[postgis-devel] RC3 build/install script bugs
strk at refractions.net
Tue Mar 1 23:12:19 PST 2005
On Wed, Mar 02, 2005 at 10:49:18AM +1100, Rhys Ickeringill wrote:
> ----- Original Message -----
> From: <strk at refractions.net>
> To: <postgis-devel at postgis.refractions.net>
> Sent: Tuesday, March 01, 2005 7:30 PM
> Subject: Re: [postgis-devel] RC3 build/install script bugs
> > Thanks Rhys, I've fixed the lwpostgis.sql install rule
> > and the FLEX/YACC settings.
> > With the FLEX/YACC patch tough, you can't redefine them using
> > environemnt variables. The question is: why doesn't PGSQL define
> > them ?
> Perhaps instead of replacing FLEX ?= flex with the ifeq( $(strip.....) why
> not use one after the other?
The ?= construct sets the value only if not already set.
It seems that PGSQL set it to the empty string instead, so the $(strip..)
is required. It *is* moved after, anyway.
> To answer your question - in my case PGSQL didn't find flex, and hence
> didn't define the variable.
> >From PGSQL's configure script:
> *** Without Flex you will not be able to build PostgreSQL from CVS or
> *** change any of the scanner definition files. You can obtain Flex from
> *** a GNU mirror site. (If you are using the official distribution of
> *** PostgreSQL then you do not need to worry about this because the Flex
> *** output is pre-generated.)
> Hence my build went ahead anyway because I was using the official
> distribution.
What do people think about doing the same ?
--strk;
> > --strk;
> - Rhys
> > On Tue, Mar 01, 2005 at 12:03:38PM +1100, Rhys Ickeringill wrote:
> > > G'day All.
> > > Hope this is the right spot to post bugs. Just had a few little hitches
> > > building RC3
> > > Some system info in case it's pertinent:
> > > OS: Linux 2.4.29 (Slackware 10.1)
> > > postgreSQL: 7.4.7
> > > make: 3.8
> > > yacc: 1.9 (byacc)
> > > bison: 1.35
> > > flex: 2.5.4
> > > First the easy one - when a "make install DESTDIR=/tmp/pkg" is issued in
> > > postgis-1.1.0-rc3, I end up with a file 'share' in
> /tmp/pkg/usr/local/pgsql.
> > > The file is actually (as I'm sure you've guessed) 'lwpostgis.sql'. This
> > > error only shows up if the $DESTDIR/usr/local/share doesn't already
> exist.
> > > Changing the action taken for target 'install-lwgeom-scripts' in
> > > postgis-1.1.0-rc3/lwgeom/Makefile from
> > > $(INSTALL_DATA) lwpostgis.sql $(DESTDIR)$(datadir)
> > > to
> > > $(INSTALL_DATA) lwpostgis.sql $(DESTDIR)$(datadir)/lwpostgis.sql
> > > seems do the 'right' thing for me in all situations.
> > > The next one seems to have been reported for RC2, but still exists in
> RC3.
> > > When a "make" is issued in postgis-1.1.0-rc3, the make fails:
> gcc -O2 -pipe -fno-strict-aliasing -Wall -Wmissing-prototypes -Wmissing-decl
> arations -g -fexceptions -fPIC -DUSE_VERSION=74 -DPOSTGIS_LIB_VERSION='"1.0.
> 0RC3"' -DPOSTGIS_SCRIPTS_VERSION='"0.2.0"' -DPOSTGIS_BUILD_DATE='"2005-03-01
> 00:21:01"' -I/usr/local/include -DUSE_GEOS -I/usr/local/include -DUSE_PROJ -
> I/usr/local/include -DAUTOCACHE_BBOX=1 -DUSE_STATS -fpic -I/usr/src/postgres
> > > ql-7.4.7/contrib/postgis-1.0.0-rc3/../../src/include -D_GNU_SOURCE -c -o
> > > wktparse.tab.o wktparse.tab.c
> > > Plwg_parse_yy -i -f -o'lex.yy.c' wktparse.lex
> > > make[1]: Plwg_parse_yy: Command not found
> > > make[1]: [lex.yy.c] Error 127 (ignored)
> > > lex.yy.o lex.yy.c
> > > gcc: lex.yy.c: No such file or directory
> > > gcc: no input files
> > > make[1]: *** [lex.yy.o] Error 1
> > > make[1]: Leaving directory
> > > `/usr/src/postgresql-7.4.7/contrib/postgis-1.0.0-rc3/lwgeom'
> > > make: *** [liblwgeom] Error 2
> > > Apparently this error is caused by $FLEX variable being incorrecly
> defined
> > > in postgis-1.0.0-rc3/lwgeom/Makefile. From what I can tell, the $FLEX
> > > variable comes from postgis-1.0.0-rc3/Makefile.config, which includes
> > > 'Makefile.global' from the directory $PGSQL_SRC (the postgreSQL source
> tree
> > > root). In my $PGSQL_SRC/Makefile.global I have the line...
> > > FLEX =
> > > ...which means the line in postgis-1.0.0-rc3/Makefile.config...
> > > FLEX ?= flex
> > > ...keeps the definition of $FLEX from $PGSQL_SRC/Makefile.global (I
> assuming
> > > that's what the ?= operator means - I'm no makefile expert)
> > > To fix this for my specific case was trivial. But to continue leveraging
> the
> > > info collected by the postgres configure script (I'm guessing this is
> why
> > > $PGSQL_SRC/Makefile.global is included) perhaps it is worth replacing
> FLEX
> > > ?= flex with something like:
> > > ifeq ($(strip $(FLEX)),)
> > > FLEX = flex
> > > endif
> > > Perhaps it would be also worthwhile to do the same for $YACC too.
> > > Regards,
> > > Rhys
> > > _______________________________________________
> > > postgis-devel mailing list
> > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
