[postgis-devel] GEOS XMLTester throws error case
strk at refractions.net
Wed Jan 5 08:50:17 PST 2005
On Wed, Jan 05, 2005 at 10:31:34AM -0500, Carl Anderson wrote:
> strk at refractions.net wrote:
> >On Tue, Jan 04, 2005 at 04:32:43PM -0500, Carl Anderson wrote:
> >>in Jump 1.1.3rc5 this case works fine
> >>using GEOS's XMLTester i get a side location conflict exception.
> >>(output validation is bogus so ignore that)
> >With JTS-1.4 testrunner it throws 'side location conflict' as well.
> >(which JTS version does your Jump use ?)
> >--strk;
> JTS-1.4.0.jar
> yes it does throw the error. I misread hthe error dialog. Jump
> mishandles the exception and pops up a confusing dialog
> Validation Errors
> Layer: test1
> No Validation Errors
> notice that both shapes report as valid.
> From here, If there is no motivation for improving the numerical
> robustness... (hope there is)
> Then I really do want to be able to set arbitrary scales for the
> PrecisionManager in the geometryFactory.
> difference(g1,g2,scale)
> which hopefully will keep precision levels low enough to avoid this issue.
I'd integrate a grid application function I wrote long ago as part
of a web gis solution.
It accepts a grid origin and cell sizes in input. Coordinate values
would then be 'snapped' to the grid and collapsed points would be
removed.
--strk;
> C.
> Carl Anderson
> GIS Manager Fulton County, Georgia
> carl.anderson at co.fulton.ga.us
> 404.730.8026
> This message has been scanned for viruses and
> dangerous content for Fulton County by DefendMail, and is
> believed to be clean.
For standing up against patentability of software,
Thank You, Poland!
Read the intervention: http://kwiki.ffii.org/ConsPolon041221En
Send your thanks: thankyoupoland.info
Read/do more: http://www.noepatents.org/
