0.0 0.0))'),
    polygonfromtext('POLYGON((0.0 2.0,1.0 2.0,1.0 3.0,0.0 3.0,0.0 2.0))')
server closed the connection unexpectedly
        This probably means the server terminated abnormally
        before or while processing the request.
Hopefully you are aware of this problem; if so please ignore me.  Otherwise,
I thought I should let you kind folks know.  Now, I know that CVS code is
sometimes unstable, but I was using 1.0.5 but it was crashing on
ExteriorRing() for me, so I thought I'd see if 1.0.6-CVS had solved my
problem (it did), but I then ran into this...
Let me know if you need more info.
Thanks,
Benj Carson
