[postgis-devel] OGC polygon constructors
Charlie Savage
cfis at interserv.com
Fri Dec 9 09:46:19 PST 2005
I'd vote for wrapping polygonize_garray so that their is only one
implementation of the code.
Charlie
strk at refractions.net wrote:
> On Fri, Dec 09, 2005 at 04:23:59PM +0100, strk at refractions.net wrote:
>> Nonetheless, many items in the TODO list are completely missed:
>> - OGC polygon constructors
> I'm approaching this. SFSQL 1.1 contains the following information
> about these:
>> As an optional feature, an implementation may also support `building' of
>> Polygon or MultiPolygon values given an arbitrary collection of possibly
>> intersecting rings or closed LineString values. Implementations that
>> support this feature should include the following functions:
>> BdPolyFromText(multiLineStringTaggedText String, SRID Integer): Polygon
>> Construct a Polygon given an arbitrary
>> collection of closed linestrings as a
>> MultiLineString text representation.
>> BdMPolyFromText(multiLineStringTaggedText String, SRID Integer): MultiPolygon
>> Construct a MultiPolygon given an
>> arbitrary collection of closed linestrings as a
> Given these specs I think we can avoid use of GEOS for the construction,
> as the only required thing is to find out what is an hole and
> what is a shell. C code for this is already present in the loader.
> The alternative would be using just a comple of wrappers
> to the polygonize_garray() function.
> Thoughts ?
> --strk;
> /"\ ASCII Ribbon Campaign
> \ / Respect for low technology.
> X Keep e-mail messages readable by any computer system.
> / \ Keep it ASCII.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20051209/d13f7102/attachment.html>
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20051209/d13f7102/attachment.bin>
