[postgis-devel] debian packaging
strk at refractions.net strk at refractions.net
Mon Mar 7 13:15:50 PST 2005
On Mon, Mar 07, 2005 at 04:44:50PM +0100, strk at refractions.net wrote:
> > > I think you should source lwpostgis.sql and spatial_ref_sys.sql.
> > if those would be so important, why are they not been both installed? see the patch i did propose, which installs and uninstalls those scripts as part of the make process.
> I'm adding those now. Would $(datadir)/contrib be more appropriate for
> the sql files ? Or $(datadir)/contrib/postgis and $(docdir)/contrib/postgis
> direcly ? What people think about this ?
I've changed the Makefile to always use the 'contrib' suffix, as
it was done with 0.8.x.
--strk;
