[postgis-devel] RC6
Gerald Fenoy
djayweb at djayux.net
Wed Mar 30 09:13:42 PST 2005
Hi all, I'm ne to this mailling list and the creator of these ebuilds.
As Jean said it before you could download our portage tree from :
01map.net/gentoo, you could use it now and there are some way to using
it, the easiest way is discribe here : you could for exemple use our
portage.01map.tar.bz2 file and decrompressing it into the
/usr/local/portage.01map directory (you've created before), you need to
edit the /etc/make.conf file and add this line :
PORTDIR_OVERLAY="/usr/local/portage.01map" at the end (note that if you
chose another path to decompress the fileset so set the appropriate path
here too ... :) ). To be able to use our postgis version nor the old
disponible version you need to add this to your
/etc/portage/pakage.keywords file : dev-db/postgis-1.0.0_rc5 ~x86 . If
you want the geos and proj support as recommended in the README file,
you need to add geos and proj in you USE flags in the make.conf file as
fo the others ebuilds.
I will become a gentoo developer in a maximum of three weeks so the
method discribed before must apply temporarly.
Thank you to sorry my poor englih.
Cordialy.
On Wed, 30 Mar 2005 19:02:53 +0100
<christian.graefe at web.de> wrote:
> Hello Jean
> You said something about Gentoo-Ebuilds.
> Are they available for me or others?
> The "normal" portage tree only includes
> an old version.
> Best regards
> Christian
> PostGIS Development Discussion <postgis-devel at postgis.refractions.net>
> schrieb am 30.03.05 18:41:11:
> > Ok so tests for AMD64 (Debian Sarge ) and the Gentoo EBuilds will be
> > done tomorrow..
> > If Paul and the others maintainers agree...
> > TECHER Jean David
> > Responsable Informatique 01MAP
> > e-mail: davidtecher at yahoo.fr
> > Bureau: 04 67 45 60 27
> > Portable: 06 85 37 36 75
> > site perso : http://techer.pascal.free.fr/postgis/
> > site pro: http://www.01map.com/download/
> > K-S:"The greatest trick the devil pulled off was convincing people
> > he didn't exist"
> > ----- Original Message -----
> > From: <strk at refractions.net>
> > To: "PostGIS Development Discussion"
> > <postgis-devel at postgis.refractions.net> Sent: Wednesday, March 30,
> > 2005 6:36 PM Subject: Re: [postgis-devel] RC6
> > > On Wed, Mar 30, 2005 at 06:33:30PM +0200, TECHER Jean David wrote:
> > > > Hi Master
> > > > I don't find RC6 on web site
> > > > By CVS ????
> > > "I'd" was a contraction for "I would".
> > > I just wanted to make sure nobody had pending patches.
> > > --strk;
> > > > TECHER Jean David
> > > > people he
> > didn't
> > > > exist"
> > > > From: "strk" <strk at keybit.net>
> > > > To: <postgis-devel at postgis.refractions.net>
> > > > Sent: Wednesday, March 30, 2005 6:00 PM
> > > > Subject: [postgis-devel] RC6
> > > > > I'd tag RC6.
> > > > > Here are the changes since RC5:
> > > > > - BUGFIX dumper 64bit
> > > > > - BUGFIX in multi()
> > > > > - BUGFIX in postgis_restore.pl script
> > > > > - early return [when noop] from multi()
> > > > > - dropped {x,y}{min,max}(box2d) functions
> > > > > A dump/reload is required to upgrade from any previous
> > > > > version.
> > > > > Does anyone have open issues ?
> > > > > --strk;
> > > > > _______________________________________________
> > > > > postgis-devel mailing list
> > > > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
FENOY Gérald
][ mail : djayweb at djayux.net
°0o_ web : none
|' [key : FENOY Gérald (the key I use) <djayweb at djayux.net>]
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050330/b416f3dd/attachment.sig>
