[postgis-devel] jdbc2 Makefile updates
Markus Schaber
schabios at logi-track.com
Thu Feb 17 06:37:03 PST 2005
I just committed a slightly updated Makefile for jdbc2.
The changes are partially a reworked version of Alex Bodnarus Patch
adding the install and installdirs Makefile targets. However, as those
two are the only targets that rely on PostgreSQL Makefile.global
inclusion, I modified his patch so that all other targets still work,
even when Makefile.global cannot be found.
I also added proper dependency calculation for the jar files, as well as
copyright notes.
Strk, what do you think about the non-jdbc2 parts of the patch?
Should we drop the old jdbc directory, as the code will not work with
postgis 1.0 servers, and is still available via 0.9 branch?
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050217/15490f43/attachment.sig>
