[postgis-devel] Re: [postgis-users] Re: Buggy transform() function in 1.0RC1 ?
Nicolas Ribot
nicky666 at gmail.com
Sun Jun 5 05:31:18 PDT 2005
> Tested with current CVS (1.0.1 basically)
> $ psql -f test_crash_postgres_reprojection.sql test
> transform_geometry
> 0101000020BE6B00006A2B98C728512241C7EA110A0A664441
> (1 row)
> UPDATE 1
> transform_geometry
> (1 row)
> What version are you using ?
POSTGIS="1.0.0" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0 .3.0" RELPROC="0.3.0"
On Windows XP SP2, Mingw compilation.
So, problem seems to be solved :-)
Nicolas
