[postgis-devel] polygonize_garray build invalid geometries
strk at refractions.net strk at refractions.net
Mon Jan 3 07:57:25 PST 2005
The problem here is in the implementation of the postgis polygonize
interface. GEOS polygonize returns a list of polygons, not a
multipolygon. Postgis is *forcing* single-geometry output, creating
a multipolygon, which probably often results in an invalid geometry.
I think the fix here is creating a collection, instead of a MultiPolygon.
Note that in this case postgis lacks a polygon construction mean.
I suggest make_polygon(geometry, geometry[]), having shell as first
argument and a list of holes as second (optional) argument.
--strk;
On Sun, Jan 02, 2005 at 12:01:35PM -0500, Carl Anderson wrote:
> against CVS Postigs and CVS GEOS
> polygonize_garray in instances returns invalid geometries
> test cases avail at
> http://wms.co.fulton.ga.us/data/postgis/polygonize_error.sql.gz
> (sorry, it was too big for the list)
> run the script to build object  then
> select isvalid(the_geom) from polygonize_error;
> select
>   isvalid(polygonize_garray(array_append('{}',
>           intersection(boundary(the_geom),boundary(the_geom))
> intersection(boundary(),boundary())  -- converts all rings into simple
> linestrings (actually OGC line geometries  SFSSQL 2.1.6)
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
For standing up against patentability of software,
  Thank You, Poland!
Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
Send your thanks:         thankyoupoland.info
Read/do more:		  http://www.noepatents.org/
