[postgis-devel] iscachable
strk at refractions.net
Fri Jan 14 08:33:39 PST 2005
I've committed a first adaption to the new way of
specifiying CREATE FUNCTION attributes.
Will anyone review it ?
When a with() clause was already specified I left it
there after a -- comment.
Often I added the IMMUTABLE key.
In very few cases I used STABLE.
I didn't know what to do with versioning funx
and 'internal' funx (geometry_analyze, postgis_gist_sel, LWGEOM_gist_*)
so I left them with no specification, suggestion welcome.
--strk;
On Fri, Jan 14, 2005 at 04:48:43PM +0100, strk at refractions.net wrote:
> I'm converting all CREATEFUNCTION calls to use these defines.
> A question (for Mark probably):
> How should "internal" functions be defined ?
> I mean, type analyzers, selectivity estimators and such...
> --strk;
> On Fri, Jan 14, 2005 at 04:38:46PM +0100, strk at refractions.net wrote:
> > Ok, here are my defines:
> > #if USE_VERSION > 72
> > # define _IMMUTABLE_STRICT IMMUTABLE STRICT
> > # define _IMMUTABLE IMMUTABLE
> > # define _STABLE_STRICT STABLE STRICT
> > # define _STABLE STABLE
> > # define _VOLATILE_STRICT VOLATILE STRICT
> > # define _VOLATILE VOLATILE
> > # define _STRICT STRICT
> > #else // USE_VERSION <= 72
> > # define _IMMUTABLE_STRICT with(iscachable,isstrict)
> > # define _IMMUTABLE with(iscachable)
> > # define _STABLE_STRICT with(isstrict)
> > # define _STABLE
> > # define _VOLATILE_STRICT with(isstrict)
> > # define _VOLATILE
> > # define _STRICT with(isstrict)
> > #endif // USE_VERSION <= 72
> > Note that _STABLE and _VOLATILE leave default behaviour for PG<73.
> > Do they sound correct to everybody ?
> > --strk;
> > On Fri, Jan 14, 2005 at 04:17:23PM +0100, Markus Schaber wrote:
> > > Hi, strk,
> > > strk at refractions.net schrieb:
> > > > Note that we could use STABLE for PG>72 with a preprocessor
> > > > switch..
> > > I think this is a good idea so PG73+ optimizers can take advantage of
> > > STABLE.
> > > Markus
> > > _______________________________________________
> > > postgis-devel mailing list
> > > postgis-devel at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
> > For standing up against patentability of software,
> > Thank You, Poland!
> > Read the intervention: http://kwiki.ffii.org/ConsPolon041221En
> > Send your thanks: thankyoupoland.info
> > Read/do more: http://www.noepatents.org/
> Thank You, Poland!
Thank You, Poland!
