[postgis-devel] RC6
Gerald Fenoy
djayweb at djayux.net
Wed Mar 30 09:22:53 PST 2005
Argh, I'm realy sorry ...
rectifications :
dev-db/postgis-1.0.0_rc5 ~x86 must be read as : dev-db/postgis ~x86
note: if you use the lastest fileset (poratage-30-03-2005.tar.bz2)
please use the following command : emerge -v =postgis-1.0.0_rc5. Indeed
if you don't specify the version number you will be in trouble for
donloading the not available file (postgis-1.0.0-rc6.tar.gz).
On Wed, 30 Mar 2005 17:13:42 +0000
Gerald Fenoy <djayweb at djayux.net> wrote:
> Hi all, I'm ne to this mailling list and the creator of these
> ebuilds. As Jean said it before you could download our portage
> tree from :
> 01map.net/gentoo, you could use it now and there are some way to using
> it, the easiest way is discribe here : you could for exemple use our
> portage.01map.tar.bz2 file and decrompressing it into the
> /usr/local/portage.01map directory (you've created before), you need
> to edit the /etc/make.conf file and add this line :
> PORTDIR_OVERLAY="/usr/local/portage.01map" at the end (note that if
> you chose another path to decompress the fileset so set the
> appropriate path here too ... :) ). To be able to use our postgis
> version nor the old disponible version you need to add this to your
> /etc/portage/pakage.keywords file : dev-db/postgis-1.0.0_rc5 ~x86 . If
> you want the geos and proj support as recommended in the README file,
> you need to add geos and proj in you USE flags in the make.conf file
> as fo the others ebuilds.
> I will become a gentoo developer in a maximum of three weeks so
> the
> method discribed before must apply temporarly.
> Thank you to sorry my poor englih.
> Cordialy.
> On Wed, 30 Mar 2005 19:02:53 +0100
> <christian.graefe at web.de> wrote:
> > Hello Jean
> > You said something about Gentoo-Ebuilds.
> > Are they available for me or others?
> > The "normal" portage tree only includes
> > an old version.
> > Best regards
> > Christian
> > PostGIS Development Discussion
> > <postgis-devel at postgis.refractions.net> schrieb am 30.03.05
> > 18:41:11:
> > > Ok so tests for AMD64 (Debian Sarge ) and the Gentoo EBuilds will
> > > be done tomorrow..
> > > If Paul and the others maintainers agree...
> > > TECHER Jean David
> > > Responsable Informatique 01MAP
> > > e-mail: davidtecher at yahoo.fr
> > > Bureau: 04 67 45 60 27
> > > Portable: 06 85 37 36 75
> > > site perso : http://techer.pascal.free.fr/postgis/
> > > site pro: http://www.01map.com/download/
> > > K-S:"The greatest trick the devil pulled off was convincing people
> > > he didn't exist"
> > > ----- Original Message -----
> > > From: <strk at refractions.net>
> > > To: "PostGIS Development Discussion"
> > > <postgis-devel at postgis.refractions.net> Sent: Wednesday, March 30,
> > > 2005 6:36 PM Subject: Re: [postgis-devel] RC6
> > > > On Wed, Mar 30, 2005 at 06:33:30PM +0200, TECHER Jean David
> > > > wrote:
> > > > > Hi Master
> > > > > I don't find RC6 on web site
> > > > > By CVS ????
> > > > "I'd" was a contraction for "I would".
> > > > I just wanted to make sure nobody had pending patches.
> > > > --strk;
> > > > > --- TECHER Jean David
> > > > > people he
> > > didn't
> > > > > exist"
> > > > > From: "strk" <strk at keybit.net>
> > > > > To: <postgis-devel at postgis.refractions.net>
> > > > > Sent: Wednesday, March 30, 2005 6:00 PM
> > > > > Subject: [postgis-devel] RC6
> > > > > > I'd tag RC6.
> > > > > > Here are the changes since RC5:
> > > > > > - BUGFIX dumper 64bit
> > > > > > - BUGFIX in multi()
> > > > > > - BUGFIX in postgis_restore.pl script
> > > > > > - early return [when noop] from multi()
> > > > > > - dropped {x,y}{min,max}(box2d) functions
> > > > > > A dump/reload is required to upgrade from any previous
> > > > > > version.
> > > > > > Does anyone have open issues ?
> > > > > > --strk;
> > > > > > _______________________________________________
> > > > > > postgis-devel mailing list
> > > > > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
> FENOY Gérald
> ][ mail : djayweb at djayux.net
> °0o_ web : none
> |' [key : FENOY Gérald (the key I use) <djayweb at djayux.net>]
FENOY Gérald
°0o_ web : none
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050330/5aff62d3/attachment.sig>
