[postgis-devel] debian packaging
strk at refractions.net
Mon Mar 7 07:44:50 PST 2005
Alex, I make postgis-devel part of the discussion, as it might
interest other people. Please include the list in your eventual
replies.
On Mon, Mar 07, 2005 at 05:08:10PM +0200, alexbodn at 012.net.il wrote:
> hi strk,
> > I've no /etc/xml directory.
> i will further inquire this issue, but please inform me how to begin: how did you make the initial xml document?
I didn't ;)
Paul did.
> > Anyway, I've made the XSLBASE directory a parameter, so you can
> > specify it in the environment.
> it is possible to use it like this, but the default should be more reliable: if the files do not exist there, i would still take the find option.
Someone has it, and releases include already built documentation.
A find seems too expensive to me. When postgis will get autoconf scripts
the find shall be there, if needed.
> > > as for the sql scripts: could you be more explicit as of the way
> > to install and use them? the debian package has an installation
> > I think you should source lwpostgis.sql and spatial_ref_sys.sql.
> if those would be so important, why are they not been both installed? see the patch i did propose, which installs and uninstalls those scripts as part of the make process.
I'm adding those now. Would $(datadir)/contrib be more appropriate for
the sql files ? Or $(datadir)/contrib/postgis and $(docdir)/contrib/postgis
direcly ? What people think about this ?
--strk;
