[postgis-devel] isvalid() error
Carl Anderson
carl.anderson at co.fulton.ga.us
Fri Jan 14 07:40:44 PST 2005
strk at refractions.net wrote:
>PostGIS always allowed polygon rings with 3 points.
>In this case it disagrees with GEOS about this.
>Also, PostGIS does not allow 0 points.
>Should we enforce GEOS constraints or just have isvalid
>return FALSE in these cases ?
a LINESTRING with 3 points is not simple (passes though the same point
in space twice) and cannot be a LINEARRING. Hence it cannot be part of a
valid POLYOGN
C.
>--strk;
>On Thu, Jan 13, 2005 at 05:07:59PM -0500, Carl Anderson wrote:
>>need to test for ring counts prior to sending to GEOS
>>select isvalid(geometry('POLYGON((0 0,0 1,0 0))'));
>>NOTICE: IllegalArgumentException: Number of points must be 0 or >3
>>ERROR: POSTGIS2GEOS conversion failed
>>Carl Anderson
>>GIS Manager Fulton County, Georgia
>>404.730.8026
>>This message has been scanned for viruses and
>>dangerous content for Fulton County by DefendMail, and is
>>believed to be clean.
>>_______________________________________________
>>postgis-devel mailing list
>>postgis-devel at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
Carl Anderson
404.730.8026
