[postgis-devel] isvalid() error
Markus Schaber
schabios at logi-track.com
Fri Jan 14 07:14:49 PST 2005
Hi, Strk,
strk at refractions.net schrieb:
>>>PostGIS always allowed polygon rings with 3 points.
>>>In this case it disagrees with GEOS about this.
The reason is that GEOS needs three _distinct_ points. As the ring has
to be closed, four coordinate pairs have to be given, whereas the last
one equals the first one.
> Question is: can we safely have GEOS accept them ?
> I belive both SnapToGrid() and Simplify() also produce 3points rings ...
Such a 3 point ring is actually "collapsed" to a line which has no area.
As Polygons describe areas, maybe such shapes should be dropped altogether.
Markus
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050114/598da50a/attachment.sig>
