[postgis-devel] OGC polygon constructors (was: PostGIS 1.1.0 - call for closeup)
strk at refractions.net
Fri Dec 9 09:08:32 PST 2005
On Fri, Dec 09, 2005 at 04:23:59PM +0100, strk at refractions.net wrote:
> Nonetheless, many items in the TODO list are completely missed:
> - OGC polygon constructors
I'm approaching this. SFSQL 1.1 contains the following information
about these:
> As an optional feature, an implementation may also support `building' of
> Polygon or MultiPolygon values given an arbitrary collection of possibly
> intersecting rings or closed LineString values. Implementations that
> support this feature should include the following functions:
> BdPolyFromText(multiLineStringTaggedText String, SRID Integer): Polygon
> Construct a Polygon given an arbitrary
> collection of closed linestrings as a
> MultiLineString text representation.
> BdMPolyFromText(multiLineStringTaggedText String, SRID Integer): MultiPolygon
> Construct a MultiPolygon given an
> arbitrary collection of closed linestrings as a
Given these specs I think we can avoid use of GEOS for the construction,
as the only required thing is to find out what is an hole and
what is a shell. C code for this is already present in the loader.
The alternative would be using just a comple of wrappers
to the polygonize_garray() function.
Thoughts ?
--strk;
/"\ ASCII Ribbon Campaign
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
