[postgis-devel] Re: [postgis-users] Re: Buggy transform() function in 1.0RC1 ?
strk at refractions.net
Sun Jun 5 02:39:17 PDT 2005
Tested with current CVS (1.0.1 basically)
$ psql -f test_crash_postgres_reprojection.sql test
transform_geometry
0101000020BE6B00006A2B98C728512241C7EA110A0A664441
(1 row)
UPDATE 1
transform_geometry
(1 row)
What version are you using ?
--strk;
On Thu, May 26, 2005 at 04:50:11PM +0200, Nicolas Ribot wrote:
> Hello all,
> > Nicolas, in the pdf you sent (good work!) you tell previous
> > postgis versions worked fine. I took a look at older definitions
> > and I found out that both +pm and +lon_0 have the same value
> > (2.337229166666667). New definition changed the +pm to Paris
> > (instead of literal number) and that seems to have broken things up.
> > Changing lon_0 to 0 fixed it again.
> > Can you confirm these being the working options:
> > 1) +pm=Paris +lon_0=0
> > 2) +pm=2.337229166666667 +lon_0=2.337229166666667
> I made some tests on Postgis 1.0 (same config as the one described in
> my previous message):
> The only working option is:
> +pm=paris +lon_0=0
> The other option gives the same result as the default proj4text
> provided with spatial_ref_sys.sql (+pm=paris +lon_0=2.33722917): a
> 2.337... coordinates east shift.
> By the way, following Gino's advice, I changed the +pm=paris parameter
> to +pm=Paris to test if case is sensitive in reprojection.
> It crashed the server (postgres.exe).
> I send you a minimal script to test the problem.
> > It would help testing both with different proj4 versions.
> > I don't whether they should be equivalent, but really do
> > not look like they are (unless Paris resolves to 2.337*2).
> > SRTEXT is not used by postgis, dunno about JUMP.
> For me, the correct definition is either:
> +pm=paris +lon_0=0 or
> +pm=2.33722917 +lon_0=0
> expressing the prime meridien either by a keyword or by its actual
> shift value from Greenwich.
> Nicolas
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
