[postgis-devel] ICONV autodetection (head branch)
Jean David TECHER davidtecher at yahoo.fr
Mon Jul 4 06:30:17 PDT 2005
No prob Sandro...I've already sent U my mail last week! Strange?
My patch is attached to this mail for win32
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
  ----- Original Message -----
  To: PostGIS Development Discussion
  Sent: Monday, July 04, 2005 3:13 PM
  Subject: Re: [postgis-devel] ICONV autodetection (head branch)
  Sorry Dave, I'm a bit slow.
  Can we try to discuss one thing at time ?
  Which patch did you apply ? Didn't postgis compile w/out patches ?
  --strk;
  On Mon, Jul 04, 2005 at 02:04:25PM +0200, Jean David TECHER wrote:
  > Yes Master!!! :-)
  > cvs checkout postgis
  > I applied my patch for windows
  > and let in postgis/Makefile.config.in
  > USE_ICONV=@USE_ICONV@
  > I got
  > for configure
  >  SUMMARY
  >  HOST_OS: mingw32
  >    PGSQL: /c/PostgreSQL/8.0.3/bin/pg_config
  >     GEOS: /c/PostgreSQL/8.0.3/bin/geos-config
  >     PROJ: dir=/c/PostgreSQL/8.0.3/bin/..
  >    ICONV: 0
  >  PORTNAME: win32
  >    PREFIX: /usr/local
  >   EPREFIX: ${prefix}
  >       DOC: ${prefix}/share/doc
  >      DATA: ${prefix}/share/postgresql/contrib
  >       MAN: ${prefix}/man
  >       BIN: c:/PostgreSQL/8.0.3/bin
  >       EXT: c:/PostgreSQL/8.0.3/lib (\$$libdir)
  > Hum....!!! The only problem is to be able to have lwpostgis.sql and spatial_ref_sys.sql in the same directory og PG SHAREDIR
  > Not really a goog idea!!! It's better to let postgis-prefix=/usr/local by default
  > I will copy *.sql done by postgis manually (*.sql + doc + man)
  > ok thanks :-)
  > However Sandro I think it will be a great idea to let for win32 Path_to_PosttGIS_library = $lidbir even if user give '--prefix=...' when he uses configure
  > I mean for win32 it's better to have
  > EXT     = (\$$libdir)
  > instead of
  > EXT   :=   ${exec_prefix}/$/libexec when we use configure
  > So I will not have to replace EXT by libdir in lwpostgis.sql since PostgreSLQ doesn't support /c/ in path
  > TECHER Jean David
  > 01MAP
  > Tél: 04 67 45 60 27
  >   From: strk at refractions.net
  >   Sent: Monday, July 04, 2005 11:48 AM
  >   Subject: [postgis-devel] ICONV autodetection (head branch)
  >   On Thu, Jun 30, 2005 at 10:36:11AM +0200, Jean David TECHER wrote:
  >   > Sorry for iconv I've had problem so I put USE_ICONV=0 in postgis/Makefile.config.in
  >   > Make and make install works fine!!!
  >   I've reworked iconv detection code to be more conservative.
  >   It should now be enabled only if the c library provide that functionality.
  >   (no external libiconv supported).
  >   This should remove the need of manually edit Makefile.config
  >   --strk;
  >   _______________________________________________
  >   postgis-devel mailing list
  >   postgis-devel at postgis.refractions.net
  >   http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050704/2315c6bd/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050704/2315c6bd/attachment.obj>
