[postgis-devel] ICONV autodetection (head branch)
strk at refractions.net
Mon Jul 4 06:13:49 PDT 2005
Sorry Dave, I'm a bit slow.
Can we try to discuss one thing at time ?
Which patch did you apply ? Didn't postgis compile w/out patches ?
--strk;
On Mon, Jul 04, 2005 at 02:04:25PM +0200, Jean David TECHER wrote:
> Yes Master!!! :-)
> cvs checkout postgis
> I applied my patch for windows
> and let in postgis/Makefile.config.in
> USE_ICONV=@USE_ICONV@
> I got
> for configure
> SUMMARY
> HOST_OS: mingw32
> PGSQL: /c/PostgreSQL/8.0.3/bin/pg_config
> GEOS: /c/PostgreSQL/8.0.3/bin/geos-config
> PROJ: dir=/c/PostgreSQL/8.0.3/bin/..
> ICONV: 0
> PORTNAME: win32
> PREFIX: /usr/local
> EPREFIX: ${prefix}
> DOC: ${prefix}/share/doc
> DATA: ${prefix}/share/postgresql/contrib
> MAN: ${prefix}/man
> BIN: c:/PostgreSQL/8.0.3/bin
> EXT: c:/PostgreSQL/8.0.3/lib (\$$libdir)
> Hum....!!! The only problem is to be able to have lwpostgis.sql and spatial_ref_sys.sql in the same directory og PG SHAREDIR
> Not really a goog idea!!! It's better to let postgis-prefix=/usr/local by default
> I will copy *.sql done by postgis manually (*.sql + doc + man)
> ok thanks :-)
> However Sandro I think it will be a great idea to let for win32 Path_to_PosttGIS_library = $lidbir even if user give '--prefix=...' when he uses configure
> I mean for win32 it's better to have
> EXT = (\$$libdir)
> instead of
> EXT := ${exec_prefix}/$/libexec when we use configure
> So I will not have to replace EXT by libdir in lwpostgis.sql since PostgreSLQ doesn't support /c/ in path
> TECHER Jean David
> 01MAP
> e-mail: david at 01map.net
> Tél: 04 67 45 60 27
> Entreprise: http://www.01map.net
> Perso: http://techer.pascal.free.fr/postgis/
> ----- Original Message -----
> From: strk at refractions.net
> To: PostGIS Development Discussion
> Sent: Monday, July 04, 2005 11:48 AM
> Subject: [postgis-devel] ICONV autodetection (head branch)
> On Thu, Jun 30, 2005 at 10:36:11AM +0200, Jean David TECHER wrote:
> > Sorry for iconv I've had problem so I put USE_ICONV=0 in postgis/Makefile.config.in
> > Make and make install works fine!!!
> I've reworked iconv detection code to be more conservative.
> It should now be enabled only if the c library provide that functionality.
> (no external libiconv supported).
> This should remove the need of manually edit Makefile.config
> --strk;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
