[postgis-devel] polygonize_garray build invalid geometries
Carl Anderson carl.anderson at vadose.org
Sun Jan 2 09:01:35 PST 2005
against CVS Postigs and CVS GEOS
polygonize_garray in instances returns invalid geometries
test cases avail at
http://wms.co.fulton.ga.us/data/postgis/polygonize_error.sql.gz
(sorry, it was too big for the list)
run the script to build object  then
select isvalid(the_geom) from polygonize_error;
select
   isvalid(polygonize_garray(array_append('{}',
           intersection(boundary(the_geom),boundary(the_geom))
intersection(boundary(),boundary())  -- converts all rings into simple
linestrings (actually OGC line geometries  SFSSQL 2.1.6)
