[postgis-devel] jdbc2 Makefile updates
strk at refractions.net
Thu Feb 17 06:51:10 PST 2005
On Thu, Feb 17, 2005 at 03:37:03PM +0100, Markus Schaber wrote:
> Hi,
> I just committed a slightly updated Makefile for jdbc2.
> The changes are partially a reworked version of Alex Bodnarus Patch
> adding the install and installdirs Makefile targets. However, as those
> two are the only targets that rely on PostgreSQL Makefile.global
> inclusion, I modified his patch so that all other targets still work,
> even when Makefile.global cannot be found.
> I also added proper dependency calculation for the jar files, as well as
> copyright notes.
> Strk, what do you think about the non-jdbc2 parts of the patch?
I already expressed my concerns.
Both doc/ and jdbc2/ cannot safely be built by default
as not all users will have the required tools to build them.
> Should we drop the old jdbc directory, as the code will not work with
> postgis 1.0 servers, and is still available via 0.9 branch?
I think we can, but Paul should have last words on this.
--strk;
> Markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 zürich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
