[postgis-devel] PostGIS RC1/2 and QGIS
Carl Anderson
carl.anderson at co.fulton.ga.us
Thu Feb 10 06:03:43 PST 2005
Carl Anderson wrote:
> the offending statement that QGIS is making is
> declare qgisf binary cursor for select oid,asbinary(shape,'NDR') as
> qgs_feature_geometry from case6 where shape &&
> GeometryFromText('BOX3D( 2288006.545455 1472366.000000,
> 2291123.454545 1475094.000000)'::box3d,102667)
it can be helped as (drop geometryfromtext and add setsrid )
qgs_feature_geometry from case6 where shape && setsrid('BOX3D(
2288006.545455 1472366.000000, 2291123.454545
> strk at refractions.net wrote:
>> On Wed, Feb 09, 2005 at 08:18:42PM -0900, Gary Sherman wrote:
>>> On Wed, 2005-02-09 at 10:33 +0100, strk at refractions.net wrote:
>>>> On Tue, Feb 08, 2005 at 06:53:44PM -0900, Gary Sherman wrote:
>>>>> The latest release candidates of PostGIS do not work with QGIS.
>>>>> Currently we use a binary cursor, using the asbinary function to
>>>>> fetch
>>>>> the features. I took a quick look around and didn't find any
>>>>> documentation on the changes in lwgeom and the appropriate way to
>>>>> read
>>>>> features.
>>>>> Can anyone point me to a document or give me a hint?
>>>> Can you give *us* an hint ? We're hunting exactly this bug. Reports
>>>> are multipolygons
>>>> work while polygons don't. Can you confirm this ?
>>>> Can you provide sample data exploiting the bug ?
>>> I am unable to display any data type (point, linestring, polygon, or
>>> multipolygon) in QGIS.
>>> I have not had time to step through the source in debug to determine
>>> the
>>> problem. A dump file of one of the polygon layers used for testing is
>>> available at http://qgis.org/lakes_dump.dmp.bz2 (this was dumped with
>>> the -d option).
>>> -gary
>> Thank you gary. I've tested your data against the wkbtester prog
>> attached in my previous mail. It reports no difference between HWGEOM
>> binary cursor and LWGEOM binary cursor !
>> The program opens a binary cursor for:
>> asbinary(force_2d(force_collection(geom))), does qgis do the same ?
>> --strk;
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>> This message has been scanned for viruses and
>> dangerous content for Fulton County by DefendMail, and is
>> believed to be clean.
Carl Anderson
GIS Manager Fulton County, Georgia
404.730.8026
